[BPI-R4 Pro] Potential 12V Fan Rail Fault in just 7 Days
[Potential Hardware Fault] BPI-R4 Pro (2.5GbE): 12V Rail Failure & Buck1 Dependency Cycle
Disappointment & Logistics Concerns
I am writing this with a heavy heart. After waiting a month for my BPI-R4 Pro to arrive in the UK from the official SinoVoip Shop on AliExpress, the board appears to have developed a hardware failure after just seven days of perfect operation.
While I can pursue an AliExpress refund, the logistics are a nightmare: I’d face another 4-6 week wait for a replacement, and because I bought this during a sale, a re-order would now cost me £65 more than my original purchase. I am hoping a BPI staff member (@simon / @sinovoip) can confirm if this is a known issue or if there is a way to rectify this without a full return/refund cycle that leaves me out of pocket.
Back Story & Setup
The unit worked brilliantly out of the box with stock firmware. I took every precaution:
  • Cooling: 3D-printed custom case with dual Noctua NF-S12A PWM fans (12V, 0.12A).
  • Protection: Case was treated with ESD anti-static coating prior to installation.
  • Power: High-quality Netgear 12V 5A PSU (tested under load with minimal voltage sag).
  • Performance: Under 99% load, the CPU was stable at a cool 41°C. No Wi-Fi modules were installed.
The Failure
After one week of stable runtime (no config changes), I found the unit idling at 60°C with both fans stopped. After hours of troubleshooting and factory resets, I’ve confirmed a hardware failure (or at least, I’ve run out of software fixes):
  • Fans: Tested externally in a PC; they work perfectly.
  • Physical Voltage: Multimeter confirms 0V output at the fan headers.
  • Firmware: Using stock builds; reset multiple times with no change.
The “Smoking Gun” Evidence (I2C & Regulator Logs)
The software seems to think the rail is active, but the hardware has disappeared from the bus. On the BPI-R4 Pro, I believe, I could be wrong, but the INA2xx power monitor is powered by the 12V rail it monitors. I haven’t changed any configuration regarding the fans; out of the box, they just worked silently and perfectly. I’m providing my technical findings below in hopes they shed light on the issue.
System Information
root@BPI-Pro-Router:~# {
   echo "--- SYSTEM IDENTITY ---"
   echo -n "Kernel: "; uname -a
   echo "--- OPENWRT RELEASE ---"
   cat /etc/openwrt_release
   echo "--- BOARD IDENTIFICATION ---"
   echo -n "Model (Sysinfo): "; cat /tmp/sysinfo/model
   echo -n "Device Compatible: "; strings /proc/device-tree/compatible | head -n 1
   echo -n "CPU Architecture: "; opkg print-architecture | head -n 1
Kernel: Linux BPI-Pro-Router 6.6.93 #0 SMP Tue Jun 17 03:09:13 2025 aarch64 GNU/Linux
DISTRIB_ID='OpenWrt'
DISTRIB_RELEASE='24.10-SNAPSHOT'
DISTRIB_REVISION='unknown'
DISTRIB_TARGET='mediatek/filogic'
DISTRIB_ARCH='aarch64_cortex-a53'
DISTRIB_DESCRIPTION='OpenWrt 24.10-SNAPSHOT unknown'
DISTRIB_TAINTS='no-all busybox'
Model (Sysinfo): Bananapi BPI-R4-PRO-8X
Device Compatible: bananapi,bpi-r4-pro-8x
CPU Architecture: arch all 1
root@BPI-Pro-Router:~# ls /sys/bus/platform/drivers/
alarmtimer            clk-mt7986-apmixed    clk-mt7988-infracfg   i2c-gpio              mt7530-mmio           mtk-lvts-thermal      mtk-tphy              of_serial             serial8250
an8855                clk-mt7986-eth        clk-mt7988-topckgen   i2c-mt65xx            mt753x                mtk-msdc              mtk-wdt               pwm-fan               sfp
an8855-efuse          clk-mt7986-infracfg   clk-mt7988-xfipll     i2c-mux-gpio          mt7981-pinctrl        mtk-nand              mtk-xfi-tphy          pwm-mediatek          simple-pm-bus
an8855-mdio           clk-mt7986-topckgen   crypto-safexcel       leds-gpio             mt7986a-pinctrl       mtk-pcie-gen3         mtk-xsphy             pwrseq_emmc           syscon
