[BPi-R4] LTE pciport/mhi crashes and cannot recover?
Hi guys, Need some help here. Have a Quectel EM120R-GL modem in the m.2 slot and as soon as I start trying to enable the internet connection over it the driver? crashes and seem to not be able to recover.
The following is the errors at the time of the crash which goes on in an endless loop:
[ 1168.733081] pcieport 0003:00:00.0: PME: Spurious native interrupt!
[ 1168.733117] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0
[ 1168.733155] pcieport 0003:00:00.0: PCIe Bus Error: severity=Uncorrectable (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 1168.733160] pcieport 0003:00:00.0:   device [14c3:7988] error status/mask=00004000/00400000
[ 1168.733166] pcieport 0003:00:00.0:    [14] CmpltTO                (First)
[ 1168.743606] pcieport 0003:00:00.0: restore config 0x2c: 0x00000000 -> 0x00000000
[ 1168.743626] pcieport 0003:00:00.0: restore config 0x28: 0x00000000 -> 0x00000000
[ 1168.743633] pcieport 0003:00:00.0: restore config 0x24: 0x0001fff1 -> 0x0001fff1
[ 1168.743669] pcieport 0003:00:00.0: PME# disabled
[ 1168.755863] mhi-pci-generic 0003:01:00.0: PME# disabled
[ 1168.755891] mhi-pci-generic 0003:01:00.0: enabling bus mastering
[ 1168.775335] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1168.775357] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 1
[ 1168.775542] wwan wwan0: port wwan0qcdm0 disconnected
[ 1168.776414] wwan wwan0: port wwan0mbim0 disconnected
[ 1168.776913] wwan wwan0: port wwan0at0 disconnected
[ 1168.887098] pcieport 0003:00:00.0: waiting 100 ms for downstream link, after activation
[ 1169.917117] pcieport 0003:00:00.0: Data Link Layer Link Active not set in 100 msec
[ 1169.917140] pcieport 0003:00:00.0: AER: Root Port link has been reset (-25)
[ 1169.917149] pcieport 0003:00:00.0: AER: subordinate device reset failed
[ 1169.917162] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 3
[ 1169.917210] pcieport 0003:00:00.0: AER: device recovery failed
[ 1171.273452] ------------[ cut here ]------------
[ 1171.273466] mhi-pci-generic 0003:01:00.0: disabling already-disabled device
[ 1171.273491] WARNING: CPU: 0 PID: 137 at drivers/pci/pci.c:2231 pci_disable_device+0x128/0x154
[ 1171.273510] Modules linked in: iptable_filter ipt_REJECT xt_addrtype nf_conntrack_netlink veth xfrm_user xfrm_algo nft_reject_ipv4 nf_reject_ipv4 nft_reject nf_flow_table_inet nf_conntrack_tftp nft_limit nft_nat nf_log_syslog nft_masq nft_log nft_fib_ipv4 nft_fib nft_redir nft_ct nft_chain_nat btrfs xor xor_neon raid6_pq xt_MASQUERADE xt_conntrack xt_iprange xt_tcpudp xt_multiport xt_nat nf_nat xt_connmark xt_LOG ip_tables x_tables tun nft_flow_offload nf_tables nfnetlink nf_flow_table nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 spidev mhi_wwan_mbim mhi_wwan_ctrl wwan mhi_pci_generic mhi
[ 1171.273620] CPU: 0 UID: 0 PID: 137 Comm: kworker/0:2 Not tainted 6.18.23-bpi-r4-main #5 NONE
[ 1171.273627] Hardware name: Banana Pi BPI-R4 (2x SFP+) (DT)
[ 1171.273631] Workqueue: pm pm_runtime_work
[ 1171.273642] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1171.273648] pc : pci_disable_device+0x128/0x154
[ 1171.273654] lr : pci_disable_device+0x128/0x154
[ 1171.273660] sp : ffffffc08256bbf0
[ 1171.273663] x29: ffffffc08256bc00 x28: ffffff80c0c5c000 x27: 0000000000000000
[ 1171.273671] x26: 0000000000000000 x25: 00000000000f4240 x24: ffffff80c01e50c0
[ 1171.273680] x23: 0000000000000000 x22: ffffffc07983c0c0 x21: ffffff80c170a000
[ 1171.273688] x20: ffffff80c170a0c8 x19: ffffff80c170a000 x18: ffffffffffffffff
[ 1171.273696] x17: 0000000000000000 x16: 0000000000000000 x15: fffffffffffe68d0
[ 1171.273703] x14: 00000000ffffffea x13: ffffffc08256b968 x12: ffffffc081589c70
[ 1171.273711] x11: ffffffc081531cc8 x10: ffffffc081589cc8 x9 : 0000000000000001
[ 1171.273719] x8 : 0000000000000001 x7 : 0000000000017fe8 x6 : 0000000000000001
[ 1171.273727] x5 : ffffff81fef48688 x4 : 0000000000000000 x3 : 0000000000000027
[ 1171.273734] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffffff80c17da080
[ 1171.273743] Call trace:
[ 1171.273747]  pci_disable_device+0x128/0x154 (P)
[ 1171.273755]  mhi_pci_runtime_suspend+0x60/0x11c [mhi_pci_generic]
[ 1171.273766]  pci_pm_runtime_suspend+0x54/0x1c4
[ 1171.273771]  __rpm_callback+0x40/0x240
[ 1171.273779]  rpm_callback+0x74/0x80
[ 1171.273785]  rpm_suspend+0xd8/0x650
[ 1171.273791]  pm_runtime_work+0x114/0x11c
[ 1171.273797]  process_one_work+0x164/0x3bc
[ 1171.273804]  worker_thread+0x1b4/0x390
[ 1171.273810]  kthread+0x114/0x1d4
[ 1171.273816]  ret_from_fork+0x10/0x20
[ 1171.273825] ---[ end trace 0000000000000000 ]---
[ 1171.323663] mhi-pci-generic 0003:01:00.0: save config 0x00: 0x00000000
[ 1171.373674] mhi-pci-generic 0003:01:00.0: save config 0x04: 0x00000000
[ 1171.423638] mhi-pci-generic 0003:01:00.0: save config 0x08: 0x00000000
[ 1171.473659] mhi-pci-generic 0003:01:00.0: save config 0x0c: 0x00000000
[ 1171.523649] mhi-pci-generic 0003:01:00.0: save config 0x10: 0x00000000
[ 1171.573625] mhi-pci-generic 0003:01:00.0: save config 0x14: 0x00000000
[ 1171.623659] mhi-pci-generic 0003:01:00.0: save config 0x18: 0x00000000
[ 1171.673669] mhi-pci-generic 0003:01:00.0: save config 0x1c: 0x00000000
[ 1171.723642] mhi-pci-generic 0003:01:00.0: save config 0x20: 0x00000000
[ 1171.773667] mhi-pci-generic 0003:01:00.0: save config 0x24: 0x00000000
[ 1171.823640] mhi-pci-generic 0003:01:00.0: save config 0x28: 0x00000000
[ 1171.873808] mhi-pci-generic 0003:01:00.0: save config 0x2c: 0x00000000
[ 1171.923639] mhi-pci-generic 0003:01:00.0: save config 0x30: 0x00000000
[ 1171.973636] mhi-pci-generic 0003:01:00.0: save config 0x34: 0x00000000
[ 1172.023654] mhi-pci-generic 0003:01:00.0: save config 0x38: 0x00000000
[ 1172.073629] mhi-pci-generic 0003:01:00.0: save config 0x3c: 0x00000000
[ 1172.923846] mhi-pci-generic 0003:01:00.0: PME# enabled
[ 1173.023762] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0
[ 1173.023786] pcieport 0003:00:00.0: PCIe Bus Error: severity=Uncorrectable (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 1173.023791] pcieport 0003:00:00.0:   device [14c3:7988] error status/mask=00004000/00400000
