[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 6.6.63 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 r28161-ea17e958b9) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Tue Dec 3 11:41:08 2024
[ 0.000000] Machine model: Bananapi BPI-R4 2.5GE PoE
[ 0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[ 0.000000] OF: reserved mem: 0x0000000043000000..0x000000004304ffff (320 KiB) nomap non-reusable secmon@43000000
[ 0.000000] OF: reserved mem: 0x0000000047cc0000..0x0000000047dbffff (1024 KiB) nomap non-reusable wmcpu-reserved@47cc0000
[ 0.000000] OF: reserved mem: 0x000000004f600000..0x000000004f63ffff (256 KiB) nomap non-reusable wo-emi@4f600000
[ 0.000000] OF: reserved mem: 0x000000004f640000..0x000000004f67ffff (256 KiB) nomap non-reusable wo-emi@4f640000
[ 0.000000] OF: reserved mem: 0x000000004f680000..0x000000004f6bffff (256 KiB) nomap non-reusable wo-emi@4f680000
[ 0.000000] OF: reserved mem: 0x000000004f700000..0x000000004fefffff (8192 KiB) nomap non-reusable wo-data@4f700000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004304ffff]
[ 0.000000] node 0: [mem 0x0000000043050000-0x0000000047cbffff]
[ 0.000000] node 0: [mem 0x0000000047cc0000-0x0000000047dbffff]
[ 0.000000] node 0: [mem 0x0000000047dc0000-0x000000004f5fffff]
[ 0.000000] node 0: [mem 0x000000004f600000-0x000000004f6bffff]
[ 0.000000] node 0: [mem 0x000000004f6c0000-0x000000004f6fffff]
[ 0.000000] node 0: [mem 0x000000004f700000-0x000000004fefffff]
[ 0.000000] node 0: [mem 0x000000004ff00000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 18 pages/cpu s35560 r8192 d29976 u73728
[ 0.000000] pcpu-alloc: s35560 r8192 d29976 u73728 alloc=18*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fa7df000-0x00000000fe7df000] (64MB)
[ 0.000000] Memory: 4024568K/4194304K available (9024K kernel code, 996K rwdata, 1664K rodata, 448K init, 307K bss, 169736K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: 0xffffffc080010080
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000001] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000064] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000071] pid_max: default: 32768 minimum: 301
[ 0.002146] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002160] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.003644] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.003929] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.004010] rcu: Hierarchical SRCU implementation.
[ 0.004012] rcu: Max phase no-delay instances is 1000.
[ 0.004305] smp: Bringing up secondary CPUs ...
[ 0.004521] Detected VIPT I-cache on CPU1
[ 0.004557] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.004580] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[ 0.004829] Detected VIPT I-cache on CPU2
[ 0.004849] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.004858] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[ 0.005085] Detected VIPT I-cache on CPU3
[ 0.005105] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.005115] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[ 0.005143] smp: Brought up 1 node, 4 CPUs
[ 0.005148] SMP: Total of 4 processors activated.
[ 0.005150] CPU features: detected: 32-bit EL0 Support
[ 0.005152] CPU features: detected: CRC32 instructions
[ 0.005170] spectre-bhb mitigation disabled by compile time option
[ 0.005183] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.005187] CPU: All CPU(s) started at EL2
[ 0.005188] alternatives: applying system-wide alternatives
[ 0.008692] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008703] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.009644] pinctrl core: initialized pinctrl subsystem
[ 0.010500] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.010797] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.010898] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.010992] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.011273] thermal_sys: Registered thermal governor 'fair_share'
[ 0.011275] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.011278] thermal_sys: Registered thermal governor 'step_wise'
[ 0.011280] thermal_sys: Registered thermal governor 'user_space'
[ 0.011327] ASID allocator initialised with 65536 entries
[ 0.012015] pstore: Using crash dump compression: deflate
[ 0.012021] printk: console [ramoops-1] enabled
[ 0.012249] pstore: Registered ramoops as persistent store backend
[ 0.012254] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.019613] Modules: 29616 pages in range for non-PLT usage
[ 0.019621] Modules: 521136 pages in range for PLT usage
[ 0.020419] cryptd: max_cpu_qlen set to 1000
[ 0.021229] SCSI subsystem initialized
[ 0.021295] libata version 3.00 loaded.
