We are talking about getting nvme slot (pcie3) working in uboot…this is working in our linux kernel, so please stay on topic…nobody talkes about key-b slot (pcie2) or the 2 mpci slots (0+1)
Just wanted to check in again, has anyone got any news on this topic? @YuyuMarco maybe? I haven’t played with the source or the board for a while now, but got time again to test out new debug methods or new source code.
Looking at the other thread about the second pcie port ([BPI-R4] how to activate key B PCIe2 @ 11280000? [solved] - #53 by vexorg), it sounds like the clock configuration for the mediatek chip is a bit special sometimes.
This is only for p2 (the key-b slot)…but i try to get p3 (key m) working…but it seems either pinctrl or clock is missing something
i also tried adding fix for p2, but still same issue (as expected as i only enabled p3 on r4).
--- a/drivers/clk/mediatek/clk-mt7988.c
+++ b/drivers/clk/mediatek/clk-mt7988.c
@@ -802,7 +802,7 @@ static const struct mtk_gate infracfg_mtk_gates[] = {
GATE_INFRA0(CK_INFRA_PCIE_PERI_26M_CK_P1,
"infra_pcie_peri_ck_26m_ck_p1", CK_INFRA_F26M_O0, 8),
GATE_INFRA0(CK_INFRA_PCIE_PERI_26M_CK_P2,
- "infra_pcie_peri_ck_26m_ck_p2", CK_INFRA_F26M_O0, 9),
+ "infra_pcie_peri_ck_26m_ck_p2", CK_INFRA_PCIE_PERI_26M_CK_P3, 9),
GATE_INFRA0(CK_INFRA_PCIE_PERI_26M_CK_P3,
"infra_pcie_peri_ck_26m_ck_p3", CK_INFRA_F26M_O0, 10),
compared clk with r3mini where pcie works, looks similar
BPI-R3M> pci enum
drivers/pci/pcie_mediatek_gen3.c:mtk_pcie_startup_port[261] detected a card
set trans table 0: 0x20000000 0x20000000, 0x10000000
BPI-R3M> clk dump
Rate Usecnt Name
12000000 0 |-- dummy12m
BPI-R3M> nvme scan
BPI-R3M> nvme info
Device 0: Vendor: 0x1c5c Rev: 80002C00 Prod: ND94N163610404F0R
Type: Hard Disk
Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
BPI-R3M>
it looks like clk command is not able to print enabled clocks somehow…
mtk-clock driver seems to use UCLASS_CLK , so it is strange that clocks are not listed
@hackpascal can you help here?
Sam is already in mail loop with daniel,john and steven. I only posted state and tried to figure out why clocks are not displayed in uboot. Thought you maybe have an idea about this.
hmm…Sam is fully in charge of the clk drivers. According to his description, the clk driver in u-boot is designed in a non-standard way that all clocks can’t be shown by the clk command.
Which description do you mean? I did not see this info in files or commits yet.
internal discussion ![]()
Hoping @sam33 / @hackpascal have managed to shed some light into their unnatural implementation choices, @frank-w - nvme for the rootfs is the last item I’m personally hoping can be enabled for the bpi-r4; everything else seems to be working in my arrangement (with everything aside from the cpu fan fixes already having been mainlined).
In the mean time, @hackpascal / @sam33 , any details you can share here (beyond just giggling, @hackpascal ) would be helpful for others attempting to debug their way through this implementation process ![]()
@dangowrt , @frank-w , you guys are champions (@YuyuMarco too!)
With big help of @sam33 i got it working when pcie2 is disabled. It seems that the not-detected slots breaking the pci core. So not yet final but working so far which is a huge step forward.
Merged it to my “main” tree,so the changes are also available by releases.
Last release also contains r3mini network fix (allow now multiple access).
Does this mean when there is no other card used in the mini pcie slots? Or disabled via the device tree of the board?
Heck yes
Awesome, @frank-w, I appreciate it
I’ll pull/cherry-pick and give it a try - thanks a ton, @sam33 ![]()
I’m assuming the menu interface for provisioning the nvme volume/configuring uboot env is still needing some implementation - once I’ve gotten a build that’s working + manually installed, I’ll take a crack at replicating these steps with the process that ends up working for me/adjusting the existing menu interface items to include nvme as an option: sdmmc, snand, emmc
Pcie2 is the keyb slot and empty in my case…have not tried without mpcie card but these are after the key-m so i guess this should not break
Have not done anything with menu for nvme yet,but if you use my precompiled you can add menuitems with uEnv.txt
btw. steps that have to be done (my nvme is currently empty, so i’m stuck here atm…need to create partitiontable first
BPI-R4> if pci enum; then echo success;fi
drivers/pci/pcie_mediatek_gen3.c:mtk_pcie_startup_port[262] detected a card
set trans table 0: 0x28200000 0x28200000, 0x7e00000
set trans table 0: 0x30200000 0x30200000, 0x7e00000
set trans table 0: 0x38200000 0x38200000, 0x7e00000
success
BPI-R4> if nvme scan; then echo success;fi
success
BPI-R4> if nvme info; then echo success;fi
Device 0: Vendor: 0x1cc1 Rev: VC0S036H Prod: 2M232LAJ8HNT
Type: Hard Disk
Capacity: 476940.0 MB = 465.7 GB (976773168 x 512)
success
BPI-R4> ls nvme 0:1
** No partition table - nvme 0 **
Couldn't find partition nvme 0:1
after creating partitions i see my testfile ![]()
BPI-R4> if nvme info;then echo success;fi
Type: Hard Disk
success
BPI-R4> ls nvme 0:1
0 bpi-boot-vfat
1 file(s), 0 dir(s)
BPI-R4> ls nvme 0:2
<DIR> 4096 .
