Hi everybody,
Can you confirm me if the BPI-R3 Model is compatible with the 10Gbps SFP Modules?
Thanks very much.
Hi everybody,
Thanks very much.
There are no UXSGMII inerfaces on MT7986, so unless the module can sync at 2.5G it won’t work. I know some transceivers only support 10G data rate.
10gbit sfps are SFP+ and not the normal SFP/MiniGBIC. Only the second are supported.
This commit says that SFP+ devices are supported. Is power the main issue?
I have this device which has a web management interface where the link speed can be adjusted to 1G/2.5G/10G. I dont see any setting to adjust the power though. When I plug it in even after setting the link speed to 1G, I get the following warning:
Tue Aug 29 03:15:57 2023 kern.info kernel: [10795.694275] sfp sfp-1: module E.C.I. NETWORKS ENXGSXXXXX rev V1.0 sn AZRXXXXX dc 23XXX
Tue Aug 29 03:15:57 2023 kern.warn kernel: [10795.703751] sfp sfp-1: Host does not support 2.0W modules, module left in power mode 1
Can someone point me to the relevant code where I can try turning off this check and powering on the SFP device anyway?
Where donyou read that sfp+ is supported? Sfp+ using different interface mode to mac which is not supported by bpi-r3 hardware…this is no software limitation. Only sfp up to 2.5g are supported because mac can operate in 2500baseX/sgmii mode.
For power there is a default of 1w,but we recently added a 3w setting in bananapi-r3 devicetree,but it is not yet merged to mainline or official openwrt. It is only in @dangowrt s fork of openwrt.
see the highlight:
Imho it is a typo maybe caused by same time working on bpi-r4 which has really sfp+ support
R3 supports even 10G copper SFPs with a speed up to 2.5G, you need to install kmod-phy-marvell-10g driver.
I ported your power changes to RC3 and now I dont get the power error anymore. But then I get the following error:
[ 83.289099] mtk_soc_eth 15100000.ethernet eth1: validation with support 0000000,00000000,00000000 failed: -22
The PON stick does get very hot so it is powered on. But ethtool eth1 still doesn’t change at all on plugging the stick in:
root@OpenWrt:~# ethtool eth1
Settings for eth1:
Supported ports: [ MII ]
Speed: 2500Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Link detected: no
@dangowrt: do you think that this is not a hardware limitation and this stick can be made to work in the SFP1 port in openwrt?
Once/if I am able to access the stick’s management console when it is plugged in the SFP1 port, I can provide more debugging info
Please provide the full bootlog as well as the output of
ethtool -m eth1
cat /sys/kernel/debug/sfp*/state
EEPROM data:
root@OpenWrt:~# ethtool -m eth1
Offset Values
0x0000: 03 04 01 20 00 00 00 00 00 00 00 03 67 00 14 c8
0x0010: 00 00 00 00 45 2e 43 2e 49 2e 20 4e 45 54 57 4f
0x0020: 52 4b 53 20 00 00 00 00 45 4e 58 47 53 46 50 50
0x0030: 4f 4d 41 43 56 32 20 20 56 31 2e 30 04 f6 00 b8
0x0040: 20 1a 00 00 41 5a 52 53 36 46 35 39 37 30 39 33
0x0050: 20 20 20 20 32 33 30 38 30 31 20 20 68 f0 08 85
0x0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0080: 53 43 32 33 32 37 30 30 38 30 31 35 30 00 00 00
0x0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0100: 5f 00 e2 00 55 00 ec 00 94 70 6d 60 88 b8 79 18
0x0110: af c8 01 f4 9c 40 03 e8 ff fe 3d e7 ff fe 4d f0
0x0120: 09 cf 00 0a 06 30 00 0e 00 00 00 00 00 00 00 00
0x0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0140: 00 00 00 00 3f 80 00 00 00 00 00 00 01 00 00 00
0x0150: 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 9b
0x0160: 43 00 80 50 1b e0 93 1f 00 99 81 90 01 48 00 00
0x0170: 00 28 00 00 00 28 00 00 00 00 00 00 00 00 00 00
0x0180: 43 4f 55 49 41 52 35 43 41 41 31 30 2d 32 34 35
0x0190: 37 2d 30 31 56 30 31 20 01 00 46 00 00 00 00 bf
0x01a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 aa aa
0x01c0: 53 46 50 2d 31 30 47 2d 4c 52 20 20 20 20 20 20
0x01d0: 20 20 20 20 31 36 00 00 00 00 00 00 00 00 00 37
0x01e0: 1e 28 2e 2e 31 34 29 36 00 00 00 00 00 00 00 00
