Hy. I have some problems with my kernel/dts.
1- I don’t see the emmc when i do the command fdisk -l, only the nand and the usb key (i boot from) 2- I don’t see the leds in /sys/class/leds. the folder is empty 3- I cannot use the ethtool -m command. My sfp modules doesn’t be recognized. I think a problem of i2c. I don’t see the modules sfp when i do the command i2cdetect -y 0 and 1. I tried with a lot of modules, which works with bpi-r3.
I use the kernel 6.5-r4 and i tried with the 6.6-r4. Same problems.
Here the dmesg:
dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 6.5.0-rc3-diagbox_G00R00C00 (root@workstation) (aarch64-linux-gnu-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #1 SMP Tue Dec 26 19:37:08 CET 2023
[ 0.000000] Machine model: BananaPi-R4
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000011000000 (options '')
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: 0x0000000043000000..0x000000004307ffff (512 KiB) nomap non-reusable secmon@43000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004307ffff]
[ 0.000000] node 0: [mem 0x0000000043080000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 18 pages/cpu s36136 r8192 d29400 u73728
[ 0.000000] pcpu-alloc: s36136 r8192 d29400 u73728 alloc=18*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: board=DiagBox rootfs=rootfs_alpha.cpio.gz console=ttyS0,115200n1 earlycon=uart8250,mmio32,0x11000000 debug=7 initrd=0x48000000,550M boot_usb=oui
[ 0.000000] Unknown kernel command line parameters "board=DiagBox rootfs=rootfs_alpha.cpio.gz boot_usb=oui", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbb23000-0x00000000ffb23000] (64MB)
[ 0.000000] Memory: 3469292K/4194304K available (10176K kernel code, 1174K rwdata, 2364K rodata, 448K init, 297K bss, 725012K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: 0xffffffc080010088
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.008296] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.018786] pid_max: default: 32768 minimum: 301
[ 0.023524] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.031030] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.039386] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.045738] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.053458] rcu: Hierarchical SRCU implementation.
[ 0.058310] rcu: Max phase no-delay instances is 1000.
[ 0.063938] smp: Bringing up secondary CPUs ...
[ 0.068698] Detected VIPT I-cache on CPU1
[ 0.068734] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.068756] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[ 0.068947] Detected VIPT I-cache on CPU2
[ 0.068967] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.068978] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[ 0.069149] Detected VIPT I-cache on CPU3
[ 0.069169] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.069179] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[ 0.069204] smp: Brought up 1 node, 4 CPUs
[ 0.126211] SMP: Total of 4 processors activated.
[ 0.130969] CPU features: detected: 32-bit EL0 Support
[ 0.136169] CPU features: detected: CRC32 instructions
[ 0.141398] CPU: All CPU(s) started at EL2
[ 0.145539] alternatives: applying system-wide alternatives
[ 0.151733] devtmpfs: initialized
[ 0.156394] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.166365] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.173390] pinctrl core: initialized pinctrl subsystem
[ 0.179173] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.185444] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.192682] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.200609] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.208845] thermal_sys: Registered thermal governor 'fair_share'
[ 0.208848] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.215016] thermal_sys: Registered thermal governor 'step_wise'
[ 0.221097] thermal_sys: Registered thermal governor 'user_space'
[ 0.227229] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.240298] ASID allocator initialised with 65536 entries
[ 0.250953] Modules: 29104 pages in range for non-PLT usage
[ 0.250958] Modules: 520624 pages in range for PLT usage
[ 0.257000] cryptd: max_cpu_qlen set to 1000
[ 0.267056] SCSI subsystem initialized
[ 0.270888] libata version 3.00 loaded.
[ 0.274834] usbcore: registered new interface driver usbfs
[ 0.280396] usbcore: registered new interface driver hub
[ 0.285789] usbcore: registered new device driver usb
[ 0.291032] i2c-gpio i2c-gpio-0: using lines 563 (SDA) and 565 (SCL)
[ 0.297491] pps_core: LinuxPPS API ver. 1 registered
[ 0.302514] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.311772] PTP clock support registered
[ 0.316497] clocksource: Switched to clocksource arch_sys_counter
[ 0.323128] NET: Registered PF_INET protocol family
[ 0.328192] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.337445] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.346099] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.353949] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.362076] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.369974] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.376685] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.383520] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.390921] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.397216] PCI: CLS 0 bytes, default 64
[ 0.401287] Unpacking initramfs...
