Hy.
Is the vh 2pins connector for a battery?
Thankss by advance ![]()
which one exactly do you mean? the one behind the USB-C-connector? imho (based on schematics) it is only another jack to supply ~20V or for measuring which Voltage come into USB-C
Hy, Yes it that’s one. Thank you for the Informations.
There is a 2pin connector near the USB-A port and serial console as well, and that’s for a battery supplying the RTC.
Hi. It’s not this one (for rtc battery). but the one near to usbc
He probably meant that connector is the only one for a battery on the board. The SOC doesn’t have an internal charger and doesn’t meant to work on a battery supply. You may manage everything externally and supply the board with constant 20v from a battery
