Good morning, @Phelan_Ward_Kell I used your SD card image. I was able to use all the bands, but only with the country shown in the image. If you change countries, some bands stop working. With yours, only the one shown in your image is valid for the country indicated.
I changed it for mine, and all the bands worked, but the rest worked fine. It recognized the 8GB on the SD card without any problems.
Then I recorded directly from the SD card to the NAND. Here’s the problem: when you boot, it says “failed” and won’t boot on the NAND. I’ll give you the error message that appears when you try to boot from the NAND.
I have used all your u-boot in your repertoire and they are valid, it recognizes in my image that I used for the 4gb nand, now it recognizes the nand as 8gb, but when recorded directly from the sd, it gives some corrupted blocks, but then when it starts again everything comes out perfect and it recognizes the 8gb nand, without any problem, if the first blocks bother someone I advise you not to use it but it works perfectly I leave the complete log so that the erroneous blocks can be seen, but then once they finish it starts to boot with the menu in nand, recognizing the 8gb.
F0: 102B 0000
FA: 1042 0000
FA: 1042 0000 [0200]
F9: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0600 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [1000]
MK: 0000 0000 [0000]
T0: 0000 01A6 [0101]
Jump to BL
NOTICE: BL2: v2.12.0(release):f749ab835-bpi-r4-spim-nand
NOTICE: BL2: Built : 08:27:56, Apr 26 2025
NOTICE: WDT: Cold boot
NOTICE: WDT: disabled
NOTICE: CPU: MT7988
NOTICE: EMI: DDR4 4BG mode
NOTICE: EMI: Using DDR unknown settings
NOTICE: EMI: Detected DRAM size: 8192 MB
NOTICE: EMI: complex R/W mem test passed
NOTICE: LVTS: Enable thermal HW reset
NOTICE: SPI_NAND parses attributes from parameter page.
NOTICE: SPI_NAND Detected ID 0xef
NOTICE: Page size 2048, Block size 131072, size 268435456
NOTICE: UBI: scanning [0x200000 - 0x10000000] ...
NOTICE: UBI: Bad EC magic in block 1008 ffffffff
NOTICE: UBI: Bad EC magic in block 1009 ffffffff
NOTICE: UBI: Bad EC magic in block 1931 ffffffff
NOTICE: UBI: Bad EC magic in block 1932 ffffffff
NOTICE: UBI: Bad EC magic in block 1933 ffffffff
NOTICE: UBI: Bad EC magic in block 1934 ffffffff
NOTICE: UBI: Bad EC magic in block 1935 ffffffff
NOTICE: UBI: Bad EC magic in block 1936 ffffffff
NOTICE: UBI: Bad EC magic in block 1937 ffffffff
NOTICE: UBI: Bad EC magic in block 1938 ffffffff
NOTICE: UBI: Bad EC magic in block 1939 ffffffff
NOTICE: UBI: Bad EC magic in block 1940 ffffffff
NOTICE: UBI: Bad EC magic in block 1941 ffffffff
NOTICE: UBI: Bad EC magic in block 1942 ffffffff
NOTICE: UBI: Bad EC magic in block 1943 ffffffff
NOTICE: UBI: Bad EC magic in block 1944 ffffffff
NOTICE: UBI: Bad EC magic in block 1945 ffffffff
NOTICE: UBI: Bad EC magic in block 1946 ffffffff
NOTICE: UBI: Bad EC magic in block 1947 ffffffff
NOTICE: UBI: Bad EC magic in block 1948 ffffffff
NOTICE: UBI: Bad EC magic in block 1949 ffffffff
NOTICE: UBI: Bad EC magic in block 1950 ffffffff
NOTICE: UBI: Bad EC magic in block 1951 ffffffff
NOTICE: UBI: Bad EC magic in block 1952 ffffffff
NOTICE: UBI: Bad EC magic in block 1953 ffffffff
NOTICE: UBI: Bad EC magic in block 1954 ffffffff
NOTICE: UBI: Bad EC magic in block 1955 ffffffff
NOTICE: UBI: Bad EC magic in block 1956 ffffffff
NOTICE: UBI: Bad EC magic in block 1957 ffffffff
NOTICE: UBI: Bad EC magic in block 1958 ffffffff
NOTICE: UBI: Bad EC magic in block 1959 ffffffff
NOTICE: UBI: Bad EC magic in block 1960 ffffffff
NOTICE: UBI: Bad EC magic in block 1961 ffffffff
NOTICE: UBI: Bad EC magic in block 1962 ffffffff
NOTICE: UBI: Bad EC magic in block 1963 ffffffff
NOTICE: UBI: Bad EC magic in block 1964 ffffffff
NOTICE: UBI: Bad EC magic in block 1965 ffffffff
NOTICE: UBI: Bad EC magic in block 1966 ffffffff
NOTICE: UBI: Bad EC magic in block 1967 ffffffff
NOTICE: UBI: Bad EC magic in block 1968 ffffffff
NOTICE: UBI: Bad EC magic in block 1969 ffffffff
NOTICE: UBI: Bad EC magic in block 1970 ffffffff
NOTICE: UBI: Bad EC magic in block 1971 ffffffff
NOTICE: UBI: Bad EC magic in block 1972 ffffffff
NOTICE: UBI: Bad EC magic in block 1973 ffffffff
NOTICE: UBI: Bad EC magic in block 1974 ffffffff
NOTICE: UBI: Bad EC magic in block 1975 ffffffff
NOTICE: UBI: Bad EC magic in block 1976 ffffffff
NOTICE: UBI: Bad EC magic in block 1977 ffffffff
NOTICE: UBI: Bad EC magic in block 1978 ffffffff
NOTICE: UBI: Bad EC magic in block 1979 ffffffff
NOTICE: UBI: Bad EC magic in block 1980 ffffffff
NOTICE: UBI: Bad EC magic in block 1981 ffffffff
NOTICE: UBI: Bad EC magic in block 1982 ffffffff
NOTICE: UBI: Bad EC magic in block 1983 ffffffff
NOTICE: UBI: Bad EC magic in block 1984 ffffffff
NOTICE: UBI: Bad EC magic in block 1985 ffffffff
NOTICE: UBI: Bad EC magic in block 1986 ffffffff
NOTICE: UBI: Bad EC magic in block 1987 ffffffff
NOTICE: UBI: Bad EC magic in block 1988 ffffffff
NOTICE: UBI: Bad EC magic in block 1989 ffffffff
NOTICE: UBI: Bad EC magic in block 1990 ffffffff
NOTICE: UBI: Bad EC magic in block 1991 ffffffff
NOTICE: UBI: Bad EC magic in block 1992 ffffffff
NOTICE: UBI: Bad EC magic in block 1993 ffffffff
NOTICE: UBI: Bad EC magic in block 1994 ffffffff
NOTICE: UBI: Bad EC magic in block 1995 ffffffff
NOTICE: UBI: Bad EC magic in block 1996 ffffffff
NOTICE: UBI: Bad EC magic in block 1997 ffffffff
NOTICE: UBI: Bad EC magic in block 1998 ffffffff
NOTICE: UBI: Bad EC magic in block 1999 ffffffff
NOTICE: UBI: Bad EC magic in block 2000 ffffffff
NOTICE: UBI: Bad EC magic in block 2001 ffffffff
NOTICE: UBI: Bad EC magic in block 2002 ffffffff
NOTICE: UBI: Bad EC magic in block 2003 ffffffff
NOTICE: UBI: Bad EC magic in block 2004 ffffffff
NOTICE: UBI: Bad EC magic in block 2005 ffffffff
NOTICE: UBI: Bad EC magic in block 2006 ffffffff
NOTICE: UBI: Bad EC magic in block 2007 ffffffff
NOTICE: UBI: Bad EC magic in block 2008 ffffffff
NOTICE: UBI: Bad EC magic in block 2009 ffffffff
NOTICE: UBI: Bad EC magic in block 2010 ffffffff
NOTICE: UBI: Bad EC magic in block 2011 ffffffff
NOTICE: UBI: Bad EC magic in block 2012 ffffffff
NOTICE: UBI: Bad EC magic in block 2013 ffffffff
NOTICE: UBI: Bad EC magic in block 2014 ffffffff
NOTICE: UBI: Bad EC magic in block 2015 ffffffff
NOTICE: UBI: Bad EC magic in block 2016 ffffffff
NOTICE: UBI: Bad EC magic in block 2017 ffffffff
NOTICE: UBI: Bad EC magic in block 2018 ffffffff
NOTICE: UBI: Bad EC magic in block 2019 ffffffff
NOTICE: UBI: Bad EC magic in block 2020 ffffffff
NOTICE: UBI: Bad EC magic in block 2021 ffffffff
NOTICE: UBI: Bad EC magic in block 2022 ffffffff
NOTICE: UBI: Bad EC magic in block 2023 ffffffff
NOTICE: UBI: Bad EC magic in block 2024 ffffffff
NOTICE: UBI: Bad EC magic in block 2025 ffffffff
NOTICE: UBI: Bad EC magic in block 2026 ffffffff
NOTICE: UBI: Bad EC magic in block 2027 ffffffff
NOTICE: UBI: Bad EC magic in block 2028 ffffffff
NOTICE: UBI: Bad EC magic in block 2029 ffffffff
NOTICE: UBI: Bad EC magic in block 2030 ffffffff
NOTICE: UBI: Bad EC magic in block 2031 ffffffff
NOTICE: UBI: scanning is finished
NOTICE: UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
NOTICE: UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
NOTICE: UBI: Volume fip (Id #0) size is 2097152 bytes
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.12.0(release):OpenWrt v2025.02.12~e0907706-1 (mt7988-spim-nand-ubi-comb)
NOTICE: BL31: Built : 18:51:15, May 7 2025
U-Boot 2025.01-OpenWrt-r29494-1b7fd8464c (May 07 2025 - 18:51:15 +0000)
CPU: MediaTek MT7988
Model: Bananapi BPI-R4
DRAM: 8 GiB
Core: 64 devices, 24 uclasses, devicetree: embed
spi-nand: spi_nand spi_nand@0: Winbond SPI NAND was found.
