[BPI-R4-PRO-4E] Troubleshooting - ERR light and non-functional ports
I’m not sure if I have a hardware fault or a bad configuration. OOTB ports 1-4, the 2.5G LAN, were unresponsive.
My board was pre-flashed with a 2025 version of OpenWRT 24.10, when trying to flash it with an SD card I kept getting CRC errors with both the officially provided version here and an OpenWRT 25 image by @frank-w I found on these forums, my gut says that’s a me problem but I can’t be sure. I was able to flash it from within OpenWRT to the officially provided updated image, same issues. The last thing I’ve found that might be related was in the getting started section of the docs is to try setting ‘setenv bootconf_extra mt7988a-bananapi-bpi-r4-pro-4e-iphy’ which seemed to be pre-set to that but I tried setting it anyway, same issues.
As for the ERR light itself, I could not find any info on what sets it off or where to even begin to try figuring that out, so here I am posting here.
First try to get serial log vis debug console to see when happens exactly.
I’m not sire the openwrt image i have built is working as i did it vefore having the board for testing…in my kernel repo i had to change aome things after it.
Grabbed the log. Cold boot, only cables in are power via barrel jack and console. LAN port 1 plugged in after the log finished but produced no output.
F0: 102B 0000
FA: 1042 0000
FA: 1042 0000 [0200]
F9: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0600 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [1000]
MK: 0000 0000 [0000]
T0: 0000 01A6 [0101]
Jump to BL
NOTICE:  BL2: v2.10.0   (release):OpenWrt v2024.01.17~bacca82a-3 (mt7988-spim-nand-ubi-comb)
NOTICE:  BL2: Built : 03:09:13, Jun 17 2025
NOTICE:  WDT: Cold boot
NOTICE:  WDT: disabled
NOTICE:  CPU: MT7988
NOTICE:  EMI: Detected DRAM size: 4096 MB
NOTICE:  SPI_NAND parses attributes from parameter page.
NOTICE:  SPI_NAND Detected ID 0xef
NOTICE:  Page size 2048, Block size 131072, size 268435456
NOTICE:  UBI: scanning [0x200000 - 0x10000000] ...
NOTICE:  UBI: Bad VID magic in block 0 00000000
NOTICE:  UBI: Bad VID magic in block 1 00000000
NOTICE:  UBI: Bad VID magic in block 2 00000000
No size specified -> Using max size (112246784)
Read 112246784 bytes from volume fit to 0000000050000000
## Checking Image at 50000000 ...
   FIT image found
   FIT description: ARM64 OpenWrt FIT (Flattened Image Tree)
    Image 0 (kernel-1)
     Description:  ARM64 OpenWrt Linux-6.6.93
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x50002000
     Data Size:    6744915 Bytes = 6.4 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x46000000
     Entry Point:  0x46000000
     Hash algo:    crc32
     Hash value:   6c9b5cb0
     Hash algo:    sha1
     Hash value:   863fad035b7ce0844109f0474434bdea8e6f685e
    Image 1 (fdt-1)
     Description:  ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree blob
     Compression:  uncompressed
     Data Start:   0x50671000
     Data Size:    52948 Bytes = 51.7 KiB
     Load Address: 0x45f00000
     Hash algo:    crc32
     Hash value:   3aa014ec
     Hash algo:    sha1
     Hash value:   1241308f89995d1b48940acc13042f9be6f3a94f
    Image 2 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-emmc)
     Description:  ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-emmc
     Data Start:   0x5067e000
     Data Size:    1550 Bytes = 1.5 KiB
     Hash algo:    crc32
     Hash value:   ac8551c7
     Hash algo:    sha1
     Hash value:   6e5a535a8f175213ef546664d26d983bdabae1a1
    Image 3 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-rtc)
     Description:  ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-rtc
     Data Start:   0x5067f000
     Data Size:    289 Bytes = 289 Bytes
     Hash algo:    crc32
     Hash value:   eb4ad5d6
     Hash algo:    sha1
     Hash value:   3a766bf82315bc38e454f5f99892dd30a1649ca8
    Image 4 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-sd)
     Description:  ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-sd
     Data Start:   0x50680000
     Data Size:    1478 Bytes = 1.4 KiB
     Hash algo:    crc32
     Hash value:   fab49425
     Hash algo:    sha1
     Hash value:   4d9f8a33ef8df4235b32116a54b98b0812ad377e
    Image 5 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-iphy)
     Description:  ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-iphy
     Data Start:   0x50681000
     Data Size:    667 Bytes = 667 Bytes
     Hash algo:    crc32
     Hash value:   20b92bbd
     Hash algo:    sha1
     Hash value:   624678ab9caa00732f5e505cb3843e35188e730d
    Image 6 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-sfp)
     Description:  ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-sfp
     Data Start:   0x50682000
     Data Size:    469 Bytes = 469 Bytes
     Hash algo:    crc32
     Hash value:   414f48f5
     Hash algo:    sha1
     Hash value:   87d75fcfbe7fb835bf8ccc9f1682fbe5de71c283
    Image 7 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-wifi-mt7996a)
     Description:  ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-wifi-mt7996a
     Data Start:   0x50683000
     Data Size:    2293 Bytes = 2.2 KiB
     Hash algo:    crc32
     Hash value:   6edb83e3
     Hash algo:    sha1
     Hash value:   007297c84042f5f0c7cc7bc6bd40490c7ba28b29
    Image 8 (rootfs-1)
     Description:  ARM64 OpenWrt bananapi_bpi-r4-pro-4e rootfs
     Type:         Filesystem Image
     Data Start:   0x50684000
     Data Size:    105287680 Bytes = 100.4 MiB
     Hash algo:    crc32
     Hash value:   ca539aae
     Hash algo:    sha1
     Hash value:   b8948bba0574ba517bd94fe0495bf75460a5e27f
    Default Configuration: 'config-mt7988a-bananapi-bpi-r4-pro-4e'
    Configuration 0 (config-mt7988a-bananapi-bpi-r4-pro-4e)
     Description:  OpenWrt bananapi_bpi-r4-pro-4e
     Kernel:       kernel-1
     FDT:          fdt-1
     Loadables:    rootfs-1
    Configuration 1 (mt7988a-bananapi-bpi-r4-pro-4e-emmc)
     Description:  OpenWrt bananapi_bpi-r4-pro-4e overlay mt7988a-bananapi-bpi-r4-pro-4e-emmc
     Kernel:       unavailable
     FDT:          fdt-mt7988a-bananapi-bpi-r4-pro-4e-emmc
    Configuration 2 (mt7988a-bananapi-bpi-r4-pro-4e-rtc)
     Description:  OpenWrt bananapi_bpi-r4-pro-4e overlay mt7988a-bananapi-bpi-r4-pro-4e-rtc
     Kernel:       unavailable
     FDT:          fdt-mt7988a-bananapi-bpi-r4-pro-4e-rtc
    Configuration 3 (mt7988a-bananapi-bpi-r4-pro-4e-sd)
     Description:  OpenWrt bananapi_bpi-r4-pro-4e overlay mt7988a-bananapi-bpi-r4-pro-4e-sd
     Kernel:       unavailable
     FDT:          fdt-mt7988a-bananapi-bpi-r4-pro-4e-sd
    Configuration 4 (mt7988a-bananapi-bpi-r4-pro-4e-iphy)
     Description:  OpenWrt bananapi_bpi-r4-pro-4e overlay mt7988a-bananapi-bpi-r4-pro-4e-iphy
     Kernel:       unavailable
     FDT:          fdt-mt7988a-bananapi-bpi-r4-pro-4e-iphy
    Configuration 5 (mt7988a-bananapi-bpi-r4-pro-4e-sfp)
     Description:  OpenWrt bananapi_bpi-r4-pro-4e overlay mt7988a-bananapi-bpi-r4-pro-4e-sfp
     Kernel:       unavailable
     FDT:          fdt-mt7988a-bananapi-bpi-r4-pro-4e-sfp
    Configuration 6 (mt7988a-bananapi-bpi-r4-pro-4e-wifi-mt7996a)
     Description:  OpenWrt bananapi_bpi-r4-pro-4e overlay mt7988a-bananapi-bpi-r4-pro-4e-wifi-mt7996a
     Kernel:       unavailable
     FDT:          fdt-mt7988a-bananapi-bpi-r4-pro-4e-wifi-mt7996a
## Checking hash(es) for FIT Image at 50000000 ...
   Hash(es) for Image 0 (kernel-1): crc32+ sha1+
   Hash(es) for Image 1 (fdt-1): crc32+ sha1+
   Hash(es) for Image 2 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-emmc): crc32+ sha1+
   Hash(es) for Image 3 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-rtc): crc32+ sha1+
   Hash(es) for Image 4 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-sd): crc32+ sha1+
   Hash(es) for Image 5 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-iphy): crc32+ sha1+
   Hash(es) for Image 6 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-sfp): crc32+ sha1+
   Hash(es) for Image 7 (fdt-mt7988a-bananapi-bpi-r4-pro-4e-wifi-mt7996a): crc32+ sha1+
