It would be nice if the EMMC storage was interchangeable.
Absolutely true!
To be honest, I am absolutelly
with the 8GB on board, BUT:
- I would like to have an option to change the emmc whenever bad block appear or needs of an bigger capacity - as I already have 256GB emmc chips and I am not able to use them
- Installation of any OS on the emmc will be much easier - it is not really big challenge whenever you know what to do, but…
What about at least 2 more sfp+ net-ifs? What would it needs?
9k MTU - does it really do not needs any hw changes and only sw changes are required?
rss/lro is available already
more powerfull cpu - does there is any available/usable
more pciEx lines?
other dependencies?
edit: added question to the 9k MTU…
more powerfull cpu - does there is any available/usable -
more pciEx lines?
R4Pro is same SoC so it has same count of pcie lanes but it is basicly switchable by a gpio between slots. But i have not tried it yet,still try to get networking working on mxl switch.
The question is why is a more powerful cpu needed…where is the bottleneck?
Btw. The schematic does not match the board i have…both sfp/10g-phy combo ports are realized with an ethmux
“basicly switchable by a gpio between slots”
→ I understand it (was not aware since now)
I did not need more cpu power … did not want more power consumption.
I would like to see more small wifi 7 modules (dreams are allowed?
I assume, that with MTU at 9k will be more efficient in the high performance tasks on sfp? Does it is possible that 2k MTU causes avg load on all 4 cpu cores to 70% and therefore limit the performance of writing data through sfp port?
Does there will be still enough cpu power in cases like fe:
- primary server functions nfs, samba, tftp, iSCSI for disc-less stations on SFP and even ETH ports
- using RJ45 ports with both of the sfp ports in case of night backups, rsyncing or something like that?
- managing of raid5/6/10 arrays, including re-shaping, re-checking on background, and also working in degraded mode?
Thanks a lot for opinion of anyone ![]()
Hello! Popping in here because I would like to know about a potential release date…
Currently I am using an ONT from my ISP that plugs in via SFP but my DrayTek router is being a bit of an issue - and a bottleneck. So I am very much looking forward for this board.
Is there any availability ETA or something? This, with OpenWrt, seems like a perfect fit for what I need.
Thanks!
There are some issues that need to be fixed in hardware and software before it is usable. I cannot recommend the R4Pro at this time.
If the R4Pro isn’t really ready and should be avoided for now, what would be a suitable choice of mainboard instead? I purchased a Turris Omnia several years ago and it was a good unit at that time, just looking for something updated to serve the same purpose. Thanks!
It depends on your needs…i use a bpi-r3 as main router with debian userspace
Hello Frank! I get you are working on it with mediatek (looking at your repo). Do you mind sharing what are these hardware/software issues?
i have a really early board, i guess most of the issues are known so far and are fixed when the board comes into sale…it is not really relevant at this time for end-users…you only need to wait some hardware iterations and software development before getting such board except you also want to TEST and DEVELOPING (at linux driver level, not userspace) it…it is not for using in production environment yet
I would like ask why it is not possible use 12V, 19V and on PRO version even 24V on every power source connector?
As I am using bpi-r4 as a nas, I am using 12V power source, and I am thinking why it is not possible to use 12V on the VH-2-pin connector?
It would be nice:
- to have possibility of using every voltage on every connector
- if power source connectors should automatically switch on order: VH-2PIN => USB Type-C => DCIN
Than it would be possible to use internal power source and even battery as backup and on different voltages.
Does it should be possible to add more leds to monitor activity of:
- every single sfp
- every single minipciEx
- every single m.2?
And then, what about using of PIN header to be able to “re-direct” any led signals to the external led connected to?
It should work like this:
- shorters will connect the signal pins to the internal leds by default
- another external led should be connected to the signal pin instead of shorter
The pin-header is for gpio,you cannot short any othr output to it. That would require a led header…that is no bad idea…so instead of soldering leds,add a pin header for it where per default a led stripe is plugged which can be removed and replaced by cables with leds to route them to a case.
I’m not sure it mpcie and m.2 have generic “activity” pins…afaik sfps do not have them.
Just an idea, adding many leds with a few wires:
PCA9685 16-Channel LED Driver Board Module - I2C Bus PWM Controller Development Board for Electronic Projects https://a.aliexpress.com/_Ex7gFTk
Or
https://a.aliexpress.com/_ExIYCKO
Only requires 2 gpio pins (supporting i2c), instead of many.
Even can control the brightness (pwm) in the hardware.
Add CONFIG_PWM_PCA9685=y to your kernel config.
Edit:
It should add a gpiochip with 16 gpio’s.
Or even could use MCP23017 module
https://a.aliexpress.com/_EuI0zgI
Also supported in linux as pinctrl
Just as You say, I did not meant to use the existing GPIO header, I mean using another header (or just pro-longed the gpio one) just for the leds.
Using the led header with the leds inserted in it is also good idea, and it could save some space ![]()
There are led boards like this but only 1 color and it could be done smaller.
But we should create separate topic for this.
My goal was not discuss here the accessories for the board, but changes for the next version of the board which could be benefitial. I can see on-board leds usefull for those who are using original-like case for their projects.
For me are all on-board leds which I am not able to replace for the external ones nothing more than another problem to solve.
I need my own case which have to be much bigger than the original one (more than 30x30x30 cm), and now I have to de-solder all on-board leds and replace them by cable or connectors to be able to connect external leds in front of the case.
I believe that this details are important for everyone who could use any bpi board (not only bpi-r4) for their business projects instead of the home ones.
I am NOT manufacturer with his own business yet, but I am working on it and building my own product right now. Therefore I have important question for @sinovoip : Does the manufacturer wants selling BPI products to home individuals or also for manufacturers for their business? What is the primary target for bpi products?
surely one can call them ? no ? email ?