0x01f0: 00 00 00 00 00 66 00 00 07 00 00 00 00 00 00 00
sfp state:
root@OpenWrt:~# ls /sys/kernel/debug/sfp*/state
/sys/kernel/debug/sfp-1/state /sys/kernel/debug/sfp-2/state
root@OpenWrt:~# cat /sys/kernel/debug/sfp-1/state
Module state: error
Module probe attempts: 0 0
Device state: up
Main state: down
Fault recovery remaining retries: 0
PHY probe remaining retries: 0
moddef0: 1
rx_los: 0
tx_fault: 1
tx_disable: 1
root@OpenWrt:~# cat /sys/kernel/debug/sfp-2/state
Module state: present
Device state: up
Main state: link_up
Fault recovery remaining retries: 5
PHY probe remaining retries: 12
moddef0: 1
rx_los: 0
tx_fault: 0
tx_disable: 0
kernel log (assuming this is what you meant by boot log):
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.127 (abhishek@optiplex) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.3.0 r23389-5deed175a5) 12.3.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Sat Aug 19 14:01:06 2023
[ 0.000000] Machine model: Bananapi BPI-R3
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
[ 0.000000] node 0: [mem 0x0000000043030000-0x000000004fbfffff]
[ 0.000000] node 0: [mem 0x000000004fc00000-0x000000004ffbffff]
[ 0.000000] node 0: [mem 0x000000004ffc0000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 17 pages/cpu s29592 r8192 d31848 u69632
[ 0.000000] pcpu-alloc: s29592 r8192 d31848 u69632 alloc=17*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: root=/dev/mmcblk0p65
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Memory: 2040596K/2097152K available (8128K kernel code, 894K rwdata, 2220K rodata, 448K init, 286K bss, 56556K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 640 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000118] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000126] pid_max: default: 32768 minimum: 301
[ 0.000331] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000343] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001374] rcu: Hierarchical SRCU implementation.
[ 0.001668] smp: Bringing up secondary CPUs ...
[ 0.001925] Detected VIPT I-cache on CPU1
[ 0.001947] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.001972] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.002232] Detected VIPT I-cache on CPU2
[ 0.002245] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.002256] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.002496] Detected VIPT I-cache on CPU3
[ 0.002506] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.002516] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.002542] smp: Brought up 1 node, 4 CPUs
[ 0.002556] SMP: Total of 4 processors activated.
[ 0.002559] CPU features: detected: 32-bit EL0 Support
[ 0.002563] CPU features: detected: CRC32 instructions
[ 0.002589] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.002642] CPU: All CPU(s) started at EL2
[ 0.002652] alternatives: patching kernel code
[ 0.005535] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.005556] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.005700] pinctrl core: initialized pinctrl subsystem
[ 0.006189] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.006434] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.006470] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.006495] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.006749] thermal_sys: Registered thermal governor 'fair_share'
[ 0.006752] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.006755] thermal_sys: Registered thermal governor 'step_wise'
[ 0.006758] thermal_sys: Registered thermal governor 'user_space'
[ 0.006934] ASID allocator initialised with 65536 entries
[ 0.007245] pstore: Registered ramoops as persistent store backend
[ 0.007249] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.017125] cryptd: max_cpu_qlen set to 1000
[ 0.018696] 1.8vd: supplied by 12vd
[ 0.018862] 3.3vd: supplied by 12vd
[ 0.019118] SCSI subsystem initialized
[ 0.019201] libata version 3.00 loaded.