[ 0.022179] clocksource: Switched to clocksource arch_sys_counter
[ 0.023824] NET: Registered PF_INET protocol family
[ 0.023960] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.026539] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.026562] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.026572] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.026672] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.027082] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.027412] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.027540] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.027591] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.027901] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.027934] PCI: CLS 0 bytes, default 64
[ 0.028869] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.032563] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.032569] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.053294] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.054268] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[ 0.054854] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.054876] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.054887] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 0.054899] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 0.054991] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 0.055001] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 0.055011] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 0.055020] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 0.055038] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[ 0.055046] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[ 0.055109] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 0.055120] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 0.055129] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 0.055138] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 0.055155] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[ 0.055162] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[ 0.055234] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 0.055244] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 0.055253] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 0.055262] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 0.055278] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[ 0.055285] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[ 0.059782] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.061899] printk: console [ttyS0] disabled
[ 0.082209] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[ 0.082246] printk: console [ttyS0] enabled
[ 1.096893] 11000100.serial: ttyS1 at MMIO 0x11000100 (irq = 100, base_baud = 2500000) is a ST16650V2
[ 1.126751] 11000200.serial: ttyS2 at MMIO 0x11000200 (irq = 101, base_baud = 2500000) is a ST16650V2
[ 1.138669] loop: module loaded
[ 1.143236] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.148555] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 1.156820] 2 fixed-partitions partitions found on MTD device spi0.0
[ 1.163191] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.170062] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.177145] Creating 2 MTD partitions on "spi0.0":
[ 1.181931] 0x000000000000-0x000000200000 : "bl2"
[ 1.188278] 0x000000200000-0x000008000000 : "ubi"
[ 1.265949] ubi0: default fastmap pool size: 50
[ 1.270481] ubi0: default fastmap WL pool size: 25
[ 1.275267] ubi0: attaching mtd1
[ 2.095624] ubi0: scanning is finished
[ 2.109267] ubi0: attached mtd1 (name "ubi", size 126 MiB)
[ 2.114765] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.121628] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.128406] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.135356] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
[ 2.141435] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
[ 2.148645] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[ 2.156983] ubi0: available PEBs: 0, total reserved PEBs: 1008, PEBs reserved for bad PEB handling: 20
[ 2.166282] ubi0: background thread "ubi_bgt0d" started, PID 314
[ 2.166365] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 2.179231] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 2.186856] block ubiblock0_4: created from ubi0:4(fit)
[ 2.323737] i2c_dev: i2c /dev entries driver
[ 2.331194] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 2.339284] mtk-cpufreq mtk-cpufreq: failed to initialize dvfs info for cpu0
[ 2.347022] NET: Registered PF_INET6 protocol family
[ 2.352444] Segment Routing with IPv6
[ 2.356123] In-situ OAM (IOAM) with IPv6
[ 2.360065] NET: Registered PF_PACKET protocol family
[ 2.365143] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.378175] 8021q: 802.1Q VLAN Support v1.8
[ 2.395093] phy phy-soc:[email protected]: type_sw - reg 0x218, index 0
[ 2.402275] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 2.409591] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 2.415862] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 2.424311] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 2.440509] mtk-msdc 11230000.mmc: Final PAD_DS_TUNE: 0x13414
[ 2.446383] mmc0: new HS400 MMC card at address 0001
[ 2.451948] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 2.457868] mmcblk0: p1 p2 p3 p4 p5 p128
[ 2.462768] mmcblk0boot0: mmc0:0001 8GTF4R 4.00 MiB
[ 2.468244] mmcblk0boot1: mmc0:0001 8GTF4R 4.00 MiB
[ 2.473359] mmcblk0rpmb: mmc0:0001 8GTF4R 512 KiB, chardev (248:0)
[ 2.782193] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 2.790993] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 2.798040] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 2.805357] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 2.811620] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 2.820054] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 3.162210] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 3.170991] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[ 3.177859] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 3.185169] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 3.191428] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 3.199863] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 3.448200] mtk-pcie-gen3 11300000.pcie: set IO trans window[0]: cpu_addr = 0x30000000, pci_addr = 0x30000000, size = 0x200000