spi-nand: spi_nand spi_nand@0: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
MMC: mmc@11230000: 0
Loading Environment from UBI... Read 126976 bytes from volume ubootenv to 00000000ff7c1c80
Read 126976 bytes from volume ubootenv2 to 00000000ff7e0cc0
OK
In: serial@11000000
Out: serial@11000000
Err: serial@11000000
reset button found
Loading Environment from UBI... UBI partition 'ubi' already selected
OK
Net: MediaTek MT7988 built-in switch
eth0: ethernet@15110100
( ( ( OpenWrt ) ) ) [SPI-NAND] U-Boot 2025.01-OpenWrt-r29494-1b7fd8464c (May 07 2025 - 18:51:15 +0000)
1. Run default boot command.
2. Boot system via TFTP.
3. Boot production system from NAND.
4. Boot recovery system from NAND.
5. Load production system via TFTP then write to NAND.
6. Load recovery system via TFTP then write to NAND.
7. Load BL31+U-Boot FIP via TFTP then write to NAND.
8. Load BL2 preloader via TFTP then write to NAND.
9. Install bootloader, recovery and production to eMMC.
a. Reboot.
b. Reset all settings to factory defaults.
0. Exit
Hit any key to stop autoboot: 2
No size specified -> Using max size (39235584)
Read 39235584 bytes from volume fit to 0000000050000000
## Checking Image at 50000000 ...
FIT image found
FIT description: ARM64 OpenWrt FIT (Flattened Image Tree)
Image 0 (kernel-1)
Description: ARM64 OpenWrt Linux-6.6.79
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x50001000
Data Size: 6684646 Bytes = 6.4 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x46000000
Entry Point: 0x46000000
Hash algo: crc32
Hash value: 4a126d20
Hash algo: sha1
Hash value: 56b96ba4b31217a257ca425105c0c49ead3b6491
Image 1 (fdt-1)
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x50661000
Data Size: 48483 Bytes = 47.3 KiB
Load Address: 0x45f00000
Hash algo: crc32
Hash value: 3bdfd4fb
Hash algo: sha1
Hash value: cb78346451120c4080efef697827a935faa8c221
Image 2 (fdt-mt7988a-bananapi-bpi-r4-emmc)
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-emmc
Data Start: 0x5066d000
Data Size: 1546 Bytes = 1.5 KiB
Hash algo: crc32
Hash value: 809404dd
Hash algo: sha1
Hash value: f5315166f38bb1d9fdd6707c00ff3f91b87fa38f
Image 3 (fdt-mt7988a-bananapi-bpi-r4-rtc)
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-rtc
Data Start: 0x5066e000
Data Size: 285 Bytes = 285 Bytes
Hash algo: crc32
Hash value: 9e869883
Hash algo: sha1
Hash value: 343be366c4680b8d5f970ece19ea9970b91e5aad
Image 4 (fdt-mt7988a-bananapi-bpi-r4-sd)
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd
Data Start: 0x5066f000
Data Size: 1474 Bytes = 1.4 KiB
Hash algo: crc32
Hash value: 992dc95a
Hash algo: sha1
Hash value: d8c80e86d46ccac204bdcf81feb9ca2802402042
Image 5 (fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a)
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a
Data Start: 0x50670000
Data Size: 2289 Bytes = 2.2 KiB
Hash algo: crc32
Hash value: ee6079f2
Hash algo: sha1
Hash value: bbc22a8adc1c3224b7049acd410ad5fc0e60ac4f
Image 6 (rootfs-1)
Description: ARM64 OpenWrt bananapi_bpi-r4 rootfs
Type: Filesystem Image
Data Start: 0x50671000
Data Size: 32428032 Bytes = 30.9 MiB
Hash algo: crc32
Hash value: 25927dd3
Hash algo: sha1
Hash value: 02fc914a421cce1d622d50fd36887c79bec30cef
Default Configuration: 'config-mt7988a-bananapi-bpi-r4'
Configuration 0 (config-mt7988a-bananapi-bpi-r4)
Description: OpenWrt bananapi_bpi-r4
Kernel: kernel-1
FDT: fdt-1
Loadables: rootfs-1
Configuration 1 (mt7988a-bananapi-bpi-r4-emmc)
Description: OpenWrt bananapi_bpi-r4 overlay mt7988a-bananapi-bpi-r4-emmc
Kernel: unavailable
FDT: fdt-mt7988a-bananapi-bpi-r4-emmc
Configuration 2 (mt7988a-bananapi-bpi-r4-rtc)
Description: OpenWrt bananapi_bpi-r4 overlay mt7988a-bananapi-bpi-r4-rtc
Kernel: unavailable
FDT: fdt-mt7988a-bananapi-bpi-r4-rtc
Configuration 3 (mt7988a-bananapi-bpi-r4-sd)
Description: OpenWrt bananapi_bpi-r4 overlay mt7988a-bananapi-bpi-r4-sd
Kernel: unavailable
FDT: fdt-mt7988a-bananapi-bpi-r4-sd
Configuration 4 (mt7988a-bananapi-bpi-r4-wifi-mt7996a)
Description: OpenWrt bananapi_bpi-r4 overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a
Kernel: unavailable
FDT: fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a
## Checking hash(es) for FIT Image at 50000000 ...
Hash(es) for Image 0 (kernel-1): crc32+ sha1+
Hash(es) for Image 1 (fdt-1): crc32+ sha1+
Hash(es) for Image 2 (fdt-mt7988a-bananapi-bpi-r4-emmc): crc32+ sha1+
Hash(es) for Image 3 (fdt-mt7988a-bananapi-bpi-r4-rtc): crc32+ sha1+
Hash(es) for Image 4 (fdt-mt7988a-bananapi-bpi-r4-sd): crc32+ sha1+
Hash(es) for Image 5 (fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a): crc32+ sha1+
Hash(es) for Image 6 (rootfs-1): crc32+ sha1+
## Loading kernel from FIT Image at 50000000 ...
Using 'config-mt7988a-bananapi-bpi-r4' configuration
Trying 'kernel-1' kernel subimage
Type: Kernel Image
OS: Linux
Hash algo: crc32
Hash algo: sha1
Verifying Hash Integrity ... crc32+ sha1+ OK
## Loading fdt from FIT Image at 50000000 ...
Trying 'fdt-1' fdt subimage
Hash algo: crc32
Hash algo: sha1
Loading fdt from 0x50661000 to 0x45f00000
Using 'mt7988a-bananapi-bpi-r4-emmc' configuration
Trying 'fdt-mt7988a-bananapi-bpi-r4-emmc' fdt subimage
Hash algo: crc32
Hash algo: sha1
Booting using the fdt blob at 0x45f00000
Working FDT set to 45f00000
## Loading loadables from FIT Image at 50000000 ...
Trying 'rootfs-1' loadables subimage
Hash algo: crc32
Hash algo: sha1
Uncompressing Kernel Image to 46000000
Loading Device Tree to 00000000fe7ed000, end 00000000fe7fb06d ... OK
Working FDT set to fe7ed000
set /chosen/rootdisk to bootrom media: rootdisk-spim-nand (phandle 0x0000005a)
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 6.6.79 (rafal@Ubuntu) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 r0+28529-56559278b7) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Wed Mar 5 08:20:06 2025
[ 0.000000] Machine model: Bananapi BPI-R4
[ 0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[ 0.000000] OF: reserved mem: 0x0000000043000000..0x000000004304ffff (320 KiB) nomap non-reusable secmon@43000000
[ 0.000000] OF: reserved mem: 0x0000000047cc0000..0x0000000047dbffff (1024 KiB) nomap non-reusable wmcpu-reserved@47cc0000
[ 0.000000] OF: reserved mem: 0x000000004f600000..0x000000004f63ffff (256 KiB) nomap non-reusable wo-emi@4f600000
[ 0.000000] OF: reserved mem: 0x000000004f640000..0x000000004f67ffff (256 KiB) nomap non-reusable wo-emi@4f640000
[ 0.000000] OF: reserved mem: 0x000000004f680000..0x000000004f6bffff (256 KiB) nomap non-reusable wo-emi@4f680000
[ 0.000000] OF: reserved mem: 0x000000004f700000..0x000000004fefffff (8192 KiB) nomap non-reusable wo-data@4f700000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000023fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004304ffff]
[ 0.000000] node 0: [mem 0x0000000043050000-0x0000000047cbffff]
[ 0.000000] node 0: [mem 0x0000000047cc0000-0x0000000047dbffff]
[ 0.000000] node 0: [mem 0x0000000047dc0000-0x000000004f5fffff]
[ 0.000000] node 0: [mem 0x000000004f600000-0x000000004f6bffff]
[ 0.000000] node 0: [mem 0x000000004f6c0000-0x000000004f6fffff]
[ 0.000000] node 0: [mem 0x000000004f700000-0x000000004fefffff]
[ 0.000000] node 0: [mem 0x000000004ff00000-0x000000023fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000023fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 28 pages/cpu s74472 r8192 d32024 u114688
[ 0.000000] pcpu-alloc: s74472 r8192 d32024 u114688 alloc=28*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait ubi.block=0,fit
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fa7ed000-0x00000000fe7ed000] (64MB)
[ 0.000000] Memory: 8135808K/8388608K available (9984K kernel code, 1576K rwdata, 3108K rodata, 512K init, 312K bss, 252800K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 13.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000238] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000245] pid_max: default: 32768 minimum: 301
[ 0.002342] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002365] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.003872] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.004164] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.004247] rcu: Hierarchical SRCU implementation.
