Hi all,
I bought a cheap 1U blanking plate off taobao and cut out the openings on the front panel using the existing BPI-R4 aluminum shell as a reference. It’s quite rough as it was mostly cut through a waterjet (and my measurements were very inaccurate), but as a proof of concept it seems to work.
The existing aluminum case is reused, and only the front panel is swapped out. The case is mounted comfortably behind the 1U plate.
A fibre laser is probably more appropriate for this, but I don’t have access to one that can cut through mild steel.
The screws are M2.5x5mm with washers. I would upload my DXF drawings, but most of the openings are too wide and slightly misplaced, so I think it would be best if BPI can upload their official, accurate drawings instead.
I have no intention of doing this commercially. Rather, I’m hoping that this might inspire the BPI team to produce and sell something like this.
