Ethtool -m eth1 output:
root@OpenWrt:~# ethtool --dump-module-eeprom eth1
Offset Values
0x0000: 03 04 01 00 00 00 02 22 00 01 00 01 0d 00 14 c8
0x0010: 00 00 00 00 4f 44 49 20 20 20 20 20 20 20 20 20
0x0020: 20 20 20 20 00 00 00 00 44 46 50 2d 33 34 58 2d
0x0030: 32 43 32 20 20 20 20 20 20 20 20 20 05 1e 00 70
0x0040: 00 1a 00 00 58 50 4f 4e 32 33 30 34 30 37 37 35
0x0050: 20 20 20 20 32 33 30 35 30 34 20 20 00 00 00 e9
0x0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0080: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x0090: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x00a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x00b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x00c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x00d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x00e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x00f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Strange, but user here has same sfp module and he has correct ethtool -m output:
https://forum.banana-pi.org/t/bpi-r3-sfp-module-compatibility/14573/30?u=voidstranger
As for kernel log, I think, this matters:
[ 15.138538] sfp sfp1: Host maximum power 3.0W
[ 15.479877] sfp sfp1: module ODI DFP-34X-2C2 rev sn XPON23040775 dc 230504
[ 15.489283] mtk_soc_eth 15100000.ethernet eth1: switched to inband/1000base-x link mode
[ 335.106997] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/1000base-x link mode
[ 346.550337] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
Full kernel log (in case, if you need it):
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.113 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.3.0 r23147-4b8b2f4f97) 12.3.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Sun May 28 18:22:23 2023
[ 0.000000] Machine model: Bananapi BPI-R3
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
[ 0.000000] node 0: [mem 0x0000000043030000-0x000000004fbfffff]
[ 0.000000] node 0: [mem 0x000000004fc00000-0x000000004ffbffff]
[ 0.000000] node 0: [mem 0x000000004ffc0000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 17 pages/cpu s30040 r8192 d31400 u69632
[ 0.000000] pcpu-alloc: s30040 r8192 d31400 u69632 alloc=17*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: root=/dev/mmcblk0p65
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Memory: 2040188K/2097152K available (8384K kernel code, 910K rwdata, 2280K rodata, 448K init, 301K bss, 56964K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 640 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000133] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000140] pid_max: default: 32768 minimum: 301
[ 0.000361] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000373] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001413] rcu: Hierarchical SRCU implementation.
[ 0.001722] smp: Bringing up secondary CPUs ...
[ 0.001982] Detected VIPT I-cache on CPU1
[ 0.002005] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.002033] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.002296] Detected VIPT I-cache on CPU2
[ 0.002306] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.002318] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.002554] Detected VIPT I-cache on CPU3
[ 0.002564] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.002573] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.002598] smp: Brought up 1 node, 4 CPUs
[ 0.002612] SMP: Total of 4 processors activated.
[ 0.002615] CPU features: detected: 32-bit EL0 Support
[ 0.002618] CPU features: detected: CRC32 instructions
[ 0.002643] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.002695] CPU: All CPU(s) started at EL2
[ 0.002705] alternatives: patching kernel code
[ 0.005773] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.005796] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.005941] pinctrl core: initialized pinctrl subsystem
[ 0.006563] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.006811] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.006843] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.006869] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.007126] thermal_sys: Registered thermal governor 'fair_share'
[ 0.007129] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.007132] thermal_sys: Registered thermal governor 'step_wise'
[ 0.007135] thermal_sys: Registered thermal governor 'user_space'
[ 0.007329] ASID allocator initialised with 65536 entries
[ 0.007656] pstore: Registered ramoops as persistent store backend
[ 0.007660] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.017428] cryptd: max_cpu_qlen set to 1000
[ 0.019310] SCSI subsystem initialized
[ 0.019391] libata version 3.00 loaded.
