Tried it with those status properties, but still no luck. Also increased the wait time in the driver from 100ms to 1s. Didn’t change anything.
This is the boot output with log level set to 7 (DEBUG). The dts part is fine, it seems and matches the controller. But the driver itself doesn’t load properly. It goes through it’s reset routine mtk_pcie_startup_port
, but then doesn’t detect the bus or port or whatever it wants to find.
resetting ...
F0: 102B 0000
FA: 1042 0000
FA: 1042 0000 [0200]
F9: 1041 0000
F3: 1001 0000 [0200]
F3: 1001 0000
F6: 380E 5800
F5: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0600 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [3000]
MK: 0000 0000 [0000]
T0: 0000 013D [0101]
Jump to BL
NOTICE: BL2: v2.9(release):310ed284c sdmmc
NOTICE: BL2: Built : 21:22:26, Feb 11 2024
NOTICE: WDT: [40000000] Software reset (reboot)
NOTICE: CPU: MT7988
NOTICE: EMI: Using DDR unknown settings
NOTICE: EMI: Detected DRAM size: 4096 MB
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.9(release):310ed284c sdmmc
NOTICE: BL31: Built : 21:22:30, Feb 11 2024
size=30, ptr=30, limit=4000: 41f27cf0
size=30, ptr=60, limit=4000: 41f27d20
size=98, ptr=f8, limit=4000: 41f27d50
bind node cpus
Device 'cpus' has no compatible string
bind node dummy40m
- attempt to match compatible string 'fixed-clock'
- found match at 'fixed_clock': 'fixed-clock' matches 'fixed-clock'
size=30, ptr=128, limit=4000: 41f27de8
size=98, ptr=1c0, limit=4000: 41f27e18
size=30, ptr=1f0, limit=4000: 41f27eb0
bind node dummy208m
size=98, ptr=288, limit=4000: 41f27ee0
size=30, ptr=2b8, limit=4000: 41f27f78
bind node hwver
- attempt to match compatible string 'mediatek,hwver'
- attempt to match compatible string 'syscon'
Skipping device pre-relocation
bind node timer
- attempt to match compatible string 'arm,armv8-timer'
No match for node 'timer'
bind node watchdog@1001c000
- attempt to match compatible string 'mediatek,mt7622-wdt'
- attempt to match compatible string 'mediatek,mt6589-wdt'
bind node interrupt-controller@c000000
- attempt to match compatible string 'arm,gic-v3'
No match for node 'interrupt-controller@c000000'
bind node infracfg_ao_cgs@10001000
- attempt to match compatible string 'mediatek,mt7988-infracfg_ao_cgs'
- found match at 'mt7988-clock-infracfg_ao_cgs': 'mediatek,mt7988-infracfg_ao_cgs' matches 'mediatek,mt7988-infracfg_ao_cgs'
size=98, ptr=350, limit=4000: 41f27fa8
bind node apmixedsys@1001e000
- attempt to match compatible string 'mediatek,mt7988-fixed-plls'
- found match at 'mt7988-clock-fixed-pll': 'mediatek,mt7988-fixed-plls' matches 'mediatek,mt7988-fixed-plls'
size=98, ptr=3e8, limit=4000: 41f28040
bind node topckgen@1001b000
- attempt to match compatible string 'mediatek,mt7988-topckgen'
- found match at 'mt7988-clock-topckgen': 'mediatek,mt7988-topckgen' matches 'mediatek,mt7988-topckgen'
size=98, ptr=480, limit=4000: 41f280d8
bind node pinctrl@1001f000
- attempt to match compatible string 'mediatek,mt7988-pinctrl'
bind node syscon@10060000
- attempt to match compatible string 'mediatek,mt7988-sgmiisys_0'
bind node syscon@10070000
- attempt to match compatible string 'mediatek,mt7988-sgmiisys_1'
bind node syscon@10080000
- attempt to match compatible string 'mediatek,mt7988-usxgmiisys_0'