[ 1173.023797] pcieport 0003:00:00.0:    [14] CmpltTO                (First)
[ 1173.085621] mhi-pci-generic 0003:01:00.0: Refused to change power state from D0 to D3hot
[ 1173.535604] pcieport 0003:00:00.0: re-enabling LTR
[ 1174.735302] sched: RT throttling activated
[ 1175.985691] mhi-pci-generic 0003:01:00.0: PME# disabled
[ 1176.085839] mhi-pci-generic 0003:01:00.0: enabling device (0000 -> 0002)
[ 1176.185735] mhi-pci-generic 0003:01:00.0: enabling bus mastering
[ 1176.235694] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1176.235704] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 1
[ 1176.236205] pcieport 0003:00:00.0: AER: broadcast resume message
[ 1176.236219] mhi-pci-generic 0003:01:00.0: PCI slot reset done
[ 1176.236246] pcieport 0003:00:00.0: AER: device recovery successful
[ 1176.236287] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236298] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236307] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236320] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236328] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236335] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236343] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236355] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236362] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236370] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1176.236702] mhi-pci-generic 0003:01:00.0: device recovery started
[ 1177.436753] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1177.586740] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1177.886712] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1177.987765] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.088894] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.189846] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.290913] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.391812] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.492803] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.593909] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.694937] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.795899] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1178.896901] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1179.046821] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.147814] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.248854] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.349892] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.450948] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.551897] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.652817] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.753693] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.854736] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1179.955707] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1180.056890] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1180.206697] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1180.306856] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1180.406706] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1181.206683] mhi-pci-generic 0003:01:00.0: reset
[ 1181.206732] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1183.297643] mhi-pci-generic 0003:01:00.0: save config 0x00: 0x00000000
[ 1183.347634] mhi-pci-generic 0003:01:00.0: save config 0x04: 0x00000000
[ 1183.397638] mhi-pci-generic 0003:01:00.0: save config 0x08: 0x00000000
[ 1183.447693] mhi-pci-generic 0003:01:00.0: save config 0x0c: 0x00000000
[ 1183.497757] mhi-pci-generic 0003:01:00.0: save config 0x10: 0x00000000
[ 1183.547653] mhi-pci-generic 0003:01:00.0: save config 0x14: 0x00000000
[ 1183.597633] mhi-pci-generic 0003:01:00.0: save config 0x18: 0x00000000
[ 1183.647628] mhi-pci-generic 0003:01:00.0: save config 0x1c: 0x00000000
[ 1183.697658] mhi-pci-generic 0003:01:00.0: save config 0x20: 0x00000000
[ 1183.747612] mhi-pci-generic 0003:01:00.0: save config 0x24: 0x00000000
[ 1183.797650] mhi-pci-generic 0003:01:00.0: save config 0x28: 0x00000000
[ 1183.847631] mhi-pci-generic 0003:01:00.0: save config 0x2c: 0x00000000
[ 1183.897634] mhi-pci-generic 0003:01:00.0: save config 0x30: 0x00000000
[ 1183.947618] mhi-pci-generic 0003:01:00.0: save config 0x34: 0x00000000
[ 1183.997647] mhi-pci-generic 0003:01:00.0: save config 0x38: 0x00000000
[ 1184.047632] mhi-pci-generic 0003:01:00.0: save config 0x3c: 0x00000000
[ 1184.847647] mhi-pci-generic 0003:01:00.0: reset via bus
[ 1184.847678] pcieport 0003:00:00.0: unlocked secondary bus reset via: pci_reset_bus_function+0x158/0x184
[ 1184.867476] pcieport 0003:00:00.0: waiting 100 ms for downstream link, after activation
[ 1185.897473] pcieport 0003:00:00.0: Data Link Layer Link Active not set in 100 msec
[ 1185.897496] mhi-pci-generic 0003:01:00.0: bus failed with -25
[ 1189.647693] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1189.797689] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1190.097698] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1190.198751] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1190.299739] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1190.400707] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1190.501702] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1190.602712] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1190.703704] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1190.804701] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1190.905697] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1191.006842] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1191.107929] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1191.257881] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1191.358893] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1191.459895] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1191.560830] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1191.661829] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1191.762803] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1191.863841] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1191.964768] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1192.065857] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1192.166895] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1192.267933] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1192.417687] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1192.517673] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1192.617688] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1193.417686] mhi-pci-generic 0003:01:00.0: reset failed