[ 0.020258] clocksource: Switched to clocksource arch_sys_counter
[ 0.020708] NET: Registered PF_INET protocol family
[ 0.020824] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.021480] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.021500] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.021508] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.021576] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.021750] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.021825] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.021853] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.021974] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.021995] PCI: CLS 0 bytes, default 64
[ 0.024129] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.026828] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.026841] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.049692] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.050885] pwm-mediatek 10048000.pwm: clock: top fail: -517
[ 0.051182] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.051205] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.051215] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 0.051263] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 0.051295] phy phy-soc:[email protected]: pcie auto load valid efuse: ENABLE with value: 1
[ 0.051319] phy phy-soc:[email protected]: u3 lane1 efuse - intr 28, rx_imp 10, tx_imp f
[ 0.051383] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
[ 0.051394] mtk-pcie-gen3 11280000.pcie: failed to get clocks
[ 0.054135] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.055814] printk: console [ttyS0] disabled
[ 0.075963] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
[ 0.780558] printk: console [ttyS0] enabled
[ 0.805347] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
[ 0.815179] mtk_rng 1020f000.trng: registered RNG driver
[ 0.815409] random: crng init done
[ 0.820763] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.831925] loop: module loaded
[ 0.835074] Loading iSCSI transport class v2.0-870.
[ 0.841365] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.846671] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.854956] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.861302] Creating 4 MTD partitions on "spi0.0":
[ 0.866076] 0x000000580000-0x000008000000 : "ubi"
[ 0.997770] 0x000000380000-0x000000580000 : "fip"
[ 1.004849] 0x000000080000-0x000000380000 : "reserved"
[ 1.013341] 0x000000000000-0x000000080000 : "bl2"
[ 1.153374] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009800000, irq 134
[ 1.163138] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009800000, irq 134
[ 1.172681] i2c_dev: i2c /dev entries driver
[ 1.178446] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.186915] NET: Registered PF_INET6 protocol family
[ 1.192461] Segment Routing with IPv6
[ 1.196129] In-situ OAM (IOAM) with IPv6
[ 1.200063] NET: Registered PF_PACKET protocol family
[ 1.205144] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.218184] 8021q: 802.1Q VLAN Support v1.8
[ 1.223184] pstore: Using crash dump compression: deflate
[ 1.233869] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 1.241225] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 1.247478] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 1.255948] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 1.264049] phy phy-soc:[email protected]: pcie auto load valid efuse: ENABLE with value: 1
[ 1.272315] phy phy-soc:[email protected]: u3 lane1 efuse - intr 28, rx_imp 10, tx_imp f
[ 1.328230] mtk-msdc 11230000.mmc: phase: [map:ffffffff] [maxlen:32] [final:10]
[ 1.337168] mmc0: new HS400 MMC card at address 0001
[ 1.342882] mmcblk0: mmc0:0001 008GB0 7.28 GiB
[ 1.350022] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3-emmc-snand" (OpenWrt bananapi_bpi-r3 with mt7986a-bananapi-bpi-r3-emmc-snand)
[ 1.363490] FIT: kernel sub-image 0x00001000..0x00530f72 "kernel-1" (ARM64 OpenWrt Linux-5.15.113)
[ 1.373390] FIT: flat_dt sub-image 0x00531000..0x00538fff "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 1.384589] FIT: flat_dt sub-image 0x00539000..0x00540fff "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 1.400737] FIT: flat_dt sub-image 0x00541000..0x00548fff "fdt-mt7986a-bananapi-bpi-r3-emmc-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-nor)
[ 1.417746] FIT: flat_dt sub-image 0x00549000..0x00550fff "fdt-mt7986a-bananapi-bpi-r3-emmc-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-snand)
[ 1.427969] mtk-pcie-gen3 11280000.pcie: set MEM trans window[0]: cpu_addr = 0x20000000, pci_addr = 0x20000000, size = 0x10000000
[ 1.435100] FIT: flat_dt sub-image 0x00551000..0x00558fff "fdt-mt7986a-bananapi-bpi-r3-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-snand)
[ 1.446843] mtk-pcie-gen3 11280000.pcie: PCI host bridge to bus 0000:00