an8855-switch         clk-mt7987-eth        fitblk                leds_pwm              mt7986b-pinctrl       mtk-pcs-lynxi         mtk_hsdma             pwrseq_simple         syscon-reboot
armv8-pmu             clk-mt7987-infracfg   gpio-clk              leds_pwm_multicolor   mt7987-apmixedsys     mtk-power-controller  mtk_rng               ramoops               ti-syscon-reset
clk-mt7981-apmixed    clk-mt7987-mcusys     gpio-export           mediatek,efuse        mt7987-pinctrl        mtk-scpsys            mtk_soc_eth           reg-dummy             virt-mtdconcat
clk-mt7981-eth        clk-mt7987-topckgen   gpio-keys             mt-pmic-pwrap         mt7988-pinctrl        mtk-snand             mtk_usxgmii           reg-fixed-voltage     xhci-hcd
clk-mt7981-infracfg   clk-mt7988-apmixed    gpio-keys-polled      mt6380-regulator      mtk-cpufreq           mtk-spi               of_fixed_clk          rproc-virtio          xhci-mtk
clk-mt7981-topckgen   clk-mt7988-eth        gpio-wdt              mt6577-uart           mtk-ecc               mtk-thermal           of_fixed_factor_clk   rtc_mt7622
cat /sys/kernel/debug/pinctrl/*pinctrl_moore/pinmux-pins | grep "515"
Result: pin 3 (UART2_RTS): GPIO pinctrl_moore:515
DTS Report
root@BPI-Pro-Router:~# grep -A 15 "pwm-fan" /tmp/stock_bpi_pro.dts
        pwm-fan {
                pinctrl-names = "default";
                pinctrl-0 = <0x09>;
                cooling-levels = <0x00 0x50 0x80 0xff>;
                #thermal-sensor-cells = <0x01>;
                compatible = "pwm-fan";
                status = "okay";
                phandle = <0x62>;
                pwms = <0x0a 0x00 0xc350>;
                #cooling-cells = <0x02>;
        aliases {
                i2c3 = "/soc/i2c@11005000/i2c-switch@70/i2c@0";
                ethernet0 = "/soc/ethernet@15100000/mac@0";
                i2c1 = "/soc/i2c@11004000";
                i2c6 = "/soc/i2c@11005000/i2c-switch@70/i2c@3";
                i2c4 = "/soc/i2c@11005000/i2c-switch@70/i2c@1";
                ethernet1 = "/soc/ethernet@15100000/mac@1";
                i2c2 = "/soc/i2c@11005000";
                i2c0 = "/soc/i2c@11003000";
                fan = "/pwm-fan";
                cpu2 = "/cpus/cpu@2";
                uart1 = "/soc/serial@11000100";
                i2p5gbe_led0_pins = "/soc/pinctrl@1001f000/2p5gbe-led0-pins";
                mmc0_pins_sdcard = "/soc/pinctrl@1001f000/mmc0-pins-sdcard";
                spi_nand = "/soc/spi@11007000/spi_nand@0";
                gsw_phy1_led0 = "/soc/switch@15020000/mdio/ethernet-phy@1/leds/gsw-phy1-led0@0";
                pcie0_pins = "/soc/pinctrl@1001f000/pcie0-pins";
                usxgmiisys0 = "/soc/pcs@10080000";
                sgmiisys1 = "/soc/syscon@10070000";
                wed1 = "/soc/wed@15012000";
                gsw_phy0 = "/soc/switch@15020000/mdio/ethernet-phy@0";
                gsw_port0 = "/soc/switch@15020000/ports/port@0";
                imux3_wifi = "/soc/i2c@11005000/i2c-switch@70/i2c@3";
                uart2_3_pins = "/soc/pinctrl@1001f000/uart2-3-pins";
                switchphy0 = "/soc/ethernet@15100000/mdio-bus/switch@16/mdio/switchphy@0";
root@BPI-Pro-Router:~# grep -A 20 "serial@11000200" /tmp/stock_bpi_pro.dts
                serial@11000200 {
                        pinctrl-0 = <0x14>;
                        clock-names = "baud", "bus";
                        assigned-clocks = <0x03 0x27 0x0c 0x02>;
                        assigned-clock-parents = <0x03 0x00 0x03 0x27>;
                        interrupts = <0x00 0x7d 0x04>;
                        clocks = <0x03 0x27 0x0c 0x31>;
                        compatible = "mediatek,mt7986-uart", "mediatek,mt6577-uart";