[ 1193.418056] mhi-pci-generic 0003:01:00.0: Recovery failed: -25
[ 1193.418077] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 1
[ 1193.418133] pcieport 0003:00:00.0: AER: broadcast resume message
[ 1193.418139] mhi-pci-generic 0003:01:00.0: PCI slot reset done
[ 1193.418164] pcieport 0003:00:00.0: AER: device recovery successful
[ 1193.418174] aer_ratelimit: 77 callbacks suppressed
[ 1193.418178] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418188] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418197] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418205] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418213] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418220] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418228] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418235] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418243] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.418251] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1193.424246] mhi-pci-generic 0003:01:00.0: device recovery started
[ 1194.624082] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1194.773756] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1195.073823] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.174751] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.275874] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.376848] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.478119] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.578785] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.679815] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.780809] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.881815] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1195.982791] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1196.083947] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1196.233715] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1196.334847] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1196.435917] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1196.536729] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1196.638044] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1196.738712] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1196.839717] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1196.940741] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1197.041683] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1197.142829] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1197.243720] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1197.393685] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1197.493831] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1197.593708] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1198.393713] mhi-pci-generic 0003:01:00.0: reset
[ 1198.393763] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1200.497622] mhi-pci-generic 0003:01:00.0: save config 0x00: 0x00000000
[ 1200.547644] mhi-pci-generic 0003:01:00.0: save config 0x04: 0x00000000
[ 1200.597332] mhi-pci-generic 0003:01:00.0: save config 0x08: 0x00000000
[ 1200.647452] mhi-pci-generic 0003:01:00.0: save config 0x0c: 0x00000000
[ 1200.697662] mhi-pci-generic 0003:01:00.0: save config 0x10: 0x00000000
[ 1200.747827] mhi-pci-generic 0003:01:00.0: save config 0x14: 0x00000000
[ 1200.797718] mhi-pci-generic 0003:01:00.0: save config 0x18: 0x00000000
[ 1200.847858] mhi-pci-generic 0003:01:00.0: save config 0x1c: 0x00000000
[ 1200.897648] mhi-pci-generic 0003:01:00.0: save config 0x20: 0x00000000
[ 1200.947649] mhi-pci-generic 0003:01:00.0: save config 0x24: 0x00000000
[ 1200.997627] mhi-pci-generic 0003:01:00.0: save config 0x28: 0x00000000
[ 1201.047627] mhi-pci-generic 0003:01:00.0: save config 0x2c: 0x00000000
[ 1201.097812] mhi-pci-generic 0003:01:00.0: save config 0x30: 0x00000000
[ 1201.147680] mhi-pci-generic 0003:01:00.0: save config 0x34: 0x00000000
[ 1201.197660] mhi-pci-generic 0003:01:00.0: save config 0x38: 0x00000000
[ 1201.247629] mhi-pci-generic 0003:01:00.0: save config 0x3c: 0x00000000
[ 1202.047867] mhi-pci-generic 0003:01:00.0: reset via bus
[ 1202.067824] pcieport 0003:00:00.0: waiting 100 ms for downstream link, after activation
[ 1203.097829] pcieport 0003:00:00.0: Data Link Layer Link Active not set in 100 msec
[ 1203.097853] mhi-pci-generic 0003:01:00.0: bus failed with -25
[ 1206.847682] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1206.997688] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1207.297685] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1207.398683] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1207.499715] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1207.600682] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1207.701709] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1207.802694] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1207.903709] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1208.004850] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1208.105755] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1208.206866] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1208.307798] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1208.457884] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1208.558881] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1208.659841] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1208.760898] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1208.861858] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1208.962838] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1209.063884] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1209.164784] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1209.265847] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1209.366709] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1209.467683] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1209.617673] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1209.717738] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1209.817710] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1210.617688] mhi-pci-generic 0003:01:00.0: reset failed