[ 3.459581] mtk-pcie-gen3 11300000.pcie: set MEM trans window[1]: cpu_addr = 0x30200000, pci_addr = 0x30200000, size = 0x200000
[ 3.471045] mtk-pcie-gen3 11300000.pcie: set MEM trans window[2]: cpu_addr = 0x30400000, pci_addr = 0x30400000, size = 0x400000
[ 3.482509] mtk-pcie-gen3 11300000.pcie: set MEM trans window[3]: cpu_addr = 0x30800000, pci_addr = 0x30800000, size = 0x800000
[ 3.493971] mtk-pcie-gen3 11300000.pcie: set MEM trans window[4]: cpu_addr = 0x31000000, pci_addr = 0x31000000, size = 0x1000000
[ 3.505520] mtk-pcie-gen3 11300000.pcie: set MEM trans window[5]: cpu_addr = 0x32000000, pci_addr = 0x32000000, size = 0x2000000
[ 3.517069] mtk-pcie-gen3 11300000.pcie: set MEM trans window[6]: cpu_addr = 0x34000000, pci_addr = 0x34000000, size = 0x4000000
[ 3.528853] mtk-pcie-gen3 11300000.pcie: PCI host bridge to bus 0000:00
[ 3.535463] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.540940] pci_bus 0000:00: root bus resource [io 0x400000-0x5fffff] (bus address [0x30000000-0x301fffff])
[ 3.550755] pci_bus 0000:00: root bus resource [mem 0x30200000-0x37ffffff]
[ 3.557619] pci_bus 0000:00: scanning bus
[ 3.561637] pci 0000:00:00.0: [14c3:7988] type 01 class 0x060400
[ 3.567649] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 3.574488] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.580572] pci 0000:00:00.0: PME# disabled
[ 3.586021] pci_bus 0000:00: fixups for bus
[ 3.590195] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 3.596889] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.604887] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 3.611625] pci_bus 0000:01: scanning bus
[ 3.615647] pci 0000:01:00.0: [14c3:7990] type 00 class 0x028000
[ 3.621662] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit pref]
[ 3.628888] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[ 3.635772] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 3.641856] pci 0000:01:00.0: PME# disabled
[ 3.672212] pci_bus 0000:01: fixups for bus
[ 3.676385] pci_bus 0000:01: bus scan returning with max=01
[ 3.681945] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.688555] pci_bus 0000:00: bus scan returning with max=01
[ 3.694131] pci 0000:00:00.0: BAR 9: assigned [mem 0x30200000-0x303fffff 64bit pref]
[ 3.701863] pci 0000:00:00.0: BAR 8: assigned [mem 0x30400000-0x304fffff]
[ 3.708641] pci 0000:00:00.0: BAR 0: assigned [mem 0x30500000-0x30507fff 64bit]
[ 3.715946] pci 0000:01:00.0: BAR 0: assigned [mem 0x30200000-0x303fffff 64bit pref]
[ 3.723687] pci 0000:01:00.0: BAR 2: assigned [mem 0x30400000-0x30407fff 64bit]
[ 3.730992] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.735950] pci 0000:00:00.0: bridge window [mem 0x30400000-0x304fffff]
[ 3.742728] pci 0000:00:00.0: bridge window [mem 0x30200000-0x303fffff 64bit pref]
[ 3.750467] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.758908] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.767407] pcieport 0000:00:00.0: assign IRQ: got 115
[ 3.772544] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 3.778634] pcieport 0000:00:00.0: enabling bus mastering
[ 3.784394] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[ 3.792832] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[ 3.801258] mtk-pcie-gen3 11300000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11300c00 data 2
[ 3.809684] mtk-pcie-gen3 11300000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11300c00 data 3
[ 3.818110] mtk-pcie-gen3 11300000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11300c00 data 4
[ 3.826536] mtk-pcie-gen3 11300000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11300c00 data 5
[ 3.834961] mtk-pcie-gen3 11300000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11300c00 data 6
[ 3.843387] mtk-pcie-gen3 11300000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11300c00 data 7
[ 3.851810] mtk-pcie-gen3 11300000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11300c00 data 8
[ 3.860236] mtk-pcie-gen3 11300000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11300c00 data 9
[ 3.868661] mtk-pcie-gen3 11300000.pcie: msi#0xa address_hi 0x0 address_lo 0x11300c00 data 10
[ 3.877173] mtk-pcie-gen3 11300000.pcie: msi#0xb address_hi 0x0 address_lo 0x11300c00 data 11
[ 3.885685] mtk-pcie-gen3 11300000.pcie: msi#0xc address_hi 0x0 address_lo 0x11300c00 data 12
[ 3.894198] mtk-pcie-gen3 11300000.pcie: msi#0xd address_hi 0x0 address_lo 0x11300c00 data 13
[ 3.902709] mtk-pcie-gen3 11300000.pcie: msi#0xe address_hi 0x0 address_lo 0x11300c00 data 14
[ 3.911220] mtk-pcie-gen3 11300000.pcie: msi#0xf address_hi 0x0 address_lo 0x11300c00 data 15
[ 3.919733] mtk-pcie-gen3 11300000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11300c00 data 16
[ 3.928333] mtk-pcie-gen3 11300000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11300c00 data 17
[ 3.936933] mtk-pcie-gen3 11300000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11300c00 data 18
[ 3.945532] mtk-pcie-gen3 11300000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11300c00 data 19
[ 3.954130] mtk-pcie-gen3 11300000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11300c00 data 20
[ 3.962728] mtk-pcie-gen3 11300000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11300c00 data 21
[ 3.971325] mtk-pcie-gen3 11300000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11300c00 data 22
[ 3.979923] mtk-pcie-gen3 11300000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11300c00 data 23
[ 3.988522] mtk-pcie-gen3 11300000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11300c00 data 24
[ 3.997125] mtk-pcie-gen3 11300000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11300c00 data 25
[ 4.005725] mtk-pcie-gen3 11300000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11300c00 data 26
[ 4.014324] mtk-pcie-gen3 11300000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11300c00 data 27
[ 4.022923] mtk-pcie-gen3 11300000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11300c00 data 28
