I didn’t spare money in awareness of crappy SD Cards so I bought a SanDisk Ultra 256GB. Since I saw no other option I burned the latest snapshot again and was able to boot and UART into OpenWrt once. Unfortuantely, after just one power cycle, I got the very same issue.
So I extFat the SD Card in order to check for errors but found none. Burned the image once more, was able to boot once but after a regular reboot … fail.
I will go buy another SD Card to test if that is really at faul today.
F0: 102B 0000
FA: 1040 0000
FA: 1040 0000 [0200]
F9: 103F 0000
F3: 1001 0000 [0200]
F3: 1001 0000
F6: 300C 0028
F5: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 2400 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [3000]
T0: 0000 02B1 [010F]
Jump to BL
NOTICE: BL2: v2.7(release):OpenWrt v2022-08-31-75393484-1 (mt7986-sdmmc-ddr4)
NOTICE: BL2: Built : 12:50:50, May 7 2023
NOTICE: WDT: disabled
NOTICE: CPU: MT7986 (2002MHz)
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.7(release):OpenWrt v2022-08-31-75393484-1 (mt7986-sdmmc-ddr4)
NOTICE: BL31: Built : 12:50:50, May 7 2023
U-Boot 2023.04-OpenWrt-r22755-326eb6e482 (May 07 2023 - 12:50:50 +0000)
CPU: MediaTek MT7986
Model: BananaPi BPi-R3
DRAM: 2 GiB
Core: 52 devices, 24 uclasses, devicetree: embed
SF: Detected w25q256 with page size 256 Bytes, erase size 64 KiB, total 32 MiB
MMC: [email protected]: 0
Loading Environment from MMC... unable to read ssr
unable to read ssr
*** Warning - bad CRC, using default environment
In: [email protected]
Out: [email protected]
Err: [email protected]
reset button found
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Net:
Warning: [email protected] (eth0) using random MAC address - 2a:fb:c6:55:c1:26
eth0: [email protected]
Cannot read EFI system partition
Failed to persist EFI variables
Saving Environment to MMC... Writing to redundant MMC(0)... OK
Saving Environment to MMC... Writing to MMC(0)... OK
off
( ( ( OpenWrt ) ) ) [SD card] U-Boot 2023.04-OpenWrt-r22755-326eb6e482 (May 07 2023 - 12:50:50 +0000)
1. Run default boot command.
2. Boot system via TFTP.
3. Boot production system from SD card.
4. Boot recovery system from SD card.
5. Load production system via TFTP then write to SD card.
6. Load recovery system via TFTP then write to SD card.
7. Install bootloader, recovery and production to NOR.
8. Install bootloader, recovery and production to NAND.
9. Reboot.
a. Reset all settings to factory defaults.
0. U-Boot console
spi-nand: spi_nand [email protected]: unknown raw ID bfacb2e0
No NAND MTD device found
MMC read: dev # 0, block # 131072, count 8 ... 8 blocks read: OK
MMC read: dev # 0, block # 131072, count 20912 ... 20912 blocks read: OK
## Loading kernel from FIT Image at 46000000 ...
Using 'config-mt7986a-bananapi-bpi-r3-nor' configuration
Description: ARM64 OpenWrt Linux-5.15.110
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x46001000
Data Size: 5414855 Bytes = 5.2 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x44000000
Entry Point: 0x44000000
Hash algo: crc32
Hash value: b685a689
Hash algo: sha1
Hash value: 7a90d47d7946cc5c28c3083bd1ba30343e343d6b
## Loading fdt from FIT Image at 46000000 ...
Trying 'fdt-1' fdt subimage
Description: ARM64 OpenWrt bananapi_bpi-r3 device tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x4652b000
Data Size: 32768 Bytes = 32 KiB
Load Address: 0x43ff8000
Hash algo: crc32
Hash value: 63f7568f
Hash algo: sha1
Hash value: 393477ff5e93ef7911e310e3b8b7e673b788a2a9
Loading fdt from 0x4652b000 to 0x43ff8000
Trying 'fdt-mt7986a-bananapi-bpi-r3-nor' fdt subimage
Description: ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor
Data Start: 0x46533000
Load Address: 0x43ff0000
Hash algo: crc32
Hash value: 95d48956
Hash algo: sha1
Hash value: 1c93f277ffa3aecc5aef781cd3d6c72297d961d5
Booting using the fdt blob at 0x43ff8000
Working FDT set to 43ff8000
## Loading loadables from FIT Image at 46000000 ...
Trying 'rootfs-1' loadables subimage
Description: ARM64 OpenWrt bananapi_bpi-r3 rootfs
Type: Filesystem Image
Data Start: 0x46553000
Data Size: 5124096 Bytes = 4.9 MiB
Hash algo: crc32
Hash value: 88249a3f
Hash algo: sha1
Hash value: 90af86746ff3500156f1ec4e9815a0b0f0fcc277
Uncompressing Kernel Image
Loading Device Tree to 00000000be7d2000, end 00000000be7dc7e6 ... OK
Working FDT set to be7d2000
Add '[email protected]' node failed: FDT_ERR_EXISTS
Starting kernel ...