[ 1210.618070] mhi-pci-generic 0003:01:00.0: Recovery failed: -25
[ 1210.618094] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 1
[ 1210.618147] pcieport 0003:00:00.0: AER: broadcast resume message
[ 1210.618154] mhi-pci-generic 0003:01:00.0: PCI slot reset done
[ 1210.618177] pcieport 0003:00:00.0: AER: device recovery successful
[ 1210.618187] aer_ratelimit: 119 callbacks suppressed
[ 1210.618191] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618201] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618210] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618218] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618225] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618232] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618240] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618248] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618256] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.618263] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1210.625363] mhi-pci-generic 0003:01:00.0: device recovery started
[ 1211.826227] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1211.976776] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1212.276826] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1212.377978] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1212.478566] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1212.579822] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1212.680908] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1212.781813] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1212.882853] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1212.983807] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1213.084862] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1213.185793] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1213.286794] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1213.436767] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1213.537880] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1213.638784] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1213.739708] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1213.840700] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1213.941714] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1214.042838] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1214.143733] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1214.244703] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1214.345684] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1214.446672] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1214.596664] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1214.696838] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1214.796701] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1215.596670] mhi-pci-generic 0003:01:00.0: reset
[ 1215.596718] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1217.697619] mhi-pci-generic 0003:01:00.0: save config 0x00: 0x00000000
[ 1217.747762] mhi-pci-generic 0003:01:00.0: save config 0x04: 0x00000000
[ 1217.797650] mhi-pci-generic 0003:01:00.0: save config 0x08: 0x00000000
[ 1217.847648] mhi-pci-generic 0003:01:00.0: save config 0x0c: 0x00000000
[ 1217.897646] mhi-pci-generic 0003:01:00.0: save config 0x10: 0x00000000
[ 1217.947642] mhi-pci-generic 0003:01:00.0: save config 0x14: 0x00000000
[ 1217.997646] mhi-pci-generic 0003:01:00.0: save config 0x18: 0x00000000
[ 1218.047621] mhi-pci-generic 0003:01:00.0: save config 0x1c: 0x00000000
[ 1218.097791] mhi-pci-generic 0003:01:00.0: save config 0x20: 0x00000000
[ 1218.147646] mhi-pci-generic 0003:01:00.0: save config 0x24: 0x00000000
[ 1218.197653] mhi-pci-generic 0003:01:00.0: save config 0x28: 0x00000000
[ 1218.247758] mhi-pci-generic 0003:01:00.0: save config 0x2c: 0x00000000
[ 1218.297638] mhi-pci-generic 0003:01:00.0: save config 0x30: 0x00000000
[ 1218.347678] mhi-pci-generic 0003:01:00.0: save config 0x34: 0x00000000
[ 1218.397643] mhi-pci-generic 0003:01:00.0: save config 0x38: 0x00000000
[ 1218.447637] mhi-pci-generic 0003:01:00.0: save config 0x3c: 0x00000000
[ 1219.247623] mhi-pci-generic 0003:01:00.0: reset via bus
[ 1219.258166] pcieport 0003:00:00.0: waiting 100 ms for downstream link, after activation
[ 1220.288193] pcieport 0003:00:00.0: Data Link Layer Link Active not set in 100 msec
[ 1220.288214] mhi-pci-generic 0003:01:00.0: bus failed with -25
[ 1224.038039] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1224.188786] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1224.488679] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1224.589684] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1224.690679] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1224.791689] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1224.892749] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1224.993712] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1225.094840] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1225.195843] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1225.296701] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1225.397717] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1225.498718] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1225.648867] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1225.749891] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1225.850830] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1225.951838] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1226.052852] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1226.153821] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1226.254864] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1226.355827] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1226.456881] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1226.557702] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1226.658699] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1226.808741] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1226.908766] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1227.008711] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1227.808678] mhi-pci-generic 0003:01:00.0: reset failed
