BPI-R4 Debian11 swiotlb buffer is full
Hello
I would like to as about any solution for the message :
swiotlb buffer is full (sz: 84 bytes), total 512 (slots), used 512 (slots)
Thank you
Which kernel/image do you use? Afair this was an issue in early network support based on 4gb ram which was fixed by 36bit adressing in ethernet and switch driver
I am using debian11 5.4
Not sure how current bpi images can be configured,but you can try passing mem=3G to linux via uboot (bootargs) to linux. In older images there was an uEnv.txt like in my images and a bootopts variable to set there
Thank you I change the uEnv.txt to 3075 and I think it works