[ 0.020038] clocksource: Switched to clocksource arch_sys_counter
[ 0.020597] NET: Registered PF_INET protocol family
[ 0.020709] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.021315] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.021335] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.021343] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.021410] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.021579] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.021657] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.021684] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.021786] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.021817] PCI: CLS 0 bytes, default 64
[ 0.023748] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.026355] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.026368] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.049375] pwm-mediatek 10048000.pwm: clock: top fail: -517
[ 0.049644] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.049664] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.049674] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 0.049755] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
[ 0.049765] mtk-pcie-gen3 11280000.pcie: failed to get clocks
[ 0.052529] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.053153] printk: console [ttyS0] disabled
[ 0.073333] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
[ 0.753363] printk: console [ttyS0] enabled
[ 0.778106] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
[ 0.807815] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 124, base_baud = 1625000) is a ST16650V2
[ 0.817645] mtk_rng 1020f000.rng: registered RNG driver
[ 0.817705] hwrng: no data available
[ 0.826468] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.834565] loop: module loaded
[ 0.838781] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.844101] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.852352] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.858690] Creating 4 MTD partitions on "spi0.0":
[ 0.863472] 0x000000580000-0x000008000000 : "ubi"
[ 0.998252] 0x000000380000-0x000000580000 : "fip"
[ 1.005321] 0x000000080000-0x000000380000 : "reserved"
[ 1.013760] 0x000000000000-0x000000080000 : "bl2"
[ 1.153177] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009680000, irq 136
[ 1.162969] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009680000, irq 136
[ 1.172509] i2c_dev: i2c /dev entries driver
[ 1.178245] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.186720] NET: Registered PF_INET6 protocol family
[ 1.192373] Segment Routing with IPv6
[ 1.196046] In-situ OAM (IOAM) with IPv6
[ 1.199981] NET: Registered PF_PACKET protocol family
[ 1.205094] 8021q: 802.1Q VLAN Support v1.8
[ 1.210045] pstore: Using crash dump compression: deflate
[ 1.221109] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 1.228418] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 1.234691] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 1.246225] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.256086] mmc0: new high speed SDHC card at address 0001
[ 1.262312] mmcblk0: mmc0:0001 SD32G 28.9 GiB
[ 1.270531] Alternate GPT is invalid, using primary GPT.
[ 1.276574] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
[ 1.285626] FIT: kernel sub-image 0x00001000..0x00507e0f "kernel-1" (ARM64 OpenWrt Linux-5.15.127)
[ 1.295526] FIT: flat_dt sub-image 0x00508000..0x0050fa34 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 1.306725] FIT: flat_dt sub-image 0x00510000..0x005101dc "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
[ 1.323039] FIT: flat_dt sub-image 0x00511000..0x00511390 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
[ 1.339354] FIT: flat_dt sub-image 0x00512000..0x0051238f "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 1.355494] FIT: flat_dt sub-image 0x00513000..0x00513146 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
[ 1.371457] FIT: filesystem sub-image 0x00514000..0x009fdfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 1.382044] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 1.389332] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p65(rootfs-1) p66(rootfs_data)
[ 1.460063] mtk-pcie-gen3 11280000.pcie: PCIe link down, ltssm reg val: 0x1000001
[ 1.467562] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 1.496360] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 1.505407] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1.514103] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=144)
[ 1.534329] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=145)