[ 1227.809050] mhi-pci-generic 0003:01:00.0: Recovery failed: -25
[ 1227.809073] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 1
[ 1227.809489] pcieport 0003:00:00.0: AER: broadcast resume message
[ 1227.809500] mhi-pci-generic 0003:01:00.0: PCI slot reset done
[ 1227.809535] pcieport 0003:00:00.0: AER: device recovery successful
[ 1227.809546] aer_ratelimit: 119 callbacks suppressed
[ 1227.809550] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809561] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809569] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809577] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809584] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809591] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809599] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809607] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809614] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.809621] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1227.814882] mhi-pci-generic 0003:01:00.0: device recovery started
[ 1229.016161] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1229.166762] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1229.466852] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1229.567837] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1229.668868] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1229.769864] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1229.870880] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1229.971864] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1230.072955] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1230.173910] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1230.274913] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1230.375896] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1230.476934] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1230.626824] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1230.727833] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1230.828923] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1230.929914] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1231.030920] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1231.131830] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1231.232900] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1231.333792] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1231.434732] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1231.535696] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1231.636684] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1231.786686] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1231.886706] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1231.986701] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1232.786695] mhi-pci-generic 0003:01:00.0: reset
[ 1232.786745] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1234.898737] mhi-pci-generic 0003:01:00.0: save config 0x00: 0x00000000
[ 1234.948654] mhi-pci-generic 0003:01:00.0: save config 0x04: 0x00000000
[ 1234.998759] mhi-pci-generic 0003:01:00.0: save config 0x08: 0x00000000
[ 1235.048668] mhi-pci-generic 0003:01:00.0: save config 0x0c: 0x00000000
[ 1235.098655] mhi-pci-generic 0003:01:00.0: save config 0x10: 0x00000000
[ 1235.148643] mhi-pci-generic 0003:01:00.0: save config 0x14: 0x00000000
[ 1235.198624] mhi-pci-generic 0003:01:00.0: save config 0x18: 0x00000000
[ 1235.248642] mhi-pci-generic 0003:01:00.0: save config 0x1c: 0x00000000
[ 1235.298643] mhi-pci-generic 0003:01:00.0: save config 0x20: 0x00000000
[ 1235.348622] mhi-pci-generic 0003:01:00.0: save config 0x24: 0x00000000
[ 1235.398657] mhi-pci-generic 0003:01:00.0: save config 0x28: 0x00000000
[ 1235.448641] mhi-pci-generic 0003:01:00.0: save config 0x2c: 0x00000000
[ 1235.498654] mhi-pci-generic 0003:01:00.0: save config 0x30: 0x00000000
[ 1235.548633] mhi-pci-generic 0003:01:00.0: save config 0x34: 0x00000000
[ 1235.598620] mhi-pci-generic 0003:01:00.0: save config 0x38: 0x00000000
[ 1235.648640] mhi-pci-generic 0003:01:00.0: save config 0x3c: 0x00000000
[ 1236.448618] mhi-pci-generic 0003:01:00.0: reset via bus
[ 1236.468527] pcieport 0003:00:00.0: waiting 100 ms for downstream link, after activation
[ 1237.498551] pcieport 0003:00:00.0: Data Link Layer Link Active not set in 100 msec
[ 1237.498574] mhi-pci-generic 0003:01:00.0: bus failed with -25
[ 1241.248812] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1241.398693] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1241.698692] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1241.799794] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1241.900754] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.001530] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.102840] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.203823] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.304842] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.405691] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.506681] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.607679] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.709023] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1242.858896] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1242.959911] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.060932] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.161840] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.262904] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.363955] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.464865] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.565849] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.666753] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.767707] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1243.869046] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1244.018699] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1244.118860] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1244.218712] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1245.018705] mhi-pci-generic 0003:01:00.0: reset failed
