[BPI-R4][closed] SFP rss/lro performance
ah, ok, this is optional step as first cpu is mostly the one with most load :wink: but it looks like you set it to cpu2 and later to 3 (or vice versa, as i see interrupts on tx for cpu0,2 and 3)
I did not attach statistics for the tests on the 6.16 kernel yet, I was thinking to figure out what I should do with the smp_affinity for ethernet TX IRQ which is not working as expected for me at this time. I do not understand why TX is able to use just only 1 CPU core, as it limits TX to 8Gbps.
Here are the test results with the IRQ stats without set-up of smp_affinity for the ethernet TX irq:
  • iperf -P 4 -t 30 --full-duplex --client
[ ID] Interval       Transfer     Bandwidth
[  1] 0.0000-30.0003 sec  22.5 GBytes  6.45 Gbits/sec
[ *1] 0.0000-30.0082 sec  20.4 GBytes  5.83 Gbits/sec
[SUM] 0.0000-30.0082 sec  42.9 GBytes  12.3 Gbits/sec
And here are the stats:
cat /proc/mtketh/hw_lro_stats
HW LRO statistic dump:
Cnt:   RING4 | RING5 | RING6 | RING7 Total
 0 :      0        0        0        0        0
 1 :      9321        0        0        0        9321
 2 :      22946        0        0        0        22946
 3 :      7955        0        0        0        7955
 4 :      15414        0        0        0        15414
 5 :      35881        0        0        0        35881
 6 :      6330        0        0        0        6330
 7 :      14123        0        0        0        14123
 8 :      1818869        0        0        0        1818869
 9 :      283        0        0        0        283
 10 :      0        0        0        0        0
 11 :      0        0        0        0        0
 12 :      0        0        0        0        0
 13 :      0        0        0        0        0
 14 :      0        0        0        0        0
 15 :      0        0        0        0        0
 16 :      0        0        0        0        0
 17 :      0        0        0        0        0
 18 :      0        0        0        0        0
 19 :      0        0        0        0        0
 20 :      0        0        0        0        0
 21 :      0        0        0        0        0
 22 :      0        0        0        0        0
 23 :      0        0        0        0        0
 24 :      0        0        0        0        0
 25 :      0        0        0        0        0
 26 :      0        0        0        0        0
 27 :      0        0        0        0        0
 28 :      0        0        0        0        0
 29 :      0        0        0        0        0
 30 :      0        0        0        0        0
 31 :      0        0        0        0        0
 32 :      0        0        0        0        0
 33 :      0        0        0        0        0
 34 :      0        0        0        0        0
 35 :      0        0        0        0        0
 36 :      0        0        0        0        0
 37 :      0        0        0        0        0
 38 :      0        0        0        0        0
 39 :      0        0        0        0        0
 40 :      0        0        0        0        0
 41 :      0        0        0        0        0
 42 :      0        0        0        0        0
 43 :      0        0        0        0        0
 44 :      0        0        0        0        0
 45 :      0        0        0        0        0
 46 :      0        0        0        0        0
 47 :      0        0        0        0        0
 48 :      0        0        0        0        0
 49 :      0        0        0        0        0
 50 :      0        0        0        0        0
 51 :      0        0        0        0        0
 52 :      0        0        0        0        0
 53 :      0        0        0        0        0
 54 :      0        0        0        0        0
 55 :      0        0        0        0        0
 56 :      0        0        0        0        0
 57 :      0        0        0        0        0
 58 :      0        0        0        0        0
 59 :      0        0        0        0        0
 60 :      0        0        0        0        0
 61 :      0        0        0        0        0
 62 :      0        0        0        0        0
 63 :      0        0        0        0        0
 64 :      0        0        0        0        0
Total agg:   RING4 | RING5 | RING6 | RING7 Total
                15010479      0      0      0      15010479
Total flush:   RING4 | RING5 | RING6 | RING7 Total
                1931122      0      0      0      1931122
Avg agg:   RING4 | RING5 | RING6 | RING7 Total
                7      0      0      0      7
HW LRO flush pkt len:
 Length  | RING4  | RING5  | RING6  | RING7 Total
0~5000: 40665      0      0      0      40665
5000~10000: 58007      0      0      0      58007
10000~15000: 1832450      0      0      0      1832450
15000~20000: 0      0      0      0      0
20000~25000: 0      0      0      0      0
25000~30000: 0      0      0      0      0
30000~35000: 0      0      0      0      0
35000~40000: 0      0      0      0      0
40000~45000: 0      0      0      0      0
45000~50000: 0      0      0      0      0
50000~55000: 0      0      0      0      0
55000~60000: 0      0      0      0      0
60000~65000: 0      0      0      0      0
65000~70000: 0      0      0      0      0
70000~75000: 0      0      0      0      0
Flush reason:   RING4 | RING5 | RING6 | RING7 Total
AGG timeout:      1252      0      0      0      1252
AGE timeout:      0      0      0      0      0
Not in-sequence:  2638      0      0      0      2638
Timestamp:        0      0      0      0      0
No LRO rule:      108465      0      0      0      108465
This configuration is for me the best one. The optimalisation of TX would be nice, there is about 1,4Gbps unused, which is about 14%.
