Hello! I’m setting up a Banana Pi BPI-R4 with OpenWRT 24.10.2 installed.
I’m a newbie and don’t know OpenWRT well. I’ve mostly been configuring router using AI (and I’ll share below some of the steps that I took with Claude), but at a some point AI hit a dead end and start going in circles. That’s why I’m looking for help here ![]()
I inserted two Foxconn-T77W968 (DW5821e) modems into the Mini-PCIe slot on the back of the board (using a Mini-PCIe to M2 Key-B adapter without SIM).
The LEDs for SIM-2 and SIM-3 are not blinking, but both modems are detected by lsusb command:
Bus 001 Device 003: ID 413c:81d6 DELL DW5821e Snapdragon X20 LTE
Bus 001 Device 004: ID 413c:81d6 DELL DW5821e Snapdragon X20 LTE
No ports were created in the /dev/ttyUSB* path. Installing the packages kmod-usb-serial kmod-usb-serial-option kmod-usb-serial-wwan didn’t help either. At this stage, Claude (as I understand it) suggests adding the drivers manually by command echo "413c 81d6" > /sys/bus/usb-serial/drivers/option1/new_id . Two ports were created automatically:
crw-rw---- 1 root dialout 188, 0 Sep 26 10:45 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Sep 26 10:45 /dev/ttyUSB1
By command lsusb -v -d 413c:81d6 | grep -A 5 -B 5 "bNumEndpoints\|bInterfaceClass", I get the following information about the modems:
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 [unknown]
bInterfaceSubClass 66 [unknown]
bInterfaceProtocol 3
iInterface 7 fastboot
Endpoint Descriptor:
bLength 7
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bLength 7
But the modems are still not being detected in any way:
- Using the ModemManager tool
mmcli -Lreturns “No modems were found” - Created ttyUSB0 and ttyUSB1 ports don’t respond to AT commands.
At this point AI start going in circles. What can be done with this modems? And is it even possible to set up them? Thanks ![]()