   Hash(es) for Image 8 (rootfs-1): crc32+ sha1+
## Loading kernel from FIT Image at 50000000 ...
   Using 'config-mt7988a-bananapi-bpi-r4-pro-4e' configuration
     Type:         Kernel Image
     OS:           Linux
     Hash algo:    crc32
     Hash algo:    sha1
## Loading fdt from FIT Image at 50000000 ...
   Trying 'fdt-1' fdt subimage
     Hash algo:    crc32
     Hash algo:    sha1
   Loading fdt from 0x50671000 to 0x45f00000
   Using 'mt7988a-bananapi-bpi-r4-pro-4e-emmc' configuration
   Trying 'fdt-mt7988a-bananapi-bpi-r4-pro-4e-emmc' fdt subimage
     Hash algo:    crc32
     Hash algo:    sha1
   Using 'mt7988a-bananapi-bpi-r4-pro-4e-iphy' configuration
   Trying 'fdt-mt7988a-bananapi-bpi-r4-pro-4e-iphy' fdt subimage
     Hash algo:    crc32
     Hash algo:    sha1
   Booting using the fdt blob at 0x45f00000
Working FDT set to 45f00000
## Loading loadables from FIT Image at 50000000 ...
   Trying 'rootfs-1' loadables subimage
     Hash algo:    crc32
     Hash algo:    sha1
   Uncompressing Kernel Image to 46000000
   Loading Device Tree to 00000000fe7eb000, end 00000000fe7fa242 ... OK
Working FDT set to fe7eb000
set /chosen/rootdisk to bootrom media: rootdisk-spim-nand (phandle 0x00000064)
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[    0.000000] Linux version 6.6.93 (linux@ubuntu2004-devel) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 unknown) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Tue Jun 17 03:09:13 2025
[    0.000000] Machine model: Bananapi BPI-R4-PRO-4E
[    0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[    0.000000] OF: reserved mem: 0x0000000043000000..0x000000004304ffff (320 KiB) nomap non-reusable secmon@43000000
[    0.000000] OF: reserved mem: 0x0000000047cc0000..0x0000000047dbffff (1024 KiB) nomap non-reusable wmcpu-reserved@47cc0000
[    0.000000] OF: reserved mem: 0x000000004f600000..0x000000004f63ffff (256 KiB) nomap non-reusable wo-emi@4f600000
[    0.000000] OF: reserved mem: 0x000000004f640000..0x000000004f67ffff (256 KiB) nomap non-reusable wo-emi@4f640000
[    0.000000] OF: reserved mem: 0x000000004f680000..0x000000004f6bffff (256 KiB) nomap non-reusable wo-emi@4f680000
[    0.000000] OF: reserved mem: 0x000000004f700000..0x000000004fefffff (8192 KiB) nomap non-reusable wo-data@4f700000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000013fffffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
[    0.000000]   node   0: [mem 0x0000000043000000-0x000000004304ffff]
[    0.000000]   node   0: [mem 0x0000000043050000-0x0000000047cbffff]
[    0.000000]   node   0: [mem 0x0000000047cc0000-0x0000000047dbffff]
[    0.000000]   node   0: [mem 0x0000000047dc0000-0x000000004f5fffff]
[    0.000000]   node   0: [mem 0x000000004f600000-0x000000004f6bffff]
[    0.000000]   node   0: [mem 0x000000004f6c0000-0x000000004f6fffff]
[    0.000000]   node   0: [mem 0x000000004f700000-0x000000004fefffff]
[    0.000000]   node   0: [mem 0x000000004ff00000-0x000000013fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 28 pages/cpu s74472 r8192 d32024 u114688
[    0.000000] pcpu-alloc: s74472 r8192 d32024 u114688 alloc=28*4096
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait ubi.block=0,fit
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fa7eb000-0x00000000fe7eb000] (64MB)
[    0.000000] Memory: 4021048K/4194304K available (9984K kernel code, 1640K rwdata, 3284K rodata, 576K init, 308K bss, 173256K reserved, 0K cma-reserved)
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 416 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[    0.000241] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[    0.000249] pid_max: default: 32768 minimum: 301
[    0.002342] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002354] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003859] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.004145] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.004225] rcu: Hierarchical SRCU implementation.
[    0.004227] rcu:     Max phase no-delay instances is 1000.
[    0.004632] smp: Bringing up secondary CPUs ...
[    0.004861] Detected VIPT I-cache on CPU1
[    0.004899] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[    0.004924] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[    0.005188] Detected VIPT I-cache on CPU2
[    0.005209] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[    0.005219] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[    0.005462] Detected VIPT I-cache on CPU3
[    0.005483] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[    0.005493] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[    0.005524] smp: Brought up 1 node, 4 CPUs
[    0.005529] SMP: Total of 4 processors activated.
[    0.005532] CPU features: detected: 32-bit EL0 Support
[    0.005535] CPU features: detected: CRC32 instructions
[    0.005565] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.005568] CPU: All CPU(s) started at EL2
[    0.005570] alternatives: applying system-wide alternatives
[    0.009428] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.009440] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.010259] pinctrl core: initialized pinctrl subsystem
[    0.011020] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.011335] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.011438] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.011532] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.011825] thermal_sys: Registered thermal governor 'fair_share'
[    0.011828] thermal_sys: Registered thermal governor 'bang_bang'
[    0.011830] thermal_sys: Registered thermal governor 'step_wise'
[    0.011831] thermal_sys: Registered thermal governor 'user_space'
[    0.011890] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.011924] ASID allocator initialised with 65536 entries
[    0.012679] pstore: Using crash dump compression: deflate
[    0.012685] printk: console [ramoops-1] enabled
[    0.012923] pstore: Registered ramoops as persistent store backend
[    0.012927] ramoops: using 0x10000@0x42ff0000, ecc: 0
[    0.015081] /soc/interrupt-controller@c000000: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000
[    0.021252] Modules: 28784 pages in range for non-PLT usage
[    0.021261] Modules: 520304 pages in range for PLT usage
[    0.022161] cryptd: max_cpu_qlen set to 1000
[    0.023779] SCSI subsystem initialized
[    0.023852] libata version 3.00 loaded.
[    0.024841] clocksource: Switched to clocksource arch_sys_counter
[    0.026667] NET: Registered PF_INET protocol family
[    0.026807] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.029159] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.029182] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.029191] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.029289] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.029699] TCP: Hash tables configured (established 32768 bind 32768)
[    0.030034] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.030161] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.030212] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.030423] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.030463] PCI: CLS 0 bytes, default 64
[    0.035776] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.039459] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.039466] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.071763] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[    0.072407] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    0.072426] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[    0.072437] mtk-pcie-gen3 11280000.pcie:       IO 0x0020000000..0x00201fffff -> 0x0020000000
[    0.072450] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[    0.072543] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[    0.072553] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[    0.072562] mtk-pcie-gen3 11290000.pcie:       IO 0x0028000000..0x00281fffff -> 0x0028000000
[    0.072572] mtk-pcie-gen3 11290000.pcie:      MEM 0x0028200000..0x002fffffff -> 0x0028200000
[    0.072590] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[    0.072598] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[    0.072661] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[    0.072671] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[    0.072680] mtk-pcie-gen3 11300000.pcie:       IO 0x0030000000..0x00301fffff -> 0x0030000000
[    0.072688] mtk-pcie-gen3 11300000.pcie:      MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[    0.072705] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[    0.072713] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[    0.072789] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[    0.072799] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[    0.072808] mtk-pcie-gen3 11310000.pcie:       IO 0x0038000000..0x00381fffff -> 0x0038000000
[    0.072817] mtk-pcie-gen3 11310000.pcie:      MEM 0x0038200000..0x003fffffff -> 0x0038200000
[    0.072833] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[    0.072840] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[    0.077760] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.078589] printk: console [ttyS0] disabled
[    0.098862] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[    0.098900] printk: console [ttyS0] enabled
[    1.117367] 11000100.serial: ttyS1 at MMIO 0x11000100 (irq = 100, base_baud = 2500000) is a ST16650V2
[    1.147302] 11000200.serial: ttyS2 at MMIO 0x11000200 (irq = 101, base_baud = 2500000) is a ST16650V2
[    1.159289] loop: module loaded
[    1.164495] spi-nand spi0.0: CASN page check failed
[    1.169393] spi-nand spi0.0: Fallback to read ID
[    1.174079] spi-nand spi0.0: Winbond SPI NAND was found.
[    1.179395] spi-nand spi0.0: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[    1.187774] 4 fixed-partitions partitions found on MTD device spi0.0
[    1.194133] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[    1.201099] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[    1.208138] Creating 4 MTD partitions on "spi0.0":
[    1.212928] 0x000000000000-0x000000200000 : "bl2"
[    1.219125] 0x000000200000-0x000000600000 : "Factory"
[    1.226768] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[    1.233766] 0x000000600000-0x000010000000 : "ubi"
[    1.390129] ubi0: default fastmap pool size: 100
[    1.394745] ubi0: default fastmap WL pool size: 50
[    1.399533] ubi0: attaching mtd2
[    2.284845] random: crng init done
[    2.928303] ubi0: scanning is finished
[    2.941810] ubi0: attached mtd2 (name "ubi", size 250 MiB)
[    2.947305] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.954168] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.960946] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.967896] ubi0: good PEBs: 1990, bad PEBs: 10, corrupted PEBs: 0
[    2.974064] ubi0: user volume: 6, internal volumes: 1, max. volumes count: 128
[    2.981275] ubi0: max/mean erase counter: 3/0, WL threshold: 4096, image sequence number: 1750129753
[    2.990394] ubi0: available PEBs: 0, total reserved PEBs: 1990, PEBs reserved for bad PEB handling: 30
[    2.999690] ubi0: background thread "ubi_bgt0d" started, PID 263
[    2.999768] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[    3.012636] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[    3.019826] block ubiblock0_4: created from ubi0:4(fit)
[    3.025106] 0x000000000000-0x000010000000 : "nand"
[    3.032906] mt7530-mmio 15020000.switch: Failed to register DSA switch: -517
[    3.166556] i2c_dev: i2c /dev entries driver
[    3.171336] /soc/i2c@11003000/rt5190a@64: Fixed dependency cycle(s) with /soc/i2c@11003000/rt5190a@64/regulators/buck1
[    3.187998] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    3.201637] hw perfevents: enabled with armv8_cortex_a73 PMU driver, 7 counters available
[    3.210632] NET: Registered PF_INET6 protocol family
[    3.215928] Segment Routing with IPv6
[    3.219591] In-situ OAM (IOAM) with IPv6
[    3.223539] NET: Registered PF_PACKET protocol family
[    3.228607] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.241679] 8021q: 802.1Q VLAN Support v1.8
[    3.257292] phy phy-soc:[email protected]: type_sw - reg 0x218, index 0
[    3.264441] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    3.271778] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[    3.278047] mtk-pcie-gen3 11280000.pcie:       IO 0x0020000000..0x00201fffff -> 0x0020000000
[    3.286486] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[    3.295013] mtk-pcie-gen3 11280000.pcie: failed to get max link width
[    3.313218] mtk-msdc 11230000.mmc: Final PAD_DS_TUNE: 0x12c14
[    3.319083] mmc0: new HS400 MMC card at address 0001
[    3.324609] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[    3.330083] Alternate GPT is invalid, using primary GPT.