[ 0.004249] rcu: Max phase no-delay instances is 1000.
[ 0.004643] smp: Bringing up secondary CPUs ...
[ 0.004874] Detected VIPT I-cache on CPU1
[ 0.004908] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.004931] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[ 0.005193] Detected VIPT I-cache on CPU2
[ 0.005214] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.005224] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[ 0.005467] Detected VIPT I-cache on CPU3
[ 0.005488] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.005498] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[ 0.005529] smp: Brought up 1 node, 4 CPUs
[ 0.005533] SMP: Total of 4 processors activated.
[ 0.005536] CPU features: detected: 32-bit EL0 Support
[ 0.005538] CPU features: detected: CRC32 instructions
[ 0.005556] spectre-bhb mitigation disabled by compile time option
[ 0.005571] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.005574] CPU: All CPU(s) started at EL2
[ 0.005576] alternatives: applying system-wide alternatives
[ 0.009533] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.009546] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.010352] pinctrl core: initialized pinctrl subsystem
[ 0.011079] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.011467] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.011657] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.011839] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.012121] thermal_sys: Registered thermal governor 'fair_share'
[ 0.012124] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.012126] thermal_sys: Registered thermal governor 'step_wise'
[ 0.012127] thermal_sys: Registered thermal governor 'user_space'
[ 0.012171] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.012204] ASID allocator initialised with 65536 entries
[ 0.012879] pstore: Using crash dump compression: deflate
[ 0.012885] printk: console [ramoops-1] enabled
[ 0.013121] pstore: Registered ramoops as persistent store backend
[ 0.013126] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.015043] /soc/interrupt-controller@c000000: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000
[ 0.020841] Modules: 28864 pages in range for non-PLT usage
[ 0.020849] Modules: 520384 pages in range for PLT usage
[ 0.021492] cryptd: max_cpu_qlen set to 1000
[ 0.023019] SCSI subsystem initialized
[ 0.023265] libata version 3.00 loaded.
[ 0.024199] clocksource: Switched to clocksource arch_sys_counter
[ 0.043096] NET: Registered PF_INET protocol family
[ 0.043325] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.047563] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.047602] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.047614] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.047807] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.048644] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.048985] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.049145] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.049235] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.049481] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.049520] PCI: CLS 0 bytes, default 64
[ 0.050448] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.054141] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.054148] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.075627] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[ 0.076273] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.076291] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.076303] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 0.076316] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 0.076407] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 0.076419] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 0.076428] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 0.076438] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 0.076456] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[ 0.076465] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[ 0.076530] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 0.076539] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 0.076548] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 0.076557] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 0.076573] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[ 0.076582] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[ 0.076657] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 0.076666] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 0.076675] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 0.076684] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 0.076700] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[ 0.076707] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[ 0.081494] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.082261] printk: console [ttyS0] disabled
[ 0.102511] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[ 0.102549] printk: console [ttyS0] enabled
[ 1.134142] 11000100.serial: ttyS1 at MMIO 0x11000100 (irq = 100, base_baud = 2500000) is a ST16650V2
[ 1.164044] 11000200.serial: ttyS2 at MMIO 0x11000200 (irq = 101, base_baud = 2500000) is a ST16650V2
[ 1.175938] loop: module loaded
[ 1.180545] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.185870] spi-nand spi0.0: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 1.194216] 2 fixed-partitions partitions found on MTD device spi0.0
[ 1.200576] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.207463] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.214490] Creating 2 MTD partitions on "spi0.0":
[ 1.219276] 0x000000000000-0x000000200000 : "bl2"
[ 1.225520] 0x000000200000-0x000008000000 : "ubi"
[ 1.313008] ubi0: default fastmap pool size: 50
[ 1.317547] ubi0: default fastmap WL pool size: 25
[ 1.322327] ubi0: attaching mtd1
[ 2.095467] ubi0: scanning is finished
[ 2.108548] ubi0: attached mtd1 (name "ubi", size 126 MiB)
[ 2.114034] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.120911] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.127690] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.134641] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
[ 2.140722] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
[ 2.147933] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[ 2.156272] ubi0: available PEBs: 0, total reserved PEBs: 1008, PEBs reserved for bad PEB handling: 40
[ 2.165569] ubi0: background thread "ubi_bgt0d" started, PID 254
[ 2.165640] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 2.178529] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 2.185768] block ubiblock0_4: created from ubi0:4(fit)
[ 2.193307] mt7530-mmio 15020000.switch: Failed to register DSA switch: -517
[ 2.325704] i2c_dev: i2c /dev entries driver
[ 2.330467] /soc/i2c@11003000/rt5190a@64: Fixed dependency cycle(s) with /soc/i2c@11003000/rt5190a@64/regulators/buck1
[ 2.342350] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 2.350442] mtk-cpufreq mtk-cpufreq: failed to initialize dvfs info for cpu0
[ 2.358860] hw perfevents: enabled with armv8_cortex_a73 PMU driver, 7 counters available
[ 2.368676] NET: Registered PF_INET6 protocol family
[ 2.374032] Segment Routing with IPv6
[ 2.377715] In-situ OAM (IOAM) with IPv6
[ 2.381673] NET: Registered PF_PACKET protocol family
[ 2.386771] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.399808] 8021q: 802.1Q VLAN Support v1.8
[ 2.416734] phy phy-soc:[email protected]: type_sw - reg 0x218, index 0
[ 2.423909] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 2.431254] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 2.437531] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 2.445974] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 2.454499] mtk-pcie-gen3 11280000.pcie: failed to get max link width
[ 2.462520] mtk-msdc 11230000.mmc: Final PAD_DS_TUNE: 0x13414
[ 2.468376] mmc0: new HS400 MMC card at address 0001
[ 2.473875] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 2.479791] mmcblk0: p1 p2 p3 p4 p5 p128
[ 2.484767] mmcblk0boot0: mmc0:0001 8GTF4R 4.00 MiB
[ 2.490313] mmcblk0boot1: mmc0:0001 8GTF4R 4.00 MiB
[ 2.495449] mmcblk0rpmb: mmc0:0001 8GTF4R 512 KiB, chardev (249:0)
[ 2.804202] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 2.813001] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 2.820068] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 2.827386] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 2.833651] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 2.842085] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 2.850566] mtk-pcie-gen3 11290000.pcie: failed to get max link width
[ 3.194208] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 3.202987] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[ 3.209893] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 3.217205] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 3.223464] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 3.231898] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 3.240355] mtk-pcie-gen3 11300000.pcie: failed to get max link width
