Hi everyone !
I am a happy owner of a BPI-R4 bought in august. Since the beginning it work like a charm with a xgspon to bypass ISP router.
XGSPON ONU Stick SFP+ (MaxLinear PRX126)
Now I’ve bought a SFP+ module on the same supplier but i struggle to make it work.
In fact, when i insert the module, it seems make the xgspon disconnect:
At startup (with only XGSPON) no problem:
[   19.624951] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[   20.642672] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[   22.744946] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
WAN is working flawlessly, but when inserting the SFP+ module:
[  116.944015] sfp sfp2: module FiberMall        SFP-10G-TS       rev A    sn MT244950001      dc 241206
[  116.983977] hwmon hwmon6: temp1_input not attached to any thermal zone
[  146.473745] sfp sfp1: module removed
[  146.477346] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  146.803747] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  146.843546] hwmon hwmon2: temp1_input not attached to any thermal zone
[  146.914954] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  146.935483] mtk_soc_eth 15100000.ethernet sfp-lan: Link is Up - 10Gbps/Full - flow control off
[  146.945680] br-lan: port 3(sfp-lan) entered blocking state
[  146.951182] br-lan: port 3(sfp-lan) entered forwarding state
[  147.004465] sfp sfp1: module removed
[  147.008065] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  147.313100] sfp sfp1: module removed
[  147.633510] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  147.683499] hwmon hwmon2: temp1_input not attached to any thermal zone
[  147.744889] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  148.947507] sfp sfp1: module removed
[  148.951125] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  149.273478] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  149.313524] hwmon hwmon2: temp1_input not attached to any thermal zone
[  149.374869] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  150.982676] sfp sfp1: module removed
[  150.986303] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  151.323481] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  151.363534] hwmon hwmon2: temp1_input not attached to any thermal zone
[  151.424868] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  155.163961] sfp sfp1: module removed
[  155.167580] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  155.493434] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  155.533470] hwmon hwmon2: temp1_input not attached to any thermal zone
[  155.594868] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  158.004217] sfp sfp1: module removed
[  158.007836] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  158.333407] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  158.373503] hwmon hwmon2: temp1_input not attached to any thermal zone
[  158.434804] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  158.657628] sfp sfp1: module removed
[  158.661276] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  158.993418] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  159.043949] hwmon hwmon2: temp1_input not attached to any thermal zone
[  159.104808] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  160.014231] sfp sfp1: module removed
[  160.017829] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  160.343401] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  160.383450] hwmon hwmon2: temp1_input not attached to any thermal zone
[  160.444791] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  162.554773] sfp sfp1: module removed
[  162.558374] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  162.883365] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  162.893340] sfp sfp1: module removed
[  163.077260] sfp sfp1: module removed
[  163.393380] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  163.433403] hwmon hwmon2: temp1_input not attached to any thermal zone
[  163.504763] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  164.658419] sfp sfp1: module removed
[  164.662019] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Down
[  164.694722] sfp sfp1: module removed
[  165.013357] sfp sfp1: module FiberMall        XGSPON-ONU-STICK rev V1.0 sn MT242960002      dc 240725
[  165.053386] hwmon hwmon2: temp1_input not attached to any thermal zone
[  165.124780] mtk_soc_eth 15100000.ethernet sfp-wan: Link is Up - 10Gbps/Full - flow control off
[  169.777516] br-lan: port 3(sfp-lan) entered disabled state
[  171.210481] sfp sfp2: module transmit fault indicated
[  171.215748] sfp sfp2: module removed
 I’m running the official OpenWrt SNAPSHOT r28675-8e78bc39a3 with his WiFi7 card (SW4 is enabled) and power with USB-C PD with a 65w adapter
Does anybody know where i can start my research, is it possible that the module is not compatible ? the two sfp leds on the board are solid green on both
 Thanks for your help
