BPI-R4 hangs at boot
I’m trying to boot my BPI-R4 but it hangs at boot. For example using mtk-bpi-r4-SD-20240620.img onto the SD card and setting the Dip switches to 1-1 I get:
I’ve also tried with the latest Openwrt Snapshot and the other Debian12 and Ubuntu from the “Getting Started Page” images but it is still not able to boot. I also tried the NAND and eMMC with no success. If I try Web Failsafe and upload an image over the Browser I get: image image
I tried different images but always get firmware integrity faiiled.
I tried different PSU to make sure that is not the problem but the problem still persists.
I’ve noticed this on boot:
NOTICE:  WDT: Reboot status is 0x40000000:
NOTICE:       Software reset (reboot)
NOTICE:  WDT: disabled
**NOTICE:  Unexpected CPU frequency measured**
NOTICE:  CPU: MT7988 (1500MHz)
**NOTICE:  EMI: Using DDR unknown settings**
NOTICE:  EMI: Detected DRAM size: 4096 MB
NOTICE:  BL2: v2.9(release):
NOTICE:  BL2: Built : 09:52:16, Jun  9 2023
NOTICE:  BL2: Booting BL31
NOTICE:  BL31: v2.9(release):
NOTICE:  BL31: Built : 18:01:46, Oct 13 2023
Could that be a problem or anyone suggests anything for me to check ?
Which uart adapter do you use (please use ftdi)? Try removing all perpherals. If issue still persist it looks like your board is broken.
Those seem to be normal as I’ve seen this by others that posted successful boots.
I continued to try many different boot images but it keeps failing. I’m starting to think that my board is defective.
Yes, FTDI 3Volts. Tried many many images. I’m running out of options.
Could try this image, it boots without u-boot, so it could skip a possible cause… Although, with that error, it does not look like it will boot anything…
http://woudstra.mywire.org/images/bpir4-sdmmc-rtnosfp.img.gz
Needs to be written to a sd card.
Thank you. I’ve downloaded and placed the image you shared on a new SD card. It still gets stuck, here is the log of first boot:
[  420.671781] rcu:     3-....: (104999 ticks this GP) idle=0ae/1/0x4000000000000002 softirq=6/6 fqs=52455
[  420.681114]  (t=105009 jiffies g=-1179 q=103)
[  420.685522] Task dump for CPU 2:
[  420.688781] kthreadd        R  running task        0     2      0 0x0000002a
[  420.695916] Call trace:
[  420.698391]  __switch_to+0xc4/0x1e0
[  420.701916]  0xffffff80faa4f728
[  420.705087] Task dump for CPU 3:
[  420.708350] kworker/u8:1    R  running task        0    29      2 0x0000002a
[  420.715489] Workqueue: events_unbound call_usermodehelper_exec_work
[  420.721831] Call trace:
[  420.724299]  dump_backtrace+0x0/0x198
[  420.728002]  show_stack+0x14/0x20
[  420.731355]  sched_show_task+0x154/0x178
[  420.735322]  dump_cpu_task+0x40/0x4c
[  420.738933]  rcu_dump_cpu_stacks+0xa0/0xe0
[  420.743076]  rcu_sched_clock_irq+0x534/0x780
[  420.747396]  update_process_times+0x2c/0x68
[  420.751630]  tick_periodic+0x38/0xd0
[  420.755244]  tick_handle_periodic+0x30/0x98
[  420.759473]  arch_timer_handler_phys+0x2c/0x38
[  420.763968]  handle_percpu_devid_irq+0x80/0x140
[  420.768553]  generic_handle_irq+0x24/0x38
[  420.772609]  __handle_domain_irq+0x60/0xb8
[  420.776752]  gic_handle_irq+0xc0/0x158
[  420.780539]  el1_irq+0xb8/0x140
[  420.783713]  queued_spin_lock_slowpath+0x218/0x2d0
[  420.788562]  copy_process+0xe9c/0x1870
