forgot that you do not use uboot…you load linux initrd and then access nvme through linux driver
ATF is not able to access this boot partition on nvme. Only patched u-boot and kernel can access nvme.
Edit:
Easiest solution is to have the boot partition on emmc or sdmmc.
Not yet. When the u-boot pcie support is mainline, I will update my uboot package, so that this is also an option.
Having different options is ok here I think. I see there are many quirks around for supporting all the different nvme drives. Who knows which quirks are available in u-boot…
Then I guess this is coming to linux-rolling-stable too soon. It will be included automatically then in my bpir-rolling-stable branch.
Note that I do not have kexec really functional. It is rebooting into atf which is then booting pre-loaded images.
Thanks all. I now understand my confusion: I assumed that somehow ATF had support for the NVME. I was going for the ATF ‘kexec’ method mentioned here BPI-R3 u-boot build help (with NVMe support, hopefully) - #25 by ericwoud, but must have misunderstood how it actually works.
On the plus side I did manage to figure it out the scripts and give the method a try. Seems to work well on my bpi-r3. However, functionality-wise it is still similar to what I had before, ATF and u-boot on sdcard and rootfs on NVME (atf w/o u-boot is a little bit faster though).
@frank-w. I noticed you merged the pci: mediatek: add PCIe controller support for Filogic patch to your 2024-01-bpi-r3mini u-boot branch. Do you think this might work for the bpi-r3 too?
john says he tested it with r3, i have only tried with r3mini, but cannot get my nvme working with it
I’m tempted to give it a go. Is that the only patch I need to cherry pick, assuming I would use your 2024-01-bpi branch?
Yes and the patch for missing constant and of course enabling the options like i did for r3mini
Then you should be able to do this
OpenWrtOne> pci enum
OpenWrtOne> pci
BusDevFun VendorId DeviceId Device Class Sub-Class
00.00.00 0x14c3 0x1f32 Bridge device 0x04
01.00.00 0x144d 0xa80b Mass storage controller 0x08
OpenWrtOne> nvme scan
OpenWrtOne> nvme info
Device 0: Vendor: 0x144d Rev: 7L1QHXC7 Prod: S67PNF0W854510
Type: Hard Disk
Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
For debugging purposes you can load u-boot.bin from usb/tftp and use go command on the loadaddr. This way you don’t need built with atf everytime and flash it…but i guess your current uboot does not have go command yet,so you have to do it once…ah you using erics image and loading uboot from atf? Then you will not need atf compile around uboot i guess
Had to change the constant patch a little bit (see attached) but other than that it worked perfectly. I now have u-boot on my sdcard and everything else on my nvme. No more messy backup restores for me. Thanks for all the help.
Btw, if anyone is interested, my nvme is a Samsung 980 1TB.
thank you very much for finding my mistake…with this fixed i can also see my nvme on r3mini
BPI-R3M> pci enum
drivers/pci/pcie_mediatek_gen3.c:mtk_pcie_startup_port[261] detected a card
set trans table 0: 0x20000000 0x20000000, 0x10000000
BPI-R3M> pci
_____________________________________________________________
01.00.00 0x1c5c 0x1327 Mass storage controller 0x08
BPI-R3M> nvme scan
BPI-R3M>
BPI-R3M> nvme info
Device 0: Vendor: 0x1c5c Rev: 80002C00 Prod: ND94N163610404F0R
Type: Hard Disk
BPI-R3M>
So we got PCIe support in U-Boot and we also got lots of on-board SPI-NOR flash and want to boot from NVMe. What I would do is what every PC or Apple mainboard is doing: store system firmware (“BIOS”) in the SPI-NOR and have that use some generic method to boot from the NVMe (e.g. UEFI or U-Boot’s distro standard boot).
In case of the R3 (or R3 mini or R4) this means that TF-A and U-Boot should be in SPI-NOR, and U-Boot can be configured to carry out UEFI Standard boot and consider both USB and NVMe according to EFI boot variables, just like on a PC. That would put an end to writing endless how-tos for each and every board, and would allow standard installers of most Linux distributions with sufficient kernel driver support to just work.
Maybe porting Tow-Boot for the R3 (and the R4 and esp. also the R2 and R2Pro!) would be a worthwhile idea for that use-case. I’m using that every day on the PineBook Pro… https://tow-boot.org/
For OpenWrt (and hence for me) this is not so attractive: OpenWrt is headless and fits in a couple of megabytes of flash; the userland is tightly tied to the kernel – no need for even a EFI boot filesystem to chose which kernel to load as kernel and userland are inseparable anyway, all in one uImage.FIT.