[ 4.031520] mtk-pcie-gen3 11300000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11300c00 data 29
[ 4.040122] mtk-pcie-gen3 11300000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11300c00 data 30
[ 4.048721] mtk-pcie-gen3 11300000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11300c00 data 31
[ 4.057744] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[ 4.066244] pcieport 0000:00:00.0: PME: Signaling with IRQ 116
[ 4.072186] pcieport 0000:00:00.0: AER: enabled with IRQ 116
[ 4.077878] pcieport 0000:00:00.0: save config 0x00: 0x798814c3
[ 4.083813] pcieport 0000:00:00.0: save config 0x04: 0x00100406
[ 4.089722] pcieport 0000:00:00.0: save config 0x08: 0x06040001
[ 4.095639] pcieport 0000:00:00.0: save config 0x0c: 0x00010000
[ 4.101546] pcieport 0000:00:00.0: save config 0x10: 0x30500004
[ 4.107456] pcieport 0000:00:00.0: save config 0x14: 0x00000000
[ 4.113365] pcieport 0000:00:00.0: save config 0x18: 0x00010100
[ 4.119272] pcieport 0000:00:00.0: save config 0x1c: 0x000001f1
[ 4.125184] pcieport 0000:00:00.0: save config 0x20: 0x30403040
[ 4.131091] pcieport 0000:00:00.0: save config 0x24: 0x30313021
[ 4.137000] pcieport 0000:00:00.0: save config 0x28: 0x00000000
[ 4.142909] pcieport 0000:00:00.0: save config 0x2c: 0x00000000
[ 4.148816] pcieport 0000:00:00.0: save config 0x30: 0x00000000
[ 4.154726] pcieport 0000:00:00.0: save config 0x34: 0x00000080
[ 4.160633] pcieport 0000:00:00.0: save config 0x38: 0x00000000
[ 4.166542] pcieport 0000:00:00.0: save config 0x3c: 0x00020173
[ 4.172786] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 4.180090] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 4.186359] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 4.194792] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 4.445089] mtk-pcie-gen3 11310000.pcie: set IO trans window[0]: cpu_addr = 0x38000000, pci_addr = 0x38000000, size = 0x200000
[ 4.456473] mtk-pcie-gen3 11310000.pcie: set MEM trans window[1]: cpu_addr = 0x38200000, pci_addr = 0x38200000, size = 0x200000
[ 4.467937] mtk-pcie-gen3 11310000.pcie: set MEM trans window[2]: cpu_addr = 0x38400000, pci_addr = 0x38400000, size = 0x400000
[ 4.479400] mtk-pcie-gen3 11310000.pcie: set MEM trans window[3]: cpu_addr = 0x38800000, pci_addr = 0x38800000, size = 0x800000
[ 4.490862] mtk-pcie-gen3 11310000.pcie: set MEM trans window[4]: cpu_addr = 0x39000000, pci_addr = 0x39000000, size = 0x1000000
[ 4.502412] mtk-pcie-gen3 11310000.pcie: set MEM trans window[5]: cpu_addr = 0x3a000000, pci_addr = 0x3a000000, size = 0x2000000
[ 4.513960] mtk-pcie-gen3 11310000.pcie: set MEM trans window[6]: cpu_addr = 0x3c000000, pci_addr = 0x3c000000, size = 0x4000000
[ 4.525631] mtk-pcie-gen3 11310000.pcie: PCI host bridge to bus 0001:00
[ 4.532241] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 4.537718] pci_bus 0001:00: root bus resource [io 0x600000-0x7fffff] (bus address [0x38000000-0x381fffff])
[ 4.547533] pci_bus 0001:00: root bus resource [mem 0x38200000-0x3fffffff]
[ 4.554398] pci_bus 0001:00: scanning bus
[ 4.558413] pci 0001:00:00.0: [14c3:7988] type 01 class 0x060400
[ 4.564425] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 4.571260] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.577345] pci 0001:00:00.0: PME# disabled
[ 4.582828] pci_bus 0001:00: fixups for bus
[ 4.587003] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 4.593695] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.601690] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 4.608436] pci_bus 0001:01: scanning bus
[ 4.612462] pci 0001:01:00.0: [14c3:7991] type 00 class 0x028000
[ 4.618478] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit pref]
[ 4.625703] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[ 4.632589] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[ 4.638673] pci 0001:01:00.0: PME# disabled
[ 4.672211] pci_bus 0001:01: fixups for bus
[ 4.676384] pci_bus 0001:01: bus scan returning with max=01
[ 4.681944] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.688554] pci_bus 0001:00: bus scan returning with max=01
[ 4.694129] pci 0001:00:00.0: BAR 9: assigned [mem 0x38200000-0x383fffff 64bit pref]
[ 4.701860] pci 0001:00:00.0: BAR 8: assigned [mem 0x38400000-0x384fffff]
[ 4.708639] pci 0001:00:00.0: BAR 0: assigned [mem 0x38500000-0x38507fff 64bit]
[ 4.715945] pci 0001:01:00.0: BAR 0: assigned [mem 0x38200000-0x383fffff 64bit pref]
[ 4.723686] pci 0001:01:00.0: BAR 2: assigned [mem 0x38400000-0x38407fff 64bit]
[ 4.730992] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 4.735949] pci 0001:00:00.0: bridge window [mem 0x38400000-0x384fffff]
[ 4.742727] pci 0001:00:00.0: bridge window [mem 0x38200000-0x383fffff 64bit pref]
[ 4.750466] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 4.758907] pci 0001:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 4.767419] pcieport 0001:00:00.0: assign IRQ: got 118
[ 4.772556] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[ 4.778646] pcieport 0001:00:00.0: enabling bus mastering
[ 4.784396] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 4.792835] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 4.801259] mtk-pcie-gen3 11310000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11310c00 data 2
[ 4.809686] mtk-pcie-gen3 11310000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11310c00 data 3
[ 4.818111] mtk-pcie-gen3 11310000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11310c00 data 4
[ 4.826537] mtk-pcie-gen3 11310000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11310c00 data 5
[ 4.834962] mtk-pcie-gen3 11310000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11310c00 data 6
[ 4.843388] mtk-pcie-gen3 11310000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11310c00 data 7
[ 4.851811] mtk-pcie-gen3 11310000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11310c00 data 8
[ 4.860236] mtk-pcie-gen3 11310000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11310c00 data 9
[ 4.868661] mtk-pcie-gen3 11310000.pcie: msi#0xa address_hi 0x0 address_lo 0x11310c00 data 10
[ 4.877174] mtk-pcie-gen3 11310000.pcie: msi#0xb address_hi 0x0 address_lo 0x11310c00 data 11
[ 4.885686] mtk-pcie-gen3 11310000.pcie: msi#0xc address_hi 0x0 address_lo 0x11310c00 data 12