[ 3.490277] mtk-pcie-gen3 11300000.pcie: set IO trans window[0]: cpu_addr = 0x30000000, pci_addr = 0x30000000, size = 0x200000
[ 3.501682] mtk-pcie-gen3 11300000.pcie: set MEM trans window[1]: cpu_addr = 0x30200000, pci_addr = 0x30200000, size = 0x200000
[ 3.513150] mtk-pcie-gen3 11300000.pcie: set MEM trans window[2]: cpu_addr = 0x30400000, pci_addr = 0x30400000, size = 0x400000
[ 3.524614] mtk-pcie-gen3 11300000.pcie: set MEM trans window[3]: cpu_addr = 0x30800000, pci_addr = 0x30800000, size = 0x800000
[ 3.536077] mtk-pcie-gen3 11300000.pcie: set MEM trans window[4]: cpu_addr = 0x31000000, pci_addr = 0x31000000, size = 0x1000000
[ 3.547627] mtk-pcie-gen3 11300000.pcie: set MEM trans window[5]: cpu_addr = 0x32000000, pci_addr = 0x32000000, size = 0x2000000
[ 3.559176] mtk-pcie-gen3 11300000.pcie: set MEM trans window[6]: cpu_addr = 0x34000000, pci_addr = 0x34000000, size = 0x4000000
[ 3.570986] mtk-pcie-gen3 11300000.pcie: PCI host bridge to bus 0000:00
[ 3.577599] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.583076] pci_bus 0000:00: root bus resource [io 0x400000-0x5fffff] (bus address [0x30000000-0x301fffff])
[ 3.592893] pci_bus 0000:00: root bus resource [mem 0x30200000-0x37ffffff]
[ 3.599757] pci_bus 0000:00: scanning bus
[ 3.603777] pci 0000:00:00.0: [14c3:7988] type 01 class 0x060400
[ 3.609791] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 3.616633] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.622717] pci 0000:00:00.0: PME# disabled
[ 3.628231] pci_bus 0000:00: fixups for bus
[ 3.632407] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 3.639100] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.647101] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 3.653838] pci_bus 0000:01: scanning bus
[ 3.657862] pci 0000:01:00.0: [14c3:7990] type 00 class 0x028000
[ 3.663877] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit pref]
[ 3.671104] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[ 3.677989] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 3.684073] pci 0000:01:00.0: PME# disabled
[ 3.714233] pci_bus 0000:01: fixups for bus
[ 3.718406] pci_bus 0000:01: bus scan returning with max=01
[ 3.723968] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.730580] pci_bus 0000:00: bus scan returning with max=01
[ 3.736155] pci 0000:00:00.0: BAR 9: assigned [mem 0x30200000-0x303fffff 64bit pref]
[ 3.743887] pci 0000:00:00.0: BAR 8: assigned [mem 0x30400000-0x304fffff]
[ 3.750666] pci 0000:00:00.0: BAR 0: assigned [mem 0x30500000-0x30507fff 64bit]
[ 3.757972] pci 0000:01:00.0: BAR 0: assigned [mem 0x30200000-0x303fffff 64bit pref]
[ 3.765714] pci 0000:01:00.0: BAR 2: assigned [mem 0x30400000-0x30407fff 64bit]
[ 3.773019] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.777975] pci 0000:00:00.0: bridge window [mem 0x30400000-0x304fffff]
[ 3.784752] pci 0000:00:00.0: bridge window [mem 0x30200000-0x303fffff 64bit pref]
[ 3.792491] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.800932] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.809454] pcieport 0000:00:00.0: assign IRQ: got 121
[ 3.814590] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 3.820680] pcieport 0000:00:00.0: enabling bus mastering
[ 3.826460] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[ 3.834898] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[ 3.843323] mtk-pcie-gen3 11300000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11300c00 data 2
[ 3.851750] mtk-pcie-gen3 11300000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11300c00 data 3
[ 3.860176] mtk-pcie-gen3 11300000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11300c00 data 4
[ 3.868601] mtk-pcie-gen3 11300000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11300c00 data 5
[ 3.877026] mtk-pcie-gen3 11300000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11300c00 data 6
[ 3.885452] mtk-pcie-gen3 11300000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11300c00 data 7
[ 3.893875] mtk-pcie-gen3 11300000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11300c00 data 8
[ 3.902301] mtk-pcie-gen3 11300000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11300c00 data 9
[ 3.910726] mtk-pcie-gen3 11300000.pcie: msi#0xa address_hi 0x0 address_lo 0x11300c00 data 10
[ 3.919239] mtk-pcie-gen3 11300000.pcie: msi#0xb address_hi 0x0 address_lo 0x11300c00 data 11
[ 3.927752] mtk-pcie-gen3 11300000.pcie: msi#0xc address_hi 0x0 address_lo 0x11300c00 data 12
[ 3.936264] mtk-pcie-gen3 11300000.pcie: msi#0xd address_hi 0x0 address_lo 0x11300c00 data 13
[ 3.944776] mtk-pcie-gen3 11300000.pcie: msi#0xe address_hi 0x0 address_lo 0x11300c00 data 14
[ 3.953286] mtk-pcie-gen3 11300000.pcie: msi#0xf address_hi 0x0 address_lo 0x11300c00 data 15
[ 3.961800] mtk-pcie-gen3 11300000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11300c00 data 16
[ 3.970399] mtk-pcie-gen3 11300000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11300c00 data 17
[ 3.978997] mtk-pcie-gen3 11300000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11300c00 data 18
[ 3.987597] mtk-pcie-gen3 11300000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11300c00 data 19
[ 3.996196] mtk-pcie-gen3 11300000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11300c00 data 20
[ 4.004795] mtk-pcie-gen3 11300000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11300c00 data 21
[ 4.013392] mtk-pcie-gen3 11300000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11300c00 data 22
[ 4.021991] mtk-pcie-gen3 11300000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11300c00 data 23
[ 4.030590] mtk-pcie-gen3 11300000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11300c00 data 24
[ 4.039189] mtk-pcie-gen3 11300000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11300c00 data 25
[ 4.047789] mtk-pcie-gen3 11300000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11300c00 data 26
[ 4.056388] mtk-pcie-gen3 11300000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11300c00 data 27
[ 4.064987] mtk-pcie-gen3 11300000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11300c00 data 28
[ 4.073584] mtk-pcie-gen3 11300000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11300c00 data 29
[ 4.082191] mtk-pcie-gen3 11300000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11300c00 data 30
[ 4.090791] mtk-pcie-gen3 11300000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11300c00 data 31
[ 4.099799] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[ 4.108307] pcieport 0000:00:00.0: PME: Signaling with IRQ 122
[ 4.114267] pcieport 0000:00:00.0: AER: enabled with IRQ 122
[ 4.119952] pcieport 0000:00:00.0: save config 0x00: 0x798814c3
[ 4.125872] pcieport 0000:00:00.0: save config 0x04: 0x00100406
[ 4.131780] pcieport 0000:00:00.0: save config 0x08: 0x06040001
[ 4.137693] pcieport 0000:00:00.0: save config 0x0c: 0x00010000
[ 4.143601] pcieport 0000:00:00.0: save config 0x10: 0x30500004
[ 4.149511] pcieport 0000:00:00.0: save config 0x14: 0x00000000
[ 4.155420] pcieport 0000:00:00.0: save config 0x18: 0x00010100
[ 4.161329] pcieport 0000:00:00.0: save config 0x1c: 0x000001f1
[ 4.167238] pcieport 0000:00:00.0: save config 0x20: 0x30403040
[ 4.173146] pcieport 0000:00:00.0: save config 0x24: 0x30313021
[ 4.179055] pcieport 0000:00:00.0: save config 0x28: 0x00000000
[ 4.184964] pcieport 0000:00:00.0: save config 0x2c: 0x00000000
[ 4.190872] pcieport 0000:00:00.0: save config 0x30: 0x00000000
[ 4.196781] pcieport 0000:00:00.0: save config 0x34: 0x00000080
[ 4.202687] pcieport 0000:00:00.0: save config 0x38: 0x00000000
[ 4.208596] pcieport 0000:00:00.0: save config 0x3c: 0x00020179
[ 4.214838] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 4.222143] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 4.228412] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 4.236845] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 4.245319] mtk-pcie-gen3 11310000.pcie: failed to get max link width
[ 4.497236] mtk-pcie-gen3 11310000.pcie: set IO trans window[0]: cpu_addr = 0x38000000, pci_addr = 0x38000000, size = 0x200000
[ 4.508620] mtk-pcie-gen3 11310000.pcie: set MEM trans window[1]: cpu_addr = 0x38200000, pci_addr = 0x38200000, size = 0x200000
[ 4.520085] mtk-pcie-gen3 11310000.pcie: set MEM trans window[2]: cpu_addr = 0x38400000, pci_addr = 0x38400000, size = 0x400000
[ 4.531549] mtk-pcie-gen3 11310000.pcie: set MEM trans window[3]: cpu_addr = 0x38800000, pci_addr = 0x38800000, size = 0x800000
[ 4.543012] mtk-pcie-gen3 11310000.pcie: set MEM trans window[4]: cpu_addr = 0x39000000, pci_addr = 0x39000000, size = 0x1000000
[ 4.554562] mtk-pcie-gen3 11310000.pcie: set MEM trans window[5]: cpu_addr = 0x3a000000, pci_addr = 0x3a000000, size = 0x2000000
[ 4.566111] mtk-pcie-gen3 11310000.pcie: set MEM trans window[6]: cpu_addr = 0x3c000000, pci_addr = 0x3c000000, size = 0x4000000
[ 4.577757] mtk-pcie-gen3 11310000.pcie: PCI host bridge to bus 0001:00
[ 4.584369] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 4.589845] pci_bus 0001:00: root bus resource [io 0x600000-0x7fffff] (bus address [0x38000000-0x381fffff])
[ 4.599661] pci_bus 0001:00: root bus resource [mem 0x38200000-0x3fffffff]
[ 4.606526] pci_bus 0001:00: scanning bus
[ 4.610544] pci 0001:00:00.0: [14c3:7988] type 01 class 0x060400
