Bpi-r4-nic-be14 - problem help!
I have a problem with my Banana Pi Bpi-R4. I just installed the NIC-BE14 Wi-Fi module, but the transmit power is very low and only reaches a maximum of 7dB (5mW). However, the technical specifications indicate that it should be 23.5dB at 2.4GHz, 18dB at 5GHz, and 16dB at 6GHz. Ive tried different settings and regions, but I still only get a maximum of 7dB. I even tried other drivers, and its the same issue.
Currently, my Banana Pi Bpi-R4 is running version 24.10 rc7. Ive also tried rc5 and rc6 with the same results. Should I use the snapshot version or the Banana Pi MP4 release?
What do I need to install or configure so that it works correctly?
Is the snapshot version the same as the 24.10 rc# release?
wifi txpower value is very low · Issue #17489 · openwrt/openwrt
Honestly, wondering if this is a thermal throttle issue. Not 100% sure, but I’ve been running with a 120mm fan on top of the wifi card and temps are between 30c → 59c.
Community calls it “common issue”. Your (and my) bpi-r4-nic-be14 can’t load correct EEPROM. I asked for this in this forum, community sends me to github, but they can’t solve this problem for a very long time. I asked Banana Pi Team for EEPROM dump to flash it directly to wifi module, but they are silent. Idk what i can do, because theese “fix” don’t work on my router… I know, i just would buy something like intel ax210 mini pcie version and i’ll use it until they release normal fix
https://docs.banana-pi.org/en/BPI-R4/BananaPi_BPI-R4_FAQ#_openwrt_mainline_image_txpower_low
Please take a look at these steps to see if they can be of help to you.
Previously, BPI had released an EEPROM file. I have kept the Google download link.
