I can not get the 6ghz to start. I have kmod-mt7916 firmware and kmod-7915e driver both loaded. My regulatory domain confirms I am allowed to use 6ghz. When I set the radio to 6ghz it just goes to disabled. As soon as I set it back to 5ghz it works. It works flawlessly on 2.4Ghz and 5Ghz. Any clues?
If anyone else is having issues with the AsiaRF-MT7916 I’ll explain what I did to make everything work.
I built my own image based on openwrt’s github. To make the MT7916 work it’s required to add kmod-mt7916-firmware, kmod-mt7915e, and wpad-basic-openssl.
After I booted the image I selected the correct regulatory domain in the adapter settings and verified 6ghz was allowed and on what channels/width it was allowed. After that I used luci to select 6ghz using the 5Ghz/6Ghz switch in the adapter settings. Then you must set WPA3 security AND Management Frame Protection to required in wireless security under adapter settings.
After that I selected channel 21 and it worked perfect on 6ghz. Initially most other channels didn’t work. After a couple reboots all channels are now working.
I like to order one, however shipping is $30. Is there another place where to buy this? Amazon dont have them…
Hi, Is there any news on compatibility, maybe with the standard snapshot? I’m also running the current snapshot (SNAPSHOT (r27243-dd1bfbe971)), but I’m stuck trying to get it recognized.
I’m trying to avoid building my own image.
If not, could you give a quick tip on how to build such an image with the necessary packages. (Yes, I’m a newbie to this topic)
Kind Regards Malte
Even though it used to work for me for quite some time, it is not working anymore with 24.10.0-rc2+ (currently running rc5). Does anyone got it working with the current release candidates?
edit: I cannot exactly state that this issue started with rc2, but I haven’t updated my installation for quite a while, so somewhen between June 2024 and rc2 it stopped working for me ![]()
edit2: Installed packages:
Output of
lsusb
OpenWrt 24.10.0-rc5, r28304-6dacba30a7
root@rpi4:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux 6.6.69 xhci-hcd xHCI Host Controller
Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc. USB2.0 Hub
Bus 001 Device 003: ID 2109:8822 VIA Labs, Inc. USB Billboard Device
Bus 002 Device 001: ID 1d6b:0003 Linux 6.6.69 xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc. USB3.1 Hub
Do you have working 6GHz with MT7916 and one of the 24.10.0-rc<1…6>?
Isn’t it a pcie card? So
dmesg | grep -i pci
dmesg | grep -i mt79
lspci
Would bring us a bit further.
I currently have the mt7916 working on rc7 on my BPI-R4 without any issues as a dumb AP. If you use firmware selector try removing -wpad-basic-mebdtls and replace it with wpad-basic-openssl.
root@rpi4:~# dmesg | grep -i pci
[ 0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait
[ 0.028017] PCI: CLS 0 bytes, default 64
[ 0.051091] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.051109] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.051122] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 0.051135] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 0.051224] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 0.051234] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 0.051245] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 0.051254] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 0.051272] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[ 0.051280] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[ 0.051342] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 0.051353] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 0.051362] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 0.051372] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 0.051388] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[ 0.051396] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[ 0.051470] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 0.051480] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 0.051489] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 0.051499] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 0.051515] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[ 0.051522] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[ 2.437169] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 2.444516] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 2.450792] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 2.459242] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 2.727449] mtk-pcie-gen3 11280000.pcie: set IO trans window[0]: cpu_addr = 0x20000000, pci_addr = 0x20000000, size = 0x200000
[ 2.738848] mtk-pcie-gen3 11280000.pcie: set MEM trans window[1]: cpu_addr = 0x20200000, pci_addr = 0x20200000, size = 0x200000
[ 2.750315] mtk-pcie-gen3 11280000.pcie: set MEM trans window[2]: cpu_addr = 0x20400000, pci_addr = 0x20400000, size = 0x400000
[ 2.761779] mtk-pcie-gen3 11280000.pcie: set MEM trans window[3]: cpu_addr = 0x20800000, pci_addr = 0x20800000, size = 0x800000
[ 2.773242] mtk-pcie-gen3 11280000.pcie: set MEM trans window[4]: cpu_addr = 0x21000000, pci_addr = 0x21000000, size = 0x1000000
[ 2.784792] mtk-pcie-gen3 11280000.pcie: set MEM trans window[5]: cpu_addr = 0x22000000, pci_addr = 0x22000000, size = 0x2000000
[ 2.796342] mtk-pcie-gen3 11280000.pcie: set MEM trans window[6]: cpu_addr = 0x24000000, pci_addr = 0x24000000, size = 0x4000000