unable to read ssr
unable to read ssr
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.110 ([email protected]) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.2.0 r22755-326eb6e482) 12.2.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Sun May 7 12:50:50 2023
[ 0.000000] Machine model: Bananapi BPI-R3
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
[ 0.000000] node 0: [mem 0x0000000043030000-0x000000004fbfffff]
[ 0.000000] node 0: [mem 0x000000004fc00000-0x000000004ffbffff]
[ 0.000000] node 0: [mem 0x000000004ffc0000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 17 pages/cpu s30040 r8192 d31400 u69632
[ 0.000000] pcpu-alloc: s30040 r8192 d31400 u69632 alloc=17*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: root=/dev/mmcblk0p65
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Memory: 2040252K/2097152K available (8384K kernel code, 902K rwdata, 2232K rodata, 448K init, 301K bss, 56900K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 640 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000137] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000145] pid_max: default: 32768 minimum: 301
[ 0.000358] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000370] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001410] rcu: Hierarchical SRCU implementation.
[ 0.001720] smp: Bringing up secondary CPUs ...
[ 0.001981] Detected VIPT I-cache on CPU1
[ 0.002004] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.002032] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.002301] Detected VIPT I-cache on CPU2
[ 0.002313] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.002324] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.002561] Detected VIPT I-cache on CPU3
[ 0.002570] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.002580] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.002606] smp: Brought up 1 node, 4 CPUs
[ 0.002620] SMP: Total of 4 processors activated.
[ 0.002623] CPU features: detected: 32-bit EL0 Support
[ 0.002626] CPU features: detected: CRC32 instructions
[ 0.002651] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.002705] CPU: All CPU(s) started at EL2
[ 0.002716] alternatives: patching kernel code
[ 0.005838] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.005861] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.006007] pinctrl core: initialized pinctrl subsystem
[ 0.006632] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.006891] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.006921] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.006947] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.007204] thermal_sys: Registered thermal governor 'fair_share'
[ 0.007207] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.007211] thermal_sys: Registered thermal governor 'step_wise'
[ 0.007213] thermal_sys: Registered thermal governor 'user_space'
[ 0.007408] ASID allocator initialised with 65536 entries
[ 0.007724] pstore: Registered ramoops as persistent store backend
[ 0.007728] ramoops: using [email protected], ecc: 0
[ 0.017483] cryptd: max_cpu_qlen set to 1000
[ 0.019366] SCSI subsystem initialized
[ 0.019455] libata version 3.00 loaded.
[ 0.020331] clocksource: Switched to clocksource arch_sys_counter
[ 0.020780] NET: Registered PF_INET protocol family
[ 0.020895] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.021556] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.021575] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.021584] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.021650] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.021823] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.021898] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.021926] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.022093] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.022115] PCI: CLS 0 bytes, default 64
[ 0.024243] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.026888] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.026901] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.048635] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.050091] mtk-pcie-gen3 11280000.pcie: host bridge /soc/[email protected] ranges:
[ 0.050118] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.050128] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 0.050178] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 0.050209] phy phy-soc:[email protected]: pcie auto load valid efuse: ENABLE with value: 1
[ 0.050233] phy phy-soc:[email protected]: u3 lane1 efuse - intr 29, rx_imp 10, tx_imp 10
[ 0.050295] /soc/[email protected]: Failed to get clk index: 0 ret: -517
[ 0.050305] mtk-pcie-gen3 11280000.pcie: failed to get clocks
[ 0.052814] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.054241] printk: console [ttyS0] disabled
[ 0.074391] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
[ 0.773368] printk: console [ttyS0] enabled
[ 0.798162] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
[ 0.808014] mtk_rng 1020f000.trng: registered RNG driver
[ 0.808243] random: crng init done
[ 0.813589] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.824763] loop: module loaded
[ 0.827913] Loading iSCSI transport class v2.0-870.