[ 1.463192] FIT: filesystem sub-image 0x00559000..0x01e76fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 1.469776] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.480357] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 1.485816] pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
[ 1.493110] mmcblk0: p1 p2 p3 p4 p5 p65(rootfs-1) p66(rootfs_data) p128
[ 1.499951] pci_bus 0000:00: scanning bus
[ 1.507780] mmcblk0boot0: mmc0:0001 008GB0 4.00 MiB
[ 1.510661] pci 0000:00:00.0: [14c3:1f32] type 01 class 0x060400
[ 1.516388] mmcblk0boot1: mmc0:0001 008GB0 4.00 MiB
[ 1.521608] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 1.526763] mmcblk0rpmb: mmc0:0001 008GB0 4.00 MiB, chardev (250:0)
[ 1.533364] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 1.545620] pci 0000:00:00.0: PME# disabled
[ 1.550651] pci_bus 0000:00: fixups for bus
[ 1.554822] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 1.561505] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.569492] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 1.576236] pci_bus 0000:01: scanning bus
[ 1.580270] pci 0000:01:00.0: [144d:a808] type 00 class 0x010802
[ 1.586282] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 1.593244] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 1.630951] pci_bus 0000:01: fixups for bus
[ 1.635121] pci_bus 0000:01: bus scan returning with max=01
[ 1.640682] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.647280] pci_bus 0000:00: bus scan returning with max=01
[ 1.652855] pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff]
[ 1.659623] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x20107fff 64bit]
[ 1.666922] pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x20003fff 64bit]
[ 1.674224] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.679172] pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff]
[ 1.686057] pcieport 0000:00:00.0: assign IRQ: got 142
[ 1.691189] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.697274] pcieport 0000:00:00.0: enabling bus mastering
[ 1.703015] mtk-pcie-gen3 11280000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11280c00 data 0
[ 1.711440] mtk-pcie-gen3 11280000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11280c00 data 1
[ 1.719854] mtk-pcie-gen3 11280000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11280c00 data 2
[ 1.728270] mtk-pcie-gen3 11280000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11280c00 data 3
[ 1.736687] mtk-pcie-gen3 11280000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11280c00 data 4
[ 1.745102] mtk-pcie-gen3 11280000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11280c00 data 5
[ 1.753522] mtk-pcie-gen3 11280000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11280c00 data 6
[ 1.761940] mtk-pcie-gen3 11280000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11280c00 data 7
[ 1.770357] mtk-pcie-gen3 11280000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11280c00 data 8
[ 1.778770] mtk-pcie-gen3 11280000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11280c00 data 9
[ 1.787186] mtk-pcie-gen3 11280000.pcie: msi#0xa address_hi 0x0 address_lo 0x11280c00 data 10
[ 1.795690] mtk-pcie-gen3 11280000.pcie: msi#0xb address_hi 0x0 address_lo 0x11280c00 data 11
[ 1.804192] mtk-pcie-gen3 11280000.pcie: msi#0xc address_hi 0x0 address_lo 0x11280c00 data 12
[ 1.812696] mtk-pcie-gen3 11280000.pcie: msi#0xd address_hi 0x0 address_lo 0x11280c00 data 13
[ 1.821199] mtk-pcie-gen3 11280000.pcie: msi#0xe address_hi 0x0 address_lo 0x11280c00 data 14
[ 1.829700] mtk-pcie-gen3 11280000.pcie: msi#0xf address_hi 0x0 address_lo 0x11280c00 data 15
[ 1.838203] mtk-pcie-gen3 11280000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11280c00 data 16
[ 1.846793] mtk-pcie-gen3 11280000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11280c00 data 17
[ 1.855383] mtk-pcie-gen3 11280000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11280c00 data 18
[ 1.863972] mtk-pcie-gen3 11280000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11280c00 data 19
[ 1.872564] mtk-pcie-gen3 11280000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11280c00 data 20
[ 1.881155] mtk-pcie-gen3 11280000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11280c00 data 21
[ 1.889741] mtk-pcie-gen3 11280000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11280c00 data 22
[ 1.898331] mtk-pcie-gen3 11280000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11280c00 data 23
[ 1.906921] mtk-pcie-gen3 11280000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11280c00 data 24
[ 1.915511] mtk-pcie-gen3 11280000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11280c00 data 25
[ 1.924100] mtk-pcie-gen3 11280000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11280c00 data 26
[ 1.932690] mtk-pcie-gen3 11280000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11280c00 data 27
