BPI-R3 wifi problems
Hi, The wifi on the BPI-R3 is unreliable, in that after a period of use, it starts refusing to forward packets to some destinations but not others. Work arounds:
  1. disconnect wifi and connect again from the client.
  2. Power cycle the BPI-R3. Not a soft reboot of the BPI-R3 does not resolve the problem.
My first ask, is
  1. Find a way that a soft reboot will resolve this, not needing a power off. I can then reboot periodically once a day to mostly resolve the problem.
In the long run, I wish to diagnose this problem. I assume the firmware in the mediatek chip can creates logs. How can we retrieve those logs into user space? When it currently stopped forwarding packets, there is not a single line in the syslog or dmesg. Not uninteresting logs, no logs at all. This problem is present on openwrt and also a normal ubuntu installation on the BPI-R3 with kernel 6.9-rc1 on it. I loaded the ubuntu and 6.9 kernel from source, so that it will be easier for me to try fixes. Any idea on how to further diagnose this?
If you know non-working targets i would try to capture these packets with tcpdump. Which period (hours,days,weeks)? Forwarding some targets and others not are strange and maybe some firewalling…as you wrote you have this issue on ubuntu too i guess you have not enabled wed,right? This is still known as broken in mainline kernel.
For the non-working targets.
Imagine I am on a 192.168.0.0/24 network. I.e. A private network.
Wifi clients get assigned addresses form 192.168.0.100 - 150.
BPI-R3 on .10
Wifi bridged to LAN, no NAT involved.
Some LAN based hosts on .1 .20 .30
When first the wifi client connects, it can ping .1 .20 .30.
After some time, maybe 24 hours, it can ping .1 and .30 but not .20.
Everything on the LAN can still ping .1 .20 .30
If the wifi client disconnects and reconnects, it can ping .1 .20 .30.
If the BPI-R3 is rebooted, the problem remains, or might work for a bit, but returns quickly, within 10 mins normally.
If the BPI-R3 is powered off, the problem disappears for about another 24 hours.
The main symptom (might be other problems as well) is that ARP requests begin to stop getting through, and thus when they expire, the problem presents itself.
The problem is the same whether openwrt or ubuntu is installed on the BPI-R3.
As an aside, other old access points that I installed openwrt on, that used mediatek chipsets also had similar problems with some packets not getting through. So, I think this has been a very long standing issue with mediatek chipsets.
So, I am basically asking for any hooks one can have into the mediatek firmware that will finally diagnose the cause of the problem, so one can work around it.
Diagnostics so far: Only plug one LAN cable into the BPI-R3. The problem remains no matter which LAN or SFP port you plug into.
So, from this I am suspecting the wifi chips / wifi firmware.
For clarification, “not enabled wed”. Please can you point me to the exact setting that toggles this. As it might be a little ambiguous otherwise.
Maybe this is the issue…
My image uses different subnets for lan and wifi (not sure if i have already changed all to systemd…used dnsmasq before and in my own setups because of mac2ip mappings which systemd not supported in my last try)
So maybe your wifi-clients get ips from wifi-subnet and then cannot access lan-clients on ip layer because they are same lan-segment but different ip subnets.
The time also would match the lease time of dhcp…
So please check ip settings of your clients.
@frank-w The IP addresses are fine. When the wifi client initially connects, it can reach everything, so routing, subnets is fine. It is only after being connected for a while that things then start failing. In case it makes a difference, I am not using the BPI-R3 as a DHCP or DNS server for the wifi clients. The DHCP/DNS server is elsewhere on the network.
TODO: I have thought of another test I can do to further diagnose this. But I am waiting for the fault to appear before posting results.
With bridged wifi/lan i guess you will not see much in tcpdump,on r2 there was an issue with this setup in wifi driver…not sure it is working on r3 without problems. But this is completely different driver.
Most debug will be in driver itself or via debugfs. You can also print interface statistics with ip or ethtool. Maybe there are some errors or dropped packets.
Have you disabled the parts for dhcp? If not you will have it stil running it in parallel with your external one which also causes strange errors
@frank-w dhcp is not running on the r3. The interface stats: It does not register that it is dropping any packets when the problem occurs.
The r3 is not running any firewall. You are correct, tcpdump on the r3 might not be capturing all the traffic, even when the r3 is forwarding packets ok. I.e. before the loss of packets bug occurs.
A problem did occur today with regards to the BPI-R3 not forwarding wifi packets.
It is probably different from some other causes, but this time I have 4 SSID.
2g-1
2g-2
5g-3
5g-4
During this problem, 2g-1 failed to forward packets. Any client attempting to connect to it failed because DHCP was failing. If the client was given a static IP address, ARPs were not resolving. If the client was given static ARPs, IP packets were not forwarding. They appear in the tcpdump -i wlan0, but were not forwarded out of the ethernet ports.