[ 0.834165] spi-nor spi0.0: w25q256 (32768 Kbytes)
[ 0.839055] 6 fixed-partitions partitions found on MTD device spi0.0
[ 0.845564] Creating 6 MTD partitions on "spi0.0":
[ 0.850346] 0x000000c00000-0x000002000000 : "fit"
[ 0.858927] 1 fit-fw partitions found on MTD device fit
[ 0.864149] Creating 1 MTD partitions on "fit":
[ 0.868664] 0x000000a10000-0x000001400000 : "rootfs_data"
[ 0.874350] 0x000000180000-0x000000c00000 : "recovery"
[ 0.879711] 0x000000100000-0x000000180000 : "fip"
[ 0.884691] 0x000000080000-0x000000100000 : "reserved2"
[ 0.890089] 0x000000040000-0x000000080000 : "u-boot-env"
[ 0.895614] 0x000000000000-0x000000040000 : "bl2"
[ 0.904478] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3-nor" (OpenWrt bananapi_bpi-r3 with mt7986a-bananapi-bpi-r3-nor)
[ 0.916738] FIT: kernel sub-image 0x00001000..0x0051e050 "kernel-1" (ARM64 OpenWrt Linux-5.15.94)
[ 0.926551] FIT: flat_dt sub-image 0x0051f000..0x00526fff "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 0.937754] FIT: flat_dt sub-image 0x00527000..0x0052efff "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 0.953895] FIT: flat_dt sub-image 0x0052f000..0x00536fff "fdt-mt7986a-bananapi-bpi-r3-emmc-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-nor)
[ 0.970904] FIT: flat_dt sub-image 0x00537000..0x0053efff "fdt-mt7986a-bananapi-bpi-r3-emmc-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-snand)
[ 0.988258] FIT: flat_dt sub-image 0x0053f000..0x00546fff "fdt-mt7986a-bananapi-bpi-r3-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-snand)
[ 1.004743] FIT: filesystem sub-image 0x00547000..0x00a0efff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 1.015330] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 1.022618] mtdblock0: p1(rootfs-1)
[ 1.173459] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009880000, irq 134
[ 1.186202] mtk_soc_eth 15100000.ethernet: generated random MAC address 36:2c:9b:0c:a4:9d
[ 1.194947] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009880000, irq 134
[ 1.204477] i2c_dev: i2c /dev entries driver
[ 1.210203] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.218693] NET: Registered PF_INET6 protocol family
[ 1.224262] Segment Routing with IPv6
[ 1.227932] In-situ OAM (IOAM) with IPv6
[ 1.231911] NET: Registered PF_PACKET protocol family
[ 1.236969] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.250075] 8021q: 802.1Q VLAN Support v1.8
[ 1.255205] pstore: Using crash dump compression: deflate
[ 1.265822] mtk-pcie-gen3 11280000.pcie: host bridge /soc/[email protected] ranges:
[ 1.273153] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 1.279525] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 1.288116] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 1.296340] phy phy-soc:[email protected]: pcie auto load valid efuse: ENABLE with value: 1
[ 1.304723] phy phy-soc:[email protected]: u3 lane1 efuse - intr 29, rx_imp 10, tx_imp 10
[ 1.338597] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.350032] mmc0: new high speed SDXC card at address aaaa
[ 1.356307] mmcblk0: mmc0:aaaa SC256 238 GiB
[ 1.364898] Alternate GPT is invalid, using primary GPT.
[ 1.370731] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3-nor" (OpenWrt bananapi_bpi-r3 with mt7986a-bananapi-bpi-r3-nor)
[ 1.382980] FIT: kernel sub-image 0x00001000..0x0052afc6 "kernel-1" (ARM64 OpenWrt Linux-5.15.110)
[ 1.392883] FIT: flat_dt sub-image 0x0052b000..0x00532fff "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 1.404085] FIT: flat_dt sub-image 0x00533000..0x0053afff "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 1.420239] FIT: flat_dt sub-image 0x0053b000..0x00542fff "fdt-mt7986a-bananapi-bpi-r3-emmc-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-nor)
[ 1.437251] FIT: flat_dt sub-image 0x00543000..0x0054afff "fdt-mt7986a-bananapi-bpi-r3-emmc-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-snand)
[ 1.454605] FIT: flat_dt sub-image 0x0054b000..0x00552fff "fdt-mt7986a-bananapi-bpi-r3-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-snand)
[ 1.471089] FIT: filesystem sub-image 0x00553000..0x00a35fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 1.481676] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 1.488966] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p65(rootfs-1) p66(rootfs_data)
[ 1.530354] mtk-pcie-gen3 11280000.pcie: PCIe link down, ltssm reg val: 0x1000001
[ 1.537861] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 1.567151] mt7530 mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 1.576021] mt7530 mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1.584707] mt7530 mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=142)
[ 1.604593] mt7530 mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=143)
[ 1.624176] mt7530 mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=144)
[ 1.643739] mt7530 mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=145)
[ 1.663318] mt7530 mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=146)
[ 1.674001] DSA: tree 0 setup
[ 1.682275] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
[ 1.689545] Freeing unused kernel memory: 448K
[ 1.760397] Run /sbin/init as init process
[ 1.764477] with arguments:
[ 1.767428] /sbin/init
[ 1.770119] with environment:
[ 1.773249] HOME=/
[ 1.775593] TERM=linux
[ 1.886549] init: Console is alive
[ 1.890045] init: - watchdog -
[ 2.153039] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 2.172901] usbcore: registered new interface driver usbfs
[ 2.178407] usbcore: registered new interface driver hub
[ 2.183748] usbcore: registered new device driver usb
[ 2.192554] phy phy-soc:[email protected]: u2 auto load valid efuse: ENABLE with value: 1
[ 2.200718] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 2.208847] phy phy-soc:[email protected]: u2 auto load valid efuse: ENABLE with value: 1
[ 2.217390] xhci-mtk 11200000.usb: xHCI Host Controller
[ 2.222615] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 2.233066] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 2.242218] xhci-mtk 11200000.usb: irq 126, io mem 0x11200000
[ 2.248040] xhci-mtk 11200000.usb: xHCI Host Controller
[ 2.253257] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 2.260638] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 2.267987] hub 1-0:1.0: USB hub found
[ 2.271748] hub 1-0:1.0: 2 ports detected
[ 2.275999] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.284346] hub 2-0:1.0: USB hub found
[ 2.288108] hub 2-0:1.0: 1 port detected
[ 2.294658] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 2.308384] init: - preinit -
[ 2.498257] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 2.506703] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 2.517033] mt7530 mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 2.740334] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 2.920988] hub 1-1:1.0: USB hub found
[ 2.924757] hub 1-1:1.0: 4 ports detected
[ 3.340332] usb 1-1.1: new high-speed USB device number 3 using xhci-mtk
[ 4.577546] mount_root: overlay filesystem in /dev/mmcblk0p66 has not been formatted yet
[ 5.310585] F2FS-fs (mmcblk0p66): Found nat_bits in checkpoint
[ 5.325243] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = 47aee43
[ 5.333086] mount_root: overlay filesystem has not been fully initialized yet
[ 5.340446] mount_root: switching to f2fs overlay
[ 5.346905] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 5.357790] urandom-seed: Seed file not found (/etc/urandom.seed)
[ 5.389370] procd: - early -
[ 5.392344] procd: - watchdog -
[ 5.918679] procd: - watchdog -
[ 5.922025] procd: - ubus -
[ 5.979764] procd: - init -
[ 6.089384] urngd: v1.0.2 started.