bind node syscon@10081000
- attempt to match compatible string 'mediatek,mt7988-usxgmiisys_1'
bind node dummy12m
size=98, ptr=518, limit=4000: 41f28170
size=30, ptr=548, limit=4000: 41f28208
bind node xhci@11200000
- attempt to match compatible string 'mediatek,mt7988-xhci'
- attempt to match compatible string 'mediatek,mtk-xhci'
bind node pcie@11280000
- attempt to match compatible string 'mediatek,mt7988-pcie'
- attempt to match compatible string 'mediatek,mt7986-pcie'
- attempt to match compatible string 'mediatek,mt8192-pcie'
bind node pcie@11290000
bind node pcie@11300000
bind node pcie@11310000
bind node usb-phy@11c50000
- attempt to match compatible string 'mediatek,mt7988'
- attempt to match compatible string 'mediatek,generic-tphy-v2'
bind node syscon@11f20000
- attempt to match compatible string 'mediatek,mt7988-xfi_pextp_0'
bind node syscon@11f30000
- attempt to match compatible string 'mediatek,mt7988-xfi_pextp_1'
bind node syscon@11f40000
- attempt to match compatible string 'mediatek,mt7988-xfi_pll'
bind node topmisc@11d10000
- attempt to match compatible string 'mediatek,mt7988-topmisc'
bind node infracfg@10001000
- attempt to match compatible string 'mediatek,mt7988-infracfg'
- found match at 'mt7988-clock-infracfg': 'mediatek,mt7988-infracfg' matches 'mediatek,mt7988-infracfg'
size=98, ptr=5e0, limit=4000: 41f28238
bind node serial@11000000
- attempt to match compatible string 'mediatek,hsuart'
- found match at 'serial_mtk': 'mediatek,hsuart' matches 'mediatek,hsuart'
size=30, ptr=610, limit=4000: 41f282d0
size=98, ptr=6a8, limit=4000: 41f28300
bind node i2c@11004000
- attempt to match compatible string 'mediatek,mt7988-i2c'
- attempt to match compatible string 'mediatek,mt7981-i2c'
No match for node 'i2c@11004000'
bind node pwm@10048000
- attempt to match compatible string 'mediatek,mt7988-pwm'
bind node spi@1100a000
- attempt to match compatible string 'mediatek,ipm-spi'
bind node mmc@11230000
- attempt to match compatible string 'mediatek,mt7988-mmc'
- attempt to match compatible string 'mediatek,mt7986-mmc'
bind node syscon@15000000
- attempt to match compatible string 'mediatek,mt7988-ethdma'
bind node syscon@15031000
- attempt to match compatible string 'mediatek,mt7988-ethwarp'
bind node ethernet@15100000
- attempt to match compatible string 'mediatek,mt7988-eth'
bind node chosen
Device 'chosen' has no compatible string
bind node memory@40000000
Device 'memory@40000000' has no compatible string
bind node regulator-3p3v
- attempt to match compatible string 'regulator-fixed'
No match for node 'regulator-3p3v'
bind node __symbols__
Device '__symbols__' has no compatible string
size=38, ptr=6e0, limit=4000: 41f28398
size=18, ptr=6f8, limit=4000: 41f283d0
Looking for infracfg_ao_cgs@10001000
- result for infracfg_ao_cgs@10001000: infracfg_ao_cgs@10001000 (ret=0)
size=20, ptr=718, limit=4000: 41f283e8
size=18, ptr=730, limit=4000: 41f28408
size=18, ptr=748, limit=4000: 41f28420
size=18, ptr=760, limit=4000: 41f28438
U-Boot 2024.04-rc1-bpi-r4-nvme-g244556540-dirty (Feb 11 2024 - 21:22:00 +0000)
size=30, ptr=790, limit=4000: 41f28450
size=30, ptr=7c0, limit=4000: 41f28480
size=98, ptr=858, limit=4000: 41f284b0
size=18, ptr=870, limit=4000: 41f28548
bind node cpu@0
