Wow, these are some nice updates. Thanks @ericwoud for setting up the tutorial. I am also a big fan of Archlinux so this is quite fortuitous. Definitely saves me a lot of time migrating things.
So anyway, the kexec experiment stranded at pcie not initializing correctly. Although a have a custom ‘hack’ / feature in mind of arm trusted firmware, to do something similar as kexec. But more of a proof of concept and for my own use and anyone interested
Hi @ericwoud. I had a look at your guide and I’d like to try the “2. ATF - KERNEL using boot partition.” boot method. However I do have three questions before I start and mess up my system.
I would like to attempt this first on a sd-card. I feel like that is easier to swap-in/out while I test out things. Do you think your guide will work with that? (I plan to run the commands manually first to figure out what happens, and can swap emmc references with the sd-card).
I am building my own kernel and would like to keep using that if possible. Do I need any specific config enabled in the kernel to support the ATF - KERNEL method or your method will work with any kernel itb image (assuming things are configured correctly)?
@frank-w you might also add something along the lines of the patch attached in the uEnv_r3.
u3dev.patch (1.5 KB)
Also, going a bit off-topic here, but I think the NOR memory would be perfect for this. I have been trying to follow your tutorial at en:bpi-r3:uboot [FW-WEB Wiki] but can’t seem to get a bootable NOR setup. Do you think I need to change anything from the linked tutorial, or it should work as is?
If i not miss anything it should work as such,make sure you use the bl2.img to have the bootrom header. What happens when you try to boot nor? Make sure all bootswitches are right.
And you have to erase the parts written later.
Why have you changed useinitrd in your patch? It then misses the “root=/dev/ram rw”
My initrd (Archlinux auto generated) was getting confused by that was halting the boot. Seemed easier to remove than figure out exactly what’s going on. This however was always the case for me and it’s not related to the NVME.
Switches seem to be right. Triple checked. I am using your repo to generate the bl2 and fip. I suspect my atf build command might be invalid, see below, but I am not sure what I can use instead.
make -f ./Makefile PLAT="mt7986" BOOT_DEVICE="${device}" DRAM_USE_DDR4=1 DDR4_FREQ_3200=1 LOG_LEVEL=20 BL33="../u-boot/u-boot.bin" all fip
For ${device} I currently have sdmmc and emmc. Not sure what the correct device value is for NOR. I was assuming emmc.
i only use emmc defconfig for nor/nand and drop the ENV_IS_IN_MMC from it…
Do you use the useinitrd? It is supposed to be called manually for testing…else root is set to the mmc-partition,i’m not sure if the initrd is used if the root is set to mmc
Thanks, that helps. Hopefully I’ll track down whatever’s wrong.
Edited: Fixed. I was not using the compressed uboot for my bl33.
Ah, that definitely explains the configs. I do actually use it as part of the normal boot. I find it useful for loading modules like rtc_ds1307, fonts, etc…
