Selling an assembled R4 complete router. Includes WIFI7 modules, antenna, fan, and power supply.
OpenWRT can be used right out of the box.
However, one thing is that the antenna is not easy to install.
Interested?
There are tons of 4G RAM in stock in Europe and the US, and a few in China.
MediaTek MT7988A (Filogic 880) quad-core Arm Corex-A73,1.8GHz processor 4GB/8GB DDR4,8GB eMMC flash, 128MB SPI-NAND Flash Micro SD card slot 2x 10Gbe SFP slot (option 1x 10Gbe SFP and 1x SOC embedded 2.5Gbe PHY. NOTE: Need to modify hardware) 4x GbE...
Price: USD 236.64
DE Amazon
US Amazon
Amazon.com: youyeetoo Banana Pi BPI-R4 WiFi 7 Router/Openwrt Router Development Board - Fully Assembled, Use Out of The Box, MediaTek MT7988A Chip, 4GB RAM, 8GB eMMC, 2X 10Gbe SFP Slots, 4X Gbe Ports, Metal Case : Electronics
$246.00
If there are any problems, you can give us feedback.
oli
(oli)
April 21, 2025, 8:35am
2
they will very likely overheat with that top
oooh any solutions? For those who don’t have DIY equipment or do-it-yourself skills.
oli
(oli)
April 22, 2025, 7:50am
4
IMO the case is broken by design. There are several issues with it:
Overheating SoC
Overheating SFP+ (when using a rj45 module)
High noise because no EMI shielding
For the first problem, i would recommend something like [BPI-R4] Replacing sinovoip FAN from heatsink - #44 by oli - its a simple perforated aluminium metal piece: Aluminium Lochblech, Stärke 1,0 mm, Rundloch ø 3 mm, Rv 3-5 ✏️
For the second problem, there are available heat sinks available which can be cooled with an extra fan, like this: [BPI-R4] Replacing sinovoip FAN from heatsink - #22 by oli - if the fan can run at 3.3v, you could use the gpio pins (like i did), then it runs all the time but very silent.
For the high noise there is no real solution yet afaik, at the moment i have -76db which is absolutely terrible, even with “good” cables (wifi chip ↔ antenna)
Maybe this is the correct use of BPI-R4?
(Video shared from the web)
