Hello guys! I’m new into all of it stuff, so as you may expect, I’m having difficulties with making BPI-R4 to work.
So, I have BPI-R4 and WIFI-7 NIC module. So, I tried to burning different images on my SD card and got no luck. If any of you can give me any advice I’d be very grateful.
My setup is the following - i’m powering up the board, and plugging ethernet cable into LAN on board and my computer. Also I have USB-Serial cord connected to it, I’m trying to view it’s output using screen /dev/ttyUSB0 115200, but it gives me nothing with any image.
I tried burning this image on my SD - it gives me power light on, green blinking, and no connection through ssh. I’m trying to do ssh [email protected] and get no response, same if i ping it.
I’m also trying to make it work with the other image under BPI-R4-Main-V11-assambly heading. This one only lights up power light. But gives me more - now i can connect via ssh [email protected], but if i’m trying to access 192.168.1.1 in my browser, i’m getting bad request, but that is not the biggest problem. If I turn it off and back on (just unplugging power), everything which I installed/set up on the board disappears. Even if i do it just by simply typing reboot gives me the same result - reset to defaults. Also, if i plug in the WLAN with internet on it - i can ping google, and just any site in general, but opkg update just hangs (i assume it is because it is trying to reach some SNAPSHOT distribution of packages, which does not exist.)
