Hello,
i wanted to upgrade openwrt from 23.05 to 24.10 and i’m getting this message :
i’m actually booting from sd-card (all jumpers high), i don’t know exactly what i am supposed to do about the bootloader, I did some research and found this page that explains what to do for spi-nand. So I did what it says, but I still get the bootloader message.
https://openwrt.org/toh/sinovoip/bananapi_bpi-r3#upgrading_bootloader
root@OpenWrt:~# opkg install kmod-mtd-rw
Package kmod-mtd-rw (5.15.167+git-20160214-2) installed in root is up to date.
root@OpenWrt:~# insmod mtd-rw i_want_a_brick=1
module is already loaded - mtd-rw
root@OpenWrt:~# mtd erase fip
Unlocking fip ...
Erasing fip ...
root@OpenWrt:~# mtd write /tmp/*bananapi_bpi-r3-snand-bl31-uboot.fip fip
Unlocking fip ...
Writing from /tmp/openwrt-24.10.0-mediatek-filogic-bananapi_bpi-r3-snand-bl31-uboot.fip to fip ...
root@OpenWrt:~# # clear environment
root@OpenWrt:~# ubiupdatevol /dev/ubi0_0 -t
root@OpenWrt:~# ubiupdatevol /dev/ubi0_1 -t
root@OpenWrt:~#
You don’t need to.
SDcard Image includes ALL you need.
So if you downloaded the new 24.10 sd card image and are running from that you can use official OpenWRT wiki from the installation part on how to flash onto eMMC.
If you can’t or don’t want to use serial console, you should boot your device from microSD. You can then instruct the bootloader to perform installation on the next reboot using the bootloader environment accessible from inside OpenWrt, eg. via SSH.
To instruct the bootloader to install to SPI-NAND (A=1, B=1, C=1, D=1):
For installation to eMMC, you need to first install to SPI-NAND, and then initialize the eMMC from there. This is because you cannot access both, microSD and eMMC, at the same time, but only what is selected on boot according to the position of dip switch D. So first install to SPI-NAND from microSD, then disconnect the board from power and set dip switches to install to eMMC (A=1, B=0, C=1, D=0). Then boot from SPI-NAND and instruct the bootloader to install to eMMC:
hi.i have similar problem.
i have BANANA BPI-R3 with openwrt 23.05.5 installed in emmc.
my sd card on Banana BPI-R3 doesn’t work.
i tried upgrading u-boot for nor and for nand and both failed and when trying to boot i don’t even get
the BOOT menu via UART.
the emmc boots fine and i also have nvme m.2 installed and working.
how can i upgrade the u-boot and than upgrade to 24.10 without sd card?
is there away to do this using usb port with sd card to usb device?
ill appreciate if you can point me to the right direction to solve this.
thank u
I tried upgrading from 35.05.5 to 24.10 via system upgrade file/menu option, but this didn’t work.
Then I tried upgrading via SD card and serial cable, but this failed too for me as my keyboard input wasnt recognized to stop endless boot cycle from SD with 24.10 image on it.
I would appreciate if anybody shared their instructions how they did it.
I started by making a backup from LUCI.
Then i removed the sdcard and installed the new version on it, with balena etcher
Then I booted on the sdcard, installed my packages and imported my backup.
here’s what i did to upgrade from 24.10.0 to 24.10.1 on my BPI-R4. after a few minutes of testing it seems to have worked fine, all my non-trivial config preserved, etc:
opkg update
opkg install owut
backup my config (for extra safety)
stop everything not necessary
docker
owut upgrade
router reboots…
restore /home symlink
last step: i have an nvme partition mounted to /opt and i symlink /home to /opt/home. i’m using user logins and sudo.
note: this downloads an image built specifically for you from the openwrt website, and some security issues have been identified and fixed in the past with that service.
It did work when i used the sd-card.
But it failed, when i tried to do this on the eMMC.
To be precise, the part that failed was sysupgrade -n.
On the sd-card, the system was updated (i.e. from 24.10.3 to 24.10.4)
When i booted from the eMMC and tried to do the same, the firmware stayed on the old version.
There was an error message saying something about card reset not possible, but i was in a hurry to re-establish the internet connection so i didn’t pay enough attention to it (family, you know).
When i find some time, i’ll try this again and make sure to save the error message for trouble shooting.
Well, i do know how it works…owut update uses sysupgrade to write the image to the flash memory.
You can test it if you use owut download instead of owut update.
This will just store the downloaded image under /tmp/firmware.bin. Then you can use sysupgrade /tmp/firmware.bin to write the image.
Whatsoever, i just wanted to state that on my BPI-R3 this only works with the sd-card, not eMMC.
Where do you run openwrt from on your R4? SD-card, eMMC or SPI-NAND?
yeah, owut may use sysupgrade under the hood, but it generates a custom fw image. if you just flash a simple fw image from the download section, then it could be missing some, which may e.g. prevent eMMC access, which in turn would derail the boot process.
my openwrt on the R4 is booting from eMMC (about 90% sure).
So, after some searching and poking i found the culprit: Me.
Somehow i forgot to add fitblk to the image, therefore sysupgrade couldn’t write to the eMMC. After fixing this, everything is working smoothly (again).
Now owut can update the router without the need to use the UART connection.
Upgrade from 24.10 to 25.12 while keeping config doesn’t work either…
ERROR: sysupgrade validation failed:
stderr =
Sat Mar 7 07:28:10 CET 2026 upgrade: The device is supported, but the config is incompatible
to the new image (1.2->1.3). Please upgrade without keeping config (sysupgrade -n).
Sat Mar 7 07:28:10 CET 2026 upgrade: First sfp port renamed from eth1 to sfp1
Image check failed.
Of course not. That’s why you shouldn’t keep the config.
But if you dare, you could try the following:
Make a complete backup and put it somewhere safe.
Edit the file
/etc/config/system
and change the line
option compat_version ‘1.2’
to
option compat_version '1.3`
Review the file
/etc/config/network
and change any eth1 to sfp1.
Edit the file
/etc/board.json
and change
lan5 to sfp2
and
eth1 to sfp1.
After this, make another backup of your configuration and restart the router.
If it boots successfully, you could try the sysupgrade while keeping the config.