[ 4.616557] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 4.623392] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.629479] pci 0001:00:00.0: PME# disabled
[ 4.635034] pci_bus 0001:00: fixups for bus
[ 4.639209] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 4.645902] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.653898] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 4.660640] pci_bus 0001:01: scanning bus
[ 4.664666] pci 0001:01:00.0: [14c3:7991] type 00 class 0x028000
[ 4.670682] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit pref]
[ 4.677907] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[ 4.684794] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[ 4.690878] pci 0001:01:00.0: PME# disabled
[ 4.724232] pci_bus 0001:01: fixups for bus
[ 4.728405] pci_bus 0001:01: bus scan returning with max=01
[ 4.733965] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.740577] pci_bus 0001:00: bus scan returning with max=01
[ 4.746153] pci 0001:00:00.0: BAR 9: assigned [mem 0x38200000-0x383fffff 64bit pref]
[ 4.753884] pci 0001:00:00.0: BAR 8: assigned [mem 0x38400000-0x384fffff]
[ 4.760663] pci 0001:00:00.0: BAR 0: assigned [mem 0x38500000-0x38507fff 64bit]
[ 4.767969] pci 0001:01:00.0: BAR 0: assigned [mem 0x38200000-0x383fffff 64bit pref]
[ 4.775710] pci 0001:01:00.0: BAR 2: assigned [mem 0x38400000-0x38407fff 64bit]
[ 4.783017] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 4.787974] pci 0001:00:00.0: bridge window [mem 0x38400000-0x384fffff]
[ 4.794752] pci 0001:00:00.0: bridge window [mem 0x38200000-0x383fffff 64bit pref]
[ 4.802491] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 4.810932] pci 0001:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 4.819437] pcieport 0001:00:00.0: assign IRQ: got 124
[ 4.824573] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[ 4.830663] pcieport 0001:00:00.0: enabling bus mastering
[ 4.836420] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 4.844858] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 4.853283] mtk-pcie-gen3 11310000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11310c00 data 2
[ 4.861710] mtk-pcie-gen3 11310000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11310c00 data 3
[ 4.870136] mtk-pcie-gen3 11310000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11310c00 data 4
[ 4.878562] mtk-pcie-gen3 11310000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11310c00 data 5
[ 4.886988] mtk-pcie-gen3 11310000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11310c00 data 6
[ 4.895413] mtk-pcie-gen3 11310000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11310c00 data 7
[ 4.903837] mtk-pcie-gen3 11310000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11310c00 data 8
[ 4.912262] mtk-pcie-gen3 11310000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11310c00 data 9
[ 4.920687] mtk-pcie-gen3 11310000.pcie: msi#0xa address_hi 0x0 address_lo 0x11310c00 data 10
[ 4.929200] mtk-pcie-gen3 11310000.pcie: msi#0xb address_hi 0x0 address_lo 0x11310c00 data 11
[ 4.937712] mtk-pcie-gen3 11310000.pcie: msi#0xc address_hi 0x0 address_lo 0x11310c00 data 12
[ 4.946225] mtk-pcie-gen3 11310000.pcie: msi#0xd address_hi 0x0 address_lo 0x11310c00 data 13
[ 4.954737] mtk-pcie-gen3 11310000.pcie: msi#0xe address_hi 0x0 address_lo 0x11310c00 data 14
[ 4.963246] mtk-pcie-gen3 11310000.pcie: msi#0xf address_hi 0x0 address_lo 0x11310c00 data 15
[ 4.971761] mtk-pcie-gen3 11310000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11310c00 data 16
[ 4.980361] mtk-pcie-gen3 11310000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11310c00 data 17
[ 4.988961] mtk-pcie-gen3 11310000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11310c00 data 18
[ 4.997560] mtk-pcie-gen3 11310000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11310c00 data 19
[ 5.006160] mtk-pcie-gen3 11310000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11310c00 data 20
[ 5.014758] mtk-pcie-gen3 11310000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11310c00 data 21
[ 5.023356] mtk-pcie-gen3 11310000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11310c00 data 22
[ 5.031954] mtk-pcie-gen3 11310000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11310c00 data 23
[ 5.040554] mtk-pcie-gen3 11310000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11310c00 data 24
[ 5.049152] mtk-pcie-gen3 11310000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11310c00 data 25
[ 5.057752] mtk-pcie-gen3 11310000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11310c00 data 26
[ 5.066351] mtk-pcie-gen3 11310000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11310c00 data 27
[ 5.074950] mtk-pcie-gen3 11310000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11310c00 data 28
[ 5.083547] mtk-pcie-gen3 11310000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11310c00 data 29
[ 5.092148] mtk-pcie-gen3 11310000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11310c00 data 30
[ 5.100747] mtk-pcie-gen3 11310000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11310c00 data 31
[ 5.109763] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 5.118276] pcieport 0001:00:00.0: PME: Signaling with IRQ 125
[ 5.124241] pcieport 0001:00:00.0: AER: enabled with IRQ 125
[ 5.129934] pcieport 0001:00:00.0: save config 0x00: 0x798814c3
[ 5.135851] pcieport 0001:00:00.0: save config 0x04: 0x00100406
[ 5.141760] pcieport 0001:00:00.0: save config 0x08: 0x06040001
[ 5.147670] pcieport 0001:00:00.0: save config 0x0c: 0x00010000
[ 5.153578] pcieport 0001:00:00.0: save config 0x10: 0x38500004
[ 5.159488] pcieport 0001:00:00.0: save config 0x14: 0x00000000
[ 5.165398] pcieport 0001:00:00.0: save config 0x18: 0x00010100
[ 5.171306] pcieport 0001:00:00.0: save config 0x1c: 0x000001f1
[ 5.177216] pcieport 0001:00:00.0: save config 0x20: 0x38403840
[ 5.183123] pcieport 0001:00:00.0: save config 0x24: 0x38313821
[ 5.189032] pcieport 0001:00:00.0: save config 0x28: 0x00000000
[ 5.194941] pcieport 0001:00:00.0: save config 0x2c: 0x00000000
[ 5.200848] pcieport 0001:00:00.0: save config 0x30: 0x00000000
[ 5.206760] pcieport 0001:00:00.0: save config 0x34: 0x00000080
[ 5.212666] pcieport 0001:00:00.0: save config 0x38: 0x00000000
[ 5.218577] pcieport 0001:00:00.0: save config 0x3c: 0x0002017c
[ 5.225625] FIT: Detected U-Boot 2025.01-OpenWrt-r29494-1b7fd8464c
[ 5.231799] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4" (OpenWrt bananapi_bpi-r4)
[ 5.240849] FIT: kernel sub-image 0x00001000..0x00660fe5 "kernel-1" (ARM64 OpenWrt Linux-6.6.79)
[ 5.250593] FIT: flat_dt sub-image 0x00661000..0x0066cd62 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r4 device tree blob)
[ 5.261809] FIT: flat_dt sub-image 0x0066d000..0x0066d609 "fdt-mt7988a-bananapi-bpi-r4-emmc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-emmc)
[ 5.278142] FIT: flat_dt sub-image 0x0066e000..0x0066e11c "fdt-mt7988a-bananapi-bpi-r4-rtc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-rtc)
[ 5.294300] FIT: flat_dt sub-image 0x0066f000..0x0066f5c1 "fdt-mt7988a-bananapi-bpi-r4-sd" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd)
[ 5.310289] FIT: flat_dt sub-image 0x00670000..0x006708f0 "fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a)
[ 5.328012] FIT: filesystem sub-image 0x00671000..0x0255dfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r4 rootfs)
[ 5.338880] block ubiblock0_4: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[ 5.347756] mt7530-mmio 15020000.switch: Failed to register DSA switch: -517
[ 5.495607] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[ 5.658238] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082a00000, irq 110
[ 5.667918] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082a00000, irq 110
[ 5.677601] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc082a00000, irq 110
[ 5.769505] mt7530-mmio 15020000.switch: configuring for fixed/internal link mode
[ 5.777017] mt7530-mmio 15020000.switch: Link is Up - 10Gbps/Full - flow control rx/tx
[ 5.806392] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=127)
[ 5.846661] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7988 PHY] (irq=128)
[ 5.887166] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=129)
[ 5.928010] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=130)
[ 5.938952] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[ 5.945660] DSA: tree 0 setup
[ 5.948618] mt7530-nl: genl_register_family_with_ops
[ 5.953892] clk: Disabling unused clocks
[ 5.963148] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
[ 5.970388] Freeing unused kernel memory: 512K
[ 5.974850] Run /sbin/init as init process
[ 5.978934] with arguments:
[ 5.981889] /sbin/init
[ 5.984587] with environment:
[ 5.987716] HOME=/
[ 5.990063] TERM=linux
[ 6.209800] init: Console is alive
[ 6.213271] init: - watchdog -
[ 6.674204] random: crng init done
[ 6.917904] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 6.943358] usbcore: registered new interface driver usbfs
[ 6.948872] usbcore: registered new interface driver hub
[ 6.954194] usbcore: registered new device driver usb
[ 6.961722] gpio_button_hotplug: loading out-of-tree module taints kernel.
