No, I cannot clarify any more details. @sinovoip should. They are the only ones to know the diff between PoE and non-PoE board and what could be the cause here.
All I can observe myself that boards with PoE expose the issue. Anything else is a pure speculation
I’m very very surprise, that nobody from @sinovoip@sinovoip1 did not reply in that thread. Such topic should be a prio for them. The customer, seeing that something does not work, begins to hesitate to buy it.
I contacted the seller about this issue and this is the reply I got
Hello, we currently only have a small number of customers who have such feedback. You can wait until your product arrives and then confirm. If there is really a problem, you can return it at that time.
So it is happening, but not sure if it affects everyone or small number of groups. unfortunately I cannot return the item since it is shipping from overseas from my relative house. I just have to live with it.
Are there any other functionalities are getting affected by this “No Link” issue? like m.2 / minipci-e etc…
I have my reasons to believe that “2.5 GbE with PoE” is the least spread model out there. So there is basically not enough data for us, community, to judge this.
If you ask myself, I can go and say “everyone with this board is affected”. If you go and ask support, they can go and say “it’s only one sample of a non-functional board”. So it’s very much word against word. Till now their only comment was “I have checked the issue on forum, but many customers use them and they work well” ¯_(ツ)_/¯
Anyway if anyone comes here from Google (for SEO: bpi-r4 2.5 g gbe poe) I could only recommend to hold on before proceeding.
Earlier in this post I noted that my BPi-R4 with 2.5 GbE but no PoE appears to work fine (OS build permitting). While any product can have random defects there doesn’t yet appear to be cause for panic about systemic problems. The PoE model has additional hardware & assembly complexity so possibilities for issues increase a bit. And yes, if you get a problematic board you’d have to deal with returns/exchanges. If this worries you perhaps you should consider where you buy from and perhaps look at Amazon instead of AliExpress for example. But you’ll likely pay more!
It is not merged upstream but at least from commit messages it does seem like this patch set may be required for the 2.5G PHY.
However, the patchset in the current form does not apply cleanly on top of 6.6.56. Can you please advise? We are not sure if the reason is that something has been partially applied already or that we are trying to build it incorrectly.
Your advice would be invaluable as this seem to be part of the code where you are fluent
The series you referenced has already been picked into OpenWrt long ago, which is why it cannot be applied again. It’s also the reason why the 2.5G port of all other MT7988 devices (I got MediaTek’s reference board as well as Adtran SmartRG SDG-8733A) work just fine.
Ok, small but important update. After additional rebuilds&tests I managed to get 2.5GbE PoE working on factory 21.0x image but without autoneg. The last bit is not very important as I do not really care.
Now additional attempts
manually built master using Mediatek feed - does not work
manually built master openwrt - does not work
master openwrt with Mediatek’s i2p5ge-phy-pmb.bin - does not work
So right now the one and only combination that works is the outdated factory image with autoneg manually disabled.
I have always tried autoneg off on openwrt builds, but looking at my own test matrix, factory image always ran with autoneg on.
Step by step, there is a remaining bit that I do not yet understand – why is master openwrt + mediatek feed not working.
The diff in ethtool is very clear and makes it obvious if the stack is healthy or not, i.e.
root@OpenWrt:~# ethtool eth1
Settings for eth1:
Supported ports: [ TP MII ]
Port: MII
Any difference in the logs. To maybe have a clue why one is working and not the other…i do not have the phy board…even if i could put my 2sfp board in same mode,i cannot test as my copper sfps have additional phys.
Hello everyone, I just wanted to give you guys an update
I finally received my BpiR4 non-poe but 2.5 version. I booted up with default NAND boot and I can see it is up and running. I can see a through put of 2.35Gbits/sec using my 2.5G switch using iperf3
here is the dmesg output
root@OpenWrt:~# dmesg | grep eth1
[ 1.718592] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc011e80000, irq 14
[ 4.877034] mediatek_soc_hnat 15100000.hnat: lan2 = eth1
[ 15.672507] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:0f] driver [MediaTek MT798x 2.5GbE PHY]
[ 15.681741] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/xgmii link mode
[ 15.689747] br-lan: port 4(eth1) entered blocking state
[ 15.694999] br-lan: port 4(eth1) entered disabled state
[ 15.700411] device eth1 entered promiscuous mode
[ 15.705361] br-lan: port 4(eth1) entered blocking state
[ 15.710610] br-lan: port 4(eth1) entered forwarding state
[ 16.502418] br-lan: port 4(eth1) entered disabled state
[ 19.799214] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 19.807858] br-lan: port 4(eth1) entered blocking state
[ 19.813094] br-lan: port 4(eth1) entered forwarding state
here is the ethtool output
Settings for eth1:
Supported link modes: 10baseT/Full
100baseT/Full
1000baseT/Full
2500baseT/Full
Advertised link modes: 10baseT/Full
100baseT/Full
1000baseT/Full
2500baseT/Full
Link partner advertised link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
2500baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Speed: 2500Mb/s
Duplex: Full
Port: MII
PHYAD: 15
Transceiver: external
Auto-negotiation: on
Link detected: yes
I am planning to upgrade to current version of openwrt, I will keep you posted.
Hey @anavas, can you please show the same output (dmesg from around firmware loading and ethtool) from the OpenWrt? Mostly interested in “Supported ports” and “Port” fields as those are dodged in my OpenWrt.
Also, where did you source the OpenWrt? Image builder with default configuration or own build?
OK, seems like it’s PoE module what makes a difference here, not 2.5G. Same dmesg for me, but ethtool output is dodged. Given it works on Mediatek’s 21.xx, I am still digging
