I have a 1200 Mbps service and a modem which has 2x 1Gbps ethernet ports and supports 802.3ad/LACP to send/receive the full service bandwidth. Does bpi-r4 (in OpenWRT) support bonding 2x ethernet ports using LACP, hardware supported to achieve combined bandwidth > 1Gbps? Can’t seem to find this documented or described anywhere, but want to confirm before I pull the trigger on a bpi-r4.
Which ISP and what kind of technology do you use to get internet to your home?
Before you push the button, you should consider more than LACP… (just my opinion
Well naturally that’s not the only thing I’m considering! I’m just looking at bpi-r4 as a potential replacement for my current raspberry pi 4 openwrt router. No WiFi, just wired.
Not sure why it matters, but I have Comcast cable-based internet.
I was just curious! I thought you could may have fiber optics. And may use the SFP modul as a modem.
But cable internet in another construction site …
Oh, how I wish I had other options besides cable!
After some more digging around, it seems that the 4 gigabit ports are a “dumb switch” and probably can only used for cpu-driven bonding. I wonder what kind of throughput can be realized.
OK I thought I should update the community with my findings. Using current (24.10) OpenWRT, bonding does not work on BPI-R4 1Gbit ethernet ports. The bonding commands work, but when a lan1-4 port is part of a bond, the port will not show a link led, and cables are not detected.
Basically, does not work, at all. I ended up using my managed switches to bond 2x 1Gbit ethernet ports into a 2.5Gbit port on an isolated VLAN and use that between the cable modem and the BPI-R4’s 2.5Gbit port (I have 2.5Gbit version). It works great, and sustains speeds well above 1Gbit.
How about a BPI-R4 derivative with 3x SFP and toss the 1Gbit “switch”? ![]()
Did you try other bonding modes? E.g., balance-xor with L3+L4 hashing is what a lot of NASes use. If you’re willing to do more troubleshooting, your could build OpenWrt with dynamic kernel debugging:
- Add
CONFIG_KERNEL_DYNAMIC_DEBUG=yto .config while building. - Run
echo "file drivers/net/* +p" > /sys/kernel/debug/dynamic_debug/controland check what errors pop up in dmesg.
Although, if an extra 10GbE is what you need, you could try an M.2 NIC like this one. In the BPI-R4 it will only have 8 Gbps bandwidth to work with, but still an upgrade over port bonding.