[ 1245.019073] mhi-pci-generic 0003:01:00.0: Recovery failed: -25
[ 1245.019095] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 1
[ 1245.019154] pcieport 0003:00:00.0: AER: broadcast resume message
[ 1245.019163] mhi-pci-generic 0003:01:00.0: PCI slot reset done
[ 1245.019187] pcieport 0003:00:00.0: AER: device recovery successful
[ 1245.019197] aer_ratelimit: 119 callbacks suppressed
[ 1245.019201] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019211] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019219] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019226] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019234] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019241] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019249] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019256] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019264] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.019271] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1245.024561] mhi-pci-generic 0003:01:00.0: device recovery started
[ 1246.224765] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1246.374733] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1246.674775] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1246.775800] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1246.876513] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1246.977914] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1247.079099] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1247.179581] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1247.280549] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1247.381520] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1247.482812] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1247.583514] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1247.684787] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1247.834763] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1247.935748] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.036922] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.137890] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.238746] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.339750] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.440715] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.541747] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.642855] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.743719] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.844689] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1248.994681] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1249.094857] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1249.194729] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1249.994689] mhi-pci-generic 0003:01:00.0: reset
[ 1249.994737] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1252.098648] mhi-pci-generic 0003:01:00.0: save config 0x00: 0x00000000
[ 1252.148639] mhi-pci-generic 0003:01:00.0: save config 0x04: 0x00000000
[ 1252.198645] mhi-pci-generic 0003:01:00.0: save config 0x08: 0x00000000
[ 1252.248654] mhi-pci-generic 0003:01:00.0: save config 0x0c: 0x00000000
[ 1252.298644] mhi-pci-generic 0003:01:00.0: save config 0x10: 0x00000000
[ 1252.348647] mhi-pci-generic 0003:01:00.0: save config 0x14: 0x00000000
[ 1252.398633] mhi-pci-generic 0003:01:00.0: save config 0x18: 0x00000000
[ 1252.448641] mhi-pci-generic 0003:01:00.0: save config 0x1c: 0x00000000
[ 1252.498630] mhi-pci-generic 0003:01:00.0: save config 0x20: 0x00000000
[ 1252.548646] mhi-pci-generic 0003:01:00.0: save config 0x24: 0x00000000
[ 1252.598617] mhi-pci-generic 0003:01:00.0: save config 0x28: 0x00000000
[ 1252.648628] mhi-pci-generic 0003:01:00.0: save config 0x2c: 0x00000000
[ 1252.698640] mhi-pci-generic 0003:01:00.0: save config 0x30: 0x00000000
[ 1252.748640] mhi-pci-generic 0003:01:00.0: save config 0x34: 0x00000000
[ 1252.798634] mhi-pci-generic 0003:01:00.0: save config 0x38: 0x00000000
[ 1252.848634] mhi-pci-generic 0003:01:00.0: save config 0x3c: 0x00000000
[ 1253.648825] mhi-pci-generic 0003:01:00.0: reset via bus
[ 1253.658964] pcieport 0003:00:00.0: waiting 100 ms for downstream link, after activation
[ 1254.688922] pcieport 0003:00:00.0: Data Link Layer Link Active not set in 100 msec
[ 1254.688944] mhi-pci-generic 0003:01:00.0: bus failed with -25
[ 1258.438715] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1258.588685] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1258.888667] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1258.989761] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.090633] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.191751] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.292816] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.393681] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.494861] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.595731] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.696710] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.797683] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1259.898697] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1260.048890] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.149860] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.250870] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.351861] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.452848] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.553829] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.654814] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.755839] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.856779] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1260.957721] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1261.058840] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1261.208691] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1261.308714] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1261.408702] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1262.208693] mhi-pci-generic 0003:01:00.0: reset failed