[    3.335412]  mmcblk0: p1 p2 p3 p4 p5 p128
[    3.340191] mmcblk0boot0: mmc0:0001 8GTF4R 4.00 MiB
[    3.345647] mmcblk0boot1: mmc0:0001 8GTF4R 4.00 MiB
[    3.350725] mmcblk0rpmb: mmc0:0001 8GTF4R 512 KiB, chardev (249:0)
[    3.644852] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[    3.653641] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[    3.660694] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[    3.668005] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[    3.674267] mtk-pcie-gen3 11290000.pcie:       IO 0x0028000000..0x00281fffff -> 0x0028000000
[    3.682700] mtk-pcie-gen3 11290000.pcie:      MEM 0x0028200000..0x002fffffff -> 0x0028200000
[    3.691172] mtk-pcie-gen3 11290000.pcie: failed to get max link width
[    4.034862] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[    4.043638] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[    4.050498] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[    4.057803] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[    4.064062] mtk-pcie-gen3 11300000.pcie:       IO 0x0030000000..0x00301fffff -> 0x0030000000
[    4.072493] mtk-pcie-gen3 11300000.pcie:      MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[    4.080947] mtk-pcie-gen3 11300000.pcie: failed to get max link width
[    4.331120] mtk-pcie-gen3 11300000.pcie: set IO trans window[0]: cpu_addr = 0x30000000, pci_addr = 0x30000000, size = 0x200000
[    4.342502] mtk-pcie-gen3 11300000.pcie: set MEM trans window[1]: cpu_addr = 0x30200000, pci_addr = 0x30200000, size = 0x200000
[    4.353965] mtk-pcie-gen3 11300000.pcie: set MEM trans window[2]: cpu_addr = 0x30400000, pci_addr = 0x30400000, size = 0x400000
[    4.365428] mtk-pcie-gen3 11300000.pcie: set MEM trans window[3]: cpu_addr = 0x30800000, pci_addr = 0x30800000, size = 0x800000
[    4.376890] mtk-pcie-gen3 11300000.pcie: set MEM trans window[4]: cpu_addr = 0x31000000, pci_addr = 0x31000000, size = 0x1000000
[    4.388438] mtk-pcie-gen3 11300000.pcie: set MEM trans window[5]: cpu_addr = 0x32000000, pci_addr = 0x32000000, size = 0x2000000
[    4.399986] mtk-pcie-gen3 11300000.pcie: set MEM trans window[6]: cpu_addr = 0x34000000, pci_addr = 0x34000000, size = 0x4000000
[    4.411750] mtk-pcie-gen3 11300000.pcie: PCI host bridge to bus 0000:00
[    4.418360] pci_bus 0000:00: root bus resource [bus 00-ff]
[    4.423836] pci_bus 0000:00: root bus resource [io  0x400000-0x5fffff] (bus address [0x30000000-0x301fffff])
[    4.433650] pci_bus 0000:00: root bus resource [mem 0x30200000-0x37ffffff]
[    4.440515] pci_bus 0000:00: scanning bus
[    4.444533] pci 0000:00:00.0: [14c3:7988] type 01 class 0x060400
[    4.450544] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[    4.457381] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[    4.463463] pci 0000:00:00.0: PME# disabled
[    4.468907] pci_bus 0000:00: fixups for bus
[    4.473081] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[    4.479773] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.487770] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[    4.494505] pci_bus 0000:01: scanning bus
[    4.498527] pci 0000:01:00.0: [14c3:7990] type 00 class 0x028000
[    4.504542] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit pref]
[    4.511765] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[    4.518647] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    4.524729] pci 0000:01:00.0: PME# disabled
[    4.554877] pci_bus 0000:01: fixups for bus
[    4.559049] pci_bus 0000:01: bus scan returning with max=01
[    4.564609] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    4.571219] pci_bus 0000:00: bus scan returning with max=01
[    4.576791] pci 0000:00:00.0: BAR 9: assigned [mem 0x30200000-0x303fffff 64bit pref]
[    4.584521] pci 0000:00:00.0: BAR 8: assigned [mem 0x30400000-0x304fffff]
[    4.591299] pci 0000:00:00.0: BAR 0: assigned [mem 0x30500000-0x30507fff 64bit]
[    4.598601] pci 0000:01:00.0: BAR 0: assigned [mem 0x30200000-0x303fffff 64bit pref]
[    4.606342] pci 0000:01:00.0: BAR 2: assigned [mem 0x30400000-0x30407fff 64bit]
[    4.613646] pci 0000:00:00.0: PCI bridge to [bus 01]
[    4.618602] pci 0000:00:00.0:   bridge window [mem 0x30400000-0x304fffff]
[    4.625379] pci 0000:00:00.0:   bridge window [mem 0x30200000-0x303fffff 64bit pref]
[    4.633116] pci 0000:00:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  256
[    4.641556] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  256
[    4.650067] pcieport 0000:00:00.0: assign IRQ: got 122
[    4.655202] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    4.661291] pcieport 0000:00:00.0: enabling bus mastering
[    4.667000] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[    4.675436] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[    4.683859] mtk-pcie-gen3 11300000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11300c00 data 2
[    4.692285] mtk-pcie-gen3 11300000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11300c00 data 3
[    4.700709] mtk-pcie-gen3 11300000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11300c00 data 4
[    4.709132] mtk-pcie-gen3 11300000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11300c00 data 5
[    4.717556] mtk-pcie-gen3 11300000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11300c00 data 6
[    4.725981] mtk-pcie-gen3 11300000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11300c00 data 7
[    4.734403] mtk-pcie-gen3 11300000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11300c00 data 8
[    4.742826] mtk-pcie-gen3 11300000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11300c00 data 9
[    4.751250] mtk-pcie-gen3 11300000.pcie: msi#0xa address_hi 0x0 address_lo 0x11300c00 data 10
[    4.759760] mtk-pcie-gen3 11300000.pcie: msi#0xb address_hi 0x0 address_lo 0x11300c00 data 11
[    4.768272] mtk-pcie-gen3 11300000.pcie: msi#0xc address_hi 0x0 address_lo 0x11300c00 data 12
[    4.776783] mtk-pcie-gen3 11300000.pcie: msi#0xd address_hi 0x0 address_lo 0x11300c00 data 13
[    4.785295] mtk-pcie-gen3 11300000.pcie: msi#0xe address_hi 0x0 address_lo 0x11300c00 data 14
[    4.793805] mtk-pcie-gen3 11300000.pcie: msi#0xf address_hi 0x0 address_lo 0x11300c00 data 15
[    4.802317] mtk-pcie-gen3 11300000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11300c00 data 16
[    4.810915] mtk-pcie-gen3 11300000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11300c00 data 17
[    4.819512] mtk-pcie-gen3 11300000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11300c00 data 18
[    4.828110] mtk-pcie-gen3 11300000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11300c00 data 19
[    4.836708] mtk-pcie-gen3 11300000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11300c00 data 20
[    4.845305] mtk-pcie-gen3 11300000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11300c00 data 21
[    4.853900] mtk-pcie-gen3 11300000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11300c00 data 22
[    4.862498] mtk-pcie-gen3 11300000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11300c00 data 23
[    4.871095] mtk-pcie-gen3 11300000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11300c00 data 24
[    4.879692] mtk-pcie-gen3 11300000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11300c00 data 25
[    4.888291] mtk-pcie-gen3 11300000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11300c00 data 26
[    4.896888] mtk-pcie-gen3 11300000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11300c00 data 27
[    4.905486] mtk-pcie-gen3 11300000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11300c00 data 28
[    4.914081] mtk-pcie-gen3 11300000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11300c00 data 29
[    4.922680] mtk-pcie-gen3 11300000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11300c00 data 30
[    4.931278] mtk-pcie-gen3 11300000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11300c00 data 31
[    4.940216] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[    4.948717] pcieport 0000:00:00.0: PME: Signaling with IRQ 123
[    4.954652] pcieport 0000:00:00.0: AER: enabled with IRQ 123
[    4.960354] pcieport 0000:00:00.0: save config 0x00: 0x798814c3
[    4.966269] pcieport 0000:00:00.0: save config 0x04: 0x00100406
[    4.972176] pcieport 0000:00:00.0: save config 0x08: 0x06040001
[    4.978086] pcieport 0000:00:00.0: save config 0x0c: 0x00010000
[    4.983993] pcieport 0000:00:00.0: save config 0x10: 0x30500004
[    4.989902] pcieport 0000:00:00.0: save config 0x14: 0x00000000
[    4.995811] pcieport 0000:00:00.0: save config 0x18: 0x00010100
[    5.001717] pcieport 0000:00:00.0: save config 0x1c: 0x000001f1
[    5.007626] pcieport 0000:00:00.0: save config 0x20: 0x30403040
[    5.013533] pcieport 0000:00:00.0: save config 0x24: 0x30313021
[    5.019441] pcieport 0000:00:00.0: save config 0x28: 0x00000000
[    5.025350] pcieport 0000:00:00.0: save config 0x2c: 0x00000000
[    5.031256] pcieport 0000:00:00.0: save config 0x30: 0x00000000
[    5.037165] pcieport 0000:00:00.0: save config 0x34: 0x00000080
[    5.043071] pcieport 0000:00:00.0: save config 0x38: 0x00000000
[    5.048979] pcieport 0000:00:00.0: save config 0x3c: 0x0002017a
[    5.055215] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[    5.062517] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[    5.068788] mtk-pcie-gen3 11310000.pcie:       IO 0x0038000000..0x00381fffff -> 0x0038000000
[    5.077221] mtk-pcie-gen3 11310000.pcie:      MEM 0x0038200000..0x003fffffff -> 0x0038200000
[    5.085698] mtk-pcie-gen3 11310000.pcie: failed to get max link width
[    5.330964] mtk-pcie-gen3 11310000.pcie: set IO trans window[0]: cpu_addr = 0x38000000, pci_addr = 0x38000000, size = 0x200000
[    5.342346] mtk-pcie-gen3 11310000.pcie: set MEM trans window[1]: cpu_addr = 0x38200000, pci_addr = 0x38200000, size = 0x200000
[    5.353809] mtk-pcie-gen3 11310000.pcie: set MEM trans window[2]: cpu_addr = 0x38400000, pci_addr = 0x38400000, size = 0x400000
[    5.365271] mtk-pcie-gen3 11310000.pcie: set MEM trans window[3]: cpu_addr = 0x38800000, pci_addr = 0x38800000, size = 0x800000
[    5.376733] mtk-pcie-gen3 11310000.pcie: set MEM trans window[4]: cpu_addr = 0x39000000, pci_addr = 0x39000000, size = 0x1000000
[    5.388280] mtk-pcie-gen3 11310000.pcie: set MEM trans window[5]: cpu_addr = 0x3a000000, pci_addr = 0x3a000000, size = 0x2000000
[    5.399828] mtk-pcie-gen3 11310000.pcie: set MEM trans window[6]: cpu_addr = 0x3c000000, pci_addr = 0x3c000000, size = 0x4000000
[    5.411462] mtk-pcie-gen3 11310000.pcie: PCI host bridge to bus 0001:00
[    5.418070] pci_bus 0001:00: root bus resource [bus 00-ff]
[    5.423545] pci_bus 0001:00: root bus resource [io  0x600000-0x7fffff] (bus address [0x38000000-0x381fffff])
[    5.433359] pci_bus 0001:00: root bus resource [mem 0x38200000-0x3fffffff]
[    5.440224] pci_bus 0001:00: scanning bus
[    5.444241] pci 0001:00:00.0: [14c3:7988] type 01 class 0x060400
[    5.450250] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[    5.457086] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[    5.463168] pci 0001:00:00.0: PME# disabled
[    5.468665] pci_bus 0001:00: fixups for bus
[    5.472838] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[    5.479532] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    5.487530] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[    5.494262] pci_bus 0001:01: scanning bus
[    5.498284] pci 0001:01:00.0: [14c3:7991] type 00 class 0x028000
[    5.504297] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit pref]