[ 4.894199] mtk-pcie-gen3 11310000.pcie: msi#0xd address_hi 0x0 address_lo 0x11310c00 data 13
[ 4.902711] mtk-pcie-gen3 11310000.pcie: msi#0xe address_hi 0x0 address_lo 0x11310c00 data 14
[ 4.911221] mtk-pcie-gen3 11310000.pcie: msi#0xf address_hi 0x0 address_lo 0x11310c00 data 15
[ 4.919736] mtk-pcie-gen3 11310000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11310c00 data 16
[ 4.928335] mtk-pcie-gen3 11310000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11310c00 data 17
[ 4.936934] mtk-pcie-gen3 11310000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11310c00 data 18
[ 4.945532] mtk-pcie-gen3 11310000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11310c00 data 19
[ 4.954136] mtk-pcie-gen3 11310000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11310c00 data 20
[ 4.962736] mtk-pcie-gen3 11310000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11310c00 data 21
[ 4.971333] mtk-pcie-gen3 11310000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11310c00 data 22
[ 4.979933] mtk-pcie-gen3 11310000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11310c00 data 23
[ 4.988533] mtk-pcie-gen3 11310000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11310c00 data 24
[ 4.997132] mtk-pcie-gen3 11310000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11310c00 data 25
[ 5.005730] mtk-pcie-gen3 11310000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11310c00 data 26
[ 5.014329] mtk-pcie-gen3 11310000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11310c00 data 27
[ 5.022928] mtk-pcie-gen3 11310000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11310c00 data 28
[ 5.031525] mtk-pcie-gen3 11310000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11310c00 data 29
[ 5.040126] mtk-pcie-gen3 11310000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11310c00 data 30
[ 5.048725] mtk-pcie-gen3 11310000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11310c00 data 31
[ 5.057775] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 5.066277] pcieport 0001:00:00.0: PME: Signaling with IRQ 119
[ 5.072241] pcieport 0001:00:00.0: AER: enabled with IRQ 119
[ 5.077929] pcieport 0001:00:00.0: save config 0x00: 0x798814c3
[ 5.083846] pcieport 0001:00:00.0: save config 0x04: 0x00100406
[ 5.089755] pcieport 0001:00:00.0: save config 0x08: 0x06040001
[ 5.095667] pcieport 0001:00:00.0: save config 0x0c: 0x00010000
[ 5.101574] pcieport 0001:00:00.0: save config 0x10: 0x38500004
[ 5.107485] pcieport 0001:00:00.0: save config 0x14: 0x00000000
[ 5.113395] pcieport 0001:00:00.0: save config 0x18: 0x00010100
[ 5.119302] pcieport 0001:00:00.0: save config 0x1c: 0x000001f1
[ 5.125211] pcieport 0001:00:00.0: save config 0x20: 0x38403840
[ 5.131118] pcieport 0001:00:00.0: save config 0x24: 0x38313821
[ 5.137028] pcieport 0001:00:00.0: save config 0x28: 0x00000000
[ 5.142937] pcieport 0001:00:00.0: save config 0x2c: 0x00000000
[ 5.148844] pcieport 0001:00:00.0: save config 0x30: 0x00000000
[ 5.154753] pcieport 0001:00:00.0: save config 0x34: 0x00000080
[ 5.160660] pcieport 0001:00:00.0: save config 0x38: 0x00000000
[ 5.166570] pcieport 0001:00:00.0: save config 0x3c: 0x00020176
[ 5.173573] FIT: Detected U-Boot 2024.10-OpenWrt-r28228-207bfee855
[ 5.179745] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4-poe" (OpenWrt bananapi_bpi-r4-poe)
[ 5.189486] FIT: kernel sub-image 0x00001000..0x0055d00f "kernel-1" (ARM64 OpenWrt Linux-6.6.63)
[ 5.199261] FIT: flat_dt sub-image 0x0055e000..0x005698f8 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r4-poe device tree blob)
[ 5.210825] FIT: flat_dt sub-image 0x0056a000..0x0056a609 "fdt-mt7988a-bananapi-bpi-r4-emmc" (ARM64 OpenWrt bananapi_bpi-r4-poe device tree overlay mt7988a-bananapi-bpi-r4-emmc)
[ 5.227505] FIT: flat_dt sub-image 0x0056b000..0x0056b11c "fdt-mt7988a-bananapi-bpi-r4-rtc" (ARM64 OpenWrt bananapi_bpi-r4-poe device tree overlay mt7988a-bananapi-bpi-r4-rtc)
[ 5.244012] FIT: flat_dt sub-image 0x0056c000..0x0056c5c1 "fdt-mt7988a-bananapi-bpi-r4-sd" (ARM64 OpenWrt bananapi_bpi-r4-poe device tree overlay mt7988a-bananapi-bpi-r4-sd)
[ 5.260346] FIT: flat_dt sub-image 0x0056d000..0x0056d8f0 "fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a" (ARM64 OpenWrt bananapi_bpi-r4-poe device tree overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a)
[ 5.278412] FIT: filesystem sub-image 0x0056e000..0x0102dfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r4-poe rootfs)
[ 5.289610] block mmcblk0p5: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[ 5.297359] block mmcblk0p5: mapped remaining space as /dev/fitrw
[ 5.433643] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[ 5.446233] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082980000, irq 106
[ 5.455936] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082980000, irq 106
[ 5.465618] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc082980000, irq 106
[ 5.562424] mt7530-mmio 15020000.switch: configuring for fixed/internal link mode
[ 5.569924] mt7530-mmio 15020000.switch: Link is Up - 10Gbps/Full - flow control rx/tx
[ 5.596709] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=121)
[ 5.634456] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7988 PHY] (irq=122)
[ 5.672769] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=123)
[ 5.711092] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=124)
[ 5.722091] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[ 5.728805] DSA: tree 0 setup
[ 5.732025] clk: Disabling unused clocks
[ 5.738507] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
[ 5.745740] Freeing unused kernel memory: 448K
[ 5.750211] Run /sbin/init as init process
[ 5.754299] with arguments:
[ 5.757255] /sbin/init
[ 5.759951] with environment:
[ 5.763083] HOME=/
[ 5.765432] TERM=linux
[ 5.870477] init: Console is alive
[ 5.873984] init: - watchdog -
[ 6.101611] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 6.122233] usbcore: registered new interface driver usbfs
[ 6.127744] usbcore: registered new interface driver hub
[ 6.133082] usbcore: registered new device driver usb
[ 6.138618] gpio_button_hotplug: loading out-of-tree module taints kernel.