[ 1262.209100] mhi-pci-generic 0003:01:00.0: Recovery failed: -25
[ 1262.209123] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 1
[ 1262.209180] pcieport 0003:00:00.0: AER: broadcast resume message
[ 1262.209187] mhi-pci-generic 0003:01:00.0: PCI slot reset done
[ 1262.209210] pcieport 0003:00:00.0: AER: device recovery successful
[ 1262.209220] aer_ratelimit: 119 callbacks suppressed
[ 1262.209224] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209234] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209242] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209249] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209256] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209263] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209271] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209279] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209286] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.209293] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1262.215136] mhi-pci-generic 0003:01:00.0: device recovery started
[ 1263.414720] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1263.564752] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1263.864709] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1263.965810] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.066912] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.167838] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.268791] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.369850] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.470826] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.571794] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.672761] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.773857] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1264.874788] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1265.024909] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.125894] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.226822] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.327748] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.428722] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.529798] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.630699] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.731857] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.832695] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1265.933695] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1266.034823] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1266.184688] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1266.284737] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1266.384708] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1267.184713] mhi-pci-generic 0003:01:00.0: reset
[ 1267.184762] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1269.298641] mhi-pci-generic 0003:01:00.0: save config 0x00: 0x00000000
[ 1269.348616] mhi-pci-generic 0003:01:00.0: save config 0x04: 0x00000000
[ 1269.398662] mhi-pci-generic 0003:01:00.0: save config 0x08: 0x00000000
[ 1269.448636] mhi-pci-generic 0003:01:00.0: save config 0x0c: 0x00000000
[ 1269.498663] mhi-pci-generic 0003:01:00.0: save config 0x10: 0x00000000
[ 1269.548661] mhi-pci-generic 0003:01:00.0: save config 0x14: 0x00000000
[ 1269.598658] mhi-pci-generic 0003:01:00.0: save config 0x18: 0x00000000
[ 1269.648635] mhi-pci-generic 0003:01:00.0: save config 0x1c: 0x00000000
[ 1269.698666] mhi-pci-generic 0003:01:00.0: save config 0x20: 0x00000000
[ 1269.748642] mhi-pci-generic 0003:01:00.0: save config 0x24: 0x00000000
[ 1269.798656] mhi-pci-generic 0003:01:00.0: save config 0x28: 0x00000000
[ 1269.848641] mhi-pci-generic 0003:01:00.0: save config 0x2c: 0x00000000
[ 1269.898667] mhi-pci-generic 0003:01:00.0: save config 0x30: 0x00000000
[ 1269.948781] mhi-pci-generic 0003:01:00.0: save config 0x34: 0x00000000
[ 1269.998653] mhi-pci-generic 0003:01:00.0: save config 0x38: 0x00000000
[ 1270.048745] mhi-pci-generic 0003:01:00.0: save config 0x3c: 0x00000000
[ 1270.848641] mhi-pci-generic 0003:01:00.0: reset via bus
[ 1270.859256] pcieport 0003:00:00.0: waiting 100 ms for downstream link, after activation
[ 1271.889285] pcieport 0003:00:00.0: Data Link Layer Link Active not set in 100 msec
[ 1271.889306] mhi-pci-generic 0003:01:00.0: bus failed with -25
[ 1275.639721] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1275.789776] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1276.089850] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.190945] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.291848] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.392517] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.493782] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.594454] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.695715] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.796478] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.897467] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1276.998558] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1277.099480] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1277.249858] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1277.350977] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1277.451809] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1277.552506] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1277.653510] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1277.754485] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1277.855821] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1277.956483] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1278.057854] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1278.158868] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1278.259775] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1278.409740] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1278.509845] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1278.609704] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1279.409682] mhi-pci-generic 0003:01:00.0: reset failed