[  420.792350]  _do_fork+0x68/0x390
[  420.795611]  kernel_thread+0x40/0x48
[  420.799227]  call_usermodehelper_exec_work+0x9c/0xb8
[  420.804252]  process_one_work+0X1fc/0x390
[  420.808309]  worker_thread+0x48/0x4d0
[  420.812014]  kthread+0x120/0x128
[  420.815278]  ret_from_fork+0x10/0x1c
F0: 102B 0000
FA: 1042 0000
FA: 1042 0000 [0200]
F9: 1041 0000
F3: 1001 0000 [0200]
F3: 1001 0000
F6: 380E 5012
F5: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0600 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [3000]
MK: 0000 0000 [0000]
T0: 0000 01BF [0101]
Jump to BL
NOTICE:  BL2: v2.9.0(release):v2.8-1889-g3f415d3fc-dirty
NOTICE:  BL2: Built : 14:13:49, Apr 18 2024
INFO:    BL2: Doing platform setup
NOTICE:  WDT: Cold boot
INFO:    PGD: disable PGD
INFO:    PGD: disable GDU
INFO:    ARMPLL_B_CON1 = 0x96000000
NOTICE:  CPU: MT7988
INFO:    WED: setup initial settings
INFO:    MediaTek MMC/SD Card Controller ver 20211209, eco 0
INFO:    Located partition 'fip/boot' at 0x100000, size 0xbf00000
INFO:    BL2: Loading image id 3
INFO:    Reading filename from bootcfg/bl31
WARNING: fat_file_open: failed opening bootcfg/bl31
WARNING: Failed to access image id=3 (-2)
INFO:    BL2: Copying id=3 from: 0x23c99d to: 0x43001000 size: 0x4300c129
INFO:    BL2: Loading image id 5
INFO:    Reading filename from bootcfg/linux
INFO:    Opening (/boot/Image)
INFO:    Loading image id=5 at address 0x44000000
INFO:    Image id=5 loaded: 0x44000000 - 0x45347200
INFO:    BL2: Loading image id 22
INFO:    Reading filename from bootcfg/initrd
INFO:    Opening (/boot/initramfs-bpir.img)
INFO:    Loading image id=22 at address 0x48000000
INFO:    Image id=22 loaded: 0x48000000 - 0x48a0ad0a
INFO:    BL2: Loading image id 27
INFO:    Reading filename from bootcfg/atfdtb
INFO:    Opening (/boot/dtbs/mt7988a-bananapi-bpi-r4-atf.dtb)
INFO:    Loading image id=27 at address 0x4ed00000
INFO:    Image id=27 loaded: 0x4ed00000 - 0x4ed09253
INFO:    Entry point address = 0x43001000
INFO:    SPSR = 0x3cd
INFO:    SPMC: Changed to SPMC mode
NOTICE:  BL31: v2.9.0(release):v2.8-1889-g3f415d3fc-dirty
NOTICE:  BL31: Built : 14:13:49, Apr 18 2024
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    Maximum SPI INTID supported: 447
INFO:    [MPU](Region0)sa:0x0300, ea:0x0303
INFO:    [MPU](Region0)apc0:0x80b6db69, apc1:0x00b6db6d
INFO:    [MPU](Region1)sa:0x0000, ea:0x0000
INFO:    [MPU](Region1)apc0:0x00000000, apc1:0x00000000
INFO:    [MPU](Region2)sa:0x0000, ea:0x0000
INFO:    [MPU](Region2)apc0:0x00000000, apc1:0x00000000
INFO:    [MPU](Region3)sa:0x0000, ea:0x0000
INFO:    [MPU](Region3)apc0:0x00000000, apc1:0x00000000
INFO:    [DEVAPC] infra_devapc_init done
INFO:    BL31: Initializing runtime services
INFO:    Secondary bootloader is AArch64
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x44000000
INFO:    SPSR = 0x3c9
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[    0.000000] Linux version 6.10.0-next-20240724-bpi (nathalieeneric@rk3588) (gcc (GCC) 14.1.1 20240507, GNU ld (GNU Binutils) 2.42.0) #3 SMP PREEMPT Tue Jul 30 15:55:12 UTC 2024
[    0.000000] Machine model: Banana Pi BPI-R4
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000011000000 (options '')
[    0.000000] printk: legacy bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: OVERLAP DETECTED!