[    5.511521] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[    5.518404] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[    5.524487] pci 0001:01:00.0: PME# disabled
[    5.554877] pci_bus 0001:01: fixups for bus
[    5.559049] pci_bus 0001:01: bus scan returning with max=01
[    5.564609] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    5.571217] pci_bus 0001:00: bus scan returning with max=01
[    5.576790] pci 0001:00:00.0: BAR 9: assigned [mem 0x38200000-0x383fffff 64bit pref]
[    5.584519] pci 0001:00:00.0: BAR 8: assigned [mem 0x38400000-0x384fffff]
[    5.591295] pci 0001:00:00.0: BAR 0: assigned [mem 0x38500000-0x38507fff 64bit]
[    5.598598] pci 0001:01:00.0: BAR 0: assigned [mem 0x38200000-0x383fffff 64bit pref]
[    5.606338] pci 0001:01:00.0: BAR 2: assigned [mem 0x38400000-0x38407fff 64bit]
[    5.613642] pci 0001:00:00.0: PCI bridge to [bus 01]
[    5.618598] pci 0001:00:00.0:   bridge window [mem 0x38400000-0x384fffff]
[    5.625375] pci 0001:00:00.0:   bridge window [mem 0x38200000-0x383fffff 64bit pref]
[    5.633113] pci 0001:00:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  256
[    5.641553] pci 0001:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  256
[    5.650050] pcieport 0001:00:00.0: assign IRQ: got 125
[    5.655184] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[    5.661273] pcieport 0001:00:00.0: enabling bus mastering
[    5.666986] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[    5.675422] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[    5.683845] mtk-pcie-gen3 11310000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11310c00 data 2
[    5.692271] mtk-pcie-gen3 11310000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11310c00 data 3
[    5.700695] mtk-pcie-gen3 11310000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11310c00 data 4
[    5.709119] mtk-pcie-gen3 11310000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11310c00 data 5
[    5.717542] mtk-pcie-gen3 11310000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11310c00 data 6
[    5.725966] mtk-pcie-gen3 11310000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11310c00 data 7
[    5.734388] mtk-pcie-gen3 11310000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11310c00 data 8
[    5.742813] mtk-pcie-gen3 11310000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11310c00 data 9
[    5.751236] mtk-pcie-gen3 11310000.pcie: msi#0xa address_hi 0x0 address_lo 0x11310c00 data 10
[    5.759747] mtk-pcie-gen3 11310000.pcie: msi#0xb address_hi 0x0 address_lo 0x11310c00 data 11
[    5.768258] mtk-pcie-gen3 11310000.pcie: msi#0xc address_hi 0x0 address_lo 0x11310c00 data 12
[    5.776769] mtk-pcie-gen3 11310000.pcie: msi#0xd address_hi 0x0 address_lo 0x11310c00 data 13
[    5.785280] mtk-pcie-gen3 11310000.pcie: msi#0xe address_hi 0x0 address_lo 0x11310c00 data 14
[    5.793789] mtk-pcie-gen3 11310000.pcie: msi#0xf address_hi 0x0 address_lo 0x11310c00 data 15
[    5.802302] mtk-pcie-gen3 11310000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11310c00 data 16
[    5.810899] mtk-pcie-gen3 11310000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11310c00 data 17
[    5.819496] mtk-pcie-gen3 11310000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11310c00 data 18
[    5.828094] mtk-pcie-gen3 11310000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11310c00 data 19
[    5.836692] mtk-pcie-gen3 11310000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11310c00 data 20
[    5.845289] mtk-pcie-gen3 11310000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11310c00 data 21
[    5.853886] mtk-pcie-gen3 11310000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11310c00 data 22
[    5.862484] mtk-pcie-gen3 11310000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11310c00 data 23
[    5.871080] mtk-pcie-gen3 11310000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11310c00 data 24
[    5.879678] mtk-pcie-gen3 11310000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11310c00 data 25
[    5.888276] mtk-pcie-gen3 11310000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11310c00 data 26
[    5.896874] mtk-pcie-gen3 11310000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11310c00 data 27
[    5.905472] mtk-pcie-gen3 11310000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11310c00 data 28
[    5.914068] mtk-pcie-gen3 11310000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11310c00 data 29
[    5.922667] mtk-pcie-gen3 11310000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11310c00 data 30
[    5.931265] mtk-pcie-gen3 11310000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11310c00 data 31
[    5.940210] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[    5.948709] pcieport 0001:00:00.0: PME: Signaling with IRQ 126
[    5.954639] pcieport 0001:00:00.0: AER: enabled with IRQ 126
[    5.960336] pcieport 0001:00:00.0: save config 0x00: 0x798814c3
[    5.966250] pcieport 0001:00:00.0: save config 0x04: 0x00100406
[    5.972157] pcieport 0001:00:00.0: save config 0x08: 0x06040001
[    5.978066] pcieport 0001:00:00.0: save config 0x0c: 0x00010000
[    5.983973] pcieport 0001:00:00.0: save config 0x10: 0x38500004
[    5.989881] pcieport 0001:00:00.0: save config 0x14: 0x00000000
[    5.995793] pcieport 0001:00:00.0: save config 0x18: 0x00010100
[    6.001700] pcieport 0001:00:00.0: save config 0x1c: 0x000001f1
[    6.007609] pcieport 0001:00:00.0: save config 0x20: 0x38403840
[    6.013516] pcieport 0001:00:00.0: save config 0x24: 0x38313821
[    6.019425] pcieport 0001:00:00.0: save config 0x28: 0x00000000
[    6.025333] pcieport 0001:00:00.0: save config 0x2c: 0x00000000
[    6.031240] pcieport 0001:00:00.0: save config 0x30: 0x00000000
[    6.037148] pcieport 0001:00:00.0: save config 0x34: 0x00000080
[    6.043055] pcieport 0001:00:00.0: save config 0x38: 0x00000000
[    6.048962] pcieport 0001:00:00.0: save config 0x3c: 0x0002017d
[    6.056756] FIT: Detected U-Boot 2024.10-OpenWrt-unknown
[    6.062060] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4-pro-4e" (OpenWrt bananapi_bpi-r4-pro-4e)
[    6.072320] FIT:           kernel sub-image 0x00002000..0x00670b52 "kernel-1" (ARM64 OpenWrt Linux-6.6.93)
[    6.082056] FIT:          flat_dt sub-image 0x00671000..0x0067ded3 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree blob)
[    6.093872] FIT:          flat_dt sub-image 0x0067e000..0x0067e60d "fdt-mt7988a-bananapi-bpi-r4-pro-4e-emmc" (ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-emmc)
[    6.112021] FIT:          flat_dt sub-image 0x0067f000..0x0067f120 "fdt-mt7988a-bananapi-bpi-r4-pro-4e-rtc" (ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-rtc)
[    6.129997] FIT:          flat_dt sub-image 0x00680000..0x006805c5 "fdt-mt7988a-bananapi-bpi-r4-pro-4e-sd" (ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-sd)
[    6.147799] FIT:          flat_dt sub-image 0x00681000..0x0068129a "fdt-mt7988a-bananapi-bpi-r4-pro-4e-iphy" (ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-iphy)
[    6.165947] FIT:          flat_dt sub-image 0x00682000..0x006821d4 "fdt-mt7988a-bananapi-bpi-r4-pro-4e-sfp" (ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-sfp)
[    6.183922] FIT:          flat_dt sub-image 0x00683000..0x006838f4 "fdt-mt7988a-bananapi-bpi-r4-pro-4e-wifi-mt7996a" (ARM64 OpenWrt bananapi_bpi-r4-pro-4e device tree overlay mt7988a-bananapi-bpi-r4-pro-4e-wifi-mt7996a)
[    6.203455] FIT:       filesystem sub-image 0x00684000..0x06aecfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r4-pro-4e rootfs)
[    6.214903] block ubiblock0_4: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[    6.223740] mt7530-mmio 15020000.switch: Failed to register DSA switch: -517
[    6.357561] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[    6.366136] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[    6.529047] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082a80000, irq 110
[    6.538991] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082a80000, irq 110
[    6.548902] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc082a80000, irq 110
[    6.558053] (unnamed net_device) (dummy): netif_napi_add_weight() called with weight 256
[    6.645827] mt7530-mmio 15020000.switch: configuring for fixed/internal link mode
[    6.653325] mt7530-mmio 15020000.switch: Link is Up - 10Gbps/Full - flow control rx/tx
[    6.683049] mt7530-mmio 15020000.switch lan0 (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=128)
[    6.693761] mt7530-mmio 15020000.switch: nonfatal error -34 setting MTU to 1500 on port 0
[    6.732540] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=130)
[    6.743243] mt7530-mmio 15020000.switch: nonfatal error -34 setting MTU to 1500 on port 2
[    6.781934] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=131)
[    6.792634] mt7530-mmio 15020000.switch: nonfatal error -34 setting MTU to 1500 on port 3
[    6.801064] eth0: mtu greater than device maximum
[    6.805764] mtk_soc_eth 15100000.ethernet eth0: error -22 setting MTU to 1504 to include DSA overhead
[    6.814971] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[    6.821671] DSA: tree 1 setup
[    6.824628] mt7530-nl: genl_register_family_with_ops
[    6.830000] mxl862xx mdio-bus:10:    Mxl862xx CPU Port 8, User Port number 5
[    6.846789] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: Firmware Version: 0.77 (0x004D test version)
[    6.885107] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: Firmware Version: 0.77 (0x004D test version)
[    6.923170] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: Firmware Version: 0.77 (0x004D test version)
[    6.961268] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: Firmware Version: 0.77 (0x004D test version)
[   11.261813] mxl862xx mdio-bus:10: mxl862xx_set_vlan_filter_limits: user_pnum:5, priv->max_vlans: 36, cpu_ingress_entries: 11, cpu_egress_entries: 74, user_ingress_entries: 77, user_egress_entries: 75
[   11.938488] mxl862xx mdio-bus:10: configuring for fixed/usxgmii link mode
[   11.945278] mxl862xx mdio-bus:10: Link is Up - 10Gbps/Full - flow control off
[   11.947589] mxl862xx mdio-bus:10 mxl_lan0 (uninitialized): PHY [mxl862xx_dsa-0:00] driver [MaxLinear Ethernet MxL862XX] (irq=POLL)
[   11.966428] mxl862xx mdio-bus:10 mxl_lan1 (uninitialized): PHY [mxl862xx_dsa-0:01] driver [MaxLinear Ethernet MxL862XX] (irq=POLL)
[   11.980363] mxl862xx mdio-bus:10 mxl_lan2 (uninitialized): PHY [mxl862xx_dsa-0:02] driver [MaxLinear Ethernet MxL862XX] (irq=POLL)
[   11.994316] mxl862xx mdio-bus:10 mxl_lan3 (uninitialized): PHY [mxl862xx_dsa-0:03] driver [MaxLinear Ethernet MxL862XX] (irq=POLL)
[   12.006634] eth2: mtu greater than device maximum
[   12.011333] mtk_soc_eth 15100000.ethernet eth2: error -22 setting MTU to 1504 to include DSA overhead
[   12.020546] mtk_soc_eth 15100000.ethernet eth2: entered promiscuous mode
[   12.027251] DSA: tree 0 setup
[   12.031100] mxl862xx mdio-bus:10: Firmware version 1.0.70.70
[   12.036910] clk: Disabling unused clocks
[   12.046537] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
[   12.053783] Freeing unused kernel memory: 576K
[   12.058258] Run /sbin/init as init process
[   12.062343]   with arguments:
[   12.065327]     /sbin/init
[   12.068022]   with environment:
[   12.071151]     HOME=/
[   12.073499]     TERM=linux
[   12.264365] init: Console is alive
[   12.267868] init: - watchdog -
[   13.124117] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[   13.158712] aeon_as21xxx: loading out-of-tree module taints kernel.