[ 2.808165] mtk-pcie-gen3 11280000.pcie: PCI host bridge to bus 0003:00
[ 2.814780] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 2.820257] pci_bus 0003:00: root bus resource [io 0x0000-0x1fffff] (bus address [0x20000000-0x201fffff])
[ 2.829899] pci_bus 0003:00: root bus resource [mem 0x20200000-0x27ffffff]
[ 2.836766] pci_bus 0003:00: scanning bus
[ 2.840785] pci 0003:00:00.0: [14c3:7988] type 01 class 0x060400
[ 2.846795] pci 0003:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 2.853633] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.859716] pci 0003:00:00.0: PME# disabled
[ 2.865141] pci_bus 0003:00: fixups for bus
[ 2.869316] pci 0003:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 2.876010] pci 0003:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.884009] pci 0003:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 2.890749] pci_bus 0003:01: scanning bus
[ 2.894776] pci 0003:01:00.0: [14c3:7906] type 00 class 0x028000
[ 2.900795] pci 0003:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 2.908022] pci 0003:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[ 2.914814] pci 0003:01:00.0: reg 0x20: [mem 0x00000000-0x00000fff 64bit pref]
[ 2.922127] pci 0003:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.928215] pci 0003:01:00.0: PME# disabled
[ 2.932436] pci 0003:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0003:00:00.0 (capable of 8.000 Gb/s with 5.0 GT/s PCIe x2 link)
[ 2.972352] pci_bus 0003:01: fixups for bus
[ 2.976526] pci_bus 0003:01: bus scan returning with max=01
[ 2.982087] pci_bus 0003:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.988697] pci_bus 0003:00: bus scan returning with max=01
[ 2.994273] pci 0003:00:00.0: BAR 8: assigned [mem 0x20200000-0x202fffff]
[ 3.001051] pci 0003:00:00.0: BAR 9: assigned [mem 0x20300000-0x204fffff 64bit pref]
[ 3.008786] pci 0003:00:00.0: BAR 0: assigned [mem 0x20500000-0x20507fff 64bit]
[ 3.016092] pci 0003:01:00.0: BAR 0: assigned [mem 0x20300000-0x203fffff 64bit pref]
[ 3.023837] pci 0003:01:00.0: BAR 2: assigned [mem 0x20200000-0x20207fff 64bit]
[ 3.031144] pci 0003:01:00.0: BAR 4: assigned [mem 0x20400000-0x20400fff 64bit pref]
[ 3.038892] pci 0003:00:00.0: PCI bridge to [bus 01]
[ 3.043851] pci 0003:00:00.0: bridge window [mem 0x20200000-0x202fffff]
[ 3.050628] pci 0003:00:00.0: bridge window [mem 0x20300000-0x204fffff 64bit pref]
[ 3.058363] pci_bus 0003:00: resource 4 [io 0x0000-0x1fffff]
[ 3.064099] pci_bus 0003:00: resource 5 [mem 0x20200000-0x27ffffff]
[ 3.070353] pci_bus 0003:01: resource 1 [mem 0x20200000-0x202fffff]
[ 3.076610] pci_bus 0003:01: resource 2 [mem 0x20300000-0x204fffff 64bit pref]
[ 3.083829] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.092270] pci 0003:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.100784] pcieport 0003:00:00.0: assign IRQ: got 115
[ 3.105920] pcieport 0003:00:00.0: enabling device (0000 -> 0002)
[ 3.112011] pcieport 0003:00:00.0: enabling bus mastering
[ 3.117780] mtk-pcie-gen3 11280000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11280c00 data 0
[ 3.126217] mtk-pcie-gen3 11280000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11280c00 data 1
[ 3.134645] mtk-pcie-gen3 11280000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11280c00 data 2
[ 3.143073] mtk-pcie-gen3 11280000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11280c00 data 3
[ 3.151497] mtk-pcie-gen3 11280000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11280c00 data 4
[ 3.159924] mtk-pcie-gen3 11280000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11280c00 data 5
[ 3.168351] mtk-pcie-gen3 11280000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11280c00 data 6
[ 3.176776] mtk-pcie-gen3 11280000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11280c00 data 7
[ 3.185202] mtk-pcie-gen3 11280000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11280c00 data 8
[ 3.193629] mtk-pcie-gen3 11280000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11280c00 data 9
[ 3.202053] mtk-pcie-gen3 11280000.pcie: msi#0xa address_hi 0x0 address_lo 0x11280c00 data 10
[ 3.210566] mtk-pcie-gen3 11280000.pcie: msi#0xb address_hi 0x0 address_lo 0x11280c00 data 11
[ 3.219082] mtk-pcie-gen3 11280000.pcie: msi#0xc address_hi 0x0 address_lo 0x11280c00 data 12
[ 3.227595] mtk-pcie-gen3 11280000.pcie: msi#0xd address_hi 0x0 address_lo 0x11280c00 data 13
[ 3.236108] mtk-pcie-gen3 11280000.pcie: msi#0xe address_hi 0x0 address_lo 0x11280c00 data 14
[ 3.244621] mtk-pcie-gen3 11280000.pcie: msi#0xf address_hi 0x0 address_lo 0x11280c00 data 15
[ 3.253134] mtk-pcie-gen3 11280000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11280c00 data 16
[ 3.261732] mtk-pcie-gen3 11280000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11280c00 data 17
[ 3.270331] mtk-pcie-gen3 11280000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11280c00 data 18
[ 3.278931] mtk-pcie-gen3 11280000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11280c00 data 19
[ 3.287531] mtk-pcie-gen3 11280000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11280c00 data 20
[ 3.296131] mtk-pcie-gen3 11280000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11280c00 data 21
[ 3.304731] mtk-pcie-gen3 11280000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11280c00 data 22
[ 3.313331] mtk-pcie-gen3 11280000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11280c00 data 23