Which iperf version do you have? I had limited throughput with default from debian. LRO needed iperf2 in my tests to reach the 9.4 gbit (max)
$ iperf --version: iperf version 2.1.8 (12 August 2022) pthreads
After dealing with the nfs error:
$ journalctl -b -u nfs-server
Jul 22 06:14:45 nas systemd[1]: Dependency failed for nfs-server.service - NFS server and services.
Jul 22 06:14:45 nas systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
I was re-compile kernel with the nfs directly in the kernel instead of module, and nfs-server started working.
  • dd if=/dev/zero of=/mnt/nvme/test.img bs=10M count=1000 oflag=dsync
10370416640 bytes (10 GB, 9.7 GiB) copied, 39 s, 266 MB/s
9961472000 bytes (10 GB, 9.3 GiB) copied, 14 s, 711 MB/s
  • dd if=/mnt/raid0/test.img of=/dev/null bs=10M iflag=direct
9856614400 bytes (9.9 GB, 9.2 GiB) copied, 13 s, 757 MB/s
Results between 6.12.32 without rss/lro and 6.16.0 with rss/lro looks not as big as expected, but, I thing that in case of using BPI-R4 as a NAS server:
  • writing to NAS means reading data by ethernet/sfp which utilise rss/lro functionality, but is probably limited by
    • write to the NVME and SATA drives is limited because of the technology - these drivers have to clear the space before writing a new data which makes writing slower, and if I remember it correctly, it reads the data to verify succesfull write.
  • reading from NAS drives is much more faster, as expected, and I am little confused here, because I did not set-up smp_affinity for TX frames.
It should make sense, but I have to ask: Does this means, that linux core utilise all cores for TX frames by default?
edit: nfs-server error added
I did test with the 3GB of ram drive:
  • dd if=/dev/zero of=/mnt/ramdrive/test.img bs=10M count=300 oflag=dsync
2883584000 bytes (2.9 GB, 2.7 GiB) copied, 5 s, 575 MB/s
  • dd if=/mnt/ramdrive/test.img of=/dev/null bs=10M iflag=direct
2170552320 bytes (2.2 GB, 2.0 GiB) copied, 2 s, 1.1 GB/s
Why is writing “only” 50% of the maximum speed?
I assume that nobody knows even an idea. I will perform similar tests on new compiled kernels in the future.
Hello again @frank-w ,
I am wondering how to persist rss & lro setup? I created a script to automate it and I can create “one shot” service to execute it, but are there any other better options?
When I was playing with it, I realize, that in my performance tests dd with the parameter --oflag=dsync lower the performance a bit, therefore I will update these test soon.
I don’t know any specific setting via systemd or any other init. So i guess creating a acript and adding it as postup/predown into the networkd units is the best way.
ls /sys/class/net/sfp-lan/queues/ rx-0 tx-0 tx-1 tx-10 tx-11 tx-12 tx-13 tx-14 tx-15 tx-2 tx-3 tx-4 tx-5 tx-6 tx-7 tx-8 tx-9 one rx vs 10 tx
It is not related to the RSS/LRO, but as I am testing everything on nvme or raid arrays, and next tests only on this raid 6 array from these days, I would like share with everyone interested thinking about using bpi-r4 as its own nas. Here is the on-going re-check performance of my raid6 array:
$ cat /proc/mdstat
Personalities : [raid4] [raid5] [raid6]
md127 : active raid6 sde[4] sdf[6] sdd[2] sdb[5] sdc[0] sda[1] sdg[7]
      14650675200 blocks super 1.2 level 6, 512k chunk, algorithm 2 [7/7] [UUUUUUU]
      [==============>......]  check = 74.8% (2193851400/2930135040) finish=117.3min speed=104553K/sec
      bitmap: 0/22 pages [0KB], 65536KB chunk
I have to say, that (as I created the array about more than 10 years ago) the array have probably NOT well optimalised stripe and stride, therefore performance of re-sync and working in degraded mode is lower. But I think that re-check is going quite fine.
