[BPI-R4 + BE14] Need a Working Wifi 7 Config
Hello all, I’ve been trying to find some working configurations with the BPI-R4 with the BE14 WiFi 7 card and there’s a LOT of stuff out there and I’ve tried a lot of them, but I simply can’t get the 6GHz channel to fully work on any of my compatible devices. I’m using OpenWRT with the most recent stable build. I am not exactly sure if I need to change any of my packages or update my config. In short, can someone help me figure out a working configuration for this device?
Here’s my current /etc/config/wireless:
config wifi-device 'radio0'
        option type 'mac80211'
        option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0'
        option radio '0'
        option band '2g'
        option channel '1'
        option htmode 'EHT20'
        option cell_density '0'
        option country 'US'
        option txpower '20'
config wifi-iface 'default_radio0'
        option device 'radio0'
        option network 'lan'
        option mode 'ap'
        option ssid 'WiFi'
        option encryption 'sae'
        option key '1234'
        option ocv '0'
        option ieee80211r '1'
        option nasid 'ap-2g'
        option mobility_domain '4f57'
        option ft_over_ds '0'
config wifi-device 'radio1'
        option radio '1'
        option band '5g'
        option channel '36'
        option htmode 'EHT80'
        option country 'US'
        option txpower '20'
config wifi-iface 'default_radio1'
        option device 'radio1'
        option mode 'ap'
        option ssid 'WiFi'
        option key '1234'
        option ocv '0'
        option nasid 'ap-5g'
config wifi-device 'radio2'
        option radio '2'
        option band '6g'
        option channel '37'
        option htmode 'EHT160'
        option country 'US'
        option txpower '20'
config wifi-iface 'default_radio2'
        option device 'radio2'
        option mode 'ap'
        option ssid 'WiFi'
        option key '1234'
        option ocv '0'
        option nasid 'ap-6g'
Here’s my iw dev:
 iw dev
phy#0
        Interface phy0.2-ap0
                ifindex 19
                wdev 0x9
                addr 4a:e3:50:1b:a7:ce
                type AP
                txpower 12.00 dBm
                multicast TXQ:
                        qsz-byt qsz-pkt flows   drops   marks   overlmt hashcol tx-bytes        tx-packets
                        0       0       0       0       0       0       0       0               0
                Radios: 2
        Interface phy0.0-ap0
                ifindex 18
                wdev 0x8
                addr 4a:e3:50:1b:a7:ae
                ssid WiFi
                type AP
                channel 1 (2412 MHz), width: 20 MHz, center1: 2412 MHz
                txpower 6.00 dBm
                multicast TXQ:
                        0       0       0       0       0       0       0       0               0
                Radios: 0
        Interface phy0.1-ap0
                ifindex 17
                wdev 0x7
                addr 4a:e3:50:1b:a7:be
                ssid WiFi
                type AP
                channel 36 (5180 MHz), width: 80 MHz, center1: 5210 MHz
                txpower 7.00 dBm
                multicast TXQ:
                        0       0       0       0       0       0       0       0               0
                Radios: 1
Even links to any working configs would be great since I am a bit overwhelmed and have already poured in quite a few hours to get this working just for it to not work at all. I have 2.4 and 5 working fine, and on LuCI, it looks like 6 works, but it definitely doesn’t
Thanks!
I have used the BE200 and Qualcomm QCNCM865 to connect to R4 wifi, but sometimes there were indeed instances of disconnection. However, using Qualcomm’s WiFi7 will result in a better connection compared to that of the BE200.