[   13.165528] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   13.174242] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.181995] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.189772] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.197520] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.206767] mxl862xx: failed to write mmd on port 30
[   13.212947] mxl862xx: failed to write mmd on port 30
[   13.217902] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.228247] mxl862xx: failed to write mmd on port 30
[   13.234425] mxl862xx: failed to write mmd on port 30
[   13.239379] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.249724] mxl862xx: failed to write mmd on port 30
[   13.255900] mxl862xx: failed to write mmd on port 30
[   13.260852] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.271202] mxl862xx: failed to write mmd on port 30
[   13.277385] mxl862xx: failed to write mmd on port 30
[   13.282337] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.291725] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   13.300437] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.308193] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.315947] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.323697] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.332382] mxl862xx: failed to write mmd on port 30
[   13.338563] mxl862xx: failed to write mmd on port 30
[   13.343514] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.353860] mxl862xx: failed to write mmd on port 30
[   13.389936] mxl862xx: failed to write mmd on port 30
[   13.394891] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.425118] mxl862xx: failed to write mmd on port 30
[   13.459791] mxl862xx: failed to write mmd on port 30
[   13.464742] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.494602] mxl862xx: failed to write mmd on port 30
[   13.530015] mxl862xx: failed to write mmd on port 30
[   13.534970] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.544333] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   13.553042] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.560796] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.568549] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.576302] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.616499] mxl862xx: failed to write mmd on port 30
[   13.651689] mxl862xx: failed to write mmd on port 30
[   13.656644] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.669714] mxl862xx: failed to write mmd on port 30
[   13.675893] mxl862xx: failed to write mmd on port 30
[   13.680844] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.691191] mxl862xx: failed to write mmd on port 30
[   13.697372] mxl862xx: failed to write mmd on port 30
[   13.702323] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.712669] mxl862xx: failed to write mmd on port 30
[   13.718923] mxl862xx: failed to write mmd on port 30
[   13.723874] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.733235] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   13.741944] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.749697] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.757451] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.765204] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.773811] mxl862xx: failed to write mmd on port 30
[   13.779993] mxl862xx: failed to write mmd on port 30
[   13.784947] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.795290] mxl862xx: failed to write mmd on port 30
[   13.801468] mxl862xx: failed to write mmd on port 30
[   13.806422] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.816767] mxl862xx: failed to write mmd on port 30
[   13.851608] mxl862xx: failed to write mmd on port 30
[   13.856563] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.886421] mxl862xx: failed to write mmd on port 30
[   13.921240] mxl862xx: failed to write mmd on port 30
[   13.926195] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.935561] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   13.944267] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.952021] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.959775] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   13.967527] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.008242] mxl862xx: failed to write mmd on port 30
[   14.043358] mxl862xx: failed to write mmd on port 30
[   14.048312] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.078173] mxl862xx: failed to write mmd on port 30
[   14.112991] mxl862xx: failed to write mmd on port 30
[   14.117946] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.131532] mxl862xx: failed to write mmd on port 30
[   14.137714] mxl862xx: failed to write mmd on port 30
[   14.142665] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.153012] mxl862xx: failed to write mmd on port 30
[   14.159193] mxl862xx: failed to write mmd on port 30
[   14.164143] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.173509] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   14.182220] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.189975] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.197729] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.205482] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.214090] mxl862xx: failed to write mmd on port 30
[   14.220272] mxl862xx: failed to write mmd on port 30
[   14.225226] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.235643] mxl862xx: failed to write mmd on port 30
[   14.241895] mxl862xx: failed to write mmd on port 30
[   14.246849] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.257195] mxl862xx: failed to write mmd on port 30
[   14.263373] mxl862xx: failed to write mmd on port 30
[   14.268328] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.278672] mxl862xx: failed to write mmd on port 30
[   14.313360] mxl862xx: failed to write mmd on port 30
[   14.318315] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.327676] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   14.336387] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.344137] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.351891] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.359644] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.400514] mxl862xx: failed to write mmd on port 30
[   14.435273] mxl862xx: failed to write mmd on port 30
[   14.440224] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.470379] mxl862xx: failed to write mmd on port 30
[   14.505143] mxl862xx: failed to write mmd on port 30
[   14.510095] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.539880] mxl862xx: failed to write mmd on port 30
[   14.575224] mxl862xx: failed to write mmd on port 30
[   14.580175] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.593318] mxl862xx: failed to write mmd on port 30
[   14.599499] mxl862xx: failed to write mmd on port 30
[   14.604451] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.613810] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   14.622520] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.630274] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.638027] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.645780] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.654388] mxl862xx: failed to write mmd on port 30
[   14.660570] mxl862xx: failed to write mmd on port 30
[   14.665524] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.675867] mxl862xx: failed to write mmd on port 30
[   14.682045] mxl862xx: failed to write mmd on port 30
[   14.687000] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.697346] mxl862xx: failed to write mmd on port 30
[   14.703524] mxl862xx: failed to write mmd on port 30
[   14.708479] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.718825] mxl862xx: failed to write mmd on port 30
[   14.725003] mxl862xx: failed to write mmd on port 30
[   14.729955] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.739316] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   14.748024] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.755779] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.763529] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.771282] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   14.779893] mxl862xx: failed to write mmd on port 30
[   14.814725] mxl862xx: failed to write mmd on port 30
[   14.819679] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.849469] mxl862xx: failed to write mmd on port 30
[   14.884682] mxl862xx: failed to write mmd on port 30
[   14.889635] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.919571] mxl862xx: failed to write mmd on port 30
[   14.954255] mxl862xx: failed to write mmd on port 30
[   14.959211] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.989446] mxl862xx: failed to write mmd on port 30
[   15.024270] mxl862xx: failed to write mmd on port 30
[   15.029224] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.038587] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   15.047296] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   15.055047] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   15.062797] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   15.070551] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   15.094338] mxl862xx: failed to write mmd on port 30
[   15.100519] mxl862xx: failed to write mmd on port 30
[   15.105474] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.115821] mxl862xx: failed to write mmd on port 30
[   15.121998] mxl862xx: failed to write mmd on port 30
[   15.126956] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.137302] mxl862xx: failed to write mmd on port 30
[   15.143480] mxl862xx: failed to write mmd on port 30
[   15.148434] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.158855] mxl862xx: failed to write mmd on port 30
[   15.165033] mxl862xx: failed to write mmd on port 30
[   15.169984] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.179346] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: aeon_read_pid aeonsemi1 PHY = 33 - 9c11
[   15.188055] MediaTek MT7988 PHY mt7530-0:00: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   15.195809] MediaTek MT7988 PHY mt7530-0:01: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   15.203559] MediaTek MT7988 PHY mt7530-0:02: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   15.211311] MediaTek MT7988 PHY mt7530-0:03: aeon_read_pid aeonsemi1 PHY = 0 - 0
[   15.219923] mxl862xx: failed to write mmd on port 30
[   15.226104] mxl862xx: failed to write mmd on port 30
[   15.231055] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.241402] mxl862xx: failed to write mmd on port 30
[   15.276602] mxl862xx: failed to write mmd on port 30
[   15.281554] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.311348] mxl862xx: failed to write mmd on port 30
[   15.346107] mxl862xx: failed to write mmd on port 30
[   15.351059] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.381364] mxl862xx: failed to write mmd on port 30
[   15.416052] mxl862xx: failed to write mmd on port 30
[   15.421004] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.433173] usbcore: registered new interface driver usbfs
[   15.438701] usbcore: registered new interface driver hub
[   15.444022] usbcore: registered new device driver usb
[   15.458737] xhci-mtk 11190000.usb: supply vbus not found, using dummy regulator
[   15.466140] xhci-mtk 11190000.usb: supply vusb33 not found, using dummy regulator
[   15.473876] xhci-mtk 11190000.usb: xHCI Host Controller
[   15.479107] xhci-mtk 11190000.usb: new USB bus registered, assigned bus number 1
[   15.486588] xhci-mtk 11190000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[   15.495743] xhci-mtk 11190000.usb: irq 132, io mem 0x11190000
[   15.501546] xhci-mtk 11190000.usb: xHCI Host Controller
[   15.506766] xhci-mtk 11190000.usb: new USB bus registered, assigned bus number 2
[   15.514150] xhci-mtk 11190000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[   15.521467] hub 1-0:1.0: USB hub found
[   15.525238] hub 1-0:1.0: 1 port detected
[   15.529321] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   15.537582] hub 2-0:1.0: USB hub found
[   15.541338] hub 2-0:1.0: 1 port detected
[   15.545532] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[   15.552888] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[   15.560772] xhci-mtk 11200000.usb: xHCI Host Controller
[   15.566003] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 3
[   15.576429] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[   15.585607] xhci-mtk 11200000.usb: irq 133, io mem 0x11200000
[   15.591404] xhci-mtk 11200000.usb: xHCI Host Controller
[   15.596623] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 4
[   15.604006] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[   15.611373] hub 3-0:1.0: USB hub found
[   15.615178] hub 3-0:1.0: 1 port detected
[   15.619263] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   15.627531] hub 4-0:1.0: USB hub found
[   15.631289] hub 4-0:1.0: 1 port detected
[   15.638563] usbcore: registered new interface driver usb-storage
[   15.645205] usbcore: registered new interface driver uas
[   15.650664] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[   15.665566] init: - preinit -
[   15.984861] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[   16.024987] usb 4-1: new SuperSpeed USB device number 2 using xhci-mtk
[   16.089864] mtk_ppe: roaming work has been activated
[   16.094861] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[   16.095123] hub 4-1:1.0: USB hub found