- attempt to match compatible string 'arm,cortex-a73'
- found match at 'mtk-cpu': 'arm,cortex-a7' matches 'arm,cortex-a73'
size=98, ptr=908, limit=4000: 41f28560
size=8, ptr=910, limit=4000: 41f285f8
size=20, ptr=930, limit=4000: 41f28600
bind node cpu@1
size=98, ptr=9c8, limit=4000: 41f28620
size=8, ptr=9d0, limit=4000: 41f286b8
size=20, ptr=9f0, limit=4000: 41f286c0
bind node cpu@2
size=98, ptr=a88, limit=4000: 41f286e0
size=8, ptr=a90, limit=4000: 41f28778
size=20, ptr=ab0, limit=4000: 41f28780
bind node cpu@3
size=98, ptr=b48, limit=4000: 41f287a0
size=8, ptr=b50, limit=4000: 41f28838
size=20, ptr=b70, limit=4000: 41f28840
Looking for hwver
Looking for hwver
size=30, ptr=ba0, limit=4000: 41f28860
- result for hwver: (none) (ret=-19)
size=98, ptr=c38, limit=4000: 41f28890
size=8, ptr=c40, limit=4000: 41f28928
size=20, ptr=c60, limit=4000: 41f28930
Looking for hwver
Looking for hwver
- result for hwver: hwver (ret=0)
Looking for hwver
Looking for hwver
Looking for hwver
Looking for hwver
CPU: MediaTek MT7988
Model: mt7988-rfb
DRAM: 4 GiB
bind node cpus
bind node dummy40m
bind node dummy208m
bind node hwver
- found match at 'syscon': 'syscon' matches 'syscon'
bind node timer
- found match at 'mt7988_pinctrl': 'mediatek,mt7988-pinctrl' matches 'mediatek,mt7988-pinctrl'
- found match at 'mt7988-clock-sgmiisys_0': 'mediatek,mt7988-sgmiisys_0' matches 'mediatek,mt7988-sgmiisys_0'
- found match at 'mt7988-clock-sgmiisys_1': 'mediatek,mt7988-sgmiisys_1' matches 'mediatek,mt7988-sgmiisys_1'
bind node dummy12m
- found match at 'xhci-mtk': 'mediatek,mtk-xhci' matches 'mediatek,mtk-xhci'
- found match at 'pcie_mediatek_gen3': 'mediatek,mt8192-pcie' matches 'mediatek,mt8192-pcie'
Device 'interrupt-controller' has no compatible string
- found match at 'mtk-tphy': 'mediatek,generic-tphy-v1' matches 'mediatek,generic-tphy-v2'
- found match at 'mtk_pwm': 'mediatek,mt7622-pwm' matches 'mediatek,mt7988-pwm'
- found match at 'mtk_spim': 'mediatek,ipm-spi' matches 'mediatek,ipm-spi'
bind node spi_nand@0
- attempt to match compatible string 'spi-nand'
- found match at 'spi_nand': 'spi-nand' matches 'spi-nand'
- found match at 'mtk_sd': 'mediatek,mt7620-mmc' matches 'mediatek,mt7986-mmc'
- found match at 'mt7988-clock-ethdma': 'mediatek,mt7988-ethdma' matches 'mediatek,mt7988-ethdma'
- found match at 'mt7988-clock-ethwarp': 'mediatek,mt7988-ethwarp' matches 'mediatek,mt7988-ethwarp'
- found match at 'mtk-eth': 'mediatek,mt7988-eth' matches 'mediatek,mt7988-eth'
bind node chosen
Looking for topckgen@1001b000
- result for topckgen@1001b000: topckgen@1001b000 (ret=0)
Looking for infracfg@10001000
- result for infracfg@10001000: infracfg@10001000 (ret=0)
Core: 51 devices, 19 uclasses, devicetree: separate (ret=0)
MMC: 0
- 0 'mmc@11230000'
- found
- 0 'mmc@11230000'
- not found
mmc@11230000: 0
Loading Environment from nowhere... OK
In: serial@11000000
Out: serial@11000000
Err: serial@11000000
Net: Looking for syscon@15000000
- result for syscon@15000000: (none) (ret=-19)
Looking for topmisc@11d10000
- result for topmisc@11d10000: topmisc@11d10000 (ret=0)
- result for syscon@15000000: reset (ret=0)
- result for syscon@15000000: syscon@15000000 (ret=0)
Looking for syscon@10080000
- result for syscon@10080000: syscon@10080000 (ret=0)