[ 1.941279] mtk-pcie-gen3 11280000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11280c00 data 28
[ 1.949866] mtk-pcie-gen3 11280000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11280c00 data 29
[ 1.958456] mtk-pcie-gen3 11280000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11280c00 data 30
[ 1.967045] mtk-pcie-gen3 11280000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11280c00 data 31
[ 1.975979] mtk-pcie-gen3 11280000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11280c00 data 0
[ 1.984499] pcieport 0000:00:00.0: PME: Signaling with IRQ 143
[ 1.990501] pcieport 0000:00:00.0: AER: enabled with IRQ 143
[ 1.996198] pcieport 0000:00:00.0: saving config space at offset 0x0 (reading 0x1f3214c3)
[ 2.004369] pcieport 0000:00:00.0: saving config space at offset 0x4 (reading 0x100406)
[ 2.012354] pcieport 0000:00:00.0: saving config space at offset 0x8 (reading 0x6040001)
[ 2.020424] pcieport 0000:00:00.0: saving config space at offset 0xc (reading 0x10000)
[ 2.028317] pcieport 0000:00:00.0: saving config space at offset 0x10 (reading 0x20100004)
[ 2.036559] pcieport 0000:00:00.0: saving config space at offset 0x14 (reading 0x0)
[ 2.044195] pcieport 0000:00:00.0: saving config space at offset 0x18 (reading 0x10100)
[ 2.052178] pcieport 0000:00:00.0: saving config space at offset 0x1c (reading 0x1f1)
[ 2.059985] pcieport 0000:00:00.0: saving config space at offset 0x20 (reading 0x20002000)
[ 2.068228] pcieport 0000:00:00.0: saving config space at offset 0x24 (reading 0x1fff1)
[ 2.076210] pcieport 0000:00:00.0: saving config space at offset 0x28 (reading 0x0)
[ 2.083847] pcieport 0000:00:00.0: saving config space at offset 0x2c (reading 0x0)
[ 2.091483] pcieport 0000:00:00.0: saving config space at offset 0x30 (reading 0x0)
[ 2.099116] pcieport 0000:00:00.0: saving config space at offset 0x34 (reading 0x80)
[ 2.106842] pcieport 0000:00:00.0: saving config space at offset 0x38 (reading 0x0)
[ 2.114479] pcieport 0000:00:00.0: saving config space at offset 0x3c (reading 0x2018e)
[ 2.144392] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 2.153443] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 2.162134] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=144)
[ 2.182343] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=145)
[ 2.202376] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=146)
[ 2.222435] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=147)
[ 2.242426] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=148)
[ 2.253513] DSA: tree 0 setup
[ 2.258658] UBI: auto-attach mtd0
[ 2.262005] ubi0: default fastmap pool size: 45
[ 2.266518] ubi0: default fastmap WL pool size: 22
[ 2.271297] ubi0: attaching mtd0
[ 5.883808] ubi0: scanning is finished
[ 5.928928] ubi0: attached mtd0 (name "ubi", size 122 MiB)
[ 5.934418] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 5.941275] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 5.948041] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 5.954983] ubi0: good PEBs: 980, bad PEBs: 0, corrupted PEBs: 0
[ 5.960971] ubi0: user volume: 6, internal volumes: 1, max. volumes count: 128
[ 5.968170] ubi0: max/mean erase counter: 4/1, WL threshold: 4096, image sequence number: 0
[ 5.976499] ubi0: available PEBs: 0, total reserved PEBs: 980, PEBs reserved for bad PEB handling: 20
[ 5.985698] ubi0: background thread "ubi_bgt0d" started, PID 558
[ 5.991797] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3-emmc-snand" (OpenWrt bananapi_bpi-r3 with mt7986a-bananapi-bpi-r3-emmc-snand)
[ 6.005273] FIT: kernel sub-image 0x00001000..0x004f82c9 "kernel-1" (ARM64 OpenWrt Linux-5.15.98)
[ 6.015085] FIT: flat_dt sub-image 0x004f9000..0x00500fff "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 6.026286] FIT: flat_dt sub-image 0x00501000..0x00508fff "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 6.042429] FIT: flat_dt sub-image 0x00509000..0x00510fff "fdt-mt7986a-bananapi-bpi-r3-emmc-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-nor)
[ 6.059437] FIT: flat_dt sub-image 0x00511000..0x00518fff "fdt-mt7986a-bananapi-bpi-r3-emmc-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc-snand)
[ 6.076791] FIT: flat_dt sub-image 0x00519000..0x00520fff "fdt-mt7986a-bananapi-bpi-r3-snand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-snand)
[ 6.093275] FIT: filesystem sub-image 0x00521000..0x0244cfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 6.103864] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 6.111151] ubiblock0_2: p1(rootfs-1)
[ 6.111272] block ubiblock0_2: created from ubi0:2(fit)
[ 6.123478] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
[ 6.130759] Freeing unused kernel memory: 448K
[ 6.200295] Run /sbin/init as init process
[ 6.204375] with arguments:
[ 6.207326] /sbin/init
[ 6.210017] with environment:
[ 6.213148] HOME=/