<DIR> 4096 ..
<DIR> 16384 lost+found
0 bpi-root-ext
BPI-R4>
BPI-R4> if fatload nvme 0:1 $loadaddr bpi-boot-vfat;then echo load success;fi
0 bytes read in 0 ms
load success
BPI-R4>
if the loaded file (e.g. from environment - fit var) you can continue with the boot-chain (bootm $loadaddr#bootconf). maybe you can copy useusb as usenvme and change related parts (that would my way).
seems nvme info returns also “success” if no device is found…mhm, imho we need to access partition to check if nvme works via script
have it now defined like this:
usenvme=pci enum; nvme scan;nvme info; if ls nvme 0:1;then setenv device nvme;setenv partition 0:1;else echo nvme partition not found;fi
seems to work ![]()
but it would be interesting, if nvme also works if there is nothing in mpcie slots
added nvme boot in my uboot 2024-04-bpi tree for r3 and r4 (currently tested only on r3mini, but should work across all devices)
Cool, thanks for the update. Will try on my R4 the next days. Currently working on a windows build setup using Powershell and Docker to build things my way. Though I also got your build.sh working in WSL.
What are the chances of this patch making it to mainline U-Boot, since what I understood was, that this was more a workaround or hack than a final fix to the issue?
John will try to upstream nvme driver next week,not sure about mt7988 support as there is the problem with the key-b slot i currently have disabled. So from driver view it will be upstreamed.
The builtin environment is my specific way to use this driver and this is not upstreamable…maybe @dangowrt add nvme boot in a similar way. If you do not want the ask for filename you have to patch it out…at this point i want it configurable
If you have it working in docker/wsl please share way how to setup…maybe anybody else will use this too
I’ve sent first version of uboot pcie driver to get first responses as rfc
https://patchwork.ozlabs.org/project/uboot/patch/[email protected]/
Hi frank-w,
I was looking in U-boot for MT7988 NVME boot and I notice that is not working. I checked this thread and I’ve applied the patch to my U-boot and I got this:
MT7988> pci enum
detected a card at 0x11290000
no card detected at 0x11300000
no card detected at 0x11310000
MT7988> pci
BusDevFun VendorId DeviceId Device Class Sub-Class
_____________________________________________________________
00.00.00 0x14c3 0x7988 Bridge device 0x04
01.00.00 0x1ed0 0x2283 Mass storage controller 0x08
MT7988> nvme scan
MT7988> nvme info
Device 0: Vendor: 0x1ed0 Rev: APF1M3R1 Prod: 702172310010561
Type: Hard Disk
MT7988> nvme detail
Blk device 0: Optional Admin Command Support:
Namespace Management/Attachment: no
Firmware Commit/Image download: yes
Format NVM: yes
Security Send/Receive: yes
Blk device 0: Optional NVM Command Support:
Reservation: yes
Save/Select field in the Set/Get features: no
Write Zeroes: yes
Dataset Management: yes
Write Uncorrectable: no
Blk device 0: Format NVM Attributes:
Support Cryptographic Erase: No
Support erase a particular namespace: Yes
Support format a particular namespace: No
Blk device 0: LBA Format Support:
LBA Format 0 Support: (current)
Metadata Size: 0
LBA Data Size: 512
Relative Performance: Better
Blk device 0: End-to-End DataProtect Capabilities:
As last eight bytes: No
As first eight bytes: No
Support Type3: No
Support Type2: No
Support Type1: No
Blk device 0: Metadata capabilities:
As part of a separate buffer: No
As part of an extended data LBA: No
MT7988> nvme device
IDE device 0: Vendor: 0x1ed0 Rev: APF1M3R1 Prod: 702172310010561
Type: Hard Disk
MT7988> nvme part
Partition Map for nvme device 0 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00008000 0x1dcf2fff ""
attrs: 0x0000000000000000
type: 0fc63daf-8483-4772-8e79-3d69d8477de4
(linux)
guid: 110b369b-ed3e-4244-9e89-d59fa1864e8b
MT7988> ls nvme 0:1
<DIR> 4096 .
<DIR> 4096 ..
So I was able to see the FS on NVME in U-boot.
I’m using a BananaPI R4 brought 1-2 weeks ago.
U-boot version is:
commit fe2ce09a0753634543c32cafe85eb87a625f76ca (HEAD -> master, origin/master, origin/HEAD)
Merge: 16324b43db 1fd754cebd
Author: Tom Rini <[email protected]>
Date: Tue Jun 18 08:34:56 2024 -0600
looks like you got it working, and yes, it is not yet merged as we have to do OF_UPSTREAM first which is very much work (requires complete clock driver change and some other driver patches to be compatible with upstream DTS)…
I hope you will be able to push it to the mainline.
Now I will be able to use NVME SSD to build my Booting and root FS on it and give it a try ![]()