[ 6.148396] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 6.155797] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 6.163697] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.168924] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 6.179439] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[ 6.188597] xhci-mtk 11200000.usb: irq 125, io mem 0x11200000
[ 6.194439] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.199656] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 6.207044] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 6.214364] hub 1-0:1.0: USB hub found
[ 6.218123] hub 1-0:1.0: 1 port detected
[ 6.222232] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.230498] hub 2-0:1.0: USB hub found
[ 6.234275] hub 2-0:1.0: 1 port detected
[ 6.240465] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.250593] init: - preinit -
[ 6.430564] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 6.438748] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 6.622187] random: crng init done
[ 6.672182] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 6.854846] hub 1-1:1.0: USB hub found
[ 6.858762] hub 1-1:1.0: 5 ports detected
[ 7.002315] usb 2-1: new SuperSpeed USB device number 2 using xhci-mtk
[ 7.034759] hub 2-1:1.0: USB hub found
[ 7.038704] hub 2-1:1.0: 4 ports detected
[ 7.314590] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 7.562183] usb 1-1.5: new high-speed USB device number 3 using xhci-mtk
[ 7.792205] usb 2-1.4: new SuperSpeed USB device number 3 using xhci-mtk
[ 11.592927] F2FS-fs (fitrw): Mounted with checkpoint version = 65c2bf5c
[ 11.600701] mount_root: loading kmods from internal overlay
[ 11.612043] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 11.624589] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[ 11.631084] scsi host0: usb-storage 2-1.4:1.0
[ 11.635661] usbcore: registered new interface driver usb-storage
[ 11.642397] usbcore: registered new interface driver uas
[ 11.647816] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 12.043349] block: attempting to load /tmp/overlay/upper/etc/config/fstab
[ 12.050695] block: extroot: not configured
[ 12.057433] UBIFS (ubi0:6): Mounting in unauthenticated mode
[ 12.063149] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 1043
[ 12.163085] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "rootfs_data"
[ 12.170909] UBIFS (ubi0:6): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 12.180817] UBIFS (ubi0:6): FS size: 74788864 bytes (71 MiB, 589 LEBs), max 599 LEBs, journal size 3682304 bytes (3 MiB, 29 LEBs)
[ 12.192457] UBIFS (ubi0:6): reserved for root: 3532462 bytes (3449 KiB)
[ 12.199058] UBIFS (ubi0:6): media format: w5/r0 (latest is w5/r0), UUID F380131A-B5AE-4865-B088-BC31A1D787D9, small LPT model
[ 12.212151] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 12.224144] block: unable to load configuration (fstab: Entry not found)
[ 12.230891] block: attempting to load /tmp/ubifs_cfg/etc/config/fstab
[ 12.237399] block: unable to load configuration (fstab: Entry not found)
[ 12.244136] block: attempting to load /etc/config/fstab
[ 12.250122] block: unable to load configuration (fstab: Entry not found)
[ 12.256851] block: no usable configuration
[ 12.264709] UBIFS (ubi0:6): un-mount UBI device 0
[ 12.269415] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" stops
[ 12.278102] mount_root: switching to f2fs overlay
[ 12.283639] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 12.294704] urandom-seed: Seeding with /etc/urandom.seed
[ 12.320203] procd: - early -
[ 12.323148] procd: - watchdog -
[ 12.712741] scsi 0:0:0:0: Direct-Access PQ: 0 ANSI: 6
[ 12.721889] sd 0:0:0:0: [sda] 247398400 512-byte logical blocks: (127 GB/118 GiB)
[ 12.729670] sd 0:0:0:0: [sda] Write Protect is off
[ 12.734459] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 12.739646] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 12.758267] sda: sda1 sda2
[ 12.761316] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 13.261525] procd: - watchdog -
[ 13.265242] procd: - ubus -
[ 13.418315] procd: - init -
[ 13.625267] kmodloader: loading kernel modules from /etc/modules.d/*
[ 13.647679] pca954x 1-0070: supply vdd not found, using dummy regulator
[ 13.654962] i2c i2c-1: Added multiplexed i2c bus 2
[ 13.659857] i2c i2c-1: Added multiplexed i2c bus 3
[ 13.664753] i2c i2c-1: Added multiplexed i2c bus 4
[ 13.669632] i2c i2c-1: Added multiplexed i2c bus 5
[ 13.674442] pca954x 1-0070: registered 4 multiplexed busses for I2C switch pca9545
[ 13.675320] urngd: v1.0.2 started.
[ 13.687592] crypto-safexcel 15600000.crypto: can't request region for resource [mem 0x15600000-0x1577ffff]
[ 13.697286] crypto-safexcel 15600000.crypto: failed to get resource
[ 13.703557] crypto-safexcel: probe of 15600000.crypto failed with error -16
[ 13.713974] at24 2-0050: supply vcc not found, using dummy regulator
[ 13.744153] at24 2-0057: supply vcc not found, using dummy regulator
[ 13.751124] at24 2-0057: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 13.758198] Loading modules backported from Linux version v6.11.2-0-g7aa21fec187b
[ 13.765714] Backport generated by backports.git v6.1.110-1-32-gc61f71fe0942
[ 13.775894] sfp sfp1: Host maximum power 3.0W
[ 13.795487] mt7996e_hif 0001:01:00.0: assign IRQ: got 118
[ 13.800905] mt7996e_hif 0001:01:00.0: enabling device (0000 -> 0002)
[ 13.807293] mt7996e_hif 0001:01:00.0: enabling bus mastering
[ 13.813132] mt7996e 0000:01:00.0: assign IRQ: got 115
[ 13.818188] mt7996e 0000:01:00.0: enabling device (0000 -> 0002)
[ 13.824222] mt7996e 0000:01:00.0: enabling bus mastering
[ 13.922265] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[ 13.930786] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 13.982552] mt7996e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240809122254a
[ 13.982552]
[ 14.090058] mt7996e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20240809122249
[ 14.132654] mt7996e 0000:01:00.0: DSP Firmware Version: ____000000, Build Time: 20240809121650
[ 14.154235] mt7996e 0000:01:00.0: WA Firmware Version: ____000000, Build Time: 20240809122214
[ 14.556488] PPP generic driver version 2.4.2
[ 14.561354] NET: Registered PF_PPPOX protocol family
[ 14.567593] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 16.698915] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 16.721182] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 16.729390] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 16.731644] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 16.746793] br-lan: port 1(lan1) entered blocking state
[ 16.752079] br-lan: port 1(lan1) entered disabled state
[ 16.757440] mt7530-mmio 15020000.switch lan1: entered allmulticast mode
[ 16.764136] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[ 16.771215] mt7530-mmio 15020000.switch lan1: entered promiscuous mode
[ 16.782941] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
[ 16.791791] br-lan: port 2(lan2) entered blocking state
[ 16.797120] br-lan: port 2(lan2) entered disabled state
[ 16.802416] mt7530-mmio 15020000.switch lan2: entered allmulticast mode
[ 16.809292] mt7530-mmio 15020000.switch lan2: entered promiscuous mode
[ 16.818939] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
[ 16.827563] br-lan: port 3(lan3) entered blocking state
[ 16.832867] br-lan: port 3(lan3) entered disabled state
[ 16.838159] mt7530-mmio 15020000.switch lan3: entered allmulticast mode
[ 16.845109] mt7530-mmio 15020000.switch lan3: entered promiscuous mode
[ 16.880564] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: Firmware date code: 0/0/0, version: 0.0
[ 16.896032] MediaTek MT7988 2.5GbE PHY mdio-bus:0f: Firmware loading/trigger ok.