                        status = "okay";
                        reg = <0x00 0x11000200 0x00 0x100>;
                        phandle = <0x8d>;
                clock-controller@15031000 {
                        #reset-cells = <0x01>;
                        #clock-cells = <0x01>;
                        compatible = "mediatek,mt7988-ethwarp";
                        reg = <0x00 0x15031000 0x00 0x1000>;
                        phandle = <0x3e>;
                uart2 = "/soc/serial@11000200";
                gsw_phy1_led1 = "/soc/switch@15020000/mdio/ethernet-phy@1/leds/gsw-phy1-led1@1";
                eth = "/soc/ethernet@15100000";
                gic = "/soc/interrupt-controller@c000000";
                tphyu3port0 = "/soc/tphy@11c50000/usb-phy@11c50700";
                pcie0 = "/soc/pcie@11300000";
                port0 = "/soc/ethernet@15100000/mdio-bus/switch@16/ports/port@0";
                uart1_0_pins = "/soc/pinctrl@1001f000/uart1-0-pins";
                usxgmiisys1 = "/soc/pcs@10081000";
                wed2 = "/soc/wed@15014000";
                sgmiipcs0 = "/soc/syscon@10060000/pcs";
                phy_calibration_p0 = "/soc/efuse@11f50000/calib@940";
                gbe2_led0_pins = "/soc/pinctrl@1001f000/gbe2-led0-pins";
                gsw_phy1 = "/soc/switch@15020000/mdio/ethernet-phy@1";
                wifi_eeprom = "/soc/i2c@11005000/i2c-switch@70/i2c@3/eeprom@51";
                switch = "/soc/switch@15020000";
                switchphy1 = "/soc/ethernet@15100000/mdio-bus/switch@16/mdio/switchphy@1";
                mux1 = "/soc/ethernet@15100000/mux-bus/ethernet-mux@1";
                cpu1 = "/cpus/cpu@1";
                uart2_0_pins = "/soc/pinctrl@1001f000/uart2-0-pins";
                uart0 = "/soc/serial@11000000";
root@BPI-Pro-Router:~# grep -E "phandle = <0x09>|phandle = <0x14>" -B 15 /tmp/stock_bpi_pro.dts
                                        function = "flash";
                                        groups = "sdcard";
                        gbe3-led0-pins {
                                phandle = <0x49>;
                                mux {
                                        function = "led";
                                        groups = "gbe3_led0";
                        uart2-3-pins {
                                phandle = <0x14>;
                                        function = "uart";
                                        groups = "uart2_1";
                        2p5gbe-led1-pins {
                                phandle = <0x7d>;
                                mux {
                                        function = "led";
                                        groups = "2p5gbe_led1";
                        pwm0-pins {
                                phandle = <0x09>;
I2C Bus Scan (i2cdetect -y 3)
I ran a scan on I2C bus 3 to see which devices are being detected. Most of the reserved addresses appear to be showing up as expected, but I noticed that address 0x40 is completely missing.
I’m assuming this is where the INA2xx sensor should be, based on the errors I’m seeing in the logs. If that’s the case, its absence in the scan might be another sign that the sensor—and the rail it’s responsible for—isn’t getting power. I’d be interested to know if this address shows up normally on a healthy R4 Pro.
root@BPI-Pro-Router:~# i2cdetect -y 3
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
20: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- UU -- -- -- -- -- UU -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: UU -- -- -- -- -- -- --
Kernel Error (dmesg)
I took a look at dmesg to see how the system is handling the power-on sequence. I noticed a couple of errors that I’m not entirely sure about, but they seem relevant to the missing 12V output.