[   16.102972] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[   16.106820] hub 4-1:1.0: 4 ports detected
[   16.165532] hub 1-1:1.0: USB hub found
[   16.169338] hub 1-1:1.0: 4 ports detected
[   16.254849] usb 3-1: new high-speed USB device number 2 using xhci-mtk
[   16.438393] hub 3-1:1.0: USB hub found
[   16.442375] hub 3-1:1.0: 4 ports detected
Cannot find device "lan1"
sendto(): Network unreachable
[   20.788193] mount_root: loading kmods from internal overlay
[   20.805483] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[   20.815720] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[   26.075066] platform gpio-leds: deferred probe pending
[   35.432944] block: attempting to load /tmp/overlay/upper/etc/config/fstab
[   35.442081] block: unable to load configuration (fstab: Entry not found)
[   35.448815] block: attempting to load /tmp/overlay/etc/config/fstab
[   35.455757] block: unable to load configuration (fstab: Entry not found)
[   35.462478] block: attempting to load /etc/config/fstab
[   35.482194] block: extroot: not configured
[   35.489104] UBIFS (ubi0:5): Mounting in unauthenticated mode
[   35.494805] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" started, PID 1129
[   35.548931] UBIFS (ubi0:5): recovery needed
[   35.663038] UBIFS (ubi0:5): recovery completed
[   35.667524] UBIFS (ubi0:5): UBIFS: mounted UBI device 0, volume 5, name "rootfs_data"
[   35.675345] UBIFS (ubi0:5): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[   35.685248] UBIFS (ubi0:5): FS size: 55869440 bytes (53 MiB, 440 LEBs), max 450 LEBs, journal size 2793472 bytes (2 MiB, 22 LEBs)
[   35.696887] UBIFS (ubi0:5): reserved for root: 2638851 bytes (2577 KiB)
[   35.703489] UBIFS (ubi0:5): media format: w5/r0 (latest is w5/r0), UUID D8BD1CED-D233-4140-8FB7-7C18E7C41695, small LPT model
[   35.716447] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[   35.731592] block: extroot: not configured
[   35.735774] UBIFS (ubi0:5): un-mount UBI device 0
[   35.740474] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" stops
[   35.749744] UBIFS (ubi0:5): Mounting in unauthenticated mode
[   35.755452] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" started, PID 1132
[   35.863136] UBIFS (ubi0:5): UBIFS: mounted UBI device 0, volume 5, name "rootfs_data"
[   35.870962] UBIFS (ubi0:5): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[   35.880863] UBIFS (ubi0:5): FS size: 55869440 bytes (53 MiB, 440 LEBs), max 450 LEBs, journal size 2793472 bytes (2 MiB, 22 LEBs)
[   35.892501] UBIFS (ubi0:5): reserved for root: 2638851 bytes (2577 KiB)
[   35.899104] UBIFS (ubi0:5): media format: w5/r0 (latest is w5/r0), UUID D8BD1CED-D233-4140-8FB7-7C18E7C41695, small LPT model
[   35.919226] mount_root: loading kmods from internal overlay
[   35.950087] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[   35.960467] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[   36.225064] block: attempting to load /tmp/overlay/upper/etc/config/fstab
[   36.238169] block: extroot: not configured
[   36.243856] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[   36.251111] block: extroot: not configured
[   36.258469] mount_root: switching to ubifs overlay
[   36.273003] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[   36.288439] urandom-seed: Seeding with /etc/urandom.seed
ip: can't find device 'lan1'
ip: SIOCGIFFLAGS: No such device
[   36.550399] procd: - early -
[   36.554887] procd: - watchdog -
[   37.096624] procd: - watchdog -
[   37.103918] procd: - ubus -
[   37.270430] procd: - init -
[   37.870073] kmodloader: loading kernel modules from /etc/modules.d/*
[   37.902624] NET: Registered PF_ALG protocol family
[   37.918993] urngd: v1.0.2 started.
[   37.936864] RPC: Registered named UNIX socket transport module.
[   37.942785] RPC: Registered udp transport module.
[   37.947494] RPC: Registered tcp transport module.
[   37.952185] RPC: Registered tcp-with-tls transport module.
[   37.957666] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   37.973597] l2tp_core: L2TP core driver, V2.0
[   37.978607] l2tp_netlink: L2TP netlink interface
[   37.984033] gre: GRE over IPv4 demultiplexor driver
[   37.989479] ip_gre: GRE over IPv4 tunneling driver
[   38.051570] pca954x 2-0070: supply vdd not found, using dummy regulator
[   38.059055] i2c i2c-2: Added multiplexed i2c bus 3
[   38.064002] i2c i2c-2: Added multiplexed i2c bus 4
[   38.068946] i2c i2c-2: Added multiplexed i2c bus 5
[   38.073927] i2c i2c-2: Added multiplexed i2c bus 6
[   38.078737] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9545
[   38.087670] pca953x 3-0020: supply vcc not found, using dummy regulator
[   38.094439] pca953x 3-0020: using no AI
[   38.108092] ntfs3: Enabled Linux POSIX ACLs support
[   38.114857] crypto-safexcel 15600000.crypto: EIP197:331(7,1,8,4)-HIA:272(2,5,5),PE:151/450(alg:7fe1fc00)/240/240/450
[   38.126062] crypto-safexcel 15600000.crypto: TRC init: 8704d,48a (32r,128h)
[   38.164526] at24 3-0057: supply vcc not found, using dummy regulator
[   38.171578] at24 3-0057: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[   38.178322] at24 6-0051: supply vcc not found, using dummy regulator
[   38.185537] at24 6-0051: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[   38.192853] Bridge firewalling registered
[   38.197645] usbcore: registered new interface driver cdc_wdm
[   38.203676] Loading modules backported from Linux version wireless-next-2025-03-20-0-g1794d7ab34d2
[   38.212636] Backport generated by backports.git a8086f9c
[   38.218535] ina2xx 3-0040: supply vs not found, using dummy regulator
[   38.225540] ina2xx 3-0040: error configuring the device: -6
[   38.247811] rtc-pcf8563 3-0051: registered as rtc0
[   38.253813] rtc-pcf8563 3-0051: setting system clock to 2026-08-03T03:22:38 UTC (1785727358)
[   38.264205] sfp sfp1: Host maximum power 3.0W
[   38.268590] sfp sfp1: tx disable 1 -> 1
[   38.272583] sfp sfp1: SM: enter empty:detached:down event dev_attach
[   38.278935] sfp sfp1: SM: exit empty:down:down
[   38.283567] sfp sfp2: Host maximum power 3.0W
[   38.287935] sfp sfp2: tx disable 1 -> 1
[   38.293804] usbcore: registered new interface driver ums-alauda
[   38.300355] usbcore: registered new interface driver ums-cypress
[   38.307181] usbcore: registered new interface driver ums-datafab
[   38.313790] usbcore: registered new interface driver ums-freecom
[   38.320534] usbcore: registered new interface driver ums-isd200
[   38.327154] usbcore: registered new interface driver ums-jumpshot
[   38.333855] usbcore: registered new interface driver ums-karma
[   38.340458] usbcore: registered new interface driver ums-sddr09
[   38.347092] usbcore: registered new interface driver ums-sddr55
[   38.353732] usbcore: registered new interface driver ums-usbat
[   38.362354] usbcore: registered new interface driver usbserial_generic
[   38.368917] usbserial: USB Serial support registered for generic
[   38.385697] xt_time: kernel timezone is -0000
[   38.390631] usbcore: registered new interface driver cdc_eem
[   38.397028] usbcore: registered new interface driver cdc_ether
[   38.403862] usbcore: registered new interface driver cdc_ncm
[   38.457861] usbcore: registered new interface driver ch341
[   38.463390] usbserial: USB Serial support registered for ch341-uart
[   38.546836] mt7996e_hif 0001:01:00.0: assign IRQ: got 125
[   38.552252] mt7996e_hif 0001:01:00.0: enabling device (0000 -> 0002)
[   38.558638] mt7996e_hif 0001:01:00.0: enabling bus mastering
[   38.564406] mt7996e 0000:01:00.0: assign IRQ: got 122
[   38.569465] mt7996e 0000:01:00.0: enabling device (0000 -> 0002)
[   38.575483] mt7996e 0000:01:00.0: enabling bus mastering
[   38.664876] mt7996e 0000:01:00.0: attaching wed device 0 version 3.0
[   38.719138] platform 15010000.wed: MTK WED WO Firmware Version: ____000000, Build Time: 20230218204509
[   38.728467] platform 15010000.wed: MTK WED WO Chip ID 00 Region 2
[   38.788787] mt7996e_hif 0001:01:00.0: attaching wed device 1 version 3.0
[   39.161222] mt7996e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20250605130343a
[   39.161222]
[   39.885571] mt7996e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20250605130338
[   39.953369] mt7996e 0000:01:00.0: DSP Firmware Version: ____000000, Build Time: 20250605125645
[   40.090065] mt7996e 0000:01:00.0: WA Firmware Version: ____000000, Build Time: 20250605130248
[   40.945070] mt7996e 0000:01:00.0: registering led 'mt76-phy0'
[   41.020243] PPP generic driver version 2.4.2
[   41.025289] PPP MPPE Compression module registered
[   41.030826] NET: Registered PF_PPPOX protocol family
[   41.036614] PPTP driver version 0.8.5
[   41.041729] usbcore: registered new interface driver qmi_wwan
[   41.049718] usbcore: registered new interface driver cdc_mbim
[   41.056607] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[   41.062409] usbcore: registered new interface driver option
[   41.068125] usbserial: USB Serial support registered for GSM modem (1-port)
[   41.077068] usbcore: registered new interface driver qcserial
[   41.082843] usbserial: USB Serial support registered for Qualcomm USB modem
[   41.090013] kmodloader: done loading kernel modules from /etc/modules.d/*
[   46.478406] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[   46.915222] mtk_ppe: roaming work has been deactivated
[   46.929659] mtk_ppe: roaming work has been activated
[   46.934647] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[   46.942829] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[   46.944740] mt7530-mmio 15020000.switch lan0: configuring for phy/internal link mode
[   46.959859] br-lan: port 1(lan0) entered blocking state
[   46.965135] br-lan: port 1(lan0) entered disabled state
[   46.970384] mt7530-mmio 15020000.switch lan0: entered allmulticast mode
[   46.977003] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[   46.983984] mt7530-mmio 15020000.switch lan0: entered promiscuous mode
[   46.995008] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
[   47.003434] br-lan: port 2(lan2) entered blocking state
[   47.008789] br-lan: port 2(lan2) entered disabled state
[   47.014045] mt7530-mmio 15020000.switch lan2: entered allmulticast mode
[   47.020912] mt7530-mmio 15020000.switch lan2: entered promiscuous mode
[   47.030371] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
[   47.039014] br-lan: port 3(lan3) entered blocking state
[   47.044249] br-lan: port 3(lan3) entered disabled state
[   47.049516] mt7530-mmio 15020000.switch lan3: entered allmulticast mode
[   47.056337] mt7530-mmio 15020000.switch lan3: entered promiscuous mode
[   47.065515] mtk_soc_eth 15100000.ethernet eth2: configuring for fixed/10gbase-r link mode
[   47.117533] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 10Gbps/Full - flow control rx/tx
[   47.133197] mxl862xx mdio-bus:10 mxl_lan0: configuring for phy/internal link mode
[   47.158807] br-lan: port 4(mxl_lan0) entered blocking state
[   47.164397] br-lan: port 4(mxl_lan0) entered disabled state
[   47.170044] mxl862xx mdio-bus:10 mxl_lan0: entered allmulticast mode
[   47.176400] mtk_soc_eth 15100000.ethernet eth2: entered allmulticast mode
[   47.414796] mxl862xx mdio-bus:10 mxl_lan0: entered promiscuous mode
[   47.446742] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:0 setting VLAN:1 with vlan_filtering disabled
[   47.570614] mxl862xx mdio-bus:10 mxl_lan1: configuring for phy/internal link mode
[   47.596091] br-lan: port 5(mxl_lan1) entered blocking state
[   47.601675] br-lan: port 5(mxl_lan1) entered disabled state
[   47.607318] mxl862xx mdio-bus:10 mxl_lan1: entered allmulticast mode
[   47.830049] mxl862xx mdio-bus:10 mxl_lan1: entered promiscuous mode
[   47.855491] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:1 setting VLAN:1 with vlan_filtering disabled
[   47.970706] mxl862xx mdio-bus:10 mxl_lan2: configuring for phy/internal link mode
[   47.996124] br-lan: port 6(mxl_lan2) entered blocking state
[   48.001697] br-lan: port 6(mxl_lan2) entered disabled state
[   48.007298] mxl862xx mdio-bus:10 mxl_lan2: entered allmulticast mode
[   48.250530] mxl862xx mdio-bus:10 mxl_lan2: entered promiscuous mode
[   48.275991] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:2 setting VLAN:1 with vlan_filtering disabled
[   48.391111] mxl862xx mdio-bus:10 mxl_lan3: configuring for phy/internal link mode
[   48.416541] br-lan: port 7(mxl_lan3) entered blocking state
[   48.422113] br-lan: port 7(mxl_lan3) entered disabled state
[   48.427719] mxl862xx mdio-bus:10 mxl_lan3: entered allmulticast mode
[   48.689134] mxl862xx mdio-bus:10 mxl_lan3: entered promiscuous mode
[   48.714523] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:3 setting VLAN:1 with vlan_filtering disabled
[   48.792157] mxl862xx mdio-bus:10 mxl_lan5: configuring for inband/10gbase-r link mode
[   48.800491] sfp sfp1: SM: enter empty:down:down event dev_up
[   48.806160] sfp sfp1: SM: exit empty:up:down
[   48.815463] br-lan: port 8(mxl_lan5) entered blocking state
[   48.821044] br-lan: port 8(mxl_lan5) entered disabled state
[   48.826673] mxl862xx mdio-bus:10 mxl_lan5: entered allmulticast mode
[   49.185336] mxl862xx mdio-bus:10 mxl_lan5: entered promiscuous mode
[   49.210770] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:12 setting VLAN:1 with vlan_filtering disabled
[   49.313818] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: Firmware date code: 2024/10/30, version: 10.0
[   49.330764] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: Firmware loading/trigger ok.