[ 1.554339] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=146)
[ 1.574337] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=147)
[ 1.594358] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=148)
[ 1.605457] DSA: tree 0 setup
[ 1.610579] UBI: auto-attach mtd0
[ 1.613892] ubi0: default fastmap pool size: 45
[ 1.618405] ubi0: default fastmap WL pool size: 22
[ 1.623202] ubi0: attaching mtd0
[ 5.237428] ubi0: scanning is finished
[ 5.282543] ubi0: attached mtd0 (name "ubi", size 122 MiB)
[ 5.288024] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 5.294885] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 5.301654] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 5.308594] ubi0: good PEBs: 980, bad PEBs: 0, corrupted PEBs: 0
[ 5.314582] ubi0: user volume: 5, internal volumes: 1, max. volumes count: 128
[ 5.321784] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[ 5.330112] ubi0: available PEBs: 0, total reserved PEBs: 980, PEBs reserved for bad PEB handling: 20
[ 5.339309] ubi0: background thread "ubi_bgt0d" started, PID 503
[ 5.345385] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
[ 5.354428] FIT: kernel sub-image 0x00001000..0x004ebc62 "kernel-1" (ARM64 OpenWrt Linux-5.15.127)
[ 5.364328] FIT: flat_dt sub-image 0x004ec000..0x004f39fc "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 5.375528] FIT: flat_dt sub-image 0x004f4000..0x004f41dc "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
[ 5.391852] FIT: flat_dt sub-image 0x004f5000..0x004f5390 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
[ 5.408166] FIT: flat_dt sub-image 0x004f6000..0x004f638f "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 5.424305] FIT: flat_dt sub-image 0x004f7000..0x004f7146 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
[ 5.440268] FIT: filesystem sub-image 0x004f8000..0x00a3bfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 5.450855] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 5.458141] ubiblock0_2: p1(rootfs-1)
[ 5.458264] block ubiblock0_2: created from ubi0:2(fit)
[ 5.472411] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
[ 5.479678] Freeing unused kernel memory: 448K
[ 5.520052] Run /sbin/init as init process
[ 5.524131] with arguments:
[ 5.527082] /sbin/init
[ 5.529772] with environment:
[ 5.532905] HOME=/
[ 5.535249] TERM=linux
[ 5.647522] init: Console is alive
[ 5.651032] init: - watchdog -
[ 5.914200] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 5.934266] usbcore: registered new interface driver usbfs
[ 5.939771] usbcore: registered new interface driver hub
[ 5.945117] usbcore: registered new device driver usb
[ 5.953685] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 5.961095] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 5.969225] xhci-mtk 11200000.usb: xHCI Host Controller
[ 5.974461] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 5.984912] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 5.994058] xhci-mtk 11200000.usb: irq 128, io mem 0x11200000
[ 5.999867] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.005101] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 6.012485] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 6.019877] hub 1-0:1.0: USB hub found
[ 6.023645] hub 1-0:1.0: 2 ports detected
[ 6.027888] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.036208] hub 2-0:1.0: USB hub found
[ 6.039961] hub 2-0:1.0: 1 port detected
[ 6.046288] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.058006] init: - preinit -
[ 6.254496] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 6.262959] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 6.271194] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 6.283324] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 6.291309] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
[ 6.480042] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 6.660715] hub 1-1:1.0: USB hub found
[ 6.664560] hub 1-1:1.0: 4 ports detected
[ 6.668793] random: procd: uninitialized urandom read (4 bytes read)
[ 8.711817] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = d70caec
[ 8.721820] mount_root: switching to f2fs overlay
[ 8.728520] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 8.744406] urandom-seed: Seeding with /etc/urandom.seed
[ 8.775047] mt7530-mdio mdio-bus:1f lan1: Link is Down
[ 8.783512] procd: - early -
[ 8.786433] procd: - watchdog -
[ 9.309210] procd: - watchdog -
[ 9.313165] procd: - ubus -
[ 9.344261] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.367254] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.375380] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.383868] procd: - init -
[ 9.524577] urngd: v1.0.2 started.