[ 6.115647] kmodloader: loading kernel modules from /etc/modules.d/*
[ 6.127010] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
[ 6.133687] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
[ 6.142680] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
[ 6.156800] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
[ 6.164330] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
[ 6.175511] sfp sfp1: Host maximum power 3.0W
[ 6.180648] sfp sfp2: Host maximum power 3.0W
[ 6.634644] mt7986-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[ 6.634644]
[ 6.761320] mt7986-wmac 18000000.wmac: WM Firmware Version: ____000000, Build Time: 20221012174805
[ 6.838724] mt7986-wmac 18000000.wmac: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[ 9.605303] PPP generic driver version 2.4.2
[ 9.610477] NET: Registered PF_PPPOX protocol family
[ 9.618012] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 12.514222] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 12.525674] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 12.534111] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 12.535216] mt7530 mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 12.552252] br-lan: port 1(lan1) entered blocking state
[ 12.557463] br-lan: port 1(lan1) entered disabled state
[ 12.564250] device lan1 entered promiscuous mode
[ 12.568851] device eth0 entered promiscuous mode
[ 12.575556] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.587674] mt7530 mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 12.597125] br-lan: port 2(lan2) entered blocking state
[ 12.602391] br-lan: port 2(lan2) entered disabled state
[ 12.609277] device lan2 entered promiscuous mode
[ 12.618423] mt7530 mdio-bus:1f lan3: configuring for phy/gmii link mode
[ 12.627854] br-lan: port 3(lan3) entered blocking state
[ 12.633093] br-lan: port 3(lan3) entered disabled state
[ 12.640135] device lan3 entered promiscuous mode
[ 12.649180] mt7530 mdio-bus:1f lan4: configuring for phy/gmii link mode
[ 12.658596] br-lan: port 4(lan4) entered blocking state
[ 12.663900] br-lan: port 4(lan4) entered disabled state
[ 12.671209] device lan4 entered promiscuous mode
[ 12.680121] mt7530 mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
[ 12.689526] br-lan: port 5(sfp2) entered blocking state
[ 12.694785] br-lan: port 5(sfp2) entered disabled state
[ 12.702181] device sfp2 entered promiscuous mode
[ 12.711000] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[ 12.721270] br-wan: port 1(eth1) entered blocking state
[ 12.726498] br-wan: port 1(eth1) entered disabled state
[ 12.731940] device eth1 entered promiscuous mode
[ 12.738103] br-wan: port 1(eth1) entered blocking state
[ 12.743373] br-wan: port 1(eth1) entered forwarding state
[ 12.750944] mt7530 mdio-bus:1f wan: configuring for phy/gmii link mode
[ 12.760583] br-wan: port 2(wan) entered blocking state
[ 12.762293] mt7530 mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.765712] br-wan: port 2(wan) entered disabled state
[ 12.779656] device wan entered promiscuous mode
[ 12.786715] br-wan: port 2(wan) entered blocking state
[ 12.791848] br-wan: port 2(wan) entered forwarding state
[ 13.591513] br-wan: port 1(eth1) entered disabled state
BusyBox v1.36.0 (2023-05-07 12:50:50 UTC) built-in shell (ash)
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
OpenWrt SNAPSHOT, r22755-326eb6e482
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
[email protected]:/# poweroff
[email protected]:/# [ 88.669908] device lan1 left promiscuous mode
[ 88.674481] br-lan: port 1(lan1) entered disabled state
[ 88.734410] device lan2 left promiscuous mode
[ 88.738842] br-lan: port 2(lan2) entered disabled state
[ 88.803960] device lan3 left promiscuous mode
[ 88.808388] br-lan: port 3(lan3) entered disabled state
[ 88.873809] device lan4 left promiscuous mode
[ 88.878238] br-lan: port 4(lan4) entered disabled state