[ 6.971925] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 6.979331] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 6.987225] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.992449] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 7.002927] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[ 7.012077] xhci-mtk 11200000.usb: irq 131, io mem 0x11200000
[ 7.017889] xhci-mtk 11200000.usb: xHCI Host Controller
[ 7.023104] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 7.030491] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 7.037766] hub 1-0:1.0: USB hub found
[ 7.041524] hub 1-0:1.0: 1 port detected
[ 7.045599] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 7.053817] hub 2-0:1.0: USB hub found
[ 7.057577] hub 2-0:1.0: 1 port detected
[ 7.064565] usbcore: registered new interface driver usb-storage
[ 7.071063] usbcore: registered new interface driver uas
[ 7.076498] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 7.091917] init: - preinit -
[ 7.514206] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 7.539010] mtk_ppe: roaming work has been activated
[ 7.543986] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 7.552115] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 7.716733] hub 1-1:1.0: USB hub found
[ 7.720652] hub 1-1:1.0: 5 ports detected
[ 7.874277] usb 2-1: new SuperSpeed USB device number 2 using xhci-mtk
[ 7.906790] hub 2-1:1.0: USB hub found
[ 7.910701] hub 2-1:1.0: 4 ports detected
[ 8.359213] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 8.424215] usb 1-1.5: new high-speed USB device number 3 using xhci-mtk
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 12.576069] mount_root: loading kmods from internal overlay
[ 12.586437] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 12.596358] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
[ 12.890216] block: attempting to load /tmp/overlay/upper/etc/config/fstab
[ 12.899238] block: unable to load configuration (fstab: Entry not found)
[ 12.905955] block: attempting to load /tmp/overlay/etc/config/fstab
[ 12.912235] block: unable to load configuration (fstab: Entry not found)
[ 12.918975] block: attempting to load /etc/config/fstab
[ 12.952219] block: extroot: not configured
[ 12.958529] UBIFS (ubi0:6): Mounting in unauthenticated mode
[ 12.964242] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 980
[ 13.010727] UBIFS (ubi0:6): recovery needed
[ 13.126410] UBIFS (ubi0:6): recovery completed
[ 13.130883] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "rootfs_data"
[ 13.138705] UBIFS (ubi0:6): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 13.148610] UBIFS (ubi0:6): FS size: 40886272 bytes (38 MiB, 322 LEBs), max 332 LEBs, journal size 2031616 bytes (1 MiB, 16 LEBs)
[ 13.160248] UBIFS (ubi0:6): reserved for root: 1931159 bytes (1885 KiB)
[ 13.166851] UBIFS (ubi0:6): media format: w5/r0 (latest is w5/r0), UUID D27E0E2A-7C56-4F8D-B6E3-4F957A3E9E07, small LPT model
[ 13.179037] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 13.191822] block: extroot: not configured
[ 13.199548] UBIFS (ubi0:6): un-mount UBI device 0
[ 13.204251] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" stops
[ 13.213571] UBIFS (ubi0:6): Mounting in unauthenticated mode
[ 13.219277] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 983
[ 13.329086] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "rootfs_data"
[ 13.336908] UBIFS (ubi0:6): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 13.346809] UBIFS (ubi0:6): FS size: 40886272 bytes (38 MiB, 322 LEBs), max 332 LEBs, journal size 2031616 bytes (1 MiB, 16 LEBs)
[ 13.358446] UBIFS (ubi0:6): reserved for root: 1931159 bytes (1885 KiB)
[ 13.365048] UBIFS (ubi0:6): media format: w5/r0 (latest is w5/r0), UUID D27E0E2A-7C56-4F8D-B6E3-4F957A3E9E07, small LPT model
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek
failed to seek[ 13.548236] block: attempting to load /tmp/overlay/upper/etc/config/fstab
failed to seek
failed to seek
failed to seek
failed to seek[ 13.561102] block: extroot: not configured
[ 13.566347] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 13.573371] block: extroot: not configured
[ 13.579428] mount_root: switching to ubifs overlay
[ 13.592558] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 13.607375] urandom-seed: Seeding with /etc/urandom.seed
[ 13.652442] procd: - early -
[ 13.655377] procd: - watchdog -
[ 14.189161] procd: - watchdog -
[ 14.194585] procd: - ubus -
[ 14.352423] procd: - init -
Please press Enter to activate this console.
[ 14.719938] kmodloader: loading kernel modules from /etc/modules.d/*
[ 14.730826] NET: Registered PF_ALG protocol family
[ 14.759575] RPC: Registered named UNIX socket transport module.
[ 14.765531] RPC: Registered udp transport module.
[ 14.770231] RPC: Registered tcp transport module.
[ 14.774929] RPC: Registered tcp-with-tls transport module.
[ 14.780406] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 14.795179] l2tp_core: L2TP core driver, V2.0
[ 14.799992] l2tp_netlink: L2TP netlink interface
[ 14.805438] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 14.812403] gre: GRE over IPv4 demultiplexor driver
[ 14.817883] ip_gre: GRE over IPv4 tunneling driver
[ 14.836671] urngd: v1.0.2 started.
[ 14.862005] pca954x 1-0070: supply vdd not found, using dummy regulator
[ 14.869211] i2c i2c-1: Added multiplexed i2c bus 2
[ 14.874063] i2c i2c-1: Added multiplexed i2c bus 3
[ 14.878942] i2c i2c-1: Added multiplexed i2c bus 4
[ 14.883781] i2c i2c-1: Added multiplexed i2c bus 5
[ 14.888583] pca954x 1-0070: registered 4 multiplexed busses for I2C switch pca9545
[ 14.901673] ntfs3: Enabled Linux POSIX ACLs support
[ 14.908085] crypto-safexcel 15600000.crypto: EIP197:331(7,1,8,4)-HIA:272(2,5,5),PE:151/450(alg:7fe1fc00)/240/240/450
[ 14.919255] crypto-safexcel 15600000.crypto: TRC init: 8704d,48a (32r,128h)
[ 14.963083] at24 2-0050: supply vcc not found, using dummy regulator
[ 14.997327] at24 2-0057: supply vcc not found, using dummy regulator
[ 15.004403] at24 2-0057: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 15.011616] Bridge firewalling registered
[ 15.015942] Loading modules backported from Linux version wireless-next-2025-01-17-0-g68abd0c4ebf2
[ 15.024897] Backport generated by backports.git a2342da8
[ 15.035210] sfp sfp1: Host maximum power 3.0W
[ 15.039599] sfp sfp1: tx disable 1 -> 1
[ 15.043442] sfp sfp1: SM: enter empty:detached:down event insert
[ 15.049460] sfp sfp1: SM: exit probe:detached:down
[ 15.054398] sfp sfp1: SM: enter probe:detached:down event dev_attach
[ 15.060740] sfp sfp1: SM: exit probe:down:down
[ 15.065413] sfp sfp2: Host maximum power 3.0W
[ 15.069792] sfp sfp2: tx disable 1 -> 1
[ 15.073634] sfp sfp2: SM: enter empty:detached:down event insert
[ 15.079643] sfp sfp2: SM: exit probe:detached:down
[ 15.084611] sfp sfp2: SM: enter probe:detached:down event dev_attach
[ 15.090954] sfp sfp2: SM: exit probe:down:down
[ 15.096436] usbcore: registered new interface driver ums-alauda
[ 15.102742] usbcore: registered new interface driver ums-cypress
[ 15.109183] usbcore: registered new interface driver ums-datafab
[ 15.115595] usbcore: registered new interface driver ums-freecom
[ 15.122015] usbcore: registered new interface driver ums-isd200
[ 15.128386] usbcore: registered new interface driver ums-jumpshot
[ 15.134865] usbcore: registered new interface driver ums-karma
[ 15.141169] usbcore: registered new interface driver ums-sddr09
[ 15.147554] usbcore: registered new interface driver ums-sddr55
[ 15.153931] usbcore: registered new interface driver ums-usbat
[ 15.167010] xt_time: kernel timezone is -0000
[ 15.311800] mt7996e_hif 0001:01:00.0: assign IRQ: got 124
[ 15.317230] mt7996e_hif 0001:01:00.0: enabling device (0000 -> 0002)
[ 15.323596] mt7996e_hif 0001:01:00.0: enabling bus mastering
[ 15.329361] mt7996e 0000:01:00.0: assign IRQ: got 121
[ 15.334417] mt7996e 0000:01:00.0: enabling device (0000 -> 0002)
[ 15.340427] mt7996e 0000:01:00.0: enabling bus mastering
[ 15.354196] sfp sfp1: SM: enter probe:down:down event timeout