But I was kinda betting that all other (more storage intense) distros would jump on the Standard Boot train to rid themselves of per-board custom installer images and all the maintenance effort associated with that.
Finally got to testing eMMC installation from Openwrt (in NAND). Downloaded pre-made AP image.gz from http://www.woudstra.mywire.org/images/bpir3-emmc-ap.img.gz and prepared to sda1 USB as instructed… Managed to install all necessary packages to openwrt and run the commands:
gunzip -c /mnt/sda1/bpir.img.gz | dd of=/dev/mmcblk0 bs=4M conv=fsync
mmc bootpart enable 7 1 /dev/mmcblk0
After few minutes all was done, but after switching DIPS to eMMC(LHHL) and PowerOn I can’t access AP on 192.168.1.33 and no WIFI24 on air.
Seems something is not working as expected…
Is the ’ bootpart enable 7 1 /dev/mmcblk0’ still valid for the latest image?
Can I do something for diagnostics from openwrt?
You can connect debuguart before powering on and share log how far the system goes…maybe system boots completely and wifi firmware is missing or any setting is wrong which basicly prevents wifi to work
I have a trick on R3, so that atf is on /dev/mmcblk0 , not boot0.
Needs dipswitches LLLH., or HLLL depends which way you look at it.
I’ll check if this is in the readme also.
“Flip SD/EMMC switch (most near to power plug), the rest stay up!”
Anyway, on the R3 the Emmc image can be written to booting from my sdmmc image. That is described in the readme.
Edit: it can actually be used to write any image to emmc while booting from sd.
Thanks, no need to messing with NAND to install eMMC image is fantastic news for me, but I’m still a bit confused and need some clarification
I’m sorry have read the readme but didn’t understand that I can do this (haven’t run your build script yet).
I prefer to flash pre-built images if possible, not used to build anything myself until I’m familiar with the process. So if I understand it correctly I can download your pre-built sdmmc image and flash it to SD card. The DIPS should stay LLLH during SD boot and eMMC installation. After booting from SD I can flash the same image file(or emmc version?) to eMMC somehow (using your script)?
Need to find some details how to format eMMC via putty (without uart) after boot from SD, or does your script also include re-formatting eMMC before image installation?
Before booting from eMMC I should switch the DIPS back to LHHL…
Everything is pre-build in packages, so even using my build script, you are not really building, only installing fully automated…
But it can be done with prebuild images.
dd the sd image to a sd card. Then cp the emmc image in the tmp folder of the sd card.(root partition), rename it bpir.img.gz.
Boot sd with the normal sd card dip settings, keep shift+e pressed. Then follow the instuctions, it tells you when to flip which dip switch. Then you are done, remove sd card and boot archlinux-arm from emmc. I could not make it easier… I have done some updates after that, but it still should work like this. If not, I would like to hear that.
Thanks, I have finally booted my Openwrt NAND to eMMC Arch installation, working fine now.
Not sure whether changing DIPS to HHHL or activating boot partition via mmc bootpart enable 1 1 /dev/mmcblk0 helped but after these 2 changes booting Arch from eMMC started to work, yay.
I’m close to replacing my old OpenWrt router for R3@ArchLinux but have last remaining WiFi issue to resolve.
Fast Transition between R3@ArchLinux and 2 remaining OpenWrt routers is not working. Same ssid & wpa_passphrase, mobility_domain set to default(which calculation is identical on both systems) but devices connected to OpenWrt refuse connection to R3@Arch. have following settings enabled on both systems:
ft_psk_generate_local=1
ft_over_ds=1
Seems something is still missing in my /etc/hostapd/wlan0.conf. Anyone with Fast transition working between Arch and OpenWrt APs with some advice?
Did you:
wpa_key_mgmt=WPA-PSK FT-PSK
You could just try to set
mobility_domain=a1b2
On all systems.
Then it is most important that everything is connected at layer-2 level. That means, only using bridges and sort. No ipforward (wan to lan transistion, nat translation, etc) in the chain between the bridges that contain the wifi interfaces.
I have only used FT, all systems running archlinuxarm.
Sure, pls see my PK & FT configuration below:
wpa=2
wpa_passphrase=xxxxxxxx
wpa_pairwise=CCMP
# 802.11r
mobility_domain=$(echo $ssid | md5sum | cut -c1-4)
nas_identifier=$HOSTNAME-$interface
ft_over_ds=1
According to OpenWrt developer mobility_domain calculation is the same:
Have checked the echo command on both systems and result was identical, but will test also with hard-coded value. Between APs is only core managed switch without VLANs. Seems to me something else must be different but can’t find it…