[ 88.943619] device sfp2 left promiscuous mode
[ 88.948045] br-lan: port 5(sfp2) entered disabled state
[ 89.216494] br-wan: port 2(wan) entered disabled state
[ 89.223072] device eth1 left promiscuous mode
[ 89.227464] br-wan: port 1(eth1) entered disabled state
[ 89.352444] device wan left promiscuous mode
[ 89.356836] br-wan: port 2(wan) entered disabled state
[ 89.442441] mt7530 mdio-bus:1f wan: Link is Down
[ 89.448899] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 93.272144] reboot: Power down
F0: 102B 0000
FA: 1040 0000
F9: 103F 0000
F3: 1001 0000
F6: 300C 0028
F5: 0000 0000
00: 0000 0000
G0: 1190 0000
T0: 0000 01C3 [010F]
Jump to BL
NOTICE: CPU: MT7986 (2000MHz)
DRAM: 2 GiB
Loading Environment from MMC... mmc fail to send stop cmd
Partition 3: invalid GUID
Partition 5: invalid GUID
Partition 6: invalid GUID
Partition 7: invalid GUID
*** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
reset button found
Loading Environment from MMC... *** Error - No Valid Environment Area found
Net:
Warning: [email protected] (eth0) using random MAC address - 42:dd:64:f8:d8:a9
** No partition table - mmc 0 **
Couldn't find partition mmc 0:5
Saving Environment to MMC... Writing to redundant MMC(0)... failed
Failed (1)
Failed (1)
off
9. Reboot.
0. U-Boot console
spi-nand: spi_nand [email protected]: unknown raw ID bfaca9a0
spi-nand: spi_nand [email protected]: unknown raw ID bfacaa70
spi-nand: spi_nand [email protected]: unknown raw ID bfac8ec0
spi-nand: spi_nand [email protected]: unknown raw ID bfacac40
Using [email protected] device
TFTP from server 192.168.1.254; our IP address is 192.168.1.1
Filename 'openwrt-mediatek-filogic-bananapi_bpi-r3-initramfs-recovery.itb'.
Load address: 0x46000000
Loading: *
ARP Retry count exceeded; starting again
Wrong Image Format for bootm command
ERROR: can't get kernel image!
spi-nand: spi_nand [email protected]: unknown raw ID bfacacc0
Loading: *
Abort
MT7986>
F0: 102B 0000
FA: 1040 0000
F9: 103F 0000
F3: 1001 0000
F6: 300C 0028
F5: 0000 0000
00: 0000 0000
G0: 1190 0000
T0: 0000 02BD [010F]
Jump to BL
DRAM: 2 GiB
Partition 1: invalid GUID
Partition 2: invalid GUID
Partition 4: invalid GUID
reset button found
Net:
Warning: [email protected] (eth0) using random MAC address - 1e:e6:31:a0:4a:0e
Couldn't find partition mmc 0:4
Failed (1)
Failed (1)
off
9. Reboot.
0. U-Boot console
spi-nand: spi_nand [email protected]: unknown raw ID bfacb280
spi-nand: spi_nand [email protected]: unknown raw ID bfacb350
spi-nand: spi_nand [email protected]: unknown raw ID bfac97a0
spi-nand: spi_nand [email protected]: unknown raw ID bfacb520
Loading: *
spi-nand: spi_nand [email protected]: unknown raw ID bfacb5a0
Loading: *
Abort
MT7986>
F0: 102B 0000
FA: 1040 0000
F9: 103F 0000
F3: 1001 0000
F6: 300C 0028
F5: 0000 0000
00: 0000 0000
G0: 1190 0000
Jump to BL
DRAM: 2 GiB
unable to read ssr
reset button found
Net:
Warning: [email protected] (eth0) using random MAC address - 82:2f:72:6e:90:35
off
9. Reboot.
0. U-Boot console
Type: Kernel Image
OS: Linux
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
Starting kernel ...
[ 0.000136] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000143] pid_max: default: 32768 minimum: 301
[ 0.000357] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001718] smp: Bringing up secondary CPUs ...
[ 0.001977] Detected VIPT I-cache on CPU1
[ 0.002000] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.002028] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.002294] Detected VIPT I-cache on CPU2
[ 0.002307] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.002319] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.002558] Detected VIPT I-cache on CPU3
[ 0.002568] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.002578] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.002604] smp: Brought up 1 node, 4 CPUs
[ 0.002619] SMP: Total of 4 processors activated.