[   49.339118] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:0f] driver [MediaTek MT7988 2.5GbE PHY] (irq=POLL)
[   49.349294] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/internal link mode
[   49.358584] br-wan: port 1(eth1) entered blocking state
[   49.363824] br-wan: port 1(eth1) entered disabled state
[   49.369101] mtk_soc_eth 15100000.ethernet eth1: entered allmulticast mode
[   49.376000] mtk_soc_eth 15100000.ethernet eth1: entered promiscuous mode
[   53.536196] Per-port-per-queue mode is going to be enabled !
[   53.541876] PPPQ use qid 3~14 (scheduler 0).
[   60.045593] mt7996e 0000:01:00.0: Platform_type = 2, bypass_rro = 1, txfree_path = 0
BusyBox v1.36.1 (2026-07-24 23:54:25 UTC) built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt 24.10-SNAPSHOT, unknown
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
root@OpenWrt:~#
Looks good so far…please show output of “ip a”
Have you tried putting posts manually up (ip link set lanX up) and assing an ip address (e.g. ip a a 192.168.0.19/24)? If the ports are bridged ip assignment must be done on the bridge
root@OpenWrt:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
    link/ether 6a:de:03:1e:11:98 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::68de:3ff:fe1e:1198/64 scope link
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq master br-wan state DOWN qlen 1000
    link/ether 0e:12:72:f2:2c:9e brd ff:ff:ff:ff:ff:ff
4: eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
    link/ether d2:72:0b:04:ef:a3 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::d072:bff:fe04:efa3/64 scope link
5: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
6: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
7: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
8: mxl_lan0@eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
9: mxl_lan1@eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
10: mxl_lan2@eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
11: mxl_lan3@eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
12: mxl_lan5@eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
13: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN qlen 1000
    link/gre 0.0.0.0 brd 0.0.0.0
14: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN qlen 1000
    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
15: erspan0@NONE: <BROADCAST,MULTICAST> mtu 1450 qdisc noop state DOWN qlen 1000
16: br-lan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
    inet 192.168.1.1/24 brd 192.168.1.255 scope global br-lan
    inet6 fd05:af69:dc21::1/60 scope global tentative noprefixroute
17: br-wan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
5: and 6: I’ve identified as the working 1G and combo 1/10/SFP ports, the state changes to up when I plug a cable in as expected. As for the rest, no change no matter which port.
I did not think to try ip link set lanX up before, I attempted it with everything and no change, no lights on the ports.
This is why I’m thinking it could be a hardware issue, the software seems to recognize that the ports are there and enabled but physically connecting a cable gets no response at all. I guess I’m just hoping against hope that I’m wrong and I forgot something stupid that’ll fix things.
Do not rely on leds…e.g. the as21 phy driver (not sure loaded here) has a bug breaking them
Try to set mxl_lan* and br-lan up give br-lan an ip address and try to ping a host in same subnet or at least look with ip a if port state goes up, currently it looks like you have bot connected a cable
Don’t rely on LEDs, got it.
That ip a was used when cables were only plugged into the 2.5G ports. I should have stated that, my bad. The lan bridge overall is working. Devices plugged into the 1G and 1/10G ports can see and ping each other just fine. Here is the output of ip a when three devices are plugged in, one to the 1G, 1/10G, and one of the 2.5G ports.
    link/ether d6:00:71:91:8a:e0 brd ff:ff:ff:ff:ff:ff
    link/ether b6:68:5c:51:c8:a2 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::b468:5cff:fe51:c8a2/64 scope link
5: lan0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
6: lan2@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
16: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
    inet6 fd05:af69:dc21::1/60 scope global noprefixroute
For the 1G and 1/10G ports, they can ping each other, I can ping them from the router, br_lan goes up, everything is as should be. But not the third one on the 2.5G port. It acts as if it’s unplugged. This is without using any other commands yet. After trying ip link up mxl_lanX for all of them, no change.
If I move all three devices to the 2.5G ports…
5: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state DOWN qlen 1000
6: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state DOWN qlen 1000
Nothing sees anything, no lights on the device end, br_lan automatically goes down, all devices act as if they’re unplugged. Manually trying to bring br_lan up results in it seeing nothing and it automatically bringing itself back down. Trying ip link up mxl_lanX up changes nothing. The output of ip a is the same, it’s like the 2.5G ports are recognized as present in software but are completely unresponsive on the hardware end.
Same here, the error light is always red despite everything working.
I’ve got the same board as you by the way so if you want to reach out, you can email me at [email protected] or ping me on Discord or something.