Looking for syscon@11f20000
- result for syscon@11f20000: syscon@11f20000 (ret=0)
Looking for syscon@11f40000
- result for syscon@11f40000: syscon@11f40000 (ret=0)
Looking for watchdog@1001c000
- result for watchdog@1001c000: watchdog@1001c000 (ret=0)
Looking for syscon@15031000
- result for syscon@15031000: reset (ret=0)
- result for syscon@15031000: (none) (ret=-19)
Warning: ethernet@15100000 (eth0) using random MAC address - a6:e3:73:c7:ab:f3
0
- 0 'ethernet@15100000'
- found
eth0: ethernet@15100000
Hit any key to stop autoboot: 0
mtk_sd mmc@11230000: sclk: 259740, timing: 0
mtk_sd mmc@11230000: sclk: 50000000, timing: 2
Signature aa55 valid
count = 128 * 128 = 16384
start 0x22, size 0x1fde, name bl2
start 0x2000, size 0x400, name u-boot-env
start 0x2400, size 0x1000, name factory
start 0x3400, size 0x1000, name fip
start 0x4400, size 0x32000, name boot
start 0x36400, size 0x32001, name rootfs
Found an unused PTE GUID at 0xFFB3DFC0
Invalid partition number 7
Found an unused PTE GUID at 0xFFB3E040
Invalid partition number 8
Found an unused PTE GUID at 0xFFB3E0C0
Invalid partition number 9
Found an unused PTE GUID at 0xFFB3E140
Invalid partition number 10
Found an unused PTE GUID at 0xFFB3E1C0
Invalid partition number 11
Found an unused PTE GUID at 0xFFB3E240
Invalid partition number 12
Found an unused PTE GUID at 0xFFB3E2C0
Invalid partition number 13
Found an unused PTE GUID at 0xFFB3E340
Invalid partition number 14
Found an unused PTE GUID at 0xFFB3E3C0
Invalid partition number 15
Found an unused PTE GUID at 0xFFB3E440
Invalid partition number 16
Found an unused PTE GUID at 0xFFB3E4C0
Invalid partition number 17
Found an unused PTE GUID at 0xFFB3E540
Invalid partition number 18
Found an unused PTE GUID at 0xFFB3E5C0
Invalid partition number 19
Found an unused PTE GUID at 0xFFB3E640
Invalid partition number 20
Found an unused PTE GUID at 0xFFB3E6C0
Invalid partition number 21
Found an unused PTE GUID at 0xFFB3E740
Invalid partition number 22
Found an unused PTE GUID at 0xFFB3E7C0
Invalid partition number 23
Found an unused PTE GUID at 0xFFB3E840
Invalid partition number 24
Found an unused PTE GUID at 0xFFB3E8C0
Invalid partition number 25
Found an unused PTE GUID at 0xFFB3E940
Invalid partition number 26
Found an unused PTE GUID at 0xFFB3E9C0
Invalid partition number 27
Found an unused PTE GUID at 0xFFB3EA40
Invalid partition number 28
Found an unused PTE GUID at 0xFFB3EAC0
Invalid partition number 29
Found an unused PTE GUID at 0xFFB3EB40
Invalid partition number 30
Found an unused PTE GUID at 0xFFB3EBC0
Invalid partition number 31
Found an unused PTE GUID at 0xFFB3EC40
Invalid partition number 32
Found an unused PTE GUID at 0xFFB3ECC0
Invalid partition number 33
Found an unused PTE GUID at 0xFFB3ED40
Invalid partition number 34
Found an unused PTE GUID at 0xFFB3EDC0
Invalid partition number 35
Found an unused PTE GUID at 0xFFB3EE40
Invalid partition number 36
Found an unused PTE GUID at 0xFFB3EEC0
Invalid partition number 37
Found an unused PTE GUID at 0xFFB3EF40
Invalid partition number 38
Found an unused PTE GUID at 0xFFB3EFC0
Invalid partition number 39
Found an unused PTE GUID at 0xFFB3F040
Invalid partition number 40
Found an unused PTE GUID at 0xFFB3F0C0
Invalid partition number 41
