Hello, I am testing the 10G SFP+ interface on two Banana Pi BPI-R4-PRO boards from OpenWrt.
Both boards drive 10G CWDM SFP+ modules from OPTCORE, plugged in the SFP-LAN port (mxl_lan5). I have tested multiple modules, including OPC10G-5340DCR and OPC10G-5540DCR, and the behaviour is unchanged.
The optical side both appears healthy, and the green LEDs are on once the fibers are plugged in:
Laser output power: +1.58 dBm
Receiver signal average optical power: -6.51 dBm
However, the Ethernet link repeatedly flaps. A typical sequence is:
[104327.519713] mxl862xx mdio-bus:10 mxl_lan5: resolve link status: system iface=0 [104327.527034] mxl862xx mdio-bus:10 mxl_lan5: Link is Down [104327.532365] br-lan: port 8(mxl_lan5) entered disabled state [104330.644353] mxl862xx mdio-bus:10 mxl_lan5: resolve link status: system iface=0 (repeated 4x) [104331.679705] mxl862xx mdio-bus:10 mxl_lan5: Link is Up - 10Gbps/Full - flow control off [104331.684378] br-lan: port 8(mxl_lan5) entered blocking state [104331.693350] br-lan: port 8(mxl_lan5) entered forwarding state [104332.729707] mxl862xx mdio-bus:10 mxl_lan5: resolve link status: system iface=0 [104332.737025] mxl862xx mdio-bus:10 mxl_lan5: Link is Down [104332.742352] br-lan: port 8(mxl_lan5) entered disabled state [104475.204355] mxl862xx mdio-bus:10 mxl_lan5: resolve link status: system iface=0 (repeated 138x) [104476.244358] mxl862xx mdio-bus:10 mxl_lan5: Link is Up - 10Gbps/Full - flow control off [104476.249035] br-lan: port 8(mxl_lan5) entered blocking state [104476.258001] br-lan: port 8(mxl_lan5) entered forwarding state [104477.279725] mxl862xx mdio-bus:10 mxl_lan5: resolve link status: system iface=0
This pattern repeats very consistently. The link can briefly enter forwarding, but ARP between the two boards fails and no stable traffic can pass. Also I noticed from the ‘Link is Up’ to ‘Link is Down’ is always an 1 second interval.
One of the board reports carrier=1 in most cases, but the other board always shows carrier=0, though the received power and green LED looks correct.
Has anyone seen this behavior? Are there known firmware, device-tree, SerDes, or driver settings required for stable 10G optical SFP+ operation?
Thanks a lot for the help:)
