it works better, but i can’t receive my IP from my ISP.
root@OpenWrt:/# ethtool eth1
Settings for eth1:
Supported ports: [ FIBRE ]
1000baseX/Full
Speed: 2500Mb/s
Duplex: Full
Auto-negotiation: on
Port: FIBRE
PHYAD: 0
Transceiver: internal
Link detected: yes
ip a
root@OpenWrt:/# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1504 qdisc mq state UP qlen 1000
link/ether b2:2d:e6:d9:d9:b3 brd ff:ff:ff:ff:ff:ff
inet6 fe80::b02d:e6ff:fed9:d9b3/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
link/ether e2:52:f8:bd:e9:e2 brd ff:ff:ff:ff:ff:ff
inet 192.168.20.1/24 brd 192.168.20.255 scope global eth1
inet6 fe80::e052:f8ff:febd:e9e2/64 scope link
4: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
5: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
6: lan2@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
7: lan3@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
8: lan4@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
9: sfp2@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
10: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN qlen 1000
link/ether 00:0c:43:26:60:00 brd ff:ff:ff:ff:ff:ff
11: wlan1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN qlen 1000
link/ether b6:2d:e6:d9:d9:b5 brd ff:ff:ff:ff:ff:ff
15: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
inet 192.168.1.1/24 brd 192.168.1.255 scope global br-lan
inet6 fd5b:6915:1f::1/60 scope global noprefixroute
ping 192.168.20.10
root@OpenWrt:/# ping 192.168.20.10
PING 192.168.20.10 (192.168.20.10): 56 data bytes
64 bytes from 192.168.20.10: seq=8 ttl=64 time=0.523 ms
64 bytes from 192.168.20.10: seq=8 ttl=64 time=0.569 ms (DUP!)
64 bytes from 192.168.20.10: seq=8 ttl=64 time=0.631 ms (DUP!)
64 bytes from 192.168.20.10: seq=9 ttl=64 time=0.817 ms
[ 940.800077] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 941.830065] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
64 bytes from 192.168.20.10: seq=9 ttl=64 time=15001.510 ms (DUP!)
64 bytes from 192.168.20.10: seq=24 ttl=64 time=0.861 ms
64 bytes from 192.168.20.10: seq=25 ttl=64 time=0.422 ms
64 bytes from 192.168.20.10: seq=26 ttl=64 time=0.368 ms
64 bytes from 192.168.20.10: seq=27 ttl=64 time=0.411 ms
64 bytes from 192.168.20.10: seq=28 ttl=64 time=0.300 ms
64 bytes from 192.168.20.10: seq=29 ttl=64 time=0.300 ms
64 bytes from 192.168.20.10: seq=30 ttl=64 time=0.351 ms
64 bytes from 192.168.20.10: seq=31 ttl=64 time=0.362 ms
64 bytes from 192.168.20.10: seq=32 ttl=64 time=4.561 ms
64 bytes from 192.168.20.10: seq=33 ttl=64 time=0.365 ms
64 bytes from 192.168.20.10: seq=34 ttl=64 time=0.292 ms
64 bytes from 192.168.20.10: seq=35 ttl=64 time=0.287 ms
64 bytes from 192.168.20.10: seq=36 ttl=64 time=0.371 ms
64 bytes from 192.168.20.10: seq=37 ttl=64 time=0.354 ms
64 bytes from 192.168.20.10: seq=38 ttl=64 time=0.302 ms
64 bytes from 192.168.20.10: seq=39 ttl=64 time=0.301 ms
64 bytes from 192.168.20.10: seq=40 ttl=64 time=0.365 ms
64 bytes from 192.168.20.10: seq=41 ttl=64 time=0.354 ms
64 bytes from 192.168.20.10: seq=42 ttl=64 time=0.413 ms
64 bytes from 192.168.20.10: seq=43 ttl=64 time=0.423 ms
64 bytes from 192.168.20.10: seq=44 ttl=64 time=0.412 ms
64 bytes from 192.168.20.10: seq=45 ttl=64 time=0.361 ms
64 bytes from 192.168.20.10: seq=43 ttl=64 time=11001.194 ms (DUP!)
64 bytes from 192.168.20.10: seq=44 ttl=64 time=10001.161 ms (DUP!)
64 bytes from 192.168.20.10: seq=45 ttl=64 time=9001.103 ms (DUP!)
64 bytes from 192.168.20.10: seq=54 ttl=64 time=0.502 ms
64 bytes from 192.168.20.10: seq=55 ttl=64 time=0.354 ms
64 bytes from 192.168.20.10: seq=55 ttl=64 time=13379.608 ms (DUP!)
64 bytes from 192.168.20.10: seq=54 ttl=64 time=14379.714 ms (DUP!)
64 bytes from 192.168.20.10: seq=45 ttl=64 time=23380.337 ms (DUP!)
64 bytes from 192.168.20.10: seq=54 ttl=64 time=14379.735 ms (DUP!)
64 bytes from 192.168.20.10: seq=55 ttl=64 time=13379.678 ms (DUP!)
64 bytes from 192.168.20.10: seq=69 ttl=64 time=0.411 ms
64 bytes from 192.168.20.10: seq=70 ttl=64 time=0.395 ms
64 bytes from 192.168.20.10: seq=55 ttl=64 time=24002.043 ms (DUP!)
64 bytes from 192.168.20.10: seq=54 ttl=64 time=25002.148 ms (DUP!)
64 bytes from 192.168.20.10: seq=69 ttl=64 time=10001.137 ms (DUP!)
64 bytes from 192.168.20.10: seq=70 ttl=64 time=9001.080 ms (DUP!)
64 bytes from 192.168.20.10: seq=55 ttl=64 time=24002.112 ms (DUP!)
64 bytes from 192.168.20.10: seq=69 ttl=64 time=10001.288 ms (DUP!)
64 bytes from 192.168.20.10: seq=80 ttl=64 time=0.295 ms
64 bytes from 192.168.20.10: seq=81 ttl=64 time=0.385 ms
^C
--- 192.168.20.10 ping statistics ---
83 packets transmitted, 30 packets received, 17 duplicates, 63% packet loss
round-trip min/avg/max = 0.287/4807.048/25002.148 ms
i can ping the ONT but here are (DUP!), so i guess something doesn’t work as expected and i don’t get my IP
the good thing is that it is now recognized at 2500mbps and eth1 is UP
Once i plug back the other ONT, everything works.