[ 1279.410055] mhi-pci-generic 0003:01:00.0: Recovery failed: -25
[ 1279.410076] mhi-pci-generic 0003:01:00.0: PCI error detected, state = 1
[ 1279.410494] pcieport 0003:00:00.0: AER: broadcast resume message
[ 1279.410506] mhi-pci-generic 0003:01:00.0: PCI slot reset done
[ 1279.410544] pcieport 0003:00:00.0: AER: device recovery successful
[ 1279.410556] aer_ratelimit: 119 callbacks suppressed
[ 1279.410559] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410570] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410578] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410585] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410593] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410600] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410608] pcieport 0003:00:00.0: AER: Multiple Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410615] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410622] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.410630] pcieport 0003:00:00.0: AER: Uncorrectable (Non-Fatal) error message received from 0003:00:00.0 (no details found
[ 1279.412611] mhi-pci-generic 0003:01:00.0: device recovery started
[ 1280.612875] mhi-pci-generic 0003:01:00.0: restore config 0x34: 0x00000000 -> 0x00000040
[ 1280.762914] mhi-pci-generic 0003:01:00.0: restore config 0x2c: 0x00000000 -> 0x20011eac
[ 1281.062907] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.164243] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.264858] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.365897] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.466895] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.567885] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.668877] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.769917] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.870885] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1281.971919] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1282.072929] mhi-pci-generic 0003:01:00.0: restore config 0x18: 0x00000000 -> 0x20201004
[ 1282.222810] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1282.323902] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1282.424855] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1282.525863] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1282.626846] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1282.727877] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1282.828795] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1282.929880] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1283.030844] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1283.131877] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1283.232936] mhi-pci-generic 0003:01:00.0: restore config 0x10: 0x00000000 -> 0x20200004
[ 1283.382772] mhi-pci-generic 0003:01:00.0: restore config 0x08: 0x00000000 -> 0xff000000
[ 1283.482764] mhi-pci-generic 0003:01:00.0: restore config 0x04: 0x00000000 -> 0x00100406
[ 1283.582768] mhi-pci-generic 0003:01:00.0: restore config 0x00: 0x00000000 -> 0x10011eac
[ 1284.382688] mhi-pci-generic 0003:01:00.0: reset
[ 1284.382737] pcieport 0003:00:00.0: AER: broadcast error_detected message
[ 1286.499644] mhi-pci-generic 0003:01:00.0: save config 0x00: 0x00000000
[ 1286.549646] mhi-pci-generic 0003:01:00.0: save config 0x04: 0x00000000
[ 1286.599662] mhi-pci-generic 0003:01:00.0: save config 0x08: 0x00000000
[ 1286.649646] mhi-pci-generic 0003:01:00.0: save config 0x0c: 0x00000000
[ 1286.699637] mhi-pci-generic 0003:01:00.0: save config 0x10: 0x00000000
[ 1286.749650] mhi-pci-generic 0003:01:00.0: save config 0x14: 0x00000000
[ 1286.799638] mhi-pci-generic 0003:01:00.0: save config 0x18: 0x00000000
[ 1286.849657] mhi-pci-generic 0003:01:00.0: save config 0x1c: 0x00000000
[ 1286.899826] mhi-pci-generic 0003:01:00.0: save config 0x20: 0x00000000
[ 1286.949664] mhi-pci-generic 0003:01:00.0: save config 0x24: 0x00000000
[ 1286.999644] mhi-pci-generic 0003:01:00.0: save config 0x28: 0x00000000
[ 1287.049811] mhi-pci-generic 0003:01:00.0: save config 0x2c: 0x00000000
[ 1287.099654] mhi-pci-generic 0003:01:00.0: save config 0x30: 0x00000000
[ 1287.149668] mhi-pci-generic 0003:01:00.0: save config 0x34: 0x00000000
[ 1287.199627] mhi-pci-generic 0003:01:00.0: save config 0x38: 0x00000000
[ 1287.249667] mhi-pci-generic 0003:01:00.0: save config 0x3c: 0x00000000
[ 1288.049633] mhi-pci-generic 0003:01:00.0: reset via bus
[ 1288.069631] pcieport 0003:00:00.0: waiting 100 ms for downstream link, after activation
[ 1289.099641] pcieport 0003:00:00.0: Data Link Layer Link Active not set in 100 msec
[ 1289.099664] mhi-pci-generic 0003:01:00.0: bus failed with -25
I’m using a powerful powersupply (12V,10A) so that shouldn’t be an issue. Using @frank-w kernel 6.18-main with the appropiate drivers enabled ofc.
What could it be? Where should I start to look?
Due to this being a PCIe modem and not an USB modem I can’t test it in another device.
You need to disable PCIe Power Management by setting correct bootargs. This is how i do it, in openwrt in ssh console you enter this:
new_bootargs="$(fw_printenv -n bootargs) pcie_port_pm=off"
fw_setenv bootargs $new_bootargs
After you verify if what you set is correct:
Afterwards you reboot, and you should be good to go. Just for everyone, if you have the same errors with PCIe WWAN modems, this is what fixed it on my end.
fw_setenv is openwrt specific. But you can set it via uEnv.txt
bootopts="pcie_port_pm=off"
Thank you very much that does the trick.
Do you use openwrt with my kernel somehow?
No, I use Alpine Linux. Just needed to add the bootarg to the kernel line in uEnv.txt and recompile, works.