[    0.000000] secmon@43000000 (0x0000000043000000--0x0000000043050000) overlaps with atf-data@43030000 (0x0000000043030000--0x0000000043030100)
[    0.000000] OF: reserved mem: 0x0000000043000000..0x000000004304ffff (320 KiB) nomap non-reusable secmon@43000000
[    0.000000] OF: reserved mem: 0x0000000043030000..0x00000000430300ff (0 KiB) nomap non-reusable atf-data@43030000
[    0.000000] OF: reserved mem: 0x0000000051000000..0x0000000052ffffff (32768 KiB) nomap non-reusable atf-buffer@51000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x000000004fffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
[    0.000000]   node   0: [mem 0x0000000043000000-0x000000004304ffff]
[    0.000000]   node   0: [mem 0x0000000043050000-0x000000004fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000004fffffff]
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 21 pages/cpu s46040 r8192 d31784 u86016
[    0.000000] pcpu-alloc: s46040 r8192 d31784 u86016 alloc=21*4096
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 858921
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: root=PARTLABEL=bpir4-sdmmc-root earlycon=uart8250,mmio32,0x11000000 console=ttyS0,115200 debug=7 rw rootwait audit=0
[    0.000000] audit: disabled (until reboot)
[    0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65536
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 0MB
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: SWIOTLB bounce buffer size roundup to 1MB
[    0.000000] software IO TLB: mapped [mem 0x000000004f88c000-0x000000004f98c000] (1MB)
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 416 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=0
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.000000] arch_timer: CPU0: Trapping CNTVCT access
[    0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[    0.008347] Console: colour dummy device 80x25
[    0.012843] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[    0.023264] pid_max: default: 32768 minimum: 301
[    0.027995] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.035268] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.043530] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.050265] rcu: Hierarchical SRCU implementation.
[    0.055081] rcu:     Max phase no-delay instances is 1000.
[    0.060456] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.068838] EFI services will not be available.
[    0.073536] smp: Bringing up secondary CPUs ...
[    0.078380] Detected VIPT I-cache on CPU1
[    0.078430] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[    0.078441] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.078457] arch_timer: CPU1: Trapping CNTVCT access
[    0.078465] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[    0.078814] Detected VIPT I-cache on CPU2
[    0.078843] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[    0.078851] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.078858] arch_timer: CPU2: Trapping CNTVCT access
[    0.078864] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[    0.079174] Detected VIPT I-cache on CPU3
[    0.079205] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[    0.079212] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.079219] arch_timer: CPU3: Trapping CNTVCT access
[    0.079224] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[    0.079271] smp: Brought up 1 node, 4 CPUs
[    0.171080] SMP: Total of 4 processors activated.
[    0.175807] CPU: All CPU(s) started at EL2
[    0.179922] CPU features: detected: 32-bit EL0 Support
[    0.185091] CPU features: detected: CRC32 instructions
[    0.190286] alternatives: applying system-wide alternatives
[    0.196001] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.204532] Memory: 221880K/262144K available (10432K kernel code, 1500K rwdata, 4292K rodata, 3392K init, 438K bss, 38460K reserved, 0K cma-reserved)
[    0.218422] devtmpfs: initialized
[    0.224996] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.234913] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.241866] 27696 pages in range for non-PLT usage
[    0.241870] 519216 pages in range for PLT usage
[    0.246749] pinctrl core: initialized pinctrl subsystem
[    0.256768] DMI not present or invalid.
[    0.262753] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.269040] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.276163] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.283994] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.292331] thermal_sys: Registered thermal governor 'fair_share'
[    0.292336] thermal_sys: Registered thermal governor 'bang_bang'
[    0.298469] thermal_sys: Registered thermal governor 'step_wise'
[    0.304508] thermal_sys: Registered thermal governor 'user_space'
[    0.310639] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.323638] ASID allocator initialised with 65536 entries
[    0.336489] platform 11280000.pcie: Fixed dependency cycle(s) with /soc/pcie@11280000/interrupt-controller
[    0.346376] platform 11290000.pcie: Fixed dependency cycle(s) with /soc/pcie@11290000/interrupt-controller
[    0.356235] platform 11300000.pcie: Fixed dependency cycle(s) with /soc/pcie@11300000/interrupt-controller
[    0.366096] platform 11310000.pcie: Fixed dependency cycle(s) with /soc/pcie@11310000/interrupt-controller
[    0.378207] cryptd: max_cpu_qlen set to 1000
[    0.545872] raid6: neonx8   gen()  4127 MB/s
[    0.715904] raid6: neonx4   gen()  4471 MB/s
[    0.885938] raid6: neonx2   gen()  3668 MB/s
[    1.055979] raid6: neonx1   gen()  2678 MB/s
[    1.226057] raid6: int64x8  gen()  1237 MB/s
[    1.396054] raid6: int64x4  gen()  1331 MB/s
[    1.566083] raid6: int64x2  gen()  1986 MB/s
[    1.736129] raid6: int64x1  gen()  1558 MB/s
[    1.740418] raid6: using algorithm neonx4 gen() 4471 MB/s
[    1.906153] raid6: .... xor() 3330 MB/s, rmw enabled
[    1.911142] raid6: using neon recovery algorithm
[    1.915972] iommu: Default domain type: Translated
[    1.920796] iommu: DMA domain TLB invalidation policy: strict mode
[    1.927228] SCSI subsystem initialized
[    1.931084] libata version 3.00 loaded.