[ 6.215492] TERM=linux
[ 6.311951] init: Console is alive
[ 6.315440] init: - watchdog -
[ 6.651768] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 6.702347] Key type encrypted registered
[ 6.709568] usbcore: registered new interface driver usbfs
[ 6.715095] usbcore: registered new interface driver hub
[ 6.720429] usbcore: registered new device driver usb
[ 6.728915] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: [email protected]
[ 6.742392] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 6.749394] fsl-ehci: Freescale EHCI Host controller driver
[ 6.755512] ehci-platform: EHCI generic platform driver
[ 6.763979] phy phy-soc:[email protected]: u2 auto load valid efuse: ENABLE with value: 1
[ 6.772135] phy phy-soc:[email protected]: u3 auto load valid efuse: ENABLE with value: 1
[ 6.780272] phy phy-soc:[email protected]: u2 auto load valid efuse: ENABLE with value: 1
[ 6.788811] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.794058] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 6.804509] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 6.813661] xhci-mtk 11200000.usb: irq 126, io mem 0x11200000
[ 6.819480] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.824697] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 6.832082] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 6.839438] hub 1-0:1.0: USB hub found
[ 6.843198] hub 1-0:1.0: 2 ports detected
[ 6.847442] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.855783] hub 2-0:1.0: USB hub found
[ 6.859538] hub 2-0:1.0: 1 port detected
[ 6.866261] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.883734] init: - preinit -
[ 7.066998] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 7.075460] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 7.084740] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 7.096592] mt7530-mdio mdio-bus:1f lan1: Link is Up - 100Mbps/Full - flow control off
[ 7.104570] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
[ 7.310262] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 7.490920] hub 1-1:1.0: USB hub found
[ 7.494695] hub 1-1:1.0: 4 ports detected
[ 7.640263] usb 1-2: new low-speed USB device number 3 using xhci-mtk
[ 9.122891] Starting lvm2 during preinit
[ 9.936423] mount_root: loading kmods from internal overlay
[ 9.948061] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 9.957491] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 11.321166] UBIFS (ubi0:5): Mounting in unauthenticated mode
[ 11.326881] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" started, PID 725
[ 11.795085] UBIFS (ubi0:5): UBIFS: mounted UBI device 0, volume 5, name "rootfs_data"
[ 11.802907] UBIFS (ubi0:5): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 11.812798] UBIFS (ubi0:5): FS size: 37711872 bytes (35 MiB, 297 LEBs), max 307 LEBs, journal size 1904640 bytes (1 MiB, 15 LEBs)
[ 11.824422] UBIFS (ubi0:5): reserved for root: 1781224 bytes (1739 KiB)
[ 11.831018] UBIFS (ubi0:5): media format: w5/r0 (latest is w5/r0), UUID C21FABF1-34A9-4E20-AE83-1E9DC07CEA7E, small LPT model
[ 11.853528] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 11.897507] block: extroot: not configured
[ 11.912581] UBIFS (ubi0:5): un-mount UBI device 0
[ 11.917281] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" stops
[ 11.980956] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = 428fab2b
[ 11.990053] mount_root: loading kmods from internal overlay
[ 12.004448] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 12.013775] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 13.345857] UBIFS (ubi0:5): Mounting in unauthenticated mode
[ 13.351587] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" started, PID 734
[ 13.819719] UBIFS (ubi0:5): UBIFS: mounted UBI device 0, volume 5, name "rootfs_data"
[ 13.827544] UBIFS (ubi0:5): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 13.837436] UBIFS (ubi0:5): FS size: 37711872 bytes (35 MiB, 297 LEBs), max 307 LEBs, journal size 1904640 bytes (1 MiB, 15 LEBs)
[ 13.849061] UBIFS (ubi0:5): reserved for root: 1781224 bytes (1739 KiB)
[ 13.855657] UBIFS (ubi0:5): media format: w5/r0 (latest is w5/r0), UUID C21FABF1-34A9-4E20-AE83-1E9DC07CEA7E, small LPT model
[ 13.878164] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 13.922155] block: extroot: not configured
[ 13.937133] UBIFS (ubi0:5): un-mount UBI device 0
[ 13.941844] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" stops
[ 13.953971] mount_root: switching to f2fs overlay
[ 13.961494] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 13.973342] urandom-seed: Seeding with /etc/urandom.seed
[ 13.998271] mt7530-mdio mdio-bus:1f lan1: Link is Down
[ 14.006443] procd: - early -
[ 14.009366] procd: - watchdog -
[ 14.537267] procd: - watchdog -
[ 14.540577] procd: - ubus -
[ 14.595456] procd: - init -
[ 14.767999] urngd: v1.0.2 started.
