Yes the RX/TX is crossed and what is mean by 8n1 and flow control setting ?
These are settings that have to be defined in your serial application. Same for flowcontrol. All of these can cause the nothing displayed issue.
I just tried with minicom with setting 115200 with 8n1 and flow chart disable and I got no response Thx
You can try to start your board with mtkuartboot.
ram preloader - mt7988-ram-comb-bl2.bin
https://downloads.openwrt.org/releases/24.10.4/targets/mediatek/filogic
If he does not see even bootrom on terminal it will not work.
@adel96 have you powered on board while serial is waiting for data (connected and minicom open)?
You cannot see serial output that was sent before.
My dead CPU was able to print some symbols xD
Yes but no lack I didn’t get any response
To be honest I use this board with usbc powe source and it’s work fine and when I connect it to 12v power it’s suddenly not working
Usb powering works? Maybe your 12v powersupply died?
Not working also try to use usbc power meter to see I got 19.98 v and 0.17A and 3.5w
minipcie switch on led is light?
M.PCI 12v led is on and green
my cpu is broken , I can boot into the system and use it normally, but lspci only shows one message.
It’s only said handshake…. And nothing happen