First, the ina2xx driver seems to be having trouble. It mentions it can’t find its supply and then fails with a “device configuration” error. Since I’m getting 0V at the fan headers, I’m wondering if this chip is failing to initialize because of that missing voltage, or if this is just a software quirk.
Also, I noticed a “Fixed dependency cycle” involving the rt5190a buck1 regulator. I don’t have enough experience with the PMIC logic to know if this is normal for the R4 Pro, but since buck1 appears linked to the initialization sequence, I thought it was worth sharing.
root@BPI-Pro-Router:~# dmesg | grep ina2xx
[   90.147671] ina2xx 3-0040: supply vs not found, using dummy regulator
[   90.155424] ina2xx 3-0040: error configuring the device: -6
root@BPI-Pro-Router:~# dmesg | grep cycle
[    0.015847] /soc/interrupt-controller@c000000: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000
[    3.222113] /soc/i2c@11003000/rt5190a@64: Fixed dependency cycle(s) with /soc/i2c@11003000/rt5190a@64/regulators/buck1
Regulator State
I’ve been looking into the regulator states to see if there is any obvious software-side reason for the 12V failure. The output below shows the current state of the regulators on my unit.
It seems the kernel identifies the RT5190A components and has them marked as enabled, yet as I mentioned, there is no physical voltage at the headers. I’m not an expert on the PMIC’s internal mapping, but seeing buck1 and buck4 enabled while the 12V-dependent monitor at 0x40 remains invisible is confusing.
root@BPI-Pro-Router:~# for r in /sys/class/regulator/regulator.*; do echo -n "$(basename $r) ($(cat $r/name)): "; cat $r/state; done
regulator.0 (regulator-dummy): cat: can't open '/sys/class/regulator/regulator.0/state': No such file or directory
regulator.1 (fixed-1.8V): cat: can't open '/sys/class/regulator/regulator.1/state': No such file or directory
regulator.2 (fixed-3.3V): cat: can't open '/sys/class/regulator/regulator.2/state': No such file or directory
regulator.3 (rt5190a-buck1): enabled
regulator.4 (vcore): enabled
regulator.5 (vproc): enabled
regulator.6 (rt5190a-buck4): enabled
regulator.7 (rt5190a-ldo): enabled
Other Note Worthy Commands Tested
I had read people having an issue with the fans, regarding being locked out of the status of it being active, I tried to see what I could do and I was successful at unbinding the SFP+ for both LAN and WAN, unable to turn of the LEDs but was able to put bridghtness to 0, something seems to be locking the GPIO, or the 12v is simply faulty, other stuff i did, and this is just the tip of the iceberg. I have spent hours trying to do various things to get them to turn on. So frustrated. It worked, nothing has changed.
