Hi all,
I did some tests with my board using PSCI in U-Boot. I’ve notice in mt7987.dtsi this:
        psci {
                compatible  = "arm,psci-0.2";
                method      = "smc";
mt7988.dtsi doesn’t have anything about PSCI in DTS.
If I’m compiling U-boot 2025.07 with Use PSCI for reset and shutdown (CONFIG_PSCI_RESET), the board is booting U-boot, is loading GRUB EFI and is booting Linux kernel without issues.
The problem happen when you want to reboot the Linux. Check #23773.
I have my own DTSes :
mt7988-bpi-r4-EasyOS.dtsi
mt7988-bpi-r4-EasyOS-leds-button.dtsi
mt7988-bpi-r4-EasyOS-emmc.dts
mt7988-bpi-r4-EasyOS-sd.dts
Based on mt7988-rfb.dts and mt7988-sd-rfb.dts, but I’ve added LED support and NVMe for boot.
DTS mt7988-bpi-r4-EasyOS-emmc.dts and mt7988-bpi-r4-EasyOS-sd.dts includes mt7988-bpi-r4-EasyOS.dtsi and mt7988-bpi-r4-EasyOS-leds-buttons.dts.
Nothing fancy.
But I’ve changed my mt7988-bpi-r4-EasyOS.dtsi and I’ve added the code from mt7987.dtsi for PSCI.
Then I recompiled U-Boot 202507 with CONFIG_PSCI_RESET:
$ grep -i PSCI u-boot-2025.07/build-mt7988/.config
CONFIG_PSCI_RESET=y
# CONFIG_ARMV8_PSCI is not set
CONFIG_ARM_PSCI_FW=y
Restart the board and now I can reboot the Linux Kernel with U-Boot PSCI enabled for reset/shutdown.
There is a reason why PSCI is not present yet in mt7988.dtsi ?
Thanks.