Found an unused PTE GUID at 0xFFB3F140
Invalid partition number 42
Found an unused PTE GUID at 0xFFB3F1C0
Invalid partition number 43
Found an unused PTE GUID at 0xFFB3F240
Invalid partition number 44
Found an unused PTE GUID at 0xFFB3F2C0
Invalid partition number 45
Found an unused PTE GUID at 0xFFB3F340
Invalid partition number 46
Found an unused PTE GUID at 0xFFB3F3C0
Invalid partition number 47
Found an unused PTE GUID at 0xFFB3F440
Invalid partition number 48
Found an unused PTE GUID at 0xFFB3F4C0
Invalid partition number 49
Found an unused PTE GUID at 0xFFB3F540
Invalid partition number 50
Found an unused PTE GUID at 0xFFB3F5C0
Invalid partition number 51
Found an unused PTE GUID at 0xFFB3F640
Invalid partition number 52
Found an unused PTE GUID at 0xFFB3F6C0
Invalid partition number 53
Found an unused PTE GUID at 0xFFB3F740
Invalid partition number 54
Found an unused PTE GUID at 0xFFB3F7C0
Invalid partition number 55
Found an unused PTE GUID at 0xFFB3F840
Invalid partition number 56
Found an unused PTE GUID at 0xFFB3F8C0
Invalid partition number 57
Found an unused PTE GUID at 0xFFB3F940
Invalid partition number 58
Found an unused PTE GUID at 0xFFB3F9C0
Invalid partition number 59
Found an unused PTE GUID at 0xFFB3FA40
Invalid partition number 60
Found an unused PTE GUID at 0xFFB3FAC0
Invalid partition number 61
Found an unused PTE GUID at 0xFFB3FB40
Invalid partition number 62
Found an unused PTE GUID at 0xFFB3FBC0
Invalid partition number 63
Found an unused PTE GUID at 0xFFB3FC40
Invalid partition number 64
Found an unused PTE GUID at 0xFFB3FCC0
Invalid partition number 65
Found an unused PTE GUID at 0xFFB3FD40
Invalid partition number 66
Found an unused PTE GUID at 0xFFB3FDC0
Invalid partition number 67
Found an unused PTE GUID at 0xFFB3FE40
Invalid partition number 68
Found an unused PTE GUID at 0xFFB3FEC0
Invalid partition number 69
Found an unused PTE GUID at 0xFFB3FF40
Invalid partition number 70
Found an unused PTE GUID at 0xFFB3FFC0
Invalid partition number 71
Found an unused PTE GUID at 0xFFB40040
Invalid partition number 72
Found an unused PTE GUID at 0xFFB400C0
Invalid partition number 73
Found an unused PTE GUID at 0xFFB40140
Invalid partition number 74
Found an unused PTE GUID at 0xFFB401C0
Invalid partition number 75
Found an unused PTE GUID at 0xFFB40240
Invalid partition number 76
Found an unused PTE GUID at 0xFFB402C0
Invalid partition number 77
Found an unused PTE GUID at 0xFFB40340
Invalid partition number 78
Found an unused PTE GUID at 0xFFB403C0
Invalid partition number 79
Found an unused PTE GUID at 0xFFB40440
Invalid partition number 80
Found an unused PTE GUID at 0xFFB404C0
Invalid partition number 81
Found an unused PTE GUID at 0xFFB40540
Invalid partition number 82
Found an unused PTE GUID at 0xFFB405C0
Invalid partition number 83
Found an unused PTE GUID at 0xFFB40640
Invalid partition number 84
Found an unused PTE GUID at 0xFFB406C0
Invalid partition number 85
Found an unused PTE GUID at 0xFFB40740
Invalid partition number 86
Found an unused PTE GUID at 0xFFB407C0
Invalid partition number 87
Found an unused PTE GUID at 0xFFB40840
Invalid partition number 88
Found an unused PTE GUID at 0xFFB408C0
Invalid partition number 89
Found an unused PTE GUID at 0xFFB40940