[ 15.371215] sfp sfp1: module PACBTECH PAC-10G-T rev 1 sn CSR20241019 dc 241016
[ 15.380607] sfp sfp1: sfp: support mode 00,00000000,00000800,00006040
[ 15.387046] mtk_soc_eth 15100000.ethernet eth2: optical SFP: interfaces=[mac=2-4,22-24,27,29, sfp=27]
[ 15.396265] mtk_soc_eth 15100000.ethernet eth2: requesting link mode inband/10gbase-r with support 00,00000000,00000800,00006440
[ 15.407821] mtk_soc_eth 15100000.ethernet eth2: switched to inband/10gbase-r link mode
[ 15.415728] sfp sfp1: SM: exit present:down:down
[ 15.420339] sfp sfp2: SM: enter probe:down:down event timeout
[ 15.424226] mt7996e 0000:01:00.0: attaching wed device 0 version 3.0
[ 15.435913] hwmon hwmon1: temp1_input not attached to any thermal zone
[ 15.443345] sfp sfp2: module OEM SFP+-T30 rev A sn C2412061188 dc 241207
[ 15.452770] sfp sfp2: sfp: support mode 00,00000000,00000800,00006040
[ 15.459233] mtk_soc_eth 15100000.ethernet eth1: optical SFP: interfaces=[mac=1-4,22-24,27,29, sfp=27]
[ 15.468468] mtk_soc_eth 15100000.ethernet eth1: requesting link mode inband/10gbase-r with support 00,00000000,00000800,00006440
[ 15.480023] mtk_soc_eth 15100000.ethernet eth1: switched to inband/10gbase-r link mode
[ 15.487930] sfp sfp2: SM: exit present:down:down
[ 15.489327] platform 15010000.wed: MTK WED WO Firmware Version: ____000000, Build Time: 20230218204509
[ 15.492581] sfp sfp2: SM: enter present:down:down event los_high
[ 15.501833] platform 15010000.wed: MTK WED WO Chip ID 00 Region 2
[ 15.513926] sfp sfp2: SM: exit present:down:down
[ 15.518545] sfp sfp1: SM: enter present:down:down event los_high
[ 15.524543] sfp sfp1: SM: exit present:down:down
[ 15.527619] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 15.555666] mt7996e_hif 0001:01:00.0: attaching wed device 1 version 3.0
[ 15.884544] mt7996e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20250324122543a
[ 15.884544]
[ 16.605790] mt7996e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20250324122536
[ 16.679256] mt7996e 0000:01:00.0: DSP Firmware Version: ____000000, Build Time: 20250324121731
[ 16.818148] mt7996e 0000:01:00.0: WA Firmware Version: ____000000, Build Time: 20250324122431
[ 17.664213] mt7996e 0000:01:00.0: registering led 'mt76-phy0'
[ 17.792711] PPP generic driver version 2.4.2
[ 17.797684] PPP MPPE Compression module registered
[ 17.803074] NET: Registered PF_PPPOX protocol family
[ 17.808550] PPTP driver version 0.8.5
[ 17.813007] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 17.819280] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 22.015381] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 22.454224] mtk_ppe: roaming work has been deactivated
[ 22.467542] mtk_ppe: roaming work has been activated
[ 22.472526] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 22.480659] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 22.483825] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 22.497692] br-lan: port 1(lan1) entered blocking state
[ 22.502910] br-lan: port 1(lan1) entered disabled state
[ 22.508147] mt7530-mmio 15020000.switch lan1: entered allmulticast mode
[ 22.514761] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[ 22.521673] mt7530-mmio 15020000.switch lan1: entered promiscuous mode
[ 22.537677] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
[ 22.546706] br-lan: port 2(lan2) entered blocking state
[ 22.551945] br-lan: port 2(lan2) entered disabled state
[ 22.557262] mt7530-mmio 15020000.switch lan2: entered allmulticast mode
[ 22.564064] mt7530-mmio 15020000.switch lan2: entered promiscuous mode
[ 22.575603] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
[ 22.584113] br-lan: port 3(lan3) entered blocking state
[ 22.589405] br-lan: port 3(lan3) entered disabled state
[ 22.594674] mt7530-mmio 15020000.switch lan3: entered allmulticast mode
[ 22.601461] mt7530-mmio 15020000.switch lan3: entered promiscuous mode
[ 22.609226] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
[ 22.628293] sfp sfp2: SM: enter present:down:down event dev_up
[ 22.634120] sfp sfp2: tx disable 1 -> 0
[ 22.637976] sfp sfp2: SM: exit present:up:wait
[ 22.655795] br-lan: port 4(eth1) entered blocking state
[ 22.661024] br-lan: port 4(eth1) entered disabled state
[ 22.666268] mtk_soc_eth 15100000.ethernet eth1: entered allmulticast mode
[ 22.673146] mtk_soc_eth 15100000.ethernet eth1: entered promiscuous mode
[ 22.685590] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
[ 22.695442] br-wan: port 1(wan) entered blocking state
[ 22.700593] br-wan: port 1(wan) entered disabled state
[ 22.705775] mt7530-mmio 15020000.switch wan: entered allmulticast mode
[ 22.712463] mt7530-mmio 15020000.switch wan: entered promiscuous mode
[ 22.719101] sfp sfp2: SM: enter present:up:wait event timeout
[ 22.724872] sfp sfp2: probing phy device through the [MDIO_I2C_NONE] protocol
[ 22.732002] sfp sfp2: SM: exit present:up:wait_los
[ 22.738310] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/10gbase-r link mode
[ 22.757457] sfp sfp1: SM: enter present:down:down event dev_up
[ 22.763287] sfp sfp1: tx disable 1 -> 0
[ 22.767185] sfp sfp1: SM: exit present:up:wait
[ 22.785269] br-wan: port 2(eth2) entered blocking state
[ 22.790507] br-wan: port 2(eth2) entered disabled state
[ 22.795777] mtk_soc_eth 15100000.ethernet eth2: entered allmulticast mode
[ 22.802692] mtk_soc_eth 15100000.ethernet eth2: entered promiscuous mode
[ 22.829259] sfp sfp1: SM: enter present:up:wait event timeout
[ 22.835034] sfp sfp1: probing phy device through the [MDIO_I2C_NONE] protocol
[ 22.842161] sfp sfp1: SM: exit present:up:wait_los
[ 23.304228] Per-port-per-queue mode is going to be enabled !
[ 23.309893] PPPQ use qid 3~12 (scheduler 0).
[ 36.704178] mt7996e 0000:01:00.0: Platform_type = 2, bypass_rro = 1, txfree_path = 0
[ 36.713301] sfp sfp2: SM: enter present:up:wait_los event los_low
[ 36.719478] sfp sfp2: SM: exit present:up:link_up
[ 36.753759] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[ 36.753798] br-lan: port 4(eth1) entered blocking state
[ 36.767367] br-lan: port 4(eth1) entered forwarding state
[ 37.592291] br-lan: port 5(ap-mld-1) entered blocking state
[ 37.597881] br-lan: port 5(ap-mld-1) entered disabled state
[ 37.603466] mt7996e 0000:01:00.0 ap-mld-1: entered allmulticast mode
[ 37.609943] mt7996e 0000:01:00.0 ap-mld-1: entered promiscuous mode
[ 37.616355] br-lan: port 5(ap-mld-1) entered blocking state
[ 37.621922] br-lan: port 5(ap-mld-1) entered forwarding state
[ 37.704210] mt7996e 0000:01:00.0: mt7996_change_vif_links: old=0x0, new=0x1, dormant=0x0
[ 37.720716] br-lan: port 5(ap-mld-1) entered disabled state
[ 37.739260] mt7996e 0000:01:00.0: mt76_add_chanctx: add 1 on mt76 band 0
[ 37.864940] mt7996e 0000:01:00.0: mt76_assign_vif_chanctx: assign link_id 0 to 2412 MHz
[ 37.872951] mt7996e 0000:01:00.0: mt7996_mcu_add_dev_info: band=0, omac=0, addr=c6:78:24:d3:38:cc, en=1
[ 37.883076] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=0, omac=0, wmm_idx=0, bssid=c6:78:24:d3:38:cc, link=0, en=1
[ 37.894285] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=0, own_mld_id=16, remap_idx=0, mld->addr[c6:78:24:d3:38:f0]
[ 37.907077] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=0, wcid=1087, newly=1, conn_state=2
[ 37.918311] mt7996e 0000:01:00.0: mt7996_vif_link_add: band=0, bss_idx=0, link_id=0, wcid=1087
[ 37.927502] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=0, omac=0, wmm_idx=0, bssid=c6:78:24:d3:38:cc, link=0, en=1
[ 37.938713] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=0, own_mld_id=16, remap_idx=0, mld->addr[c6:78:24:d3:38:f0]
[ 37.951266] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=0, wcid=1087, newly=0, conn_state=2
[ 37.964801] br-lan: port 5(ap-mld-1) entered blocking state
[ 37.970368] br-lan: port 5(ap-mld-1) entered forwarding state
[ 38.024206] mt7996e 0000:01:00.0: mt7996_set_key: keyidx=1, link_bitmap=0x1
[ 38.031171] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=0, omac=0, wmm_idx=0, bssid=c6:78:24:d3:38:cc, link=0, en=1
[ 38.042384] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=0, own_mld_id=16, remap_idx=0, mld->addr[c6:78:24:d3:38:f0]