[ 14.790604] kmodloader: loading kernel modules from /etc/modules.d/*
[ 14.826378] nvme 0000:01:00.0: assign IRQ: got 142
[ 14.831326] nvme nvme0: pci function 0000:01:00.0
[ 14.836041] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 14.841967] nvme 0000:01:00.0: enabling bus mastering
[ 14.847118] mtk-pcie-gen3 11280000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11280c00 data 1
[ 14.855584] nvme 0000:01:00.0: saving config space at offset 0x0 (reading 0xa808144d)
[ 14.863405] nvme 0000:01:00.0: saving config space at offset 0x4 (reading 0x100406)
[ 14.871046] nvme 0000:01:00.0: saving config space at offset 0x8 (reading 0x1080200)
[ 14.878769] nvme 0000:01:00.0: saving config space at offset 0xc (reading 0x0)
[ 14.885974] nvme 0000:01:00.0: saving config space at offset 0x10 (reading 0x20000004)
[ 14.893874] nvme 0000:01:00.0: saving config space at offset 0x14 (reading 0x0)
[ 14.901167] nvme 0000:01:00.0: saving config space at offset 0x18 (reading 0x0)
[ 14.908456] nvme 0000:01:00.0: saving config space at offset 0x1c (reading 0x0)
[ 14.915749] nvme 0000:01:00.0: saving config space at offset 0x20 (reading 0x0)
[ 14.923041] nvme 0000:01:00.0: saving config space at offset 0x24 (reading 0x0)
[ 14.930333] nvme 0000:01:00.0: saving config space at offset 0x28 (reading 0x0)
[ 14.937623] nvme 0000:01:00.0: saving config space at offset 0x2c (reading 0xa801144d)
[ 14.945523] nvme 0000:01:00.0: saving config space at offset 0x30 (reading 0x0)
[ 14.952816] nvme 0000:01:00.0: saving config space at offset 0x34 (reading 0x40)
[ 14.960192] nvme 0000:01:00.0: saving config space at offset 0x38 (reading 0x0)
[ 14.967485] nvme 0000:01:00.0: saving config space at offset 0x3c (reading 0x18e)
[ 14.977927] nvme nvme0: missing or invalid SUBNQN field.
