BPI-R4 Pro 8X - Cannot get LAN SFP/PHY to connect
Hi. I’m trying to replace my “standard” R4 with a PRO 8X. The main attraction was that the LAN ports are 2.5G, and more memory, of course.
I’m unable to get either the SFP or the RJ45 LAN to come up completely - no carrier. For both, I can see outbound activity to my 10G LAN switch, but no inbound traffic. I’m using the overlays to alternate between the SFP and RJ45, which works well. WAN has no such issue, SFP or RJ45 both work properly.
If I unplug from the PRO and reconnect to the R4, everything works so that rules out my LAN.
There’s much documentation strewn across a few sites and some is for 8X while there’s also 4E, so I may have gotten mixed up.
I’ve deduced that the SFP/PHY LAN interface would be LAN6 and yet, at times I see references to SFP-LAN, which is the name I have on my current R4.If it isn’t LAN6, then what should I be using?
I’m running the latest OpenWRT SNAPSHOT, which I upgrade every couple of days.
Rather than dump everything that I think might be useful right now, I’ll provide whatever diagnostic data is asked for. Or maybe I get lucky and someone else has has the issue and worked through it.
Thanks much in advance.
Have you upgraded your switch firmware? Can you post complete bootlog (including devicetree overlays applied) and output of ethtool and ethtool -m?
Hi Frank.
I have not upgraded the firmware, so that’s likely the cause of my problem. But now, I have a problem trying to resolve the problem!
Looking into doing the upgrade, I see it makes use of three tools that I can’t find using apk: ethswbox, fapi-GSW-FW-Update, ssb_smdio_download.
A Google AI search yielded indications that these might not be available under a SNAPSHOT environment. It suggested renaming the downloaded firmware file to mxl862xx_fw.bin, uploading the downloaded firmware into /lib/firmware and rebooting. That did not work. Maybe Google AI was hallucinating?
Could you point me in the right direction, please?
Thank you.
https://wiki.fw-web.de/doku.php?id=en:bpi-r4pro:start#mxl_switch_upgrade
I used file provided by bpi and using ip command. Like described in the forum link in my wiki.
And please show error messages,behaviour and such…for “does not work” it is hard to know which problem occours
Thank you so much, Frank.
My BPI-R4 Pro is now running everything that was on my BPI-R4. The switch firmware update fixed the problem.
I very much appreciate your help.