[ 9.543294] random: crng init done
[ 9.546695] random: 23 urandom warning(s) missed due to ratelimiting
[ 9.549181] kmodloader: loading kernel modules from /etc/modules.d/*
[ 9.564237] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
[ 9.570999] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
[ 9.579951] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
[ 9.593931] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
[ 9.601470] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
[ 9.612310] sfp sfp-1: Host maximum power 3.0W
[ 9.617498] sfp sfp-2: Host maximum power 3.0W
[ 9.949605] sfp sfp-1: module E.C.I. NETWORKS ENXGSFPPOMACV2 rev V1.0 sn AZRS6F597093 dc 230801
[ 9.959094] mtk_soc_eth 15100000.ethernet eth1: validation with support 0000000,00000000,00000000 failed: -22
[ 10.010499] sfp sfp-2: module TP-Link TL-SM331T(UN) rev 1.0 sn 2234489000355 dc 230428
[ 10.019970] mt7530-mdio mdio-bus:1f sfp2: switched to inband/1000base-x link mode
[ 10.020844] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 10.100355] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[ 10.100355]
[ 10.227213] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805
[ 10.305272] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[ 13.066019] PPP generic driver version 2.4.2
[ 13.070975] NET: Registered PF_PPPOX protocol family
[ 13.078300] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 14.823315] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 14.834816] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 14.843361] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 14.844402] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 14.859850] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.866472] br-lan: port 1(lan1) entered blocking state
[ 14.871719] br-lan: port 1(lan1) entered disabled state
[ 14.878461] device lan1 entered promiscuous mode
[ 14.883134] device eth0 entered promiscuous mode
[ 14.898840] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 14.908733] br-lan: port 2(lan2) entered blocking state
[ 14.914041] br-lan: port 2(lan2) entered disabled state
[ 14.921197] device lan2 entered promiscuous mode
[ 14.930571] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[ 14.940577] br-lan: port 3(lan3) entered blocking state
[ 14.945807] br-lan: port 3(lan3) entered disabled state
[ 14.952872] device lan3 entered promiscuous mode
[ 14.961815] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
[ 14.972615] br-lan: port 4(lan4) entered blocking state
[ 14.977851] br-lan: port 4(lan4) entered disabled state
[ 14.985177] device lan4 entered promiscuous mode
[ 14.993904] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/1000base-x link mode
[ 15.003842] br-lan: port 5(sfp2) entered blocking state
[ 15.009074] br-lan: port 5(sfp2) entered disabled state
[ 15.016601] device sfp2 entered promiscuous mode
[ 15.025469] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[ 15.035579] br-wan: port 1(eth1) entered blocking state
[ 15.040859] br-wan: port 1(eth1) entered disabled state
[ 15.046323] device eth1 entered promiscuous mode
[ 15.052590] br-wan: port 1(eth1) entered blocking state
[ 15.057820] br-wan: port 1(eth1) entered forwarding state
[ 15.065105] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
[ 15.074937] br-wan: port 2(wan) entered blocking state
[ 15.080085] br-wan: port 2(wan) entered disabled state
[ 15.086552] device wan entered promiscuous mode
[ 15.956268] br-lan: port 6(phy0-ap0) entered blocking state
[ 15.961908] br-lan: port 6(phy0-ap0) entered disabled state
[ 15.967671] device phy0-ap0 entered promiscuous mode
[ 15.972811] br-lan: port 6(phy0-ap0) entered blocking state
[ 15.978379] br-lan: port 6(phy0-ap0) entered forwarding state
[ 15.985716] br-wan: port 1(eth1) entered disabled state
[ 15.991285] br-lan: port 6(phy0-ap0) entered disabled state
[ 16.070459] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 1Gbps/Full - flow control off
[ 16.078601] br-lan: port 5(sfp2) entered blocking state
[ 16.083867] br-lan: port 5(sfp2) entered forwarding state
[ 16.090227] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 22.409596] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 22.417545] br-lan: port 1(lan1) entered blocking state