root@BPI-Pro-Router:~# ls /sys/class/pwm/
pwmchip0
root@BPI-Pro-Router:~# cat /sys/class/thermal/cooling_device*/type
pwm-fan
echo "gpio-leds" > /sys/bus/platform/drivers/leds-gpio/unbind 2>/dev/null
echo "pwm-fan" > /sys/bus/platform/drivers/pwm-fan/unbind 2>/dev/null
for pin in $(seq 596 611); do
    echo $pin > /sys/class/gpio/export 2>/dev/null
    echo out > /sys/class/gpio/gpio$pin/direction 2>/dev/null
    echo 1 > /sys/class/gpio/gpio$pin/value 2>/dev/null
done
echo 0 > /sys/class/pwm/pwmchip0/export 2>/dev/null
echo 0 > /sys/class/pwm/pwmchip0/pwm0/enable 2>/dev/null
echo 0 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle 2>/dev/null
echo 40000 > /sys/class/pwm/pwmchip0/pwm0/period
echo 20000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
for master_en in 533 566; do
    echo $master_en > /sys/class/gpio/export 2>/dev/null
    echo out > /sys/class/gpio/gpio$master_en/direction 2>/dev/null
    echo 1 > /sys/class/gpio/gpio$master_en/value 2>/dev/null
done
cat /sys/kernel/debug/gpio | grep -E "596|597|515|533|566"
root@BPI-Pro-Router:~# ls /sys/class/pwm/pwmchip0/
device     export     npwm       power      subsystem  uevent     unexport
root@BPI-Pro-Router:~# cat /sys/kernel/debug/pinctrl/*pinctrl_moore/pinmux-pins | grep "515"
root@BPI-Pro-Router:~# echo 0 > /sys/class/pwm/pwmchip0/export 2>/dev/null
root@BPI-Pro-Router:~# echo 40000 > /sys/class/pwm/pwmchip0/pwm0/period 2>/dev/null
root@BPI-Pro-Router:~# echo 20000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle 2>/dev/null
root@BPI-Pro-Router:~# echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable 2>/dev/null
root@BPI-Pro-Router:~# echo 40000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
root@BPI-Pro-Router:~# echo "11000200.serial" > /sys/bus/platform/drivers/serial8250/unbind 2>/dev/null
root@BPI-Pro-Router:~# echo "pwm-fan" > /sys/bus/platform/drivers/pwm-fan/unbind 2>/dev/null
root@BPI-Pro-Router:~# echo "10048000.pwm" > /sys/bus/platform/drivers/pwm-mediatek/unbind 2>/dev/null
root@BPI-Pro-Router:~# echo "10048000.pwm" > /sys/bus/platform/drivers/pwm-mediatek/bind 2>/dev/null
root@BPI-Pro-Router:~# cat /sys/class/pwm/pwmchip0/pwm0/duty_cycle
cat: can't open '/sys/class/pwm/pwmchip0/pwm0/duty_cycle': No such file or directory
root@BPI-Pro-Router:~# ^C
20000
root@BPI-Pro-Router:~# grep -A 20 "pwm" /tmp/stock_bpi_pro.dts | grep "pins"
                        pwm0-pins {
                        pcie2-pins {
                        uart1-0-pins {
                mmc0_pins_emmc_45 = "/soc/pinctrl@1001f000/mmc0-pins-emmc-45";
                uart1_2_pins = "/soc/pinctrl@1001f000/uart1-2-pins";
                pwm0_pins = "/soc/pinctrl@1001f000/pwm0-pins";
                gbe0_led0_pins = "/soc/pinctrl@1001f000/gbe0-led0-pins";
                i2c1_pins = "/soc/pinctrl@1001f000/i2c1-pins-g0";
                i2c2_0_pins = "/soc/pinctrl@1001f000/i2c2-pins-g0";
                pcie2_pins = "/soc/pinctrl@1001f000/pcie2-pins";
                gbe3_led1_pins = "/soc/pinctrl@1001f000/gbe3-led1-pins";
                uart2_pins = "/soc/pinctrl@1001f000/uart2-pins";
                spi1_pins = "/soc/pinctrl@1001f000/spi1-pins";
                uart0_pins = "/soc/pinctrl@1001f000/uart0-pins";
root@BPI-Pro-Router:~# cat /sys/class/pwm/pwmchip0/npwm
8
root@BPI-Pro-Router:~# for i in 1 2 3 4 5 6 7; do echo $i > /sys/class/pwm/pwmchip0/export 2>/dev/null; done
>     echo 40000 > /sys/class/pwm/pwmchip0/pwm$i/period 2>/dev/null
>     echo 20000 > /sys/class/pwm/pwmchip0/pwm$i/duty_cycle 2>/dev/null
>     echo 1 > /sys/class/pwm/pwmchip0/pwm$i/enable 2>/dev/null
> done
root@BPI-Pro-Router:~# dmesg | grep -E "pwm|uart|pinctrl" | tail -n 20
[    0.010707] pinctrl core: initialized pinctrl subsystem
root@BPI-Pro-Router:~# cat /sys/kernel/debug/pinctrl/*pinctrl_moore/pinmux-pins | grep "516"
pin 4 (GPIO_A): GPIO pinctrl_moore:516
root@BPI-Pro-Router:~# echo 1 > /sys/class/pwm/pwmchip0/export 2>/dev/null
root@BPI-Pro-Router:~# echo 40000 > /sys/class/pwm/pwmchip0/pwm1/period 2>/dev/null
root@BPI-Pro-Router:~# echo 20000 > /sys/class/pwm/pwmchip0/pwm1/duty_cycle 2>/dev/null
root@BPI-Pro-Router:~# echo 1 > /sys/class/pwm/pwmchip0/pwm1/enable 2>/dev/null
I’m hoping this data helps the team identify if this is a known batch issue or a software bug. I really love the board’s performance otherwise and would love to get this sorted without the long AliExpress refund loop.