[ 38.124191] mt7996e 0000:01:00.0: mt7996_set_key: keyidx=4, link_bitmap=0x1
[ 38.131223] mt7996e 0000:01:00.0: mt7996_set_key: keyidx=6, link_bitmap=0x1
[ 38.139341] br-lan: port 6(phy0.0-ap0) entered blocking state
[ 38.145135] br-lan: port 6(phy0.0-ap0) entered disabled state
[ 38.150929] mt7996e 0000:01:00.0 phy0.0-ap0: entered allmulticast mode
[ 38.157586] mt7996e 0000:01:00.0 phy0.0-ap0: entered promiscuous mode
[ 38.164253] br-lan: port 6(phy0.0-ap0) entered blocking state
[ 38.169990] br-lan: port 6(phy0.0-ap0) entered forwarding state
[ 38.176861] mt7996e 0000:01:00.0: mt76_assign_vif_chanctx: assign link_id 0 to 2412 MHz
[ 38.184933] mt7996e 0000:01:00.0: mt7996_mcu_add_dev_info: band=0, omac=17, addr=c6:78:24:d3:38:cd, en=1
[ 38.194515] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=0, omac=17, wmm_idx=0, bssid=c6:78:24:d3:38:cd, link=0, en=1
[ 38.205829] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=255, own_mld_id=17, remap_idx=255, mld->addr[00:00:00:00:00:00]
[ 38.218776] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=0, wcid=1086, newly=1, conn_state=2
[ 38.229931] mt7996e 0000:01:00.0: mt7996_vif_link_add: band=0, bss_idx=1, link_id=0, wcid=1086
[ 38.241259] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=0, omac=17, wmm_idx=0, bssid=c6:78:24:d3:38:cd, link=0, en=1
[ 38.252564] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=255, own_mld_id=17, remap_idx=255, mld->addr[00:00:00:00:00:00]
[ 38.265417] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=0, wcid=1086, newly=0, conn_state=2
[ 41.974236] mt7996e 0000:01:00.0: mt7996_change_vif_links: old=0x1, new=0x3, dormant=0x0
[ 41.983664] nl80211_start_radar_detection: region = 1, center freq1 = 5250, center freq2 = 0, cac time ms = 60000
[ 41.993970] mt7996e 0000:01:00.0: mt76_add_chanctx: add 36 on mt76 band 1
[ 42.016148] mt7996e 0000:01:00.0: mt76_assign_vif_chanctx: assign link_id 1 to 5180 MHz
[ 42.024147] mt7996e 0000:01:00.0: mt7996_mcu_add_dev_info: band=1, omac=0, addr=c6:78:24:d3:38:dc, en=1
[ 42.034395] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=1, omac=0, wmm_idx=0, bssid=c6:78:24:d3:38:dc, link=1, en=1
[ 42.045606] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=0, own_mld_id=18, remap_idx=0, mld->addr[c6:78:24:d3:38:f0]
[ 42.058632] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=1, wcid=1085, newly=1, conn_state=2
[ 42.069862] mt7996e 0000:01:00.0: mt7996_vif_link_add: band=1, bss_idx=2, link_id=1, wcid=1085
[ 42.079051] mt7996e 0000:01:00.0: mt76_change_chanctx: change to 36, 0x4
[ 44.944872] mt7996e 0000:01:00.0: mt7996_change_vif_links: old=0x3, new=0x7, dormant=0x0
[ 44.966655] mt7996e 0000:01:00.0: mt7996_set_key: keyidx=1, link_bitmap=0x4
[ 44.973775] mt7996e 0000:01:00.0: mt7996_set_key: keyidx=4, link_bitmap=0x4
[ 44.981299] mt7996e 0000:01:00.0: mt7996_set_key: keyidx=6, link_bitmap=0x4
[ 44.989575] br-lan: port 7(phy0.2-ap0) entered blocking state
[ 44.995427] br-lan: port 7(phy0.2-ap0) entered disabled state
[ 45.001218] mt7996e 0000:01:00.0 phy0.2-ap0: entered allmulticast mode
[ 45.007921] mt7996e 0000:01:00.0 phy0.2-ap0: entered promiscuous mode
[ 45.014599] br-lan: port 7(phy0.2-ap0) entered blocking state
[ 45.020338] br-lan: port 7(phy0.2-ap0) entered forwarding state
[ 45.029707] br-lan: port 7(phy0.2-ap0) entered disabled state
[ 45.084209] mt7996e 0000:01:00.0: mt7996_set_key: keyidx=1, link_bitmap=0x1
[ 45.134193] mt7996e 0000:01:00.0: mt7996_set_key: keyidx=4, link_bitmap=0x1
[ 45.141516] mt7996e 0000:01:00.0: mt76_add_chanctx: add 37 on mt76 band 2
[ 46.232881] mt7996e 0000:01:00.0: mt76_assign_vif_chanctx: assign link_id 2 to 6135 MHz
[ 46.241082] mt7996e 0000:01:00.0: mt7996_mcu_add_dev_info: band=2, omac=0, addr=c6:78:24:d3:38:ec, en=1
[ 46.251339] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=2, omac=0, wmm_idx=0, bssid=c6:78:24:d3:38:ec, link=2, en=1
[ 46.262554] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=0, own_mld_id=19, remap_idx=0, mld->addr[c6:78:24:d3:38:f0]
[ 46.275133] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=2, wcid=1084, newly=1, conn_state=2
[ 46.286340] mt7996e 0000:01:00.0: mt7996_vif_link_add: band=2, bss_idx=3, link_id=2, wcid=1084
[ 46.296096] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=2, omac=0, wmm_idx=0, bssid=c6:78:24:d3:38:ec, link=2, en=1
[ 46.307311] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=0, own_mld_id=19, remap_idx=0, mld->addr[c6:78:24:d3:38:f0]
[ 46.319923] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=2, wcid=1084, newly=0, conn_state=2
[ 46.337218] mt7996e 0000:01:00.0: mt76_assign_vif_chanctx: assign link_id 0 to 6135 MHz
[ 46.345409] mt7996e 0000:01:00.0: mt7996_mcu_add_dev_info: band=2, omac=17, addr=c6:78:24:d3:38:ed, en=1
[ 46.355689] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=2, omac=17, wmm_idx=0, bssid=c6:78:24:d3:38:ed, link=0, en=1
[ 46.366994] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=255, own_mld_id=20, remap_idx=255, mld->addr[00:00:00:00:00:00]
[ 46.379873] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=0, wcid=1083, newly=1, conn_state=2
[ 46.391060] mt7996e 0000:01:00.0: mt7996_vif_link_add: band=2, bss_idx=4, link_id=0, wcid=1083
[ 46.400167] mt7996e 0000:01:00.0: mt7996_mcu_bss_basic_tlv: band=2, omac=17, wmm_idx=0, bssid=c6:78:24:d3:38:ed, link=0, en=1
[ 46.411495] mt7996e 0000:01:00.0: mt7996_mcu_bss_mld_tlv: group_mld_id=255, own_mld_id=20, remap_idx=255, mld->addr[00:00:00:00:00:00]
[ 46.424436] mt7996e 0000:01:00.0: mt7996_mcu_add_sta: link=0, wcid=1083, newly=0, conn_state=2
[ 46.436789] br-lan: port 7(phy0.2-ap0) entered blocking state
[ 46.442531] br-lan: port 7(phy0.2-ap0) entered forwarding state
I’m posting the image from the NAND, as if it recognizes 8GB.
Then I downloaded CFDisk from the NAND flash drive and installed it.
Once installed, we run cfdisk /dev/mmcblk0 and I’ve given it more space in eMMC so we have more gigabytes to be able to install everything we want since I have both the 4GB RAM and the 8GB RAM. This space exists and is the same on both boards and is unused. Once we run the command, a screen like this will appear.
In free space, in green, you’ll see 7.2GB free. This, which is unused on both boards, we’ll give to eMMC.
We’ll search for dev/mmcblk0p5 and go to resize. We’ll delete the 7.2G. I put 5G. You have to enter it that way for it to recognize it. We’ll press Enter. Then we’ll go to the write tab and it will ask you to confirm with yes. Write it, and that’s it! That’s it!
Now we’ll reboot into NAND, but when the menu appears, we’ll click on install in EMMC. However, once you reboot, you’ll see that those 5 GB still don’t appear in the software, which is where they should appear. However, this is normal since we’ve already recorded the NAND image. Now you can install your OpenWRT-MediaTek-Filogic-Bananapi_bpi-r4-Squashfs-SysUpgrade.itb from EMMC. Once you reboot, the 5 GB will appear, allowing you to install everything you wanted.
I leave an image with the 5GB that we have given to be able to install everything we need
Now, I’ll leave you the image I used to burn the first image to SD, which perfectly recognizes the 8 GB. This image has no errors, but it’s very simple, since we want it to be the base for burning it to NAND, since the NAND doesn’t have much space, so you can’t do much.
Here’s an image of the 8GB of RAM recognized by the SSD.
SD card image
sd-nand-8gb-ram
Here’s the image I used in EMMC to update Kernel 6.6.86 in case anyone wants to try it. It’s not mine, it’s from my colleague @RafalB82.
openwrt-mediatek-filogic-bananapi_bpi-r4-squashfs-sysupgrade.itb
As I mentioned, if you don’t mind the first bad blocks in NAND, you won’t have any problems if you want to try it. It’s the easiest way I’ve found: with a 4GB RAM image, the NAND will recognize the 8GB from the SD, so that the NAND will recognize all 8. And we can write to eMMC from the same menu. Then, everyone can update to the version they normally use.
If anyone knows how to remove the first bad errors, I’d appreciate it, although they don’t bother me.
have a nice day