[ 22.422767] br-lan: port 1(lan1) entered forwarding state
[ 24.556670] IPv6: ADDRCONF(NETDEV_CHANGE): phy0-ap0: link becomes ready
[ 24.563414] br-lan: port 6(phy0-ap0) entered blocking state
[ 24.568972] br-lan: port 6(phy0-ap0) entered forwarding state
[ 205.603931] mt7530-mdio mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control rx/tx
[ 205.611811] br-wan: port 2(wan) entered blocking state
[ 205.616939] br-wan: port 2(wan) entered forwarding state
[ 213.325880] mt7530-mdio mdio-bus:1f lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[ 213.334024] br-lan: port 2(lan2) entered blocking state
[ 213.339243] br-lan: port 2(lan2) entered forwarding state
[ 225.413622] mt7530-mdio mdio-bus:1f lan3: Link is Up - 100Mbps/Full - flow control off
[ 225.421570] br-lan: port 3(lan3) entered blocking state
[ 225.426783] br-lan: port 3(lan3) entered forwarding state
[ 229.714638] mt7530-mdio mdio-bus:1f lan4: Link is Up - 100Mbps/Full - flow control off
[ 229.722596] br-lan: port 4(lan4) entered blocking state
[ 229.727811] br-lan: port 4(lan4) entered forwarding state
[ 236.182004] mt7530-mdio mdio-bus:1f lan4: Link is Down
[ 236.187213] br-lan: port 4(lan4) entered disabled state
[ 239.600371] mt7530-mdio mdio-bus:1f lan4: Link is Up - 100Mbps/Full - flow control off
[ 239.608317] br-lan: port 4(lan4) entered blocking state
[ 239.613543] br-lan: port 4(lan4) entered forwarding state
[ 240.569527] mt7530-mdio mdio-bus:1f lan4: Link is Down
[ 240.574748] br-lan: port 4(lan4) entered disabled state
[ 242.697111] mt7530-mdio mdio-bus:1f lan4: Link is Up - 100Mbps/Full - flow control off
[ 242.705064] br-lan: port 4(lan4) entered blocking state
[ 242.710289] br-lan: port 4(lan4) entered forwarding state
Bumping this thread!
I’m looking for some manufacturer and model numbers that would allow me to use my SFP port and utilize the 2.5g my modem supports. Currently it’s capping (at the advertised) 1g using the traditional WAN port. Googling offers various but inconsistent options. Ideally available on Amazon.
I know this thread is old now, but there’s not really any other relevant ones here. I can confirm that the SFP+ XGS-PON ONT on-a-stick devices (maybe not all, check first) can work in the bpi-r3. Most of the available ones are based on the PRX126 SOC, which does support 10G/2.5G/1G. The EEPROM they come with only advertises 10G-KR, however editing the EEPROM is possible so that it advertises in such a way that the bpi-r3 will attempt negotiation. Unfortunately you can’t just edit the EEPROM from the bpi-r3, you either need another device such as a dumb media converter, or hook up the SFP to UART (check the 8311 PON wiki for pinouts). It’s not the most straightforward setup, but it can work (with stock openwrt as well!) Good luck to anyone who decides to go ahead!
The main issue with 10G SFP (not only xPON) is the serdes modes supported by the sfp (must be sgmii or rgmii for R3 compatibility). Of course if you use dump mediaconverter it will work but why not using compatible device and run at 10G which produces much more heat and power consumption?
Yea i know. Or HSGMII
I was mostly curious to see if I could make heads and tails of the bpi-r3’s HSGMII interfaces. There’s not a whole lot of documentation for many SFP+ modules. I eventually stumbled on the Adtran SDX630 which does mention it supports HSGMII/2.5G. I later learned about the 8311 SFP ONT modules.
The main issue I had was just getting OpenWRT to even try to communicate. When the device only advertised 10G, OpenWRT completely refused to communicate even with ethtool -s eth1 autoneg off speed 2500, whereas a dumb 2.5G media converter will happily try 2.5G without caring about the EEPROM.
Sorry, not sure I completely understand? The bpi-r3 can only run up to 2.5G? The SFP+ ONT i have is XGS-PON so it has to work up to 10G in order to keep up, however since I only get 1G/1G the 2.5G from the bpi-r3 is more than enough.
@Skyler84 any hints on how to bring the correct eeprom values to a prx126 based XS-LL1015 XGS-PON stick? Stick runs 8311 firmware… i have pretty much your usecase (awaiting 1G fibre with XGS-PON technology) but only have a BPiR3 available. BPiR4 seems to be a rare and expensive thing… Can access the stick with my regular workstation having a X520 network card.