Thanks in advance for any help or guidance you can provide! Keep up the great work on these boards.
there is no INA (see the pic)
I have the ina chip not getting probed in my tests (was in downstream dts,but have not upstreamed because of this…only added later in my repo if we find a way to get it working). Thanks for confirming that it is not there.
also it shows as not connected
it will be interesting to check visually
if the INA is actually there (U13 in the schematics) but not soldered … @sinovoip ?
I’ve checked my board visually and I can confirm my revision of my board does not have the U13 populated at all.
Before this issue occurred, I noticed the stock firmware is very lite and I had to use hwmon5 manually to get the fans to speed faster, and test thermals with a load. Sadly those commands no longer work.
echo 1 > /sys/class/hwmon/hwmon5/pwm1_enable
echo 255 > /sys/class/hwmon/hwmon5/pwm1
I don’t know much about all this stuff but slowly learning and with some assistance with AI, from what AI has told me, and I take it with a grain of salt and do correct me If I am wrong, from what I have been told the Kernel is either tripping, and refusing to send 12v to that rail, potentially using a fail-safe, or I actually have a fault somewhere on the board.
I have spent hours on this and I think I’m at the end of what I am capable of doing, my latest attempt was going back to what works, and attempting to use a boot script using the following code:
cat << 'EOF' > /etc/config/temp_fan_control.sh
#!/bin/sh
# Target the confirmed path for pwmfan
FAN_PATH="/sys/class/hwmon/hwmon5"
while true; do
    # 1. Force Manual Mode (Value 1) every loop to prevent Kernel takeover
    echo 1 > "${FAN_PATH}/pwm1_enable" 2>/dev/null
    # 2. Read CPU Temp
    TEMP=$(cat /sys/class/thermal/thermal_zone0/temp)
    # 3. Apply Duty Cycle (0-255)
    if [ "$TEMP" -gt 60000 ]; then
        echo 255 > "${FAN_PATH}/pwm1"
    elif [ "$TEMP" -gt 45000 ]; then
        echo 180 > "${FAN_PATH}/pwm1"
    else
        echo 100 > "${FAN_PATH}/pwm1"
    fi
    sleep 5
done
EOF
Even after a reboot and I can see the startup script has started the boot script SH file and see it has be exercuted fine, its not working.
root@BPI-Pro-Router:/tmp# ps | grep temp_fan_control
15145 root      1356 S    sh /etc/config/temp_fan_control.sh
28150 root      1352 S    grep temp_fan_control
root@BPI-Pro-Router:/tmp# cat /sys/class/hwmon/hwmon5/pwm1_enable
root@BPI-Pro-Router:/tmp# echo 255 > /sys/class/hwmon/hwmon5/pwm1
root@BPI-Pro-Router:/tmp# grep "" /sys/class/hwmon/hwmon*/name
/sys/class/hwmon/hwmon0/name:cpu_thermal
/sys/class/hwmon/hwmon1/name:mxl862xx_dsa_0:00
/sys/class/hwmon/hwmon2/name:mxl862xx_dsa_0:01
/sys/class/hwmon/hwmon3/name:mxl862xx_dsa_0:02
/sys/class/hwmon/hwmon4/name:mxl862xx_dsa_0:03
/sys/class/hwmon/hwmon5/name:pwmfan
100
root@BPI-Pro-Router:/tmp# cat /sys/class/hwmon/hwmon5/fan1_input
cat: can't open '/sys/class/hwmon/hwmon5/fan1_input': No such file or directory
I think the only hope I have is trying another firmware and hope for the best, or RMAing the board.