[    1.935030] usbcore: registered new interface driver usbfs
[    1.940559] usbcore: registered new interface driver hub
[    1.945924] usbcore: registered new device driver usb
[    1.951108] mc: Linux media interface: v0.10
[    1.955412] videodev: Linux video capture interface: v2.00
[    1.960954] pps_core: LinuxPPS API ver. 1 registered
[    1.965943] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    1.975141] PTP clock support registered
[    1.980097] vgaarb: loaded
[    1.983019] clocksource: Switched to clocksource arch_sys_counter
[    1.993292] NET: Registered PF_INET protocol family
[    1.998274] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    2.005956] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[    2.014407] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    2.022202] TCP established hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    2.030006] TCP bind hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    2.037217] TCP: Hash tables configured (established 2048 bind 2048)
[    2.043657] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    2.050231] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    2.057326] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    2.063049] PCI: CLS 0 bytes, default 64
[    2.067101] Unpacking initramfs...
[    2.073759] Initialise system trusted keyrings
[    2.078341] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    2.085110] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.091003] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    2.122305] xor: measuring software checksum speed
[    2.128796]    8regs           :  5987 MB/sec
[    2.134800]    32regs          :  6161 MB/sec
[    2.141491]    arm64_neon      :  4263 MB/sec
[    2.145877] xor: using function: 32regs (6161 MB/sec)
[    2.150968] Key type asymmetric registered
[    2.155092] Asymmetric key parser 'x509' registered
[    2.160109] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.167575] io scheduler mq-deadline registered
[    2.172132] io scheduler kyber registered
[    2.176217] io scheduler bfq registered
[    2.181273] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[    2.199077] mtk-socinfo mtk-socinfo.0.auto: error -ENOENT: Failed to get socinfo data
[    2.206997] mtk-socinfo mtk-socinfo.0.auto: probe with driver mtk-socinfo failed with error -2
[    2.216265] Unable to handle kernel paging request at virtual address ffff8000a148b890
[    2.224248] Mem abort info:
[    2.227052]   ESR = 0x0000000096000006
[    2.230818]   EC = 0x25: DABT (current EL), IL = 32 bits
[    2.236160]   SET = 0, FnV = 0
[    2.239226]   EA = 0, S1PTW = 0
[    2.242378]   FSC = 0x06: leveL 2 translation fault
[    2.247280] Data abort info:
[    2.250169]   ISV = 0, ISS = 0x00000006, ISS2 = 0x00000000
[    2.255683]   CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[    2.260761]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[    2.266101] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000044e7a000
[    2.272842] [ffff8000a148b890] pgd=0000000000000000, p4d=10000000453b6003, pud=10000000453b7003, pmd=0000000000000000
[    2.283527] Internal error: Oops: 0000000096000006 [#1] PREEMPT SMP
[    2.283533] Modules linked in:
[    2.283540] CPU: 3 UID: 0 PID: 11 Comm: kworker/u16:0 Not tainted 6.10.0-next-20240724-bPi #3
[    2.283550] Hardware name: Banana Pi BPI-R4 (DT)
[    2.283554] Workqueue: events_unbound call_usermodehelper_exec_work
[    2.283571] pstate: 804000c5 (Nzcv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    2.283577] pc : __memcpy+0x1a0/0x230
[    2.283585] lr : blake2s_final+0x64/0x88
[    2.283593] sp : ffff80008148b850
