I know that it’s going to be a while yet before the BPI-R4 has anything other than a snapshot image via the OpenWRT firmware selector. I’ve been evaluating the snapshot images for a bit now and everything has been working, but the board is definitely not yet performing consistently. I’m not using the Wi-Fi capabilities. I’m only using this as a modem replacement to allow me to customize the IPv6 Prefix size I receive from my ISP (/60 instead of /64) and to increase the permitted connection buffer available to the WAN vs the ISP’s modem. I have a block of 16 static public IPs as well so I’m not using the OpenWRT masquerade or NAT capabilities at all. In fact, I’ve disabled them which should increase performance.
That all said, whilst connected directly to the WAN SFP+ port and the LAN SFP+ port, I’m lucky to get over 780Mbps download and 150Mbps upload. I have a gigabit symmetrical ISP and when connected to the ISP’s provided modem, I receive an actual 960Mbps download, 995Mbps upload, darn near line-rate.
I’ve noticed that there is an OpenWRT stable release for the MT7988 RFB v23.05.4, which from the best I can figure, is the same board the BPI-R4 is based on via the MediaTek <=> BananaPi collaboration on this project. They look nearly identical! When MediaTek + BPI debuted the BE1900 last year, MediaTek released an image of the BE1900 running on what looks like a release candidate board that is identical to the BPI-R4. See here: MediaTek | MediaTek Filogic 880 | BPI-R4 Wi-Fi 7 OpenWRT
This makes me wonder if I can just install the MT7988A-RFB image instead of the BPI-R4 snapshot based on the same hardware. Has anyone tried?
Also, what’s your LAN performance been like (not Wi-Fi)?