[ 16.904742] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:0f] driver [MediaTek MT7988 2.5GbE PHY] (irq=POLL)
[ 16.915012] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/internal link mode
[ 16.924301] br-lan: port 4(eth1) entered blocking state
[ 16.929548] br-lan: port 4(eth1) entered disabled state
[ 16.934832] mtk_soc_eth 15100000.ethernet eth1: entered allmulticast mode
[ 16.941875] mtk_soc_eth 15100000.ethernet eth1: entered promiscuous mode
[ 16.952188] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
[ 16.960561] br-wan: port 1(wan) entered blocking state
[ 16.965731] br-wan: port 1(wan) entered disabled state
[ 16.970878] mt7530-mmio 15020000.switch wan: entered allmulticast mode
[ 16.977550] mt7530-mmio 15020000.switch wan: entered promiscuous mode
[ 16.986776] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/10gbase-r link mode
[ 17.019193] br-wan: port 2(eth2) entered blocking state
[ 17.024480] br-wan: port 2(eth2) entered disabled state
[ 17.029727] mtk_soc_eth 15100000.ethernet eth2: entered allmulticast mode
[ 17.036774] mtk_soc_eth 15100000.ethernet eth2: entered promiscuous mode
[ 20.042888] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
[ 33.036895] br-wan: port 1(wan) entered blocking state
[ 33.043003] br-wan: port 1(wan) entered forwarding state
[ 33.401305] br-lan: port 5(phy0.0-ap0) entered blocking state
[ 33.407101] br-lan: port 5(phy0.0-ap0) entered disabled state
[ 33.412913] mt7996e 0000:01:00.0 phy0.0-ap0: entered allmulticast mode
[ 33.419593] mt7996e 0000:01:00.0 phy0.0-ap0: entered promiscuous mode
[ 33.426195] br-lan: port 5(phy0.0-ap0) entered blocking state
[ 33.431933] br-lan: port 5(phy0.0-ap0) entered forwarding state
[ 34.114145] br-lan: port 6(phy0.1-ap0) entered blocking state
[ 34.119899] br-lan: port 6(phy0.1-ap0) entered disabled state
[ 34.125690] mt7996e 0000:01:00.0 phy0.1-ap0: entered allmulticast mode
[ 34.132359] mt7996e 0000:01:00.0 phy0.1-ap0: entered promiscuous mode
[ 34.612163] br-lan: port 6(phy0.1-ap0) entered blocking state
[ 34.617924] br-lan: port 6(phy0.1-ap0) entered forwarding state
[ 582.582654] usb 2-1.4: USB disconnect, device number 3
[ 596.219038] usb 2-1.4: new SuperSpeed USB device number 4 using xhci-mtk
[ 596.252178] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[ 596.258642] scsi host0: usb-storage 2-1.4:1.0
[ 597.289566] scsi 0:0:0:0: Direct-Access PQ: 0 ANSI: 6
[ 597.298793] sd 0:0:0:0: [sda] 247398400 512-byte logical blocks: (127 GB/118 GiB)
[ 597.306580] sd 0:0:0:0: [sda] Write Protect is off
[ 597.311370] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 597.316587] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 597.334774] sda: sda1 sda2
[ 597.337772] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 718.280858] EXT4-fs (sda1): mounted filesystem 25721aa0-5839-4a91-baee-ae4b25e71f13 r/w with ordered data mode. Quota mode: disabled.
