[BPI-R4] Wifi connection issues on Linux
I am running a BPI-R4 with Archlinux, and the kernel 6.11-rc and firmware from @frank-w repo. I am using hostapd 2.11 for wifi and I can see the 2.4GHz and the 5GHz networks on my PC and 2.4GHz, 5GHz, 6GHz on my phone (Google Pixel 6).
All the devices connect ok to the WiFi, but I am having some issues with the actual data transfers (on the WiFi connection, ethernet seems ok-ish). Packets seem to drop out to the point where I am having trouble even ssh-ing into the BPI. Anyone experience anything similar?
From what I am seeing here (on the forum) OpenWrt seems to work ok with respect to network conectivity. Are there any WiFi bands or hostapd config options I should avoid?
Unless this is a particular known issue, I’d start with changing WiFi channels and channel bandwidth and testing each setting with iPerf. I found the throughput to be wildly different on some channels even on the stock BPI image, which seems to have the most stable WiFi as for now.
That kernel does not have the (latest) wifi patches. It is only a testing kernel for running the board. I do not have a wifi board, and I am too busy on another project concerning the R64/R3/R4.
You may want to rebuild the kernel from a source that does have the needed wifi patches.
Check PKGBUILD here:
https://github.com/ericwoud/archlinuxarm-repo/blob/linux-bpir-git/PKGBUILD
Change branch and url to whatever branch that has the desired patches.
Then build the R4 kernel with:
TARGET=bpir4 makepkg
Unlike any other pakage for aarch64, this package can be build on a x86-64 running on archlinux.
Thanks @ericwoud. I do have a PKGBUILD for your repo too. Actually, what I seem to be doing is juggling between your kernel and @frank-w whenever something is not working. Will give this a try and report back.
Hi @ericwoud I had a look at both bpir-rolling-stable and mt7988-for-next on your repo ( https://github.com/ericwoud/linux.git), but can’t really tell which ones are the wifi patches you are refering to. Am I looking in the right place or should I be looking at a different repo altogether?
Is for R64/R3 only.
Is for R4, a copy of https://github.com/dangowrt/linux/tree/mt7988-for-next
So you may want to choose https://github.com/frank-w/BPI-Router-Linux/tree/6.11-rc instead of the old copy
Don’t know if you also need to add new CONFIG_XXX’s, maybe not,
Is anyone else experiencing this?
I have installed the latest OpenWRT snapshot(r28004-d64e1ed421) and I am still having the same issues outlined for Archlinux back in Sept: when connected to any BPI-R4 wifi (2.4Ghz, 5Ghz, 6Ghz) if I SSH to the device the connection hangs (or drops from hanging timeout) 90% of the time.
Other traffic seems ok-ish. I am not fully able to test this because without a fully working SSH I cannot deploy the device into my network.
Could I have a damaged BE-14 board? Can anyone propose some tests for this?
Happens to me, just switch from dropbear to openssh and it solves the issues pretty much
I am already using openssh unfortunately, and observing this error. This is quite interesting though. Might it be related to some faulty crypto accelerator? I remember openssh disabled support for those a few years ago.
I am having issues with mwan3 loadbalancer and it keeps dropping as well. So far I am completely dissatisfied with this product. Given the cost and setup headache the R4 is not worth
