[BPI-R4] SFP Ipolex module Aquantia AQR113C PHY
Hi everyone, I’m running OpenWrt and having trouble with a Ipolex 10GBase-T SFP module (OEM SFP-10G-T, rev 02). The system detects the module in both and ports, and reports the host maximum power as 3.0W. However, when inserted into , I get the following errors in ################################################# Aquantia AQR113C: probe of i2c:sfp1:11 failed with error -22
sfp sfp1: sfp_add_phy failed: -EINVAL ################################################# Later, the module is removed from and reappears in , but no link is established. It seems like the PHY driver (AQR113C) isn’t initializing the module properly. Has anyone encountered this with 10G copper modules on OpenWrt? Is this a driver compatibility issue or a hardware limitation? Thanks in advance!