[ 5803.006934] ------------[ cut here ]------------
[ 5803.011576] 0xffffffc0805f0c84: returned: -95
[ 5803.015943] WARNING: CPU: 3 PID: 8597 at 0xffffffc0805f2178
[ 5803.021507] Modules linked in: pppoe ppp_async nft_fib_inet nf_flow_table_inet pppox ppp_generic nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_chain_nat nf_tables nf_nat nf_flow_table nf_conntrack mt7996e(O) mt76_connac_lib(O) mt76(O) mac80211(O) cfg80211(O) slhc sfp rtc_pcf8563 nfnetlink nf_reject_ipv6 nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 mdio_i2c libcrc32c compat(O) at24 crypto_safexcel pwm_fan i2c_mux_pca954x i2c_mux sha512_arm64 sha1_ce sha1_generic seqiv md5 geniv des_generic libdes authencesn authenc uas usb_storage exfat leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd xhci_hcd gpio_button_hotplug(O) usbcore usb_common aquantia
[ 5803.093050] CPU: 3 PID: 8597 Comm: kworker/u8:3 Tainted: G O 6.6.63 #0
[ 5803.102334] Hardware name: Bananapi BPI-R4 2.5GE PoE (DT)
[ 5803.107721] Workqueue: events_power_efficient 0xffffffc0805f20e8
[ 5803.113719] pstate: 80400005 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 5803.120751] pc : 0xffffffc0805f2178
[ 5803.124228] lr : 0xffffffc0805f2178
[ 5803.127877] sp : ffffffc085abbd50
[ 5803.131263] x29: ffffffc085abbd50 x28: 0000000000000000 x27: 61c8864680b583eb
[ 5803.138467] x26: ffffff80c0011028 x25: ffffff80c000ac80 x24: ffffff80c0017c05
[ 5803.145670] x23: 00000000ffffffa1 x22: 0000000000000004 x21: ffffff80c08abc90
[ 5803.152795] x20: ffffff80c08abce8 x19: ffffff80c08ab800 x18: 0000000000000263
[ 5803.159919] x17: 0000000000000000 x16: 0000000000000000 x15: ffffffc080b1f268
[ 5803.167123] x14: 0000000000000729 x13: 0000000000000263 x12: 00000000ffffffea
[ 5803.174248] x11: 00000000ffffefff x10: ffffffc080b77268 x9 : ffffffc080b1f210
[ 5803.181373] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000000001
[ 5803.188578] x5 : ffffff80ff79d790 x4 : 0000000000000000 x3 : 0000000000000027
[ 5803.195702] x2 : 0000000000000027 x1 : 0000000000000023 x0 : 0000000000000021
[ 5803.202827] Call trace:
[ 5803.205264] 0xffffffc0805f2178
[ 5803.208395] 0xffffffc080056f2c
[ 5803.211525] 0xffffffc08005736c
[ 5803.214654] 0xffffffc08005ea0c
[ 5803.217785] 0xffffffc080013024
[ 5803.220915] ---[ end trace 0000000000000000 ]---
[ 5941.724920] sfp sfp1: Unable to ascertain link mode
[ 5941.729807] mtk_soc_eth 15100000.ethernet eth2: selection of interface failed, advertisement 00,00000000,00000000,00006208
[12990.323738] mt7530-mmio 15020000.switch wan: Link is Down
[12990.329755] br-wan: port 1(wan) entered disabled state
[13000.237336] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
[13000.237916] br-wan: port 1(wan) entered blocking state
[13000.250654] br-wan: port 1(wan) entered forwarding state
[13002.794627] mt7530-mmio 15020000.switch wan: Link is Down
[13002.800656] br-wan: port 1(wan) entered disabled state
[13005.409535] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
[13005.410113] br-wan: port 1(wan) entered blocking state
[13005.422854] br-wan: port 1(wan) entered forwarding state
[13023.439253] mt7530-mmio 15020000.switch wan: Link is Down
[13023.445256] br-wan: port 1(wan) entered disabled state
[13025.802425] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
[13025.803005] br-wan: port 1(wan) entered blocking state
[13025.815762] br-wan: port 1(wan) entered forwarding state
root@OpenWrt:~# ifconfig -a
br-lan Link encap:Ethernet HWaddr 76:DA:E1:AD:07:AD
inet addr:192.168.55.1 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::74da:e1ff:fead:7ad/64 Scope:Link
inet6 addr: fd6c:8d21:71da::1/60 Scope:Global
inet6 addr: fde4:8a7e:fb1e:4::1/62 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:104618088 errors:0 dropped:0 overruns:0 frame:0
TX packets:207429809 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:153252056632 (142.7 GiB) TX bytes:274432356607 (255.5 GiB)
br-wan Link encap:Ethernet HWaddr 76:DA:E1:AD:07:AD
inet addr:192.168.1.202 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fde4:8a7e:fb1e:0:74da:e1ff:fead:7ad/64 Scope:Global
inet6 addr: fde4:8a7e:fb1e::e63/128 Scope:Global
RX packets:174265015 errors:0 dropped:0 overruns:0 frame:0
TX packets:215193476 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:298209208177 (277.7 GiB) TX bytes:163886656066 (152.6 GiB)
eth0 Link encap:Ethernet HWaddr 76:DA:E1:AD:07:AD
UP BROADCAST RUNNING MULTICAST MTU:1504 Metric:1
RX packets:318533477 errors:106 dropped:0 overruns:0 frame:0
TX packets:215196752 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:308526904979 (287.3 GiB) TX bytes:164805503134 (153.4 GiB)
Interrupt:106
eth1 Link encap:Ethernet HWaddr 76:DA:E1:AD:07:AE
UP BROADCAST MULTICAST MTU:1500 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:106
eth2 Link encap:Ethernet HWaddr 3A:11:45:D9:8E:8C
Interrupt:106
lan1 Link encap:Ethernet HWaddr 76:DA:E1:AD:07:AD
lan2 Link encap:Ethernet HWaddr 76:DA:E1:AD:07:AD
lan3 Link encap:Ethernet HWaddr 76:DA:E1:AD:07:AD
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:5936 errors:0 dropped:0 overruns:0 frame:0
TX packets:5936 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:650194 (634.9 KiB) TX bytes:650194 (634.9 KiB)
phy0.0-ap0 Link encap:Ethernet HWaddr 76:DA:E1:AD:07:AF
RX packets:336 errors:0 dropped:0 overruns:0 frame:0
TX packets:13622 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:29581 (28.8 KiB) TX bytes:2772361 (2.6 MiB)
phy0.1-ap0 Link encap:Ethernet HWaddr 76:DA:E1:AD:07:BF
RX packets:175118585 errors:0 dropped:0 overruns:0 frame:0
TX packets:267861616 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:158327511895 (147.4 GiB) TX bytes:277697070640 (258.6 GiB)
RX packets:318533477 errors:0 dropped:0 overruns:0 frame:0
TX packets:215193278 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:307252771071 (286.1 GiB) TX bytes:163886597272 (152.6 GiB)