Please post output of
dmesg | grep -i mxl
After your ip link up and cable connections
Only eror i see above in log is this
But mtu is still 1500 so should be right
root@OpenWrt:~# dmesg | grep -i mxl
[    6.829274] mxl862xx mdio-bus:10:    Mxl862xx CPU Port 8, User Port number 5
[    6.846055] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: Firmware Version: 0.77 (0x004D test version)
[    6.884137] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: Firmware Version: 0.77 (0x004D test version)
[    6.922314] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: Firmware Version: 0.77 (0x004D test version)
[    6.960376] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: Firmware Version: 0.77 (0x004D test version)
[   11.251815] mxl862xx mdio-bus:10: mxl862xx_set_vlan_filter_limits: user_pnum:5, priv->max_vlans: 36, cpu_ingress_entries: 11, cpu_egress_entries: 74, user_ingress_entries: 77, user_egress_entries: 75
[   11.928719] mxl862xx mdio-bus:10: configuring for fixed/usxgmii link mode
[   11.935510] mxl862xx mdio-bus:10: Link is Up - 10Gbps/Full - flow control off
[   11.937742] mxl862xx mdio-bus:10 mxl_lan0 (uninitialized): PHY [mxl862xx_dsa-0:00] driver [MaxLinear Ethernet MxL862XX] (irq=POLL)
[   11.956660] mxl862xx mdio-bus:10 mxl_lan1 (uninitialized): PHY [mxl862xx_dsa-0:01] driver [MaxLinear Ethernet MxL862XX] (irq=POLL)
[   11.970613] mxl862xx mdio-bus:10 mxl_lan2 (uninitialized): PHY [mxl862xx_dsa-0:02] driver [MaxLinear Ethernet MxL862XX] (irq=POLL)
[   11.984591] mxl862xx mdio-bus:10 mxl_lan3 (uninitialized): PHY [mxl862xx_dsa-0:03] driver [MaxLinear Ethernet MxL862XX] (irq=POLL)
[   12.021293] mxl862xx mdio-bus:10: Firmware version 1.0.70.70
[   13.198214] mxl862xx: failed to write mmd on port 30
[   13.204465] mxl862xx: failed to write mmd on port 30
[   13.209422] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.219772] mxl862xx: failed to write mmd on port 30
[   13.225953] mxl862xx: failed to write mmd on port 30
[   13.230905] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.241253] mxl862xx: failed to write mmd on port 30
[   13.247436] mxl862xx: failed to write mmd on port 30
[   13.252387] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.262735] mxl862xx: failed to write mmd on port 30
[   13.268917] mxl862xx: failed to write mmd on port 30
[   13.273869] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.323989] mxl862xx: failed to write mmd on port 30
[   13.330171] mxl862xx: failed to write mmd on port 30
[   13.335125] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.345468] mxl862xx: failed to write mmd on port 30
[   13.381588] mxl862xx: failed to write mmd on port 30
[   13.386545] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.416367] mxl862xx: failed to write mmd on port 30
[   13.451609] mxl862xx: failed to write mmd on port 30
[   13.456563] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.486309] mxl862xx: failed to write mmd on port 30
[   13.521104] mxl862xx: failed to write mmd on port 30
[   13.526058] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.608310] mxl862xx: failed to write mmd on port 30
[   13.643476] mxl862xx: failed to write mmd on port 30
[   13.648431] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.661507] mxl862xx: failed to write mmd on port 30
[   13.667690] mxl862xx: failed to write mmd on port 30
[   13.672641] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.682987] mxl862xx: failed to write mmd on port 30
[   13.689168] mxl862xx: failed to write mmd on port 30
[   13.694119] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.704466] mxl862xx: failed to write mmd on port 30
[   13.710647] mxl862xx: failed to write mmd on port 30
[   13.715602] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.765617] mxl862xx: failed to write mmd on port 30
[   13.771794] mxl862xx: failed to write mmd on port 30
[   13.776749] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.787094] mxl862xx: failed to write mmd on port 30
[   13.793272] mxl862xx: failed to write mmd on port 30
[   13.798227] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.808573] mxl862xx: failed to write mmd on port 30
[   13.843741] mxl862xx: failed to write mmd on port 30
[   13.848696] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   13.878510] mxl862xx: failed to write mmd on port 30
[   13.913229] mxl862xx: failed to write mmd on port 30
[   13.918185] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.000289] mxl862xx: failed to write mmd on port 30
[   14.035022] mxl862xx: failed to write mmd on port 30
[   14.039974] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.070095] mxl862xx: failed to write mmd on port 30
[   14.104823] mxl862xx: failed to write mmd on port 30
[   14.109779] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.123001] mxl862xx: failed to write mmd on port 30
[   14.129183] mxl862xx: failed to write mmd on port 30
[   14.134134] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.144554] mxl862xx: failed to write mmd on port 30
[   14.150736] mxl862xx: failed to write mmd on port 30
[   14.155691] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.205631] mxl862xx: failed to write mmd on port 30
[   14.211809] mxl862xx: failed to write mmd on port 30
[   14.216764] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.227109] mxl862xx: failed to write mmd on port 30
[   14.233287] mxl862xx: failed to write mmd on port 30
[   14.238242] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.248661] mxl862xx: failed to write mmd on port 30
[   14.254839] mxl862xx: failed to write mmd on port 30
[   14.259790] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.270135] mxl862xx: failed to write mmd on port 30
[   14.304938] mxl862xx: failed to write mmd on port 30
[   14.309890] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.392082] mxl862xx: failed to write mmd on port 30
[   14.426807] mxl862xx: failed to write mmd on port 30
[   14.431759] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.461874] mxl862xx: failed to write mmd on port 30
[   14.496672] mxl862xx: failed to write mmd on port 30
[   14.501624] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.531446] mxl862xx: failed to write mmd on port 30
[   14.566692] mxl862xx: failed to write mmd on port 30
[   14.571644] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.584794] mxl862xx: failed to write mmd on port 30
[   14.590976] mxl862xx: failed to write mmd on port 30
[   14.595929] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.645871] mxl862xx: failed to write mmd on port 30
[   14.652049] mxl862xx: failed to write mmd on port 30
[   14.657004] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.667351] mxl862xx: failed to write mmd on port 30
[   14.673529] mxl862xx: failed to write mmd on port 30
[   14.678482] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.688829] mxl862xx: failed to write mmd on port 30
[   14.695008] mxl862xx: failed to write mmd on port 30
[   14.699959] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.710305] mxl862xx: failed to write mmd on port 30
[   14.716487] mxl862xx: failed to write mmd on port 30
[   14.721438] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.771453] mxl862xx: failed to write mmd on port 30
[   14.806260] mxl862xx: failed to write mmd on port 30
[   14.811212] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.841030] mxl862xx: failed to write mmd on port 30
[   14.876129] mxl862xx: failed to write mmd on port 30
[   14.881081] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.910906] mxl862xx: failed to write mmd on port 30
[   14.945639] mxl862xx: failed to write mmd on port 30
[   14.950591] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   14.980997] mxl862xx: failed to write mmd on port 30
[   15.015863] mxl862xx: failed to write mmd on port 30
[   15.020815] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.085957] mxl862xx: failed to write mmd on port 30
[   15.092135] mxl862xx: failed to write mmd on port 30
[   15.097089] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.107436] mxl862xx: failed to write mmd on port 30
[   15.113613] mxl862xx: failed to write mmd on port 30
[   15.118570] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.128917] mxl862xx: failed to write mmd on port 30
[   15.135095] mxl862xx: failed to write mmd on port 30
[   15.140046] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.150393] mxl862xx: failed to write mmd on port 30
[   15.156574] mxl862xx: failed to write mmd on port 30
[   15.161524] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.211469] mxl862xx: failed to write mmd on port 30
[   15.217724] mxl862xx: failed to write mmd on port 30
[   15.222675] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:00: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.233022] mxl862xx: failed to write mmd on port 30
[   15.267748] mxl862xx: failed to write mmd on port 30
[   15.272700] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:01: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.302824] mxl862xx: failed to write mmd on port 30
[   15.337632] mxl862xx: failed to write mmd on port 30
[   15.342583] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:02: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   15.372406] mxl862xx: failed to write mmd on port 30
[   15.407726] mxl862xx: failed to write mmd on port 30
[   15.412677] MaxLinear Ethernet MxL862XX mxl862xx_dsa-0:03: aeon_read_pid aeonsemi1 PHY = c133 - 5528
[   46.985216] mxl862xx mdio-bus:10 mxl_lan0: configuring for phy/internal link mode
[   47.010726] br-lan: port 4(mxl_lan0) entered blocking state
[   47.016315] br-lan: port 4(mxl_lan0) entered disabled state
[   47.021895] mxl862xx mdio-bus:10 mxl_lan0: entered allmulticast mode
[   47.267074] mxl862xx mdio-bus:10 mxl_lan0: entered promiscuous mode
[   47.298998] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:0 setting VLAN:1 with vlan_filtering disabled
[   47.421100] mxl862xx mdio-bus:10 mxl_lan1: configuring for phy/internal link mode
[   47.446507] br-lan: port 5(mxl_lan1) entered blocking state
[   47.452073] br-lan: port 5(mxl_lan1) entered disabled state
[   47.457668] mxl862xx mdio-bus:10 mxl_lan1: entered allmulticast mode
[   47.680751] mxl862xx mdio-bus:10 mxl_lan1: entered promiscuous mode
[   47.706228] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:1 setting VLAN:1 with vlan_filtering disabled
[   47.821841] mxl862xx mdio-bus:10 mxl_lan2: configuring for phy/internal link mode
[   47.847923] br-lan: port 6(mxl_lan2) entered blocking state
[   47.853514] br-lan: port 6(mxl_lan2) entered disabled state
[   47.859161] mxl862xx mdio-bus:10 mxl_lan2: entered allmulticast mode
[   48.103255] mxl862xx mdio-bus:10 mxl_lan2: entered promiscuous mode
[   48.128625] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:2 setting VLAN:1 with vlan_filtering disabled
[   48.244271] mxl862xx mdio-bus:10 mxl_lan3: configuring for phy/internal link mode
[   48.269809] br-lan: port 7(mxl_lan3) entered blocking state
[   48.275387] br-lan: port 7(mxl_lan3) entered disabled state
[   48.280981] mxl862xx mdio-bus:10 mxl_lan3: entered allmulticast mode
[   48.542326] mxl862xx mdio-bus:10 mxl_lan3: entered promiscuous mode
[   48.567565] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:3 setting VLAN:1 with vlan_filtering disabled
[   48.645435] mxl862xx mdio-bus:10 mxl_lan5: configuring for inband/10gbase-r link mode
[   48.668827] br-lan: port 8(mxl_lan5) entered blocking state
[   48.674406] br-lan: port 8(mxl_lan5) entered disabled state
[   48.680012] mxl862xx mdio-bus:10 mxl_lan5: entered allmulticast mode
[   49.033109] mxl862xx mdio-bus:10 mxl_lan5: entered promiscuous mode
[   49.058504] mxl862xx mdio-bus:10: mxl862xx_port_vlan_add: port:12 setting VLAN:1 with vlan_filtering disabled
After ip link set mxl_lanX up for 0,1,2,3,5 and cable connections.
And just to throw stuff at the wall
root@OpenWrt:~# dmesg | grep -i eth2
[    6.548903] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc082b00000, irq 110
[   11.996901] eth2: mtu greater than device maximum
[   12.001601] mtk_soc_eth 15100000.ethernet eth2: error -22 setting MTU to 1504 to include DSA overhead
[   12.010813] mtk_soc_eth 15100000.ethernet eth2: entered promiscuous mode
[   46.907707] mtk_soc_eth 15100000.ethernet eth2: configuring for fixed/10gbase-r link mode
[   46.959490] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 10Gbps/Full - flow control rx/tx
[   47.028245] mtk_soc_eth 15100000.ethernet eth2: entered allmulticast mode
I did figure out that the firmware flash I thought I did didn’t take though, so I put a fresh image on a new SD card. No CRC errors this time so looks like the card I was using before was bad. I reran everything in this thread while running off the SD card using the firmware from the docs and no change. I also did manage to get your image (r34425-3de501d56da4 from Jul 4) to work this time and it doesn’t even see the mxl_lan ports. ip a doesn’t have them listed, dmesg | grep -i mxl returns nothing. Other ports still seemed to work, connection refused when I tried to access luci. Dunno if that’s expected behavior or not.
In the end I didn’t reflash the emmc, it’s the same as it was before.
And also, thanks for your time trying to help. I might be a bit of a noob in over my head, but even if the problems persist I feel like I’m learning stuff just by guided poking at things.
my older image had an dts error for 4e variant. have not yet updated my 4e openwrt tree as i still have issues getting the mxl switch on my board working (ports visible, but no traffic, seems to be firmware-related so i have to fist update it)
Hi Frank, thanks again for all your time and work. I was checking your wiki last week and there it was mention the MXL switch is working. Then I went to your tree and there we have R4Pro_newmxl 1 till 4. So I was a bit confused.
Then I tried the U-boot releases but that didnt seem to be what I needed either. After I tried rmandrad github but did not work in the end either. Lastly I tried some files from a google drive you posted. That booted but the 2.5 gb/s ports are not working. So I went back to the current working image from the banana docs.
According to the AI these ports where not even visible in the CLI. Checking the forums I can see this “switch” is still a problem sadly. Previously I misunderstood switch the 10gbe RJ45 / SFP. At least now I understand what is missing :slight_smile:
I will give it another try next month. Let me know if I can help you with my logs?
Last trees are the PR trees,but they only support the 8x variant.afaik 4e is broken. I have to get 4e working first in non-openwrt code before porting necessary patches for openwrt. Currently i have issues with new firmware/driver and lan1
ok, fixed the lan1 issue with a patch from @Leth, but i have not yet traffic over serdes…something is still wrong
Edit: this throughput issue seems to affect only the 4e variant…my 8x board works with same kernel binary with traffic