[ 0.002622] CPU features: detected: 32-bit EL0 Support
[ 0.002625] CPU features: detected: CRC32 instructions
[ 0.002648] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.002702] CPU: All CPU(s) started at EL2
[ 0.002712] alternatives: patching kernel code
[ 0.005829] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.005852] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.006001] pinctrl core: initialized pinctrl subsystem
[ 0.006625] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.006881] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.006912] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.006938] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.007193] thermal_sys: Registered thermal governor 'fair_share'
[ 0.007196] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.007200] thermal_sys: Registered thermal governor 'step_wise'
[ 0.007203] thermal_sys: Registered thermal governor 'user_space'
[ 0.007397] ASID allocator initialised with 65536 entries
[ 0.007708] pstore: Registered ramoops as persistent store backend
[ 0.007713] ramoops: using [email protected], ecc: 0
[ 0.017443] cryptd: max_cpu_qlen set to 1000
[ 0.019334] SCSI subsystem initialized
[ 0.019420] libata version 3.00 loaded.
[ 0.020301] clocksource: Switched to clocksource arch_sys_counter
[ 0.020749] NET: Registered PF_INET protocol family
[ 0.020863] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.021523] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.021542] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.021551] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.021617] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.021788] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.021864] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.021891] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.022011] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.022080] PCI: CLS 0 bytes, default 64
[ 0.024150] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.026792] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.026807] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.049458] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.050919] mtk-pcie-gen3 11280000.pcie: host bridge /soc/[email protected] ranges:
[ 0.050945] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.050955] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 0.051003] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 0.051036] phy phy-soc:[email protected]: pcie auto load valid efuse: ENABLE with value: 1
[ 0.051060] phy phy-soc:[email protected]: u3 lane1 efuse - intr 29, rx_imp 10, tx_imp 10
[ 0.051118] /soc/[email protected]: Failed to get clk index: 0 ret: -517
[ 0.051127] mtk-pcie-gen3 11280000.pcie: failed to get clocks
[ 0.053645] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.055083] printk: console [ttyS0] disabled
[ 0.075237] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
[ 0.774193] printk: console [ttyS0] enabled
[ 0.798991] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
[ 0.808850] mtk_rng 1020f000.trng: registered RNG driver
[ 0.808909] hwrng: no data available
[ 0.814424] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.825894] loop: module loaded
[ 0.829044] Loading iSCSI transport class v2.0-870.
[ 0.835375] spi-nor spi0.0: w25q256 (32768 Kbytes)
[ 0.840283] 6 fixed-partitions partitions found on MTD device spi0.0
[ 0.846823] Creating 6 MTD partitions on "spi0.0":
[ 0.851607] 0x000000c00000-0x000002000000 : "fit"
[ 0.860209] 1 fit-fw partitions found on MTD device fit
[ 0.865447] Creating 1 MTD partitions on "fit":
[ 0.869962] 0x000000a10000-0x000001400000 : "rootfs_data"
[ 0.875702] 0x000000180000-0x000000c00000 : "recovery"
[ 0.881214] 0x000000100000-0x000000180000 : "fip"
[ 0.886111] 0x000000080000-0x000000100000 : "reserved2"
[ 0.891552] 0x000000040000-0x000000080000 : "u-boot-env"
[ 0.897054] 0x000000000000-0x000000040000 : "bl2"
[ 0.905971] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3-nor" (OpenWrt bananapi_bpi-r3 with mt7986a-bananapi-bpi-r3-nor)
[ 0.918229] FIT: kernel sub-image 0x00001000..0x0051e050 "kernel-1" (ARM64 OpenWrt Linux-5.15.94)
[ 0.928043] FIT: flat_dt sub-image 0x0051f000..0x00526fff "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 0.939245] FIT: flat_dt sub-image 0x00527000..0x0052efff "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 0.955386] FIT: flat_dt sub-image 0x0052f000..0x00536fff "fdt-mt7986a-bananapi-bpi-r3-emmc-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-nor)
[ 0.972394] FIT: flat_dt sub-image 0x00537000..0x0053efff "fdt-mt7986a-bananapi-bpi-r3-emmc-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-snand)
[ 0.989749] FIT: flat_dt sub-image 0x0053f000..0x00546fff "fdt-mt7986a-bananapi-bpi-r3-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-snand)
[ 1.006233] FIT: filesystem sub-image 0x00547000..0x00a0efff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 1.016819] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 1.024113] mtdblock0: p1(rootfs-1)
[ 1.173497] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009880000, irq 134
[ 1.186247] mtk_soc_eth 15100000.ethernet: generated random MAC address fe:30:8b:57:f5:47
[ 1.195049] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009880000, irq 134
[ 1.204582] i2c_dev: i2c /dev entries driver
[ 1.210365] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.218899] NET: Registered PF_INET6 protocol family
[ 1.224545] Segment Routing with IPv6
[ 1.228219] In-situ OAM (IOAM) with IPv6
[ 1.232188] NET: Registered PF_PACKET protocol family
[ 1.237245] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.250380] 8021q: 802.1Q VLAN Support v1.8
[ 1.255398] pstore: Using crash dump compression: deflate
[ 1.266513] mtk-pcie-gen3 11280000.pcie: host bridge /soc/[email protected] ranges:
[ 1.273837] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 1.280090] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 1.288558] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 1.296673] phy phy-soc:[email protected]: pcie auto load valid efuse: ENABLE with value: 1
[ 1.297618] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.304937] phy phy-soc:[email protected]: u3 lane1 efuse - intr 29, rx_imp 10, tx_imp 10
[ 1.324304] mmc0: new high speed SDXC card at address aaaa
[ 1.330626] mmcblk0: mmc0:aaaa SC256 238 GiB
[ 1.339237] Alternate GPT is invalid, using primary GPT.