Loadavg is about 2:
And kernel info:
$ uname -a
Linux nas 6.16.0-rc1-bpi-r4-rsslro #1 SMP Wed Aug 13 11:33:51 CEST 2025 aarch64 GNU/Linux
working with a kernel built from 6.16-rsslro. I have two questions.
a) ethtool -K eth0 lro on gets me an error “Could not change any device features”, is there some magic I need first? a kernel CONFIG_* flag? does the order in which ethtool flags are set matter?
b) if I try to set more than two RSS rules [e.g., use loc 2 or loc 3] I get EINVAL. Do I just need to choose the two dst-ips that matter the most for performance, or is there a way I can enable RSS for each VLAN?
Afair the “lro on” via ethtool was dropped at some state because needs to be defined by dest-ip. So afaik lro is working on layer 3 (mapping fastpath via ip header).
I have only tested with 1 rule,but afaik 4 should be possible
running debian bookworm
root@ratatosk:~# dpkg -l |grep ethtool
ii  ethtool                            1:6.1-1                                 arm64        display or change Ethernet device settings
root@ratatosk:~# ethtool -n eth0
4 RX rings available
Total 1 rules
rxclass: Cannot get RX class rules: Message too long
RX classification rule retrieval failed
root@ratatosk:~# ethtool -n ethLAN
Total 2 rules
Filter: 0
        Rule Type: TCP over IPv4
        Src IP addr: 0.0.0.0 mask: 0.0.0.0
        Dest IP addr: 192.168.88.253 mask: 255.255.255.255
        TOS: 0x0 mask: 0x0
        Src port: 0 mask: 0x0
        Dest port: 0 mask: 0x0
        Action: Direct to queue 0
Filter: 1
        Dest IP addr: 192.168.80.253 mask: 255.255.255.255
        TOS: 0x0 mask: 0x0
root@ratatosk:~# ethtool -N ethLAN flow-type tcp4 dst-ip 192.168.100.253 action 0 loc 2
rmgr: Cannot insert RX class rule: Invalid argument
is there something I did wrong in my attempt to push the rules?
Maybe try the previous version afaik 6.15-rsslro. maybe i/we did something wrong while porting after the sram/irq changes.
testing with 6.14-rsslro. note there is no 6.15-rsslro branch. Can try testing with 6.14-rsslro2 next.
root@bananapir4:~# ethtool -N eth0 flow-type tcp4 dst-ip 192.168.89.92 action 0 loc 0
root@bananapir4:~# ethtool -N eth0 flow-type tcp4 dst-ip 192.168.89.91 action 0 loc 1
root@bananapir4:~# ethtool -N eth0 flow-type tcp4 dst-ip 192.168.89.90 action 0 loc 2
root@bananapir4:~# ethtool -n eth0
Total 2 rules
Filter: 0
        Dest IP addr: 192.168.89.92 mask: 255.255.255.255
        TOS: 0x0 mask: 0x0
Filter: 1
        Dest IP addr: 192.168.89.91 mask: 255.255.255.255
        TOS: 0x0 mask: 0x0
root@bananapir4:~# uname -a
Linux bananapir4 6.14.0-rc1-edge-filogic #1 SMP Sun Mar 16 16:40:16 UTC 2025 aarch64 GNU/Linux
It will let me use ethtool -N eth0 flow-type tcp4 dst-ip 192.168.89.90 action 1 loc 0 ← note sending to queue 1
but ethtool -n eth0 does not show the rule, so I can’t prove [trivially] that it works.
6.14-rsslro2 compiling with the same config I used for 6.14-rsslro & 6.16-rsslro did not produce a kernel that sees the network interfaces. it’s 4AM here so I may not fix the config til later.
using the mt7988a_bpi-r4_defconfig [admittedly filtered through the Armbian build framework] still has not produced a usable kernel. it’s now quarter to 5AM EDT.
You should use defconfig in the same branch. In 6.16 the sram was changed from allocating in ethernet driver to dedicated sram-mmio driver. I guess this is missing when you use older defconfig.
Not sure if i tested the 6.16 tree again after rebasing rss/lro patches on the irq/sram changes.