[ 3.321929] mtk-pcie-gen3 11280000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11280c00 data 24
[ 3.330529] mtk-pcie-gen3 11280000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11280c00 data 25
[ 3.339131] mtk-pcie-gen3 11280000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11280c00 data 26
[ 3.347730] mtk-pcie-gen3 11280000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11280c00 data 27
[ 3.356330] mtk-pcie-gen3 11280000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11280c00 data 28
[ 3.364933] mtk-pcie-gen3 11280000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11280c00 data 29
[ 3.373533] mtk-pcie-gen3 11280000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11280c00 data 30
[ 3.382129] mtk-pcie-gen3 11280000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11280c00 data 31
[ 3.391157] mtk-pcie-gen3 11280000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11280c00 data 0
[ 3.399655] pcieport 0003:00:00.0: PME: Signaling with IRQ 116
[ 3.405600] pcieport 0003:00:00.0: AER: enabled with IRQ 116
[ 3.411285] pcieport 0003:00:00.0: save config 0x00: 0x798814c3
[ 3.417201] pcieport 0003:00:00.0: save config 0x04: 0x00100406
[ 3.423113] pcieport 0003:00:00.0: save config 0x08: 0x06040001
[ 3.429022] pcieport 0003:00:00.0: save config 0x0c: 0x00010000
[ 3.434931] pcieport 0003:00:00.0: save config 0x10: 0x20500004
[ 3.440839] pcieport 0003:00:00.0: save config 0x14: 0x00000000
[ 3.446748] pcieport 0003:00:00.0: save config 0x18: 0x00010100
[ 3.452660] pcieport 0003:00:00.0: save config 0x1c: 0x000001f1
[ 3.458567] pcieport 0003:00:00.0: save config 0x20: 0x20202020
[ 3.464477] pcieport 0003:00:00.0: save config 0x24: 0x20412031
[ 3.470386] pcieport 0003:00:00.0: save config 0x28: 0x00000000
[ 3.476296] pcieport 0003:00:00.0: save config 0x2c: 0x00000000
[ 3.482204] pcieport 0003:00:00.0: save config 0x30: 0x00000000
[ 3.488113] pcieport 0003:00:00.0: save config 0x34: 0x00000080
[ 3.494022] pcieport 0003:00:00.0: save config 0x38: 0x00000000
[ 3.499929] pcieport 0003:00:00.0: save config 0x3c: 0x00020173
[ 3.506172] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 3.513483] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 3.519747] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 3.528181] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 3.872320] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 3.881108] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[ 3.888057] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 3.895372] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 3.901634] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 3.910068] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 4.167438] mtk-pcie-gen3 11300000.pcie: set IO trans window[0]: cpu_addr = 0x30000000, pci_addr = 0x30000000, size = 0x200000
[ 4.178818] mtk-pcie-gen3 11300000.pcie: set MEM trans window[1]: cpu_addr = 0x30200000, pci_addr = 0x30200000, size = 0x200000
[ 4.190283] mtk-pcie-gen3 11300000.pcie: set MEM trans window[2]: cpu_addr = 0x30400000, pci_addr = 0x30400000, size = 0x400000
[ 4.201747] mtk-pcie-gen3 11300000.pcie: set MEM trans window[3]: cpu_addr = 0x30800000, pci_addr = 0x30800000, size = 0x800000
[ 4.213210] mtk-pcie-gen3 11300000.pcie: set MEM trans window[4]: cpu_addr = 0x31000000, pci_addr = 0x31000000, size = 0x1000000
[ 4.224760] mtk-pcie-gen3 11300000.pcie: set MEM trans window[5]: cpu_addr = 0x32000000, pci_addr = 0x32000000, size = 0x2000000
[ 4.236309] mtk-pcie-gen3 11300000.pcie: set MEM trans window[6]: cpu_addr = 0x34000000, pci_addr = 0x34000000, size = 0x4000000
[ 4.247987] mtk-pcie-gen3 11300000.pcie: PCI host bridge to bus 0000:00
[ 4.254597] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.260074] pci_bus 0000:00: root bus resource [io 0x400000-0x5fffff] (bus address [0x30000000-0x301fffff])
[ 4.269892] pci_bus 0000:00: root bus resource [mem 0x30200000-0x37ffffff]
[ 4.276759] pci_bus 0000:00: scanning bus
[ 4.280777] pci 0000:00:00.0: [14c3:7988] type 01 class 0x060400
[ 4.286788] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 4.293626] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.299710] pci 0000:00:00.0: PME# disabled
[ 4.305194] pci_bus 0000:00: fixups for bus
[ 4.309369] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 4.316063] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.324061] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 4.330804] pci_bus 0000:01: scanning bus
[ 4.334830] pci 0000:01:00.0: [14c3:7906] type 00 class 0x028000
[ 4.340850] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 4.348078] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[ 4.354869] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00000fff 64bit pref]
[ 4.362184] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 4.368272] pci 0000:01:00.0: PME# disabled
[ 4.372494] pci 0000:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 8.000 Gb/s with 5.0 GT/s PCIe x2 link)
[ 4.412352] pci_bus 0000:01: fixups for bus
[ 4.416525] pci_bus 0000:01: bus scan returning with max=01
[ 4.422087] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.428698] pci_bus 0000:00: bus scan returning with max=01
[ 4.434274] pci 0000:00:00.0: BAR 8: assigned [mem 0x30200000-0x302fffff]
[ 4.441052] pci 0000:00:00.0: BAR 9: assigned [mem 0x30300000-0x304fffff 64bit pref]
[ 4.448785] pci 0000:00:00.0: BAR 0: assigned [mem 0x30500000-0x30507fff 64bit]
