BPI-R3 using both SFP as LAN
I’ve just got my BPI-R3 and planning to use it as OpenWRT router. I wanted to know if both SFP ports can be used as LAN, (I’ll be using 1Gb port used as WAN since my ISP ~ 400mb).
Thanks
Should be possible because these are only interfaces…just move wan (switchport afaik named differently in openwrt) out of lanbr and the sfp interfaces into it
I was worried it might be hardware-bound.
I’ll give it a try. Thanks
I’ve got my BPI-R3 and did as you said. It did not work.
I’m using the WAN port to connect to my modem. When I plug my PC to sfp1, I don’t get an IP.
Here’s my network config:
>_ cat /etc/config/network
config interface 'loopback'
	option device 'lo'
	option proto 'static'
	option ipaddr '127.0.0.1'
	option netmask '255.0.0.0'
config globals 'globals'
	option ula_prefix 'fddb:f70f:69da::/48'
config device
	option name 'br-lan'
	option type 'bridge'
	list ports 'eth1'
	list ports 'lan1'
	list ports 'lan2'
	list ports 'lan3'
	list ports 'lan4'
	list ports 'sfp2'
config interface 'lan'
	option device 'br-lan'
	option ipaddr '10.0.1.1'
	option netmask '255.255.255.0'
	option ip6assign '60'
config device
	option name 'wan'
	option macaddr '56:c8:b5:c7:2e:0c'
config device
	option name 'eth1'
config interface 'wan'
	option device 'wan'
	option proto 'dhcp'
config interface 'wan6'
	option device 'br-wan'
	option proto 'dhcpv6'
	option auto '0'
	option reqaddress 'try'
	option reqprefix 'auto'
You need to remove eth1 and option device ‘br-wan’ from the wan bridge
	option device 'lo'
config device
	list ports 'eth1'
	list ports 'lan1'
	list ports 'lan2'
	list ports 'lan3'
	list ports 'lan4'
	list ports 'sfp2'
config device
	option name 'wan'
	option device 'wan'
	option proto 'dhcp'
	option device 'wan'
	option auto '0'
Thanks @AntonyFl for your help.
I’ve managed to get it working. The source of the problem was that I needed to reboot the router for changes to work (the “refresh” and “save changes” did not help). I did not know if the changes I applied were correct or not to earn a reboot.
As you’ve stated, the working config.
# >_ cat /etc/config/network
	option device 'lo'
config device
	list ports 'eth1'
	list ports 'lan1'
	list ports 'lan2'
	list ports 'lan3'
	list ports 'lan4'
	list ports 'sfp2'
	option device 'wan'
	option proto 'dhcp'
	option auto '0'
