[BPI-R4-PRO] SFP+ DAC cable not work
I want to connect my BPI-R4 Pro with the SFP+ DAC cable to my Xiaomi Router BE10000 (RC01).
The link is up with “10Gbps/Full - flow control off” but soon tx disabled due to “tx_fault event timeout”.
The light of the RC01‘s SFP+ port is blinking after the module is inserted.
Using BPI official firmware (BPI-R4Pro-8X-BE14-MT76-OpenWRT24.10-DSA-251229) download from bpi docs.
The SFP+ DAC is Samzhe(山泽) 10G SFP+ DAC.
root@OpenWrt:~# dmesg
[ 1435.036453] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 1435.042717] br-wan: port 1(eth1) entered disabled state
[ 1438.073790] br-wan: left allmulticast mode
[ 1438.078050] br-lan: left allmulticast mode
[ 1461.423319] sfp sfp2: SM: enter empty:down:down event los_low
[ 1461.429079] sfp sfp2: SM: exit empty:down:down
[ 1461.433521] sfp sfp2: SM: enter empty:down:down event insert
[ 1461.439177] sfp sfp2: SM: exit probe:down:down
[ 1461.716443] mtk_soc_eth 15100000.ethernet: ethernet mux: switch to channel1
[ 1461.723406] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
[ 1461.742383] sfp sfp2: SM: enter probe:down:down event dev_up
[ 1461.748036] sfp sfp2: SM: exit probe:up:down
[ 1461.752295] sfp sfp2: SM: enter probe:up:down event timeout
[ 1461.769146] sfp sfp2: module OEM              DAC-10G-01       rev 1.0  sn 2605100288       dc 260510
[ 1461.778538] sfp sfp2: sfp: support mode 00,00000000,00000800,00006040
[ 1461.784968] mtk_soc_eth 15100000.ethernet eth1: optical SFP: interfaces=[mac=1-4,22-24,27,29, sfp=27]
[ 1461.794181] mtk_soc_eth 15100000.ethernet eth1: requesting link mode inband/10gbase-r with support 00,00000000,00000800,00006040
[ 1461.805736] sfp sfp2: tx disable 1 -> 0
[ 1461.809576] sfp sfp2: SM: exit present:up:wait
[ 1461.824934] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 1461.866448] sfp sfp2: SM: enter present:up:wait event timeout
[ 1461.872191] sfp sfp2: probing phy device through the [MDIO_I2C_NONE] protocol
[ 1461.879321] sfp sfp2: SM: exit present:up:link_up
[ 1461.906922] sfp sfp2: SM: enter present:up:link_up event tx_fault
[ 1461.925235] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[ 1461.933579] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 1461.939234] sfp sfp2: module transmit fault indicated
[ 1461.944274] sfp sfp2: SM: exit present:up:tx_fault
[ 1462.956460] sfp sfp2: SM: enter present:up:tx_fault event timeout
[ 1462.962597] sfp sfp2: SM: exit present:up:reinit
[ 1463.266923] sfp sfp2: SM: enter present:up:reinit event timeout
[ 1463.272832] sfp sfp2: SM: exit present:up:tx_fault
[ 1464.316465] sfp sfp2: SM: enter present:up:tx_fault event timeout
[ 1464.322586] sfp sfp2: SM: exit present:up:reinit
[ 1464.626471] sfp sfp2: SM: enter present:up:reinit event timeout
[ 1464.632382] sfp sfp2: SM: exit present:up:tx_fault
[ 1465.676473] sfp sfp2: SM: enter present:up:tx_fault event timeout
[ 1465.682591] sfp sfp2: SM: exit present:up:reinit
[ 1465.986478] sfp sfp2: SM: enter present:up:reinit event timeout
[ 1465.992388] sfp sfp2: SM: exit present:up:tx_fault
[ 1467.046486] sfp sfp2: SM: enter present:up:tx_fault event timeout
[ 1467.052603] sfp sfp2: SM: exit present:up:reinit
[ 1467.356501] sfp sfp2: SM: enter present:up:reinit event timeout
[ 1467.362412] sfp sfp2: module persistently indicates fault, disabling
[ 1467.368761] sfp sfp2: SM: exit present:up:tx_disable
root@OpenWrt:~# ethtool eth1
Settings for eth1:
	Supported ports: [  ]
	Supported link modes:   10000baseSR/Full
	Advertised link modes:  10000baseSR/Full
	Speed: 10000Mb/s
	Duplex: Full
	Auto-negotiation: on
	Port: Direct Attach Copper
	PHYAD: 0
	Transceiver: internal
	Link detected: no