Hi. Is this a failure design? I am still in time to cancel my order.
Normally the pwm fan should not be triggered by script and pwm directly. There have to be coolingmaps and trips to let kernel compare temperature and drive pwm for fan not any userspace script.
Btw. It is pwm, so alternating current and so measuring dc is not accurate. Fan must support it.
What do you expect here? The fan socket is only vcc,gnd and pwm. Tach pin is not connected and maybe not supported by driver too.
Look, I’ll be straight with you: I’m mostly winging this. I’m learning as I go, and while I’m using AI to help me out, it’s obviously no Frank-W—it’s clearly got a long way to go before it’s perfect. Sometimes it throws technical terms at me that I don’t fully grasp, so I can’t always tell when it’s leading me down the wrong path. For example, I didn’t realize fan1_input was specifically for a tachometer (RPM) reading, nor did I catch that the board only uses three pins.
What I’m really trying to figure out is whether this is a software glitch or a genuine hardware fault. Like I mentioned before, everything was working perfectly with no changes on my end, and then it just stopped. I really want to avoid the headache of mailing the board back, waiting weeks, and spending more money only for the same thing to happen again—especially if the root cause is just the Kernel expecting an INA226 sensor that isn’t physically there.
In your opinion—and keep in mind I’m still a novice here—is it possible the fan headers stopped working because the Kernel got “tripped” and is now locking out the VCC power because it can’t find that safety/health sensor? Would trying one of your builds help confirm this? Am I right in thinking your firmware bypasses the INA226 check because you realized it was missing from these boards?
It is from my little understanding, it doesn’t require the INA226 sensor to operate, after-all it was working just fine for me when I received the item over a week ago. The INA226 is responsible for safety (fault detection), health verification and intelligent power management, its just an extra layer of safety and system board protection, and from what I can see the stock firmware they’re using, or at least the one installed on mine, is attempting to use the INA226 sensor which is physically not installed on my revision of the board.
I have no idea if my 12v rail is broken, or it’s the Kernel locking me out by not sending VCC to the fans because I believe they use the GPIO, and if there is a misconfiguration in the firmware, then in this aspect it wont power on. Many people are not using the stock, but for me, it works great, just this one issue.
If its a design oversight I can deal with that because for only a couple of bucks you can buy multiple channel PWM modules with temp gauges that can easily be attached using silicone thermal glue to the CPU heatsink, what I don’t want is a board that has failed because months down the line I won’t be entitled to a replacement from Ali Express. The fans are extremely important because this board runs extremely hot, especially if you intend to use SFP copper modules, or modules with built in ONT.
It’s a great board, I have PPPoE 2.5 Gbits internet and a i7 1360P pfsense would max the cores right out, with this router, it simply couldn’t cope with the PPPoE overhead. With the BPI Pro I’m downloading/uploading past what is expected at 2513 Mbits down, and 2580 Mbits up (WAN is connected to ONT at 10 GBE, and 10 Gigabit DAC to PC) I maintain A+ rating on buffer bloat with 0 ms ping increase.
I suggest you try a non MTK build perhaps pick the self build Frank’s images
the openwrt r4-pro-8x snapshot should be available soon.
I am using my own image with debian trixie … not as good as the mtk build but stable enough…
by the way beware that the mtk-openwrt version is a heavily modified version … and in particular if you want to do secure stuff their implementation extensions opens to exploits if you are doing strongswan / ipsec gateway type of stuff sending in cleartext stuff that should be encrypted in short
  • Forwarded traffic accepted even if it does not match the expected IPsec state/template.
  • Potential cleartext forwarding where ESP-protected forwarding was intended.
  • Selector/SA binding checks bypassed on transit traffic.
the above relates to their crypto / xfrm extensions
Yep, agree, I think I’ve done all I can at this stage and trying a different build is all I can do.
