The BPI-R4 (v1.1) and BPI-R4-NIC-BE14 (v1.0) worked for a while.
One day, the router shut down.
A very quiet ticking sound was heard on the router and power supply, occurring once per second. All LEDs were off.
When I removed the BPI-R4-NIC-BE14 board, the router turned on.
Turning switch SW4 on and off didn’t change the situation.
I thought the BPI-R4-NIC-BE14 was faulty.
I replaced it with a DR7915 + MT7925 based on the forum’s advice.
But the problem persists (SW4 off) – the router won’t turn on.
I tried removing the MT7925 and swapping DR7915s – no change.
However, the router works with the MT7925 in any port.
Also confusing is that the 12V LED lights up in both cases: SW4 on or off.
I tried different power supplies: a standard 12V 5A or a Ugreen 65W PD Type-C.
just remove all peripherals (sfp,nvme, pcie cards,…) and try to boot the r4 with looking on the debug-uart…if not even the bootrom comes up, i guess something in power part is broken