Clients trying to connect to 2g-2, 5g-3 and 5g-4 continued to work. I looked at the bridge status, and 2g-1 interface had dropped off the list of interfaces on the bridge, 2g-2, 5g-3 and 5g-4 interfaces were still there. restarting hostapd (the one for 2g-1 and 2g-2) fixed the problem, and 2g-1 and 2g-2 now appeared on the bridge. Also the clients were able to forward packets again through the BPI-R3.
So, I have found one bug and it looks to be caused by hostapd removing an interface from the bridge for no apparent reason.
I now have some better methods to diagnose the problem, so I will look to see if it happens again the next time packets stop forwarding.
I’m reposting this because I think I’ve run into the same problem.
tl;dr: On my BPI-R3, bridging the onboard MT7915 Wi-Fi (wlan1) into br0 causes broken ARP forwarding. The kernel shows offload FDB entries for Wi-Fi clients, and their traffic bypasses the bridge datapath — so frames on wlan1 are not visible on br0. This happens even with recent kernels (e.g. CI-BUILD-6.6-main-6.6.101-2025-08-10_0749) and up-to-date linux-firmware.
My Experience: BPI-R3 WiFi Bridge + Offload Issue (MT7915 / mt76)
I want to share my findings about a persistent issue I see on my Banana Pi R3 when using it as a WiFi access point bridged to the LAN interface.
:desktop_computer: Setup
Firmware: latest Mediatek WiFi firmware from linux-firmware.git
  • (as of 2025-09-17)
  • Driver: mt7915e (mt76-based)
  • Interfaces:
    • wlan1 (5 GHz AP)
    • fth4 (LAN)
    • both bridged into br0
:warning: Problem: Stuck Offloaded FDB Entries
Even with the new kernel + latest firmware, I still see this:
# bridge fdb show | egrep '60:df:bb:89:03:c6|00:db:cf:24:03:7b'
00:db:cf:24:03:7b dev fth4 master br0
00:db:cf:24:03:7b dev fth4 self
60:df:bb:89:03:c6 dev wlan1 offload master br0
  • Note the offload flag on the wlan1 entry.
  • Packets visible on wlan1 do not always appear on br0, which breaks ARP resolution.
  • This results in clients associated via WiFi sometimes being invisible to other bridge members, even though they are connected and passing traffic.
2 tcpdumps show the issue. One is running on br0 the other is running on wlan1. The ARP replies available on wlan1 are not forwarded to br0:
# tcpdump -i br0 arp and host roset and host karath
08:53:19.860245 ARP, Request who-has roset.test.de tell karath.test.de, length 46
08:53:21.373596 ARP, Request who-has roset.test.de tell karath.test.de, length 46
08:53:22.132287 ARP, Request who-has roset.test.de tell karath.test.de, length 46
08:53:22.901243 ARP, Request who-has roset.test.de tell karath.test.de, length 46
# tcpdump -i wlan1 arp and host roset and host karath
08:53:19.860258 ARP, Request who-has roset.test.de tell karath.test.de, length 46
08:53:20.031953 ARP, Reply roset.test.de is-at 00:db:cf:24:03:7b (oui Unknown), length 28
08:53:21.373629 ARP, Request who-has roset.test.de tell karath.test.de, length 46
08:53:21.467209 ARP, Reply roset.test.de is-at 00:db:cf:24:03:7b (oui Unknown), length 28
08:53:22.132303 ARP, Request who-has roset.test.de tell karath.test.de, length 46
08:53:22.285808 ARP, Reply roset.test.de is-at 00:db:cf:24:03:7b (oui Unknown), length 28
08:53:22.901256 ARP, Request who-has roset.test.de tell karath.test.de, length 46
08:53:23.105893 ARP, Reply roset.test.de is-at 00:db:cf:24:03:7b (oui Unknown), length 28
:thought_balloon: Current Conclusion
It looks like the driver/hardware is offloading traffic bypassing the Linux bridge datapath, which causes ARP and broadcast traffic to vanish. This makes bridging unreliable on the BPI-R3’s onboard WiFi.
If anyone has managed to completely disable the hardware offload path on mt76/mt7915, I’d love to hear about it.
As of now running the mentioned kernel/firmware the BPI-R3 is not usable for bridging AP ports.
Imho related: Regression: DSA breaks roaming to WLAN bridged to VLAN · Issue #11650 · openwrt/openwrt · GitHub
Thanks for the tip.
But I don’t use VLANs. Just a rather basic bridge bridging some of the ethernet ports to the AP port created by hostapd. Nothing special. No firewall/iptables.
Is there a way to disable offloading somehow? Are there kernel/firmware versions I could try?
I now found a workaround for the broken ARP forwarding issue on BPI-R3 boards (debian 12.12, kernel 6.12.51-bpi-r3):
along with roaming whenever a wireless client shows up on a new access point (aka another BPI-R3 board) I automatically purge (aka deauthenticate) old MAC address entries of this client from all other access points per:
hostapd_cli -i wlan1 deauthenticate <MAC addr>
this completely “fixes” the issue described above :+1:‍
