[BPI-R4] Enable PoE with RT5400
I recently bought and set up a BPi-R4 for its open approach with schematics and option’s galore. While a lot of features worked out of the box - thanks to a lot of work that has been put into openwrt by folks on this forum - I can’t figure out how to enable the PoE module which i recently soldered to the expansion contacts on the port. The closest I’ve gotten so far: The module might expect a GPIO pin to be set high for it to power on. Unfortunately the pin does not appear to be labeled in sysfs nor did i find the clue in the MT7988A manual. I did find out something about how the RT5400 is wired up in the schematics of the board on page 9. Unlike e.g. the green led for the lan ports, which is distinctly labeled as GPIO68_LED_E which translates to pad_led_e there is no easy way to see if the PoE is powered on or what i need to do in order to change that. Any help to make PoE work would be highly appreciated. I see that this dev board is not all plug and play - as expected. I am also willing to put my own elbow grease in. Please just point me in the right direction what to do or how i can help to make this feature work.
what do you want to do with this feature? I’m not sure about this topic, but I thought the POE module can only receive POE not supply. This is your usecase?
And this is how your R4 looks now?:
I found a discussion about it:
The person who wrote this mentioned, that you need two things:
→ LPJG0926HENL
→ RT5400 PoE
I am not 100% certain about the following statement, but I think it is true:
The reason you need to also solder on the RJ45 connector is that the POE is an input only via that port. None of the 4 ports grouped together receive or transmit POE.
Thanks a lot for getting back to me, even though i did not have the time to follow up on this. So i understood that providing PoE is not possible atm. Is there anyone who considered modding the board to make the possible? I still could not get around to figure out all of the BPI-R4‘s wiring. Yet with the GPIO pins, there is the option to provide DC power directly. So given my Power Supply suffices there should be a way to tinker up a PoE (out) hat. Looks like I‘ve got some more reading to do… Anybody know where the PCB and Pi HAT folk hang around?
@Carl_Fritze There are two versions of the BPI-R4 board. If you wish POE, you need to get the POE version. e.g. https://www.aliexpress.com/item/1005006671856477.html?spm=a2g0o.productlist.main.83.1c8d3RXd3RXdXv&algo_pvid=6068c9c5-9f9f-4cd9-a2c6-97ae96778d2e&algo_exp_id=6068c9c5-9f9f-4cd9-a2c6-97ae96778d2e-41&pdp_npi=4%40dis!GBP!176.37!176.37!!!1586.03!1586.03!%40211b600917170183839951286e2b09!12000037977573968!sea!UK!3021760511!&curPageLogUid=YKKc77eqpymL&utparam-url=scene%3Asearch|query_from%3A
And can this variant supply poe so I can connect a poe surveillence camera?
No R4 can not supply POE, it can just recieve POE like your camera!
USE a POE injector for this :+1:
Side question, is the 2.5GbE port expected to work also without PoE or is it meant to go up only when provided with external power?
What a bummer. I hope I could power some devices over POE using R4. I already decided, but now seems better the new board I will buy that doesn’t have POE. I need two SFPs more, for the internet uplink and the downlink for the switch, than be powered by POE.
