I’m wanting to make a switch that will run a command. Can’t find much info on the gpio for the R4. Any help would be appreciated.
You can follow the same instructions as on the BPI-R3, it works great on the R4 too - on both the official Sinovoip images and on the snapshot from the OpenWrt GitHub. ![]()
For example: if you want to change gpio 22 as out highlevel, you need input commands like this:
- echo 433(22+411) > /sys/class/gpio/export
- echo out > /sys/class/gpio/gpio433/direction
- echo 1 > /sys/class/gpio/gpio433/value