[    2.283595] x29: ffff80008148b850 x28: ffff800082090000 x27: ffff0000025b3180
[    2.283601] x26: ffff00000223ce80 x25: ffff800080e0b000 x24: 000000000000004
[    2.283607] x23: ffff8000812d0b20 x22: 00000000000000c0 x21: ffff80008148b8b0
[    2.283613] x20: ffff80008148b968 x19: ffff80008148b880 x18: 00000000ff0f56a0
[    2.283619] x17: 00000002a2cda87 x16: 00000000aff2ecac x15: 00000000c4627ce8
[    2.283624] x14: 00000000000000e8 x13: 0000000080293afb x12: 0000000072bd45c3
[    2.283630] x11: 00000006f667c9c x10: 00000000641ee4c9 x9 : 00000000e1961276
[    2.283636] x8 : 00000000d86d0a55 x7 : 00000000ff1a78c2 x6 : 00000000aa7923c1
[    2.283641] x5 : ffff800a148b988 x4 : ffff8000a148b8a0 x3 : ffff80008148b880
[    2.283647] x2 : 0000000020000020 x1 : ffff80008148b880 x0 : ffff80008148b968
[    2.283653] Call trace:
[    2.283657]  __memcpy+0x1a0/0x230
[    2.283662]  blake2s.constprop.0+0x50/0x80
[    2.283671]  extract_entropy.constprop.0+0xa4/0x168
[    2.283677]  crng_make_state+0xfc/0x148
[    2.283683]  _get_randoM_bytes+0x58/0xfc
[    2.283690]  get_random_u64+0x50/0x100
[    2.283697]  copy_process+0x378/0x1648
[    2.283702]  kernel_clone+0x9c/0x208
[    2.283707]  user_mode_thread+0x6c/0xa0
[    2.283711]  call_usermodehelper_exec_work+0x88/0x94
[    2.283717]  process_scheduled_works+0x1c4/0x274
[    2.283721]  worker_thread+0x190/0x1d4
[    2.283725]  kthread+0xd8/0xe8
[    2.283731]  ret_from_fork+0x10/0x20
[    2.283740] Code: a93e24a8 a93f2caa d65f03c0 d503201f (a97f348c)
[    2.283745] ---[ end trace 0000000000000000 ]---
[    2.319248] Freeing initrd memory: 10280K
[    2.319619] Kernel panic - not syncing: Oops: Fatal exception
[    2.319623] SMP: stopping secondary CPUs
[    3.394627] SMP: failed to stop secondary CPUs 2-3
[    3.394632] Kernel Offset: disabled
[    3.394634] CPU featureS: 0x00,00000081,00100000,4200420b
[    3.394638] Memory Limit: none
PANIC at PC : 0x0000000043004c0c
F0: 102B 0000
FA: 1042 0000
F9: 1041 0000
F3: 1001 0000
F6: 380E 5012
F5: 0000 0000
00: 0000 0000
G0: 1190 0000
T0: 0000 0154 [0101]
Jump to BL
NOTICE:  WDT: [40000000] Software reset (reboot)
NOTICE:  CPU: MT7988
INFO:    SPSR = 0x3cd
INFO:    SPSR = 0x3c9
[    0.008349] Console: colour dummy device 80x25
[    0.012844] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[    0.023265] pid_max: default: 32768 minimum: 301
[    0.027993] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.035266] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.043525] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.060458] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.068843] EFI services will not be available.
[    0.073539] smp: Bringing up secondary CPUs ...
[    0.078390] Detected VIPT I-cache on CPU1
[    0.078440] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[    0.078452] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.078468] arch_timer: CPU1: Trapping CNTVCT access
[    0.078476] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[    0.078824] Detected VIPT I-cache on CPU2
[    0.078854] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[    0.078861] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.078868] arch_timer: CPU2: Trapping CNTVCT access
[    0.078873] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[    0.079184] Detected VIPT I-cache on CPU3
[    0.079213] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[    0.079221] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.079227] arch_timer: CPU3: Trapping CNTVCT access
[    0.079232] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[    0.079280] smp: Brought up 1 node, 4 CPUs
[    0.171089] SMP: Total of 4 processors activated.
