I had been using BPI R4 with the BE14 WiFi card for a month with no issues. It’s been used for a very light load. I am on the most up to date stable OpenWRT (OpenWrt 25.12.5 r33051-f5dae5ece4).
Suddenly the router stopped working. I saw the WiFi network drop, and the board turned off completely.
When I try to turn on the R4 now with SW4 switch in the on position, the mPCIe 12V LED on the board is flashing. When I switch SW4 to off, the router boots up fine (without WiFi obviously).
The board also seems to have developed a bit of a coil whine too - not sure if this is significant.
I’ve been powering it via a ThinkPad 65W USB-C laptop charger and it worked fine so far. Alternative power supplies also produce the same outcome.
Does this mean there’s a problem with the board or just the WiFi card is gone? How would I go about troubleshooting this?