[ 0.416976] Initialise system trusted keyrings
[ 0.421570] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.428353] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.434285] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.453118] jitterentropy: Initialization failed with host not compliant with requirements: 9
[ 0.461778] Key type asymmetric registered
[ 0.465926] Asymmetric key parser 'x509' registered
[ 0.471861] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[ 0.484415] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.491695] printk: console [ttyS0] disabled
[ 0.516302] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[ 0.525598] printk: console [ttyS0] enabled
[ 0.533974] printk: bootconsole [uart8250] disabled
[ 0.544476] mtk_rng soc:trng@1020f000: registered RNG driver
[ 0.544527] random: crng init done
[ 0.555121] loop: module loaded
[ 0.559221] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.564532] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 2.941465] Initramfs unpacking failed: invalid magic at start of compressed archive
[ 3.085765] Freeing initrd memory: 563200K
[ 3.094886] 5 fixed-partitions partitions found on MTD device spi0.0
[ 3.101268] Creating 5 MTD partitions on "spi0.0":
[ 3.106049] 0x000000000000-0x000000100000 : "bl2"
[ 3.112253] 0x000000100000-0x000000180000 : "u-boot-env"
[ 3.118518] 0x000000180000-0x000000580000 : "factory"
[ 3.127854] 0x000000580000-0x000000780000 : "fip"
[ 3.134820] 0x000000780000-0x000007800000 : "ubi"
[ 3.253623] sfp sfp2-lan: Host maximum power 3.0W
[ 3.387655] mtk_soc_eth 15100000.ethernet: generated random MAC address 0e:2e:df:ea:9d:0a
[ 3.395875] mtk_soc_eth 15100000.ethernet: generated random MAC address c6:34:17:b2:b7:b2
[ 3.404061] mtk_soc_eth 15100000.ethernet: generated random MAC address 2a:2c:dd:30:cf:b8
[ 4.446961] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc081d80000, irq 101
[ 4.456512] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc081d80000, irq 101
[ 4.466043] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc081d80000, irq 101
[ 4.475528] usbcore: registered new interface driver usb-storage
[ 4.481592] i2c_dev: i2c /dev entries driver
[ 4.486420] i2c 1-0064: Fixed dependency cycle(s) with /soc/i2c@11003000/rt5190a@64/regulators/buck1
[ 4.496013] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 4.504090] mtk-cpufreq mtk-cpufreq: failed to initialize dvfs info for cpu0
[ 4.511502] armv8-pmu pmu: hw perfevents: no irqs for PMU, sampling events not supported
[ 4.519743] hw perfevents: enabled with armv8_cortex_a73 PMU driver, 7 counters available
[ 4.528792] xt_time: kernel timezone is -0000
[ 4.533262] NET: Registered PF_INET6 protocol family
[ 4.538659] Segment Routing with IPv6
[ 4.542329] In-situ OAM (IOAM) with IPv6
[ 4.546290] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.552537] NET: Registered PF_PACKET protocol family
[ 4.641530] mmc0: Failed to initialize a non-removable card
[ 5.436538] Bridge firewalling registered
[ 5.446134] 8021q: 802.1Q VLAN Support v1.8
[ 5.453683] Loading compiled-in X.509 certificates
[ 5.467251] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 5.474566] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 5.480841] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 5.489290] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 5.716512] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 5.725340] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[ 5.732435] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 5.739765] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 5.746041] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 5.754485] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 5.976509] mtk-pcie-gen3 11300000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 5.985316] mtk-pcie-gen3: probe of 11300000.pcie failed with error -110
[ 5.992296] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 5.999622] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 6.005896] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 6.014342] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 6.236510] mtk-pcie-gen3 11310000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 6.245315] mtk-pcie-gen3: probe of 11310000.pcie failed with error -110
[ 6.426523] mt7530-mmio 15020000.switch: configuring for fixed/internal link mode
[ 6.434020] mt7530-mmio 15020000.switch: Link is Up - 10Gbps/Full - flow control rx/tx
[ 6.434616] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [Generic PHY] (irq=POLL)
[ 6.452918] mt7530-mmio 15020000.switch lan0 (uninitialized): PHY [mt7530-0:01] driver [Generic PHY] (irq=POLL)
[ 6.463814] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:02] driver [Generic PHY] (irq=POLL)
[ 6.474817] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:03] driver [Generic PHY] (irq=POLL)
[ 6.485237] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[ 6.491951] DSA: tree 0 setup
[ 6.495215] xhci-mtk 11190000.usb: supply vbus not found, using dummy regulator
[ 6.502573] xhci-mtk 11190000.usb: supply vusb33 not found, using dummy regulator
[ 6.510362] xhci-mtk 11190000.usb: xHCI Host Controller
[ 6.515585] xhci-mtk 11190000.usb: new USB bus registered, assigned bus number 1