[    0.175816] CPU: All CPU(s) started at EL2
[    0.179930] CPU features: detected: 32-bit EL0 Support
[    0.185098] CPU features: detected: CRC32 instructions
[    0.190293] alternatives: applying system-wide alternatives
[    0.196007] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.204538] Memory: 221880K/262144K available (10432K kernel code, 1500K rwdata, 4292K rodata, 3392K init, 438K bss, 38460K reserved, 0K cma-reserved)
[    0.218427] devtmpfs: initialized
[    0.224994] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.241869] 519216 pages in range for PLT usage
[    0.246748] pinctrl core: initialized pinctrl subsystem
[    0.256769] DMI not present or invalid.
[    0.269039] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.276160] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.283990] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.292323] thermal_sys: Registered thermal governor 'fair_share'
[    0.292327] thermal_sys: Registered thermal governor 'bang_bang'
[    0.298461] thermal_sys: Registered thermal governor 'step_wise'
[    0.304499] thermal_sys: Registered thermal governor 'user_space'
[    0.310632] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.323629] ASID allocator initialised with 65536 entries
[    0.336477] platform 11280000.pcie: Fixed dependency cycle(s) with /soc/pcie@11280000/interrupt-controller
[    0.346364] platform 11290000.pcie: Fixed dependency cycle(s) with /soc/pcie@11290000/interrupt-controller
[    0.356226] platform 11300000.pcie: Fixed dependency cycle(s) with /soc/pcie@11300000/interrupt-controller
[    0.366088] platform 11310000.pcie: Fixed dependency cycle(s) with /soc/pcie@11310000/interrupt-controller
[    0.378203] cryptd: max_cpu_qlen set to 1000
[    0.545866] raid6: neonx8   gen()  4126 MB/s
[    0.715899] raid6: neonx4   gen()  4475 MB/s
[    0.885933] raid6: neonx2   gen()  3668 MB/s
[    1.055973] raid6: neonx1   gen()  2677 MB/s
The it stays stuck. I’ve reset it a couple times and it would get stuck at a few different spots which leads me to believe it must be a hardware issue.
Example Stuck again after reset:
[    0.298480] thermal_sys: Registered thermal governor 'step_wise'
[    0.304519] thermal_sys: Registered thermal governor 'user_space'
[    0.310651] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.323650] ASID allocator initialised with 65536 entries
Which power supply are you using?
I tried with both 12V 1.5A power supply and with a USB-C 100W that I use for my laptop.
I do not think this is enough.
Should be ok, but there may be negotiation issues, where the required voltage is not present (fast enough)?
If you have a heavier fixed voltage supply lying around, I think it is worth a try.
Just tried with another 12V 2Amps Adapter and it still same trouble. Also connected a Killawatt to see the consumption and it does not go beyond 7 watts while the PSU could technically provide 24 watts.
NOTICE:  CPU: MT7988
INFO:    SPSR = 0x3cd
INFO:    SPSR = 0x3c9
[    0.027994] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.035267] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.043531] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.050266] rcu: Hierarchical SRCU implementation.
[    0.055082] rcu:     Max phase no-delay instances is 1000.
[    0.068840] EFI services will not be available.
[    0.073538] smp: Bringing up secondary CPUs ...
[    0.078385] Detected VIPT I-cache on CPU1
[    0.078434] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[    0.078445] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.078461] arch_timer: CPU1: Trapping CNTVCT access
[    0.078469] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[    0.078818] Detected VIPT I-cache on CPU2
[    0.078847] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[    0.078854] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.078861] arch_timer: CPU2: Trapping CNTVCT access
[    0.078867] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[    0.079181] Detected VIPT I-cache on CPU3
[    0.079210] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[    0.079218] arch_timer: Enabling local workaround for ARM erratum 858921
[    0.079224] arch_timer: CPU3: Trapping CNTVCT acCess
[    0.079230] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[    0.079278] smp: Brought up 1 node, 4 CPUs
[    0.185099] CPU features: detected: CRC32 instructions
I also thought of power supply. Not long after receiving the router, my R4 suddenly failed to boot - hanging at various stages. I replaced with a 2.5A supply and never had an issue since. Just sharing my experience.