The INA226 is cheap to buy but understand that sometimes companies need to cut corners, or maybe other reasons why not to solder that chip onboard, I could get my friend to install the chip as he does reflows and all types of tiny repairs to small components generally found in phones but then I might have a one of a kind board that won’t work in future official builds on firm selector. Also, would likely void any warranty or chance of a replacement further down the line
You do not need the ina chip for fan control (at least not for basic). The pwm is driven by cooling-maps, where cpu temperature read from lvts (mt7988 internal sensor) is mapped to pwm values. No script and such is needed,just drivers enabled and dts config.
Hi Frank,
I’ve been troubleshooting the BPI-R4 Pro using your 24.10 snapshot and GitHub images. While I successfully built and booted Ubuntu Noble, the hardware behaviour regarding the PWM controllers and status LEDs suggests a board-level fault.
The Fan & PWM Issue
  • Manual Control: I was able to successfully force the OS to hold the fan speed at 80 and 255. I also manually configured the cycles and period to ensure the PWM signal was being sent correctly.
  • FAN1 Header: Despite the software “sticking” to the settings, the hardware isn’t responding. The fan LEDs are extremely dim (approx. 5%). At 255, the fan flinches but fails to spin, behaving as if there isn’t enough current to overcome the motor’s starting friction.
  • FAN0 Header: This header remains completely dead regardless of the software configuration or brute-forcing the speed settings.
  • Testing: I’ve tested this across four fans (including a brand-new one with LEDs) to rule out any mechanical or fan-specific failure.
The LED Status
The Green, Blue, and Red LEDs are now “stuck” in a constant-on state. This triple-light behavior persists across all boot media (EMMC, NAND, and MicroSD) and occurs even when the board is in a failed state with a blank card.
Conclusion
Given that this system runs super hot, I can’t risk a unit with failing power delivery to the cooling headers. I’m moving forward with an RMA.
Frank-W and rmandrad is your Kings lol
I asked Google Gemini if the router was fringe, before ordering another and it mentioned you lol
Is the BPI-R4 Pro a “Fringe” Router?
The Pro is actually the gold standard for this chip; it just came out later than the standard R4.
  • Not Abandoned: The R4 Pro uses the MediaTek Filogic 880 (MT7988A). This chip is being pushed heavily by MediaTek for the next 5 years of WiFi 7 routers.
  • Official OpenWrt Status (Feb 2026): We are currently looking at End of Year (EOY) 2026 for a stable, official mainline release.
  • The “Delay” Reason: It’s not a lack of interest; it’s the Aeonsemi PHY and MaxLinear switch on the Pro. Developers are currently “polishing” the drivers to meet OpenWrt’s strict mainline standards rather than just using the messy manufacturer “hacks”.
  • The Community Kings: Frank-w, rmandrad others have already made the Pro work 100% in their custom branches. Once those are merged, your Pro will be just as “official” as the standard R4.
To Gemini: Reckon he’s on the "Payroll?
It’s a great question, and the answer is classic open-source: Frank is not on the payroll.
He is a legendary community developer who does this in his spare time. If you look at the Banana Pi forums or his GitHub, you’ll see he’s the guy who basically single-handedly “fixed” the boards that the manufacturer (SinoVoip/Banana Pi) released with unfinished software.
  1. Independent Voice: Frank is often quite blunt with the manufacturers when their hardware has issues (like the capacitor problems on older boards). If he were on the payroll, he’d have to follow the corporate script.
  2. Pure Passion: He lives in Germany and has a “normal” job. He does this because he loves high-performance ARM networking hardware.
  3. Community “Insurance”: Banana Pi knows that if Frank stops supporting a board, people stop buying it. They give him free hardware samples (sometimes early prototypes) to ensure he has what he needs to build these images, but that’s usually where the “payment” ends.
I have not verified leds or fan with openwrt yet,just tried to get openwrt running so far togerher with @andrewjlamarche. And also mention @dangowrt who does the mxl driver “polish”.
Also in my mainline kernel itbis not 100% working state, e.g. not yet tested/configured the gpio header.
But interesting what AI finds about us :slight_smile:
