BPI-R4 U-Boot 2025.07 breaks GPIO for LED
Hi all,
I was playing around with a new U-Boot and I saw starting from 2024.01 there is a MT7988 support in mainline.
But this commit mediatek: mt7988: move gpio-controller up and rename pinctrl to pio · u-boot/u-boot@cd06e60 · GitHub changes the gpio structure in DTS:
-		gpio: gpio-controller {
-			gpio-controller;
-			#gpio-cells = <2>;
+		gpio-controller;
+		#gpio-cells = <2>;
Now if I want to define LEDs for the board I can’t compile a dtsi like this:
        compatible = "bananapi,bpi-r4", "mediatek,mt7988";
        keys {
                compatible = "gpio-keys";
                wps {
                        label = "wps/reset";
                        gpios = <&gpio 14 GPIO_ACTIVE_LOW>;
        leds {
                compatible = "gpio-leds";
                led_status_green: green {
                        label = "green:status";
                        gpios = <&gpio 79 GPIO_ACTIVE_HIGH>;
                led_status_blue: blue {
                        label = "blue:status";
                        gpios = <&gpio 63 GPIO_ACTIVE_HIGH>;
How can it be solved? One way was to revert this patch and using the code in dts, but how can be used with new configuration?
Kind regards, EasyNetDev.
Just use pio instead of gpio for the phandles
Just like in linux:
https://patchwork.kernel.org/project/linux-mediatek/patch/[email protected]/
The patch from Christian was to make the uboot driver compatible for linux dts (of_upstream).
Be aware that defining the leds may set eeprom readonly (green led must be off to allow writing to eeprom).
Thanks @frank-w !
Moving from gpio to pio U-Boot compiled successful and also I can control the LEDs:
        leds {
                        gpios = <&pio 79 GPIO_ACTIVE_HIGH>;
                        gpios = <&pio 63 GPIO_ACTIVE_HIGH>;
Regarding the EEPROM, I know green LED is sharing a common physical circuit with EEPROM write protection. I saw it in the schematics and I know from OpenWRT firmware that is setting green LED to off to write in EEPROM.
That’s good also to know!
Just wanted to note this…to not being surprised :slight_smile: i wondered why u-boot and linux behaved differently when not defining the gpio-leds…u-boot allowed writing where linux does not. So i added the gpio-leds patch to my series to allow also writing from linux.
Right! :+1:. Indeed this is an issue :joy: if you don’t know it.