[ 4.456090] pci 0000:01:00.0: BAR 0: assigned [mem 0x30300000-0x303fffff 64bit pref]
[ 4.463833] pci 0000:01:00.0: BAR 2: assigned [mem 0x30200000-0x30207fff 64bit]
[ 4.471141] pci 0000:01:00.0: BAR 4: assigned [mem 0x30400000-0x30400fff 64bit pref]
[ 4.478887] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 4.483846] pci 0000:00:00.0: bridge window [mem 0x30200000-0x302fffff]
[ 4.490623] pci 0000:00:00.0: bridge window [mem 0x30300000-0x304fffff 64bit pref]
[ 4.498358] pci_bus 0000:00: resource 4 [io 0x400000-0x5fffff]
[ 4.504267] pci_bus 0000:00: resource 5 [mem 0x30200000-0x37ffffff]
[ 4.510521] pci_bus 0000:01: resource 1 [mem 0x30200000-0x302fffff]
[ 4.516777] pci_bus 0000:01: resource 2 [mem 0x30300000-0x304fffff 64bit pref]
[ 4.523995] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 4.532441] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 4.540938] pcieport 0000:00:00.0: assign IRQ: got 118
[ 4.546073] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 4.552164] pcieport 0000:00:00.0: enabling bus mastering
[ 4.557928] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[ 4.566363] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[ 4.574791] mtk-pcie-gen3 11300000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11300c00 data 2
[ 4.583217] mtk-pcie-gen3 11300000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11300c00 data 3
[ 4.591641] mtk-pcie-gen3 11300000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11300c00 data 4
[ 4.600068] mtk-pcie-gen3 11300000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11300c00 data 5
[ 4.608494] mtk-pcie-gen3 11300000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11300c00 data 6
[ 4.616920] mtk-pcie-gen3 11300000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11300c00 data 7
[ 4.625345] mtk-pcie-gen3 11300000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11300c00 data 8
[ 4.633771] mtk-pcie-gen3 11300000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11300c00 data 9
[ 4.642195] mtk-pcie-gen3 11300000.pcie: msi#0xa address_hi 0x0 address_lo 0x11300c00 data 10
[ 4.650708] mtk-pcie-gen3 11300000.pcie: msi#0xb address_hi 0x0 address_lo 0x11300c00 data 11
[ 4.659223] mtk-pcie-gen3 11300000.pcie: msi#0xc address_hi 0x0 address_lo 0x11300c00 data 12
[ 4.667735] mtk-pcie-gen3 11300000.pcie: msi#0xd address_hi 0x0 address_lo 0x11300c00 data 13
[ 4.676248] mtk-pcie-gen3 11300000.pcie: msi#0xe address_hi 0x0 address_lo 0x11300c00 data 14
[ 4.684760] mtk-pcie-gen3 11300000.pcie: msi#0xf address_hi 0x0 address_lo 0x11300c00 data 15
[ 4.693273] mtk-pcie-gen3 11300000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11300c00 data 16
[ 4.701872] mtk-pcie-gen3 11300000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11300c00 data 17
[ 4.710473] mtk-pcie-gen3 11300000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11300c00 data 18
[ 4.719073] mtk-pcie-gen3 11300000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11300c00 data 19
[ 4.727673] mtk-pcie-gen3 11300000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11300c00 data 20
[ 4.736273] mtk-pcie-gen3 11300000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11300c00 data 21
[ 4.744872] mtk-pcie-gen3 11300000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11300c00 data 22
[ 4.753472] mtk-pcie-gen3 11300000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11300c00 data 23
[ 4.762070] mtk-pcie-gen3 11300000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11300c00 data 24
[ 4.770669] mtk-pcie-gen3 11300000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11300c00 data 25
[ 4.779270] mtk-pcie-gen3 11300000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11300c00 data 26
[ 4.787870] mtk-pcie-gen3 11300000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11300c00 data 27
[ 4.796470] mtk-pcie-gen3 11300000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11300c00 data 28
[ 4.805070] mtk-pcie-gen3 11300000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11300c00 data 29
[ 4.813670] mtk-pcie-gen3 11300000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11300c00 data 30
[ 4.822268] mtk-pcie-gen3 11300000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11300c00 data 31
[ 4.831318] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[ 4.839838] pcieport 0000:00:00.0: PME: Signaling with IRQ 119
[ 4.845773] pcieport 0000:00:00.0: AER: enabled with IRQ 119
[ 4.851464] pcieport 0000:00:00.0: save config 0x00: 0x798814c3
[ 4.857382] pcieport 0000:00:00.0: save config 0x04: 0x00100406
[ 4.863294] pcieport 0000:00:00.0: save config 0x08: 0x06040001
[ 4.869201] pcieport 0000:00:00.0: save config 0x0c: 0x00010000
[ 4.875110] pcieport 0000:00:00.0: save config 0x10: 0x30500004
[ 4.881018] pcieport 0000:00:00.0: save config 0x14: 0x00000000
[ 4.886927] pcieport 0000:00:00.0: save config 0x18: 0x00010100
[ 4.892837] pcieport 0000:00:00.0: save config 0x1c: 0x000001f1
[ 4.898743] pcieport 0000:00:00.0: save config 0x20: 0x30203020
[ 4.904653] pcieport 0000:00:00.0: save config 0x24: 0x30413031
[ 4.910559] pcieport 0000:00:00.0: save config 0x28: 0x00000000
[ 4.916468] pcieport 0000:00:00.0: save config 0x2c: 0x00000000
[ 4.922377] pcieport 0000:00:00.0: save config 0x30: 0x00000000
[ 4.928283] pcieport 0000:00:00.0: save config 0x34: 0x00000080
[ 4.934192] pcieport 0000:00:00.0: save config 0x38: 0x00000000
[ 4.940100] pcieport 0000:00:00.0: save config 0x3c: 0x00020176