[ 1.345121] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3-nor" (OpenWrt bananapi_bpi-r3 with mt7986a-bananapi-bpi-r3-nor)
[ 1.357363] FIT: kernel sub-image 0x00001000..0x0052afc6 "kernel-1" (ARM64 OpenWrt Linux-5.15.110)
[ 1.367263] FIT: flat_dt sub-image 0x0052b000..0x00532fff "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 1.378462] FIT: flat_dt sub-image 0x00533000..0x0053afff "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 1.394605] FIT: flat_dt sub-image 0x0053b000..0x00542fff "fdt-mt7986a-bananapi-bpi-r3-emmc-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-nor)
[ 1.411614] FIT: flat_dt sub-image 0x00543000..0x0054afff "fdt-mt7986a-bananapi-bpi-r3-emmc-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-snand)
[ 1.428968] FIT: flat_dt sub-image 0x0054b000..0x00552fff "fdt-mt7986a-bananapi-bpi-r3-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-snand)
[ 1.445452] FIT: filesystem sub-image 0x00553000..0x00a35fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 1.456041] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 1.463334] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p65(rootfs-1) p66(rootfs_data)
[ 1.520328] mtk-pcie-gen3 11280000.pcie: PCIe link down, ltssm reg val: 0x1000001
[ 1.527837] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 1.557252] mt7530 mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 1.566137] mt7530 mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1.574823] mt7530 mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=142)
[ 1.594604] mt7530 mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=143)
[ 1.614224] mt7530 mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=144)
[ 1.633803] mt7530 mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=145)
[ 1.653403] mt7530 mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=146)
[ 1.664100] DSA: tree 0 setup
[ 1.672560] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
[ 1.679830] Freeing unused kernel memory: 448K
[ 1.720349] Run /sbin/init as init process
[ 1.724430] with arguments:
[ 1.727381] /sbin/init
[ 1.730072] with environment:
[ 1.733202] HOME=/
[ 1.735547] TERM=linux
[ 1.846609] init: Console is alive
[ 1.850116] init: - watchdog -
[ 2.113384] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 2.133328] usbcore: registered new interface driver usbfs
[ 2.138838] usbcore: registered new interface driver hub
[ 2.144199] usbcore: registered new device driver usb
[ 2.153081] phy phy-soc:[email protected]: u2 auto load valid efuse: ENABLE with value: 1
[ 2.161246] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 2.169375] phy phy-soc:[email protected]: u2 auto load valid efuse: ENABLE with value: 1
[ 2.177906] xhci-mtk 11200000.usb: xHCI Host Controller
[ 2.183133] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 2.193599] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 2.202756] xhci-mtk 11200000.usb: irq 126, io mem 0x11200000
[ 2.208586] xhci-mtk 11200000.usb: xHCI Host Controller
[ 2.213806] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 2.221188] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 2.228557] hub 1-0:1.0: USB hub found
[ 2.232353] hub 1-0:1.0: 2 ports detected
[ 2.236634] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.244971] hub 2-0:1.0: USB hub found
[ 2.248727] hub 2-0:1.0: 1 port detected
[ 2.255305] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 2.266733] init: - preinit -
[ 2.457877] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 2.466323] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 2.479640] mt7530 mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 2.491953] random: procd: uninitialized urandom read (4 bytes read)
[ 2.700306] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 2.880968] hub 1-1:1.0: USB hub found
[ 2.884739] hub 1-1:1.0: 4 ports detected
[ 4.440306] usb 1-1.1: new high-speed USB device number 3 using xhci-mtk
[ 4.540671] mount_root: overlay filesystem in /dev/mmcblk0p66 has not been formatted yet
[ 4.592604] random: mkfs.f2fs: uninitialized urandom read (16 bytes read)
[ 4.903141] F2FS-fs (mmcblk0p66): Found nat_bits in checkpoint
[ 4.917875] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = 47aee43
[ 4.925739] mount_root: overlay filesystem has not been fully initialized yet
[ 4.933126] mount_root: switching to f2fs overlay
[ 4.939605] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 4.950527] urandom-seed: Seed file not found (/etc/urandom.seed)
[ 4.982208] procd: - early -
[ 4.985130] procd: - watchdog -
[ 5.511108] procd: - watchdog -
[ 5.514462] procd: - ubus -
[ 5.542139] random: ubusd: uninitialized urandom read (4 bytes read)
[ 5.568888] random: ubusd: uninitialized urandom read (4 bytes read)
[ 5.578598] procd: - init -
[ 5.657186] random: jshn: uninitialized urandom read (4 bytes read)
[ 5.665905] random: ubusd: uninitialized urandom read (4 bytes read)
[ 5.672439] random: ubus: uninitialized urandom read (4 bytes read)
[ 5.708410] urngd: v1.0.2 started.
