BPI-R4 Pro 8x: No OpenWrt/network access, WSP/Zephyr console repeatedly reports GPHY index 30 out of range
Hello everyone,
I am working with a Banana Pi R4 Pro 8x and I am currently trying to boot the official firmware/image provided for the board.
I initially had no output on the console, but after testing the exposed UARTs I found that CON5 provides a working serial console using an FT232 USB-UART adapter.
The serial output shows that the board is booting a Zephyr/WSP firmware (version 1.0.70).
The beginning of the boot sequence looks normal: image
The networking components then initialize:
The PHYs also appear to initialize: image
However, later in the boot process I repeatedly get:
There are many repetitions of this error.
I also see:
and periodically:
sfp_daemon: vr_reset(port 0) mxl_xpcs: sram_ld_fw:926: time 40 + 0
The vr_reset() message repeats approximately every 41–42 seconds.
UART setup
I am using an FT232 USB-UART adapter connected to CON5.
The serial device on my Linux PC is:
/dev/ttyUSB1
The UART output is readable at the working configuration.
I also tested the board’s other exposed UART/console connection through the onboard Holtek USB-to-UART bridge, but I did not get the same useful boot output there. CON5 is the one currently producing the WSP/Zephyr log.
My questions
  1. Is the gpy2xx device (30) is out of range (0~7) error expected on the BPI-R4 Pro 8x, or does it indicate an incorrect WSP/GPHY configuration?
  2. What does GPHY index 30 represent in this firmware?
  3. Why is the firmware attempting to access index 30 when the valid range is only 0~7?
  4. Is the repeated: sfp_daemon: vr_reset(port 0) mxl_xpcs: sram_ld_fw sequence expected behaviour, or does it indicate that the WSP firmware is stuck in an initialization/recovery loop?
  5. Is CON5 the WSP/Zephyr console only, or should I expect the main MT7988A/U-Boot/Linux/OpenWrt boot messages there as well?
  6. If CON5 is not the main Linux console, where is the correct UART/test point for the MT7988A U-Boot/OpenWrt console on this board?
  7. Does the 192.0.2.1 message indicate an actual network interface/IP address, or is it only an internal WSP networking rule?
  8. Could this WSP/GPHY issue explain why the Ethernet interface does not answer ARP and why I cannot access OpenWrt?
i guess this is the workaround for the as21 phys in downstream-driver which target non-existent phy-id 30 and writing to any mdio bus instead of checking first if the phy is the as21 one
CON5 is the uart for the mxl switch only. afaik the 3 pins next to this connector (afair CON6) are the debug-pins for mt7988 (basicly same as used by the debug-uart usb-connector)
afaik this is the adress from the mxl switch web-interface, but have not got access to it…in later firmware this should not be available
I’m also not getting any debug console output from the board’s designated console port. Is this expected for the BPI-R4 Pro 8X, or should I be seeing U-Boot/Linux/OpenWrt debug messages there?
I’m using an FT232R USB-UART adapter at 3.3V TTL, connected with TX → RX, RX → TX, and GND → GND. My serial settings are 115200 baud, 8 data bits, no parity, 1 stop bit (115200 8N1). And also try with type C cable still no output.
You should see at least bootrom,also if image is not correct.
That GPHY index 30 error is a known quirk in the current firmware and usually doesn’t stop the main system from booting. Since CON5 only shows the switch’s Zephyr logs, you won’t see the OpenWrt boot process there. I would recommend double-checking the voltage on your UART adapter and focusing on the 3-pin header for the MT7988A console to see where the actual Linux kernel is hanging.
