Context
Hi guys, I just got my BPI-R4 several days ago. For that, I built a relative large OpenWRT image (~150MB) which should not install into the 128MB NAND flash. (I know I can install it into EMMC by utitlize /tmp and dd command, but using an optane ssd would be better.)
Add nvme support (Failed)
1. Enable NVM Express device / NVM Express PCI device support on menuconfig
- go into the uboot source
./build_dir/target-aarch64_cortex-a53_musl/u-boot-mt7988_bananapi_bpi-r4-snand/u-boot-2024.01 make menuconfig
2. A dive into OpenWRT’s DTS
We can find the OpenWRT’s DTS here:
./target/linux/mediatek/files-6.1/arch/arm64/boot/dts/mediatek
2.1 PCIe pinctrl in mt7988a.dtsi
pcie3_pins: pcie3-pins {
mux {
function = "pcie";
groups = "pcie_1l_1_pereset", "pcie_clk_req_n3",
"pcie_wake_n3_0";
2.2 PCIe device in mt7988a.dtsi
pcie3: pcie@11290000 {
compatible = "mediatek,mt7988-pcie",
"mediatek,mt7986-pcie",
"mediatek,mt8192-pcie";
reg = <0 0x11290000 0 0x2000>;
reg-names = "pcie-mac";
ranges = <0x81000000 0x00 0x28000000 0x00
0x28000000 0x00 0x00200000>,
<0x82000000 0x00 0x28200000 0x00
0x28200000 0x00 0x07e00000>;
device_type = "pci";
linux,pci-domain = <2>;
interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>;
bus-range = <0x00 0xff>;
clocks = <&infracfg CLK_INFRA_PCIE_PIPE_P3>,
<&infracfg CLK_INFRA_PCIE_GFMUX_TL_P3>,
<&infracfg CLK_INFRA_PCIE_PERI_26M_CK_P3>,
<&infracfg CLK_INFRA_133M_PCIE_CK_P3>;
clock-names = "pl_250m", "tl_26m", "peri_26m",
"top_133m";
pinctrl-names = "default";
pinctrl-0 = <&pcie3_pins>;
#interrupt-cells = <1>;
interrupt-map-mask = <0 0 0 0x7>;
interrupt-map = <0 0 0 1 &pcie_intc3 0>,
<0 0 0 2 &pcie_intc3 1>,
<0 0 0 3 &pcie_intc3 2>,
<0 0 0 4 &pcie_intc3 3>;
#address-cells = <3>;
#size-cells = <2>;
status = "disabled";
pcie_intc3: interrupt-controller {
#address-cells = <0>;
interrupt-controller;
2.3 PCIe enable entries in mt7988a-bananapi-bpi-r4.dts
/* M.2 key-M SSD */
&pcie3 {
status = "okay";
3. Add PCIe3 into uboot’s DTS
We only care about &pcie3 because that is the one for SSD.
3.1 Find the DTS files
Under path
./build_dir/target-aarch64_cortex-a53_musl/u-boot-mt7988_bananapi_bpi-r4-snand/u-boot-2024.01/arch/arm/dts
we can find the following dts file:
and we can find the following build targets from.config
CONFIG_DEFAULT_FDT_FILE="mediatek/mt7988a-bpi-r4-emmc.dtb"
CONFIG_OF_LIST="mt7988a-bananapi-bpi-r4-emmc"
3.2 The including relationship between DTS files
mt7988a-bananapi-bpi-r4-emmc.dts
→ mt7988a-bananapi-bpi-r4.dtsi
→ → mt7988.dtsi
3.3 Add PCIe3 Device support in mt7988.dtsi
clocks = <&infracfg_ao CK_INFRA_PCIE_PIPE_P3>,
<&infracfg_ao CK_INFRA_PCIE_GFMUX_TL_P3>,
<&infracfg_ao CK_INFRA_PCIE_PERI_26M_CK_P3>,
<&infracfg_ao CK_INFRA_133M_PCIE_CK_P3>;
"top_133m";
#size-cells = <2>;
There are things to notice when migrate from OpenWRT’s DTS:
- Change
&infracfgto&infracfg_ao: because the label forpinctrlis different. - Change the “CLK_” prefix to
CK_: because the drive for uboot is different than the one in Linux/Openwrt kernal - I removed the
pinctrl-0 = <&pcie3_pins>because I want to defined it later.
3.4 Add PCIe3 pinctrl define in mt7988a-bananapi-bpi-r4.dtsi
Under the pinctrl section, add:
mux {
function = "pcie";
"pcie_wake_n3_0";
3.5 Add PCIe3 enable in mt7988a-bananapi-bpi-r4-emmc.dts
/* M.2 key-M SSD */
&pcie3 {
status = "okay";
4. Compile the fip file
4.1 Compile Uboot first
Simply run the following command and be sure to replace the placeholder:
make clean; make CROSS_COMPILE=<your_openwrt_path>/staging_dir/toolchain-<suffix_is_variated>/bin/<suffix_is_variated>-linux- -j<THREAD> STAGING_DIR=<your_openwrt_path>/staging_dir
And you would see u-boot.bin file.
4.2 Compile the arm-trusted-firmware
Under path:
./build_dir/target-aarch64_cortex-a53_musl/arm-trusted-firmware-mediatek-mt7988-sdmmc-comb/arm-trusted-firmware-mediatek-<suffix_is_variated>
Run:
make -f Makefile PLAT=mt7988 BOOT_DEVICE=snand BL33=<PATH_TO_UBOOT_BIN> all fip CROSS_COMPILE=<your_openwrt_path>/staging_dir/toolchain-<suffix_is_variated>/bin/<suffix_is_variated>-linux- STAGIN_DIR=<your_openwrt_path>/staging_dir
The artifact is under:
build/mt7988/release/fip.bin
5. Install your custom uboot
5.1 Pre-request
You should flash openwrt(official one or your custom build? doesn’t matter) into NAND.
5.2 Flash it!
- Download you fip.bin
- Choose #7 in the Uboot menu
- Rename it as Uboot wants (in my case
openwrt-mediatek-filogic-bananapi_bpi-r4-snand-bl31-uboot.fip) - Run you TFTP server
You will see this when success:
- Press the Reset button to load the new uboot
However, this method failed
No nvme device detacted
The FDT did work, however
Load FDT
List it
We can see that we did assign the device, status, and pinctrl
fdt print /pinctrl@1001f000
Conclusion
I failed to add nvme support to uBoot and the reason is unknow.
May be
- we can discuss the possible reason for this
- we should find a way to list all device (
pcicommand give me empty output) - we should find a way to make Uboot print detail start log
Any help will be appreciated!