[ 14.983325] nvme nvme0: Shutdown timeout set to 8 seconds
[ 14.993031] mtk-pcie-gen3 11280000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11280c00 data 1
[ 15.001523] mtk-pcie-gen3 11280000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11280c00 data 2
[ 15.009941] mtk-pcie-gen3 11280000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11280c00 data 3
[ 15.018367] mtk-pcie-gen3 11280000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11280c00 data 4
[ 15.026803] mtk-pcie-gen3 11280000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11280c00 data 5
[ 15.038809] nvme nvme0: 4/0/0 default/read/poll queues
[ 15.049382] tun: Universal TUN/TAP device driver, 1.6
[ 15.069213] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
[ 15.075893] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
[ 15.085353] ntfs3: Max link count 4000
[ 15.089103] ntfs3: Enabled Linux POSIX ACLs support
[ 15.095740] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
[ 15.110220] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
[ 15.117744] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
[ 15.143751] sfp sfp2: Host maximum power 3.0W
[ 15.152150] xt_time: kernel timezone is -0000
[ 15.610581] mt7986-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[ 15.610581]
[ 15.717535] mt7986-wmac 18000000.wmac: WM Firmware Version: ____000000, Build Time: 20221012174805
[ 15.786504] mt7986-wmac 18000000.wmac: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[ 18.554515] PPP generic driver version 2.4.2
[ 18.559600] NET: Registered PF_PPPOX protocol family
[ 18.565917] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 18.573764] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[ 18.584798] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 331.976179] F2FS-fs (nvme0n1): Mounted with checkpoint version = 285245ac
[ 334.896868] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 334.916079] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 334.925410] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 334.934353] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 334.943224] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 334.953814] br-lan: port 1(lan1) entered blocking state
[ 334.959046] br-lan: port 1(lan1) entered disabled state
[ 334.966014] device lan1 entered promiscuous mode
[ 334.970681] device eth0 entered promiscuous mode
[ 334.982380] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 334.992339] br-lan: port 2(lan2) entered blocking state
[ 334.997583] br-lan: port 2(lan2) entered disabled state
[ 335.004953] device lan2 entered promiscuous mode
[ 335.014265] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[ 335.024171] br-lan: port 3(lan3) entered blocking state
[ 335.029418] br-lan: port 3(lan3) entered disabled state
[ 335.036828] device lan3 entered promiscuous mode
[ 335.045521] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
[ 335.055490] br-lan: port 4(lan4) entered blocking state
[ 335.060728] br-lan: port 4(lan4) entered disabled state
[ 335.067942] device lan4 entered promiscuous mode
[ 335.076415] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
[ 335.085965] br-lan: port 5(sfp2) entered blocking state
[ 335.091211] br-lan: port 5(sfp2) entered disabled state
[ 335.098605] device sfp2 entered promiscuous mode
[ 335.116841] br-wan: port 1(eth1) entered blocking state
[ 335.122086] br-wan: port 1(eth1) entered disabled state
[ 335.127471] device eth1 entered promiscuous mode
[ 335.133768] br-wan: port 1(eth1) entered blocking state
[ 335.139000] br-wan: port 1(eth1) entered forwarding state
[ 335.146109] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
[ 335.155876] br-wan: port 2(wan) entered blocking state
[ 335.161033] br-wan: port 2(wan) entered disabled state
[ 335.167561] device wan entered promiscuous mode
[ 336.295268] br-wan: port 1(eth1) entered disabled state
[ 336.317428] br-lan: port 6(phy1-ap0) entered blocking state
[ 336.323085] br-lan: port 6(phy1-ap0) entered disabled state
[ 336.328961] device phy1-ap0 entered promiscuous mode
[ 337.415652] br-lan: port 7(phy0-ap0) entered blocking state
[ 337.421273] br-lan: port 7(phy0-ap0) entered disabled state
[ 337.427081] device phy0-ap0 entered promiscuous mode
[ 338.545052] usb 1-2: USB disconnect, device number 3
[ 340.090371] usb 1-2: new low-speed USB device number 4 using xhci-mtk
[ 345.494264] IPv6: ADDRCONF(NETDEV_CHANGE): phy1-ap0: link becomes ready
[ 345.501039] br-lan: port 6(phy1-ap0) entered blocking state
[ 345.506617] br-lan: port 6(phy1-ap0) entered forwarding state
[ 345.513410] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 346.558846] br-wan: port 1(eth1) entered blocking state
[ 346.564158] br-wan: port 1(eth1) entered forwarding state
[ 348.945400] IPv6: ADDRCONF(NETDEV_CHANGE): phy0-ap0: link becomes ready
[ 348.952309] br-lan: port 7(phy0-ap0) entered blocking state
[ 348.957903] br-lan: port 7(phy0-ap0) entered forwarding state
[ 354.054388] usb 1-2: USB disconnect, device number 4
[ 358.310279] usb 1-2: new low-speed USB device number 5 using xhci-mtk
Ethtool eth1 output:
root@OpenWrt:~# ethtool eth1
Settings for eth1:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseX/Full
Advertised link modes: 1000baseX/Full
Link partner advertised link modes: 1000baseX/Full
Link partner advertised pause frame use: Symmetric Receive-only
Speed: 1000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Link detected: yes