[ 6.523191] xhci-mtk 11190000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[ 6.532344] xhci-mtk 11190000.usb: irq 112, io mem 0x11190000
[ 6.538148] xhci-mtk 11190000.usb: xHCI Host Controller
[ 6.543363] xhci-mtk 11190000.usb: new USB bus registered, assigned bus number 2
[ 6.550759] xhci-mtk 11190000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 6.558109] hub 1-0:1.0: USB hub found
[ 6.561878] hub 1-0:1.0: 1 port detected
[ 6.565965] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.574261] hub 2-0:1.0: USB hub found
[ 6.578038] hub 2-0:1.0: 1 port detected
[ 6.582313] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 6.589689] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 6.597581] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.602812] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 3
[ 6.613253] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[ 6.622416] xhci-mtk 11200000.usb: irq 113, io mem 0x11200000
[ 6.628226] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.633451] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 4
[ 6.640853] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 6.648149] hub 3-0:1.0: USB hub found
[ 6.651910] hub 3-0:1.0: 1 port detected
[ 6.655977] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.664266] hub 4-0:1.0: USB hub found
[ 6.668035] hub 4-0:1.0: 1 port detected
[ 6.674146] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.688861] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.694576] clk: Disabling unused clocks
[ 6.716819] Freeing unused kernel memory: 448K
[ 7.126498] usb 3-1: new high-speed USB device number 2 using xhci-mtk
[ 7.216584] Run /init as init process
[ 7.220247] with arguments:
[ 7.223216] /init
[ 7.225491] with environment:
[ 7.228636] HOME=/
[ 7.230997] TERM=linux
[ 7.233705] board=DiagBox
[ 7.236673] rootfs=rootfs_alpha.cpio.gz
[ 7.240855] boot_usb=oui
[ 7.309128] hub 3-1:1.0: USB hub found
[ 7.313002] hub 3-1:1.0: 5 ports detected
[ 7.365225] /dev/sda1: Can't open blockdev
[ 7.369364] /dev/sda1: Can't open blockdev
[ 7.373473] /dev/sda1: Can't open blockdev
[ 7.377589] /dev/sda1: Can't open blockdev
[ 7.576603] usb 4-1: new SuperSpeed USB device number 2 using xhci-mtk
[ 7.609167] hub 4-1:1.0: USB hub found
[ 7.613164] hub 4-1:1.0: 4 ports detected
[ 8.056503] usb 3-1.4: new high-speed USB device number 3 using xhci-mtk
[ 8.237722] usb-storage 3-1.4:1.0: USB Mass Storage device detected
[ 8.244145] scsi host0: usb-storage 3-1.4:1.0
[ 8.346499] usb 3-1.5: new high-speed USB device number 4 using xhci-mtk
[ 8.393293] /dev/sda1: Can't open blockdev
[ 8.397448] /dev/sda1: Can't open blockdev
[ 8.401558] /dev/sda1: Can't open blockdev
[ 8.405666] /dev/sda1: Can't open blockdev
[ 9.406915] scsi 0:0:0:0: Direct-Access Mass Storage Device 1.00 PQ: 0 ANSI: 0 CCS
[ 9.415954] sd 0:0:0:0: [sda] 15437824 512-byte logical blocks: (7.90 GB/7.36 GiB)
[ 9.421364] /dev/sda1: Can't open blockdev
[ 9.427674] /dev/sda1: Can't open blockdev
[ 9.431776] /dev/sda1: Can't open blockdev
[ 9.431786] sd 0:0:0:0: [sda] Write Protect is off
[ 9.435870] /dev/sda1: Can't open blockdev
[ 9.440641] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 9.449888] sd 0:0:0:0: [sda] No Caching mode page found
[ 9.456478] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 9.466044] sda: sda1 sda2 sda3
[ 9.470153] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 10.475580] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 10.644716] EXT4-fs (sda2): warning: maximal mount count reached, running e2fsck is recommended
[ 10.658231] EXT4-fs (sda2): recovery complete
[ 10.664921] EXT4-fs (sda2): mounted filesystem 5706b3c5-2c29-4461-881f-a21c5c3ec2f4 r/w with ordered data mode. Quota mode: disabled.
[ 10.693742] EXT4-fs (sda3): warning: maximal mount count reached, running e2fsck is recommended
[ 10.707985] EXT4-fs (sda3): recovery complete
[ 10.712346] EXT4-fs (sda3): mounted filesystem b161d208-d166-46ee-97f7-20fa612ab42a r/w with ordered data mode. Quota mode: disabled.
[ 11.408061] udevd[998]: starting version 3.2.11
[ 11.430875] udevd[999]: starting eudev-3.2.11
[ 11.501219] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[ 11.501273] mtdblock: MTD device 'u-boot-env' is NAND, please consider using UBI block devices instead.
[ 11.512828] mtdblock: MTD device 'factory' is NAND, please consider using UBI block devices instead.
[ 11.516179] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[ 11.537347] mtdblock: MTD device 'fip' is NAND, please consider using UBI block devices instead.
[ 13.386514] sfp sfp2-lan: please wait, module slow to respond
[ 17.156825] platform sfp1-wan: deferred probe pending
[ 29.089009] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[ 29.089541] mtdblock: MTD device 'u-boot-env' is NAND, please consider using UBI block devices instead.
[ 29.089748] mtdblock: MTD device 'factory' is NAND, please consider using UBI block devices instead.
[ 29.098418] mtdblock: MTD device 'fip' is NAND, please consider using UBI block devices instead.
[ 29.107374] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[ 81.706509] sfp sfp2-lan: failed to read EEPROM: -ENXIO
Can someone help me please
Thanks by advance
