I recently bought a Banana Pi Revision 1.1 in order to use it as my main router with OpenWRT.
I plan to add a M.2 NVMe SSD and a Wifi7 NIC once it is available and supported.
It seems there is a Revision 1.2  and I’d like to know the changes between Rev. 1.1 and 1.2
Do you know what Rev. 1.2 fixes or adds? Can I add a M.2 NVMe SSD and a Wifi7 NIC with my BPI-R4 Rev. 1.1?
Thanks for your help.
                frank-w
                    March 17, 2024,  9:04pm
                  2
              Your link points to bpi r64,not r4
              Oh you’re right sorry I was looking for rev 1.1 information and then I got on this page.
Then I guess there is no Rev. 1.2 for BPI-R4 at the moment, I was scared I might encounter this kind of issue  with my NVMe SSD.
Anyway I’ll try and see how it goes, thanks for your help.
                frank-w
                    March 19, 2024,  6:49am
                  4
              You can cover the 2 pins used for i2c…have done it too without testing before if my ssd is affected (because i was scared it can damage ssd).
                Casulo
                    June 21, 2024, 10:21am
                  5
              How to tape them? Or disable them without using soldering stuff.
                frank-w
                    June 22, 2024,  7:00am
                  6
              This shows location of the pins to be taped…make sure you only cover these 2 pins only
    Beware of NVME M2 key M. In the electrical circuit there is an I2C bus.
 [image]
I got in trouble for this.
My disk is Miсron 2200 512GB.
 [51xpbTapoFL.AC_SL1200]
As soon as I install it, the entire I2C bus goes down.
Not a single device is detected.
I had to cover these 2 pins with Scotch tape to solve this.
[5190v7R+GxL.AC_SL1200_1]