[ 5.726538] random: crng init done
[ 5.729942] random: 21 urandom warning(s) missed due to ratelimiting
[ 5.735747] kmodloader: loading kernel modules from /etc/modules.d/*
[ 5.747489] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
[ 5.754243] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
[ 5.763229] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
[ 5.777301] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
[ 5.784810] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
[ 5.795627] sfp sfp1: Host maximum power 3.0W
[ 5.800768] sfp sfp2: Host maximum power 3.0W
[ 6.254595] mt7986-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[ 6.254595]
[ 6.381241] mt7986-wmac 18000000.wmac: WM Firmware Version: ____000000, Build Time: 20221012174805
[ 6.459473] mt7986-wmac 18000000.wmac: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[ 9.224477] PPP generic driver version 2.4.2
[ 9.229603] NET: Registered PF_PPPOX protocol family
[ 9.237113] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 11.713180] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 11.724809] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 11.733250] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 11.734357] mt7530 mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 11.749141] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.755615] br-lan: port 1(lan1) entered blocking state
[ 11.760843] br-lan: port 1(lan1) entered disabled state
[ 11.767474] device lan1 entered promiscuous mode
[ 11.772150] device eth0 entered promiscuous mode
[ 11.784461] mt7530 mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 11.793880] br-lan: port 2(lan2) entered blocking state
[ 11.799115] br-lan: port 2(lan2) entered disabled state
[ 11.806159] device lan2 entered promiscuous mode
[ 11.815444] mt7530 mdio-bus:1f lan3: configuring for phy/gmii link mode
[ 11.825066] br-lan: port 3(lan3) entered blocking state
[ 11.830290] br-lan: port 3(lan3) entered disabled state
[ 11.837344] device lan3 entered promiscuous mode
[ 11.846306] mt7530 mdio-bus:1f lan4: configuring for phy/gmii link mode
[ 11.855732] br-lan: port 4(lan4) entered blocking state
[ 11.861011] br-lan: port 4(lan4) entered disabled state
[ 11.868293] device lan4 entered promiscuous mode
[ 11.877231] mt7530 mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
[ 11.886653] br-lan: port 5(sfp2) entered blocking state
[ 11.891890] br-lan: port 5(sfp2) entered disabled state
[ 11.899236] device sfp2 entered promiscuous mode
[ 11.907977] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[ 11.917977] br-wan: port 1(eth1) entered blocking state
[ 11.923245] br-wan: port 1(eth1) entered disabled state
[ 11.928641] device eth1 entered promiscuous mode
[ 11.934821] br-wan: port 1(eth1) entered blocking state
[ 11.940056] br-wan: port 1(eth1) entered forwarding state
[ 11.947320] mt7530 mdio-bus:1f wan: configuring for phy/gmii link mode
[ 11.956664] br-wan: port 2(wan) entered blocking state
[ 11.961807] br-wan: port 2(wan) entered disabled state
[ 11.968373] device wan entered promiscuous mode
[ 12.791303] br-wan: port 1(eth1) entered disabled state
_______ ________ __
[email protected]:/# reboot
[email protected]:/# [ 47.613162] device lan1 left promiscuous mode
[ 47.617601] br-lan: port 1(lan1) entered disabled state
[ 47.724242] device lan2 left promiscuous mode
[ 47.728654] br-lan: port 2(lan2) entered disabled state
[ 47.823877] device lan3 left promiscuous mode
[ 47.828281] br-lan: port 3(lan3) entered disabled state
[ 47.893706] device lan4 left promiscuous mode
[ 47.898111] br-lan: port 4(lan4) entered disabled state
[ 47.993506] device sfp2 left promiscuous mode
[ 47.997909] br-lan: port 5(sfp2) entered disabled state
[ 48.209859] device eth1 left promiscuous mode
[ 48.214294] br-wan: port 1(eth1) entered disabled state
[ 48.302577] device wan left promiscuous mode
[ 48.306964] br-wan: port 2(wan) entered disabled state
[ 48.374662] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 52.672139] reboot: Restarting system
F0: 102B 0000
FA: 1040 0000
F9: 103F 0000
F3: 1001 0000
F6: 300C 0028
F5: 0000 0000
00: 0000 0000
G0: 1190 0000
Jump to BL
DRAM: 2 GiB
Loading Environment from MMC... Partition 1: invalid GUID
reset button found
Net:
Warning: [email protected] (eth0) using random MAC address - d2:2e:cc:70:01:1c
No EFI system partition
Failed (1)
Failed (1)
off
9. Reboot.
0. U-Boot console
spi-nand: spi_nand [email protected]: unknown raw ID bfaca370
spi-nand: spi_nand [email protected]: unknown raw ID bfaca440
spi-nand: spi_nand [email protected]: unknown raw ID bfac8890
spi-nand: spi_nand [email protected]: unknown raw ID bfaca610
Loading: *
spi-nand: spi_nand [email protected]: unknown raw ID bfaca690
Loading: *
Abort
MT7986>