[ 4.946348] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 4.953658] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 4.959923] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 4.968358] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 5.215004] mtk-pcie-gen3 11310000.pcie: set IO trans window[0]: cpu_addr = 0x38000000, pci_addr = 0x38000000, size = 0x200000
[ 5.226387] mtk-pcie-gen3 11310000.pcie: set MEM trans window[1]: cpu_addr = 0x38200000, pci_addr = 0x38200000, size = 0x200000
[ 5.237852] mtk-pcie-gen3 11310000.pcie: set MEM trans window[2]: cpu_addr = 0x38400000, pci_addr = 0x38400000, size = 0x400000
[ 5.249316] mtk-pcie-gen3 11310000.pcie: set MEM trans window[3]: cpu_addr = 0x38800000, pci_addr = 0x38800000, size = 0x800000
[ 5.260778] mtk-pcie-gen3 11310000.pcie: set MEM trans window[4]: cpu_addr = 0x39000000, pci_addr = 0x39000000, size = 0x1000000
[ 5.272329] mtk-pcie-gen3 11310000.pcie: set MEM trans window[5]: cpu_addr = 0x3a000000, pci_addr = 0x3a000000, size = 0x2000000
[ 5.283878] mtk-pcie-gen3 11310000.pcie: set MEM trans window[6]: cpu_addr = 0x3c000000, pci_addr = 0x3c000000, size = 0x4000000
[ 5.295555] mtk-pcie-gen3 11310000.pcie: PCI host bridge to bus 0001:00
[ 5.302159] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.307642] pci_bus 0001:00: root bus resource [io 0x600000-0x7fffff] (bus address [0x38000000-0x381fffff])
[ 5.317459] pci_bus 0001:00: root bus resource [mem 0x38200000-0x3fffffff]
[ 5.324325] pci_bus 0001:00: scanning bus
[ 5.328347] pci 0001:00:00.0: [14c3:7988] type 01 class 0x060400
[ 5.334361] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 5.341198] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.347285] pci 0001:00:00.0: PME# disabled
[ 5.352747] pci_bus 0001:00: fixups for bus
[ 5.356922] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 5.363614] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 5.371610] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 5.378350] pci_bus 0001:01: scanning bus
[ 5.382376] pci 0001:01:00.0: [14c3:7915] type 00 class 0x000280
[ 5.388395] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 5.395621] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.402847] pci 0001:01:00.0: reg 0x20: [mem 0x00000000-0x00000fff 64bit pref]
[ 5.410160] pci 0001:01:00.0: supports D1 D2
[ 5.414422] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 5.421027] pci 0001:01:00.0: PME# disabled
[ 5.452351] pci_bus 0001:01: fixups for bus
[ 5.456525] pci_bus 0001:01: bus scan returning with max=01
[ 5.462086] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 5.468697] pci_bus 0001:00: bus scan returning with max=01
[ 5.474273] pci 0001:00:00.0: BAR 9: assigned [mem 0x38200000-0x383fffff 64bit pref]
[ 5.482004] pci 0001:00:00.0: BAR 0: assigned [mem 0x38400000-0x38407fff 64bit]
[ 5.489311] pci 0001:01:00.0: BAR 0: assigned [mem 0x38200000-0x382fffff 64bit pref]
[ 5.497055] pci 0001:01:00.0: BAR 2: assigned [mem 0x38300000-0x38303fff 64bit pref]
[ 5.504798] pci 0001:01:00.0: BAR 4: assigned [mem 0x38304000-0x38304fff 64bit pref]
[ 5.512541] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 5.517499] pci 0001:00:00.0: bridge window [mem 0x38200000-0x383fffff 64bit pref]
[ 5.525233] pci_bus 0001:00: resource 4 [io 0x600000-0x7fffff]
[ 5.531141] pci_bus 0001:00: resource 5 [mem 0x38200000-0x3fffffff]
[ 5.537398] pci_bus 0001:01: resource 2 [mem 0x38200000-0x383fffff 64bit pref]
[ 5.544619] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 5.553062] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 5.561573] pcieport 0001:00:00.0: assign IRQ: got 121
[ 5.566709] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[ 5.572805] pcieport 0001:00:00.0: enabling bus mastering
[ 5.578543] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 5.586979] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 5.595405] mtk-pcie-gen3 11310000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11310c00 data 2
[ 5.603831] mtk-pcie-gen3 11310000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11310c00 data 3
[ 5.612255] mtk-pcie-gen3 11310000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11310c00 data 4
[ 5.620681] mtk-pcie-gen3 11310000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11310c00 data 5
[ 5.629107] mtk-pcie-gen3 11310000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11310c00 data 6
[ 5.637533] mtk-pcie-gen3 11310000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11310c00 data 7
[ 5.645959] mtk-pcie-gen3 11310000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11310c00 data 8
[ 5.654385] mtk-pcie-gen3 11310000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11310c00 data 9
[ 5.662811] mtk-pcie-gen3 11310000.pcie: msi#0xa address_hi 0x0 address_lo 0x11310c00 data 10
[ 5.671321] mtk-pcie-gen3 11310000.pcie: msi#0xb address_hi 0x0 address_lo 0x11310c00 data 11
[ 5.679834] mtk-pcie-gen3 11310000.pcie: msi#0xc address_hi 0x0 address_lo 0x11310c00 data 12
[ 5.688347] mtk-pcie-gen3 11310000.pcie: msi#0xd address_hi 0x0 address_lo 0x11310c00 data 13
[ 5.696863] mtk-pcie-gen3 11310000.pcie: msi#0xe address_hi 0x0 address_lo 0x11310c00 data 14
[ 5.705376] mtk-pcie-gen3 11310000.pcie: msi#0xf address_hi 0x0 address_lo 0x11310c00 data 15
[ 5.713888] mtk-pcie-gen3 11310000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11310c00 data 16
[ 5.722488] mtk-pcie-gen3 11310000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11310c00 data 17