Invalid partition number 90
Found an unused PTE GUID at 0xFFB409C0
Invalid partition number 91
Found an unused PTE GUID at 0xFFB40A40
Invalid partition number 92
Found an unused PTE GUID at 0xFFB40AC0
Invalid partition number 93
Found an unused PTE GUID at 0xFFB40B40
Invalid partition number 94
Found an unused PTE GUID at 0xFFB40BC0
Invalid partition number 95
Found an unused PTE GUID at 0xFFB40C40
Invalid partition number 96
Found an unused PTE GUID at 0xFFB40CC0
Invalid partition number 97
Found an unused PTE GUID at 0xFFB40D40
Invalid partition number 98
Found an unused PTE GUID at 0xFFB40DC0
Invalid partition number 99
Found an unused PTE GUID at 0xFFB40E40
Invalid partition number 100
Found an unused PTE GUID at 0xFFB40EC0
Invalid partition number 101
Found an unused PTE GUID at 0xFFB40F40
Invalid partition number 102
Found an unused PTE GUID at 0xFFB40FC0
Invalid partition number 103
Found an unused PTE GUID at 0xFFB41040
Invalid partition number 104
Found an unused PTE GUID at 0xFFB410C0
Invalid partition number 105
Found an unused PTE GUID at 0xFFB41140
Invalid partition number 106
Found an unused PTE GUID at 0xFFB411C0
Invalid partition number 107
Found an unused PTE GUID at 0xFFB41240
Invalid partition number 108
Found an unused PTE GUID at 0xFFB412C0
Invalid partition number 109
Found an unused PTE GUID at 0xFFB41340
Invalid partition number 110
Found an unused PTE GUID at 0xFFB413C0
Invalid partition number 111
Found an unused PTE GUID at 0xFFB41440
Invalid partition number 112
Found an unused PTE GUID at 0xFFB414C0
Invalid partition number 113
Found an unused PTE GUID at 0xFFB41540
Invalid partition number 114
Found an unused PTE GUID at 0xFFB415C0
Invalid partition number 115
Found an unused PTE GUID at 0xFFB41640
Invalid partition number 116
Found an unused PTE GUID at 0xFFB416C0
Invalid partition number 117
Found an unused PTE GUID at 0xFFB41740
Invalid partition number 118
Found an unused PTE GUID at 0xFFB417C0
Invalid partition number 119
Found an unused PTE GUID at 0xFFB41840
Invalid partition number 120
Found an unused PTE GUID at 0xFFB418C0
Invalid partition number 121
Found an unused PTE GUID at 0xFFB41940
Invalid partition number 122
Found an unused PTE GUID at 0xFFB419C0
Invalid partition number 123
Found an unused PTE GUID at 0xFFB41A40
Invalid partition number 124
Found an unused PTE GUID at 0xFFB41AC0
Invalid partition number 125
Found an unused PTE GUID at 0xFFB41B40
Invalid partition number 126
Found an unused PTE GUID at 0xFFB41BC0
Invalid partition number 127
Found an unused PTE GUID at 0xFFB41C40
Invalid partition number 128
FAT read(sect=404), clust_size=4, read_size=4
*** U-Boot Boot Menu ***
1. Enter kernel-name to boot from SD/EMMC.
2. Boot kernel from TFTP.
3. Boot from SD/EMMC.
Exit
## Error: "initrd" not defined
PARTITION_CONFIG only exists on eMMC
sd available
bootconf=#conf-sd
fit=bpi-r4.itb
Failed to load 'bpi-r4.itb'
BPI-R4> pci enum
Looking for usb-phy@11e13000
- result for usb-phy@11e13000: (none) (ret=-19)
Looking for usb-phy@11c50000
- result for usb-phy@11c50000: usb-phy@11c50000 (ret=0)
Looking for dummy12m
- result for dummy12m: dummy12m (ret=0)
drivers/pci/pcie_mediatek_gen3.c:mtk_pcie_startup_port[258] no card detected
BPI-R4>