[ 5.731086] mtk-pcie-gen3 11310000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11310c00 data 18
[ 5.739685] mtk-pcie-gen3 11310000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11310c00 data 19
[ 5.748285] mtk-pcie-gen3 11310000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11310c00 data 20
[ 5.756884] mtk-pcie-gen3 11310000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11310c00 data 21
[ 5.765485] mtk-pcie-gen3 11310000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11310c00 data 22
[ 5.774084] mtk-pcie-gen3 11310000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11310c00 data 23
[ 5.782685] mtk-pcie-gen3 11310000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11310c00 data 24
[ 5.791282] mtk-pcie-gen3 11310000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11310c00 data 25
[ 5.799882] mtk-pcie-gen3 11310000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11310c00 data 26
[ 5.808482] mtk-pcie-gen3 11310000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11310c00 data 27
[ 5.817083] mtk-pcie-gen3 11310000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11310c00 data 28
[ 5.825683] mtk-pcie-gen3 11310000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11310c00 data 29
[ 5.834282] mtk-pcie-gen3 11310000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11310c00 data 30
[ 5.842882] mtk-pcie-gen3 11310000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11310c00 data 31
[ 5.851887] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 5.860384] pcieport 0001:00:00.0: PME: Signaling with IRQ 122
[ 5.866332] pcieport 0001:00:00.0: AER: enabled with IRQ 122
[ 5.872020] pcieport 0001:00:00.0: save config 0x00: 0x798814c3
[ 5.877941] pcieport 0001:00:00.0: save config 0x04: 0x00100406
[ 5.883853] pcieport 0001:00:00.0: save config 0x08: 0x06040001
[ 5.889760] pcieport 0001:00:00.0: save config 0x0c: 0x00010000
[ 5.895670] pcieport 0001:00:00.0: save config 0x10: 0x38400004
[ 5.901577] pcieport 0001:00:00.0: save config 0x14: 0x00000000
[ 5.907487] pcieport 0001:00:00.0: save config 0x18: 0x00010100
[ 5.913396] pcieport 0001:00:00.0: save config 0x1c: 0x000001f1
[ 5.919303] pcieport 0001:00:00.0: save config 0x20: 0x0000fff0
[ 5.925212] pcieport 0001:00:00.0: save config 0x24: 0x38313821
[ 5.931119] pcieport 0001:00:00.0: save config 0x28: 0x00000000
[ 5.937028] pcieport 0001:00:00.0: save config 0x2c: 0x00000000
[ 5.942938] pcieport 0001:00:00.0: save config 0x30: 0x00000000
[ 5.948845] pcieport 0001:00:00.0: save config 0x34: 0x00000080
[ 5.954754] pcieport 0001:00:00.0: save config 0x38: 0x00000000
[ 5.960661] pcieport 0001:00:00.0: save config 0x3c: 0x00020179
[ 14.852438] mtk-pcie-gen3 11280000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11280c00 data 1
[ 15.502424] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[ 15.982418] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 84.976027] Modules linked in: pppoe ppp_async nft_fib_inet nf_flow_table_inet pppox ppp_generic nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_chain_nat nf_tables nf_nat nf_flow_table nf_conntrack mt7996e(O) mt7915e(O) mt7615e(O) mt7615_common(O) mt76_connac_lib(O) mt76(O) mac80211(O) cfg80211(O) slhc sfp rtc_pcf8563 nfnetlink nf_reject_ipv6 nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 mdio_i2c compat(O) at24 crypto_safexcel pwm_fan i2c_mux_pca954x i2c_mux xxhash_generic sha512_arm64 sha1_ce sha1_generic seqiv md5 geniv des_generic libdes blake2b_generic authencesn authenc leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd xhci_hcd gpio_button_hotplug(O) btrfs xor xor_neon raid6_pq libcrc32c usbcore usb_common aquantia
root@rpi4:~# dmesg | grep -i mt79
[ 5.973697] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4" (OpenWrt bananapi_bpi-r4)
[ 6.003738] FIT: flat_dt sub-image 0x0056a000..0x0056a609 "fdt-mt7988a-bananapi-bpi-r4-emmc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-emmc)
[ 6.020072] FIT: flat_dt sub-image 0x0056b000..0x0056b11c "fdt-mt7988a-bananapi-bpi-r4-rtc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-rtc)
[ 6.036234] FIT: flat_dt sub-image 0x0056c000..0x0056c5c1 "fdt-mt7988a-bananapi-bpi-r4-sd" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd)
[ 6.052221] FIT: flat_dt sub-image 0x0056d000..0x0056d8f0 "fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a)
[ 6.381436] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=124)
[ 6.419131] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7988 PHY] (irq=125)
[ 6.456792] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=126)
[ 6.494428] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=127)
[ 14.763882] mt7915e 0003:01:00.0: assign IRQ: got 115
[ 14.768957] mt7915e 0003:01:00.0: enabling device (0000 -> 0002)
[ 14.775009] mt7915e 0003:01:00.0: enabling bus mastering
[ 14.894421] mt7915e 0003:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240823172725a
[ 15.027869] mt7915e 0003:01:00.0: WM Firmware Version: ____000000, Build Time: 20240823172741
[ 15.139886] mt7915e 0003:01:00.0: WA Firmware Version: DEV_000000, Build Time: 20240823172837
[ 15.306867] mt7915e 0003:01:00.0: registering led 'mt76-phy0'
[ 15.373538] mt7915e 0003:01:00.0: registering led 'mt76-phy1'
[ 15.413628] mt7915e 0000:01:00.0: assign IRQ: got 118
[ 15.418697] mt7915e 0000:01:00.0: enabling device (0000 -> 0002)
[ 15.424749] mt7915e 0000:01:00.0: enabling bus mastering
[ 15.532594] mt7915e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240823172725a
[ 15.548550] mt7915e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20240823172741
[ 15.580636] mt7915e 0000:01:00.0: WA Firmware Version: DEV_000000, Build Time: 20240823172837
[ 15.747067] mt7915e 0000:01:00.0: registering led 'mt76-phy2'
[ 15.813508] mt7915e 0000:01:00.0: registering led 'mt76-phy3'
[ 15.853809] mt7915e 0001:01:00.0: assign IRQ: got 121
[ 15.858878] mt7915e 0001:01:00.0: enabling device (0000 -> 0002)
[ 15.864930] mt7915e 0001:01:00.0: enabling bus mastering
[ 16.038023] mt7915e 0001:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240429200716a
[ 16.137860] mt7915e 0001:01:00.0: WM Firmware Version: ____000000, Build Time: 20240429200752
[ 16.161270] mt7915e 0001:01:00.0: WA Firmware Version: DEV_000000, Build Time: 20240429200812
[ 16.315973] mt7915e 0001:01:00.0: registering led 'mt76-phy4'
[ 21.952995] mt7915e 0000:01:00.0 kabellos2WZ: entered allmulticast mode
[ 21.959794] mt7915e 0000:01:00.0 kabellos2WZ: entered promiscuous mode
[ 22.932964] mt7915e 0003:01:00.0 kabellos2EZ: entered allmulticast mode
[ 22.939760] mt7915e 0003:01:00.0 kabellos2EZ: entered promiscuous mode
[ 23.227607] mt7915e 0001:01:00.0 kabellos1EG: entered allmulticast mode
[ 23.234365] mt7915e 0001:01:00.0 kabellos1EG: entered promiscuous mode
[ 25.045974] mt7915e 0001:01:00.0 kabellos2EG2g: entered allmulticast mode
[ 25.052906] mt7915e 0001:01:00.0 kabellos2EG2g: entered promiscuous mode
[ 25.074390] mt7915e 0001:01:00.0 kabellos2EG2g: left allmulticast mode
[ 25.080925] mt7915e 0001:01:00.0 kabellos2EG2g: left promiscuous mode
[ 25.145915] mt7915e 0001:01:00.0 kabellos2EG2g: entered allmulticast mode
[ 25.152798] mt7915e 0001:01:00.0 kabellos2EG2g: entered promiscuous mode
[ 25.275622] mt7915e 0001:01:00.0 kabellos3EG: entered allmulticast mode
[ 25.282380] mt7915e 0001:01:00.0 kabellos3EG: entered promiscuous mode
[ 25.302783] mt7915e 0001:01:00.0 kabellos3EG: left allmulticast mode
[ 25.309146] mt7915e 0001:01:00.0 kabellos3EG: left promiscuous mode
[ 25.395338] mt7915e 0001:01:00.0 kabellos3EG: entered allmulticast mode
[ 25.402063] mt7915e 0001:01:00.0 kabellos3EG: entered promiscuous mode
[ 25.575429] mt7915e 0001:01:00.0 kabellos4EG: entered allmulticast mode
[ 25.582177] mt7915e 0001:01:00.0 kabellos4EG: entered promiscuous mode
[ 25.602906] mt7915e 0001:01:00.0 kabellos4EG: left allmulticast mode
[ 25.609268] mt7915e 0001:01:00.0 kabellos4EG: left promiscuous mode
[ 25.665184] mt7915e 0001:01:00.0 kabellos4EG: entered allmulticast mode
[ 25.671913] mt7915e 0001:01:00.0 kabellos4EG: entered promiscuous mode
[ 25.794668] mt7915e 0001:01:00.0 Zeug2EG: entered allmulticast mode
[ 25.801075] mt7915e 0001:01:00.0 Zeug2EG: entered promiscuous mode
[ 25.819846] mt7915e 0001:01:00.0 Zeug2EG: left allmulticast mode
[ 25.825861] mt7915e 0001:01:00.0 Zeug2EG: left promiscuous mode
[ 25.894406] mt7915e 0001:01:00.0 Zeug2EG: entered allmulticast mode
[ 25.900797] mt7915e 0001:01:00.0 Zeug2EG: entered promiscuous mode
[ 85.775083] mt7915e 0000:01:00.0 kabellos5WZ: entered allmulticast mode
[ 85.781824] mt7915e 0000:01:00.0 kabellos5WZ: entered promiscuous mode
[ 85.803209] mt7915e 0000:01:00.0 kabellos5WZ: left allmulticast mode
[ 85.809568] mt7915e 0000:01:00.0 kabellos5WZ: left promiscuous mode
[ 85.915021] mt7915e 0000:01:00.0 kabellos5WZ: entered allmulticast mode
[ 85.921736] mt7915e 0000:01:00.0 kabellos5WZ: entered promiscuous mode
[ 86.905095] mt7915e 0003:01:00.0 kabellos5EZ: entered allmulticast mode
[ 86.911840] mt7915e 0003:01:00.0 kabellos5EZ: entered promiscuous mode
[ 86.933122] mt7915e 0003:01:00.0 kabellos5EZ: left allmulticast mode
[ 86.939478] mt7915e 0003:01:00.0 kabellos5EZ: left promiscuous mode
[ 87.015206] mt7915e 0003:01:00.0 kabellos5EZ: entered allmulticast mode
[ 87.021989] mt7915e 0003:01:00.0 kabellos5EZ: entered promiscuous mode
root@rpi4:~# lspci
0000:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0000:01:00.0 Network controller: MEDIATEK Corp. Device 7906
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0001:01:00.0 Unclassified device [0002]: MEDIATEK Corp. MT7915E 802.11ax PCI Express Wireless Network Adapter
0003:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0003:01:00.0 Network controller: MEDIATEK Corp. Device 7906
I replaced wpad-basic-mebdtls by wpad-openssl, so this should’nt be the issue, right?
This is the full list of packages, I replaced/added: wpad-openssl luci-ssl openssh-server openssh-sftp-server speedtest-netperf kmod-mt7915e kmod-mt7915-firmware kmod-mt7916-firmware kmod-mt7615-common kmod-mt7615e kmod-mt7615-firmware lsblk usbutils pciutils block-mount kmod-fs-ext4 e2fsprogs iperf luci-app-dawn btrfs-progs kmod-fs-btrfs coreutils-sha256sum lm-sensors wget-ssl drill openssl-util luci-app-attendedsysupgrade
edit: just now tested replacing wpad-openssl by wpad-basic-openssl, but still no possiblity to change from 5GHz to 6GHz
Sorry, I only use the 5.500 GHz band so didn’t notice that 6g was no longer available as an option in luci until I just double checked. Yes the option is gone in rc7. I was able to manually change it in /etc/config/wireless but not in luci so not sure what the issue is.
this looks like there happens a crash/oops…try this:
dmesg | grep -B5 -A20 "Modules linked in:"
but here it seems your card is recognized
but i wonder why there are 5 phys for 2 cards…shouldn’t it be 6 (3 per card)?
root@PatIsa_AP_EG:~# dmesg | grep -B5 -A20 "Modules linked in:"
[ 25.340892] mt7915e 0001:01:00.0 Zeug2EG: entered promiscuous mode
[ 25.347204] br-iot: port 4(Zeug2EG) entered blocking state
[ 25.352720] br-iot: port 4(Zeug2EG) entered forwarding state
[ 84.963123] ------------[ cut here ]------------
[ 84.967746] WARNING: CPU: 2 PID: 778 at 0xffffffc078f0f6e4 [cfg80211@00000000c3bc8158+0x3e000]
[ 84.976363] Modules linked in: pppoe ppp_async nft_fib_inet nf_flow_table_inet pppox ppp_generic nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_chain_nat nf_tables nf_nat nf_flow_table nf_conntrack mt7996e(O) mt7915e(O) mt7615e(O) mt7615_common(O) mt76_connac_lib(O) mt76(O) mac80211(O) cfg80211(O) slhc sfp rtc_pcf8563 nfnetlink nf_reject_ipv6 nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 mdio_i2c compat(O) at24 crypto_safexcel pwm_fan i2c_mux_pca954x i2c_mux xxhash_generic sha512_arm64 sha1_ce sha1_generic seqiv md5 geniv des_generic libdes blake2b_generic authencesn authenc leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd xhci_hcd gpio_button_hotplug(O) btrfs xor xor_neon raid6_pq libcrc32c usbcore usb_common aquantia
[ 85.053892] CPU: 2 PID: 778 Comm: kworker/u8:4 Tainted: G O 6.6.69 #0
[ 85.061711] Hardware name: Bananapi BPI-R4 (DT)
[ 85.066230] Workqueue: events_unbound 0xffffffc078edc198 [cfg80211@00000000c3bc8158+0x3e000]
[ 85.074665] pstate: 80400005 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 85.081615] pc : 0xffffffc078f0f6e4 [cfg80211@00000000c3bc8158+0x3e000]
[ 85.088221] lr : 0xffffffc078f7ad60 [mac80211@00000000c03cd38a+0x74000]
[ 85.094826] sp : ffffffc083433cd0
[ 85.098129] x29: ffffffc083433cd0 x28: 0000000000000000 x27: 61c8864680b583eb
[ 85.105255] x26: ffffff80c0011028 x25: ffffff80c57783c0 x24: 0000000000000cc0
[ 85.112379] x23: ffffffc083433d50 x22: ffffff80c84cc950 x21: ffffff80c84cc000
[ 85.119503] x20: 0000000000000000 x19: 0000000000000001 x18: 00000000ffffffff
[ 85.126628] x17: 000015b800260008 x16: 0000000100a80008 x15: 0000000100000001
[ 85.133753] x14: ffffffc080c3c1e8 x13: 0000000000000000 x12: 0000000000000002
[ 85.140877] x11: 0000000000000000 x10: 00000000000008a0 x9 : ffffffc0834337b0
[ 85.148002] x8 : ffffff80ff79dd00 x7 : 0000000000010000 x6 : 0000000000000001
[ 85.155126] x5 : ffffff80c84cc950 x4 : 0000000000000000 x3 : 0000000000000cc0
[ 85.162250] x2 : 0000000000000001 x1 : ffffffc083433d50 x0 : 0000000000000000
[ 85.169374] Call trace:
[ 85.171810] 0xffffffc078f0f6e4 [cfg80211@00000000c3bc8158+0x3e000]
[ 85.178068] 0xffffffc078f7ad60 [mac80211@00000000c03cd38a+0x74000]
I have 3 cards installed: 2xMT7916 + 1xMT7915E. As the MT7915E is not DBDC and thus creates only 1 phy, it is 5 phys in total.
The cards are not only recognized, but do function just as desired, when using the 2,4GHz- and 5,8GHz-phys. The only issue I encountered so far is only that I cannot choose the WIFI 6E-channels instead of WIFI 6-5GHz-channels.
Ok, so this is indeed a luci-issue → I will need to create a ticket in OpenWRT bug tracker. Could you share the config part for setting up a 6GHz-SSID?
So yes something crashes here,but location is not easy to get…normally warnings are posted with filename and linenumber. Also calltrace looks strange…there should be function names which then can be filled with printks to get the rootcause.
You could try searching for the warning and cfg80211…
Oh overseen this because the mt7915e is not recognized as network device ( Unclassified device in lspci).
Hello! I have BPI R4 equipped with a MT7916 NPD PCIE and is working as expected without wireless offloading. However once I enable WED, although I see the binds for the offloading @/sys/kernel/debug/pp*/bind downlink is capped at 6 Mbps. I am on OpenWrt 24.10.5 / r29087-d9c5716d1d. Also tried latest Snapshot with same behavior.
Wifi config:
config wifi-device 'radio1'
option type 'mac80211'
option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0+1'
option band '5g'
option channel '149'
option htmode 'HE80'
option disabled '0'
option country 'GB'
option txpower '20'
option cell_density '0'
config wifi-iface 'default_radio1'
option device 'radio1'
option network 'lan'
option mode 'ap'
option ssid 'BPI_5G'
option encryption 'psk2'
and negotiated capabilities with client
Station 0e:06:45:5b:33:f0 (on phy1-ap0)
inactive time: 890 ms
rx bytes: 14589
rx packets: 211
tx bytes: 14180
tx packets: 81
tx retries: 43
tx failed: 43
rx drop misc: 1
signal: -77 [-84, -78] dBm
signal avg: -77 [-82, -79] dBm
tx bitrate: 6.0 MBit/s
tx duration: 21216 us
rx bitrate: 12.0 MBit/s 80MHz
rx duration: 48769 us
last ack signal:-78 dBm
avg ack signal: -76 dBm
airtime weight: 256
authorized: yes
authenticated: yes
associated: yes
preamble: long
WMM/WME: yes
MFP: no
TDLS peer: no
DTIM period: 2
beacon interval:100
short slot time:yes
connected time: 13 seconds
associated at [boottime]: 4156.751s
associated at: 1770477873146 ms
current time: 1770477886020 ms
Does anyone know if WED is supposed to be working and/or if there is a workaround for this behavior? I was not able to find anything in the forum. Please let me know if I should grab any set of logs. Thank you!
WED will only work with BE14/BE19 afaik.
