Purchased TL-SM410U electrical port module, installed on the machine can not be used, can not get the IP address
root@OpenWrt:~# ifconfig -a
br-lan Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:73
inet addr:192.168.50.1 Bcast:192.168.50.255 Mask:255.255.255.0
inet6 addr: fd7a:178d:efe5::1/60 Scope:Global
inet6 addr: fe80::e8fb:aeff:fed1:3e73/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1013800 errors:0 dropped:0 overruns:0 frame:0
TX packets:1696934 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:110884345 (105.7 MiB) TX bytes:2526937020 (2.3 GiB)
br-wan Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:74
inet addr:192.168.1.198 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::e8fb:aeff:fed1:3e74/64 Scope:Link
RX packets:959577 errors:0 dropped:19423 overruns:0 frame:0
TX packets:1068681 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:860386584 (820.5 MiB) TX bytes:128888870 (122.9 MiB)
eth0 Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:73
UP BROADCAST RUNNING MULTICAST MTU:1504 Metric:1
RX packets:5390036 errors:0 dropped:0 overruns:0 frame:0
TX packets:4521748 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5479999743 (5.1 GiB) TX bytes:3513381438 (3.2 GiB)
Interrupt:132
eth1 Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:74
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:132
lan1 Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:73
RX packets:5236 errors:0 dropped:7 overruns:0 frame:0
TX packets:4574 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:783372 (765.0 KiB) TX bytes:8753953 (8.3 MiB)
lan2 Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:73
lan3 Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:73
lan4 Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:73
RX packets:1257839 errors:0 dropped:0 overruns:0 frame:0
TX packets:2005507 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:181605451 (173.1 MiB) TX bytes:3155882109 (2.9 GiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:46051 errors:0 dropped:0 overruns:0 frame:0
TX packets:46051 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3702649 (3.5 MiB) TX bytes:3702649 (3.5 MiB)
sfp2 Link encap:Ethernet HWaddr EA:FB:AE:D1:3E:73
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
tunl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
RX packets:4126961 errors:0 dropped:0 overruns:0 frame:0
TX packets:2012662 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5200590272 (4.8 GiB) TX bytes:280530046 (267.5 MiB)
wlan0 Link encap:Ethernet HWaddr 00:0C:43:26:60:00
inet6 addr: fe80::20c:43ff:fe26:6000/64 Scope:Link
TX packets:6181 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1791286 (1.7 MiB)
wlan1 Link encap:Ethernet HWaddr 82:0C:43:26:60:00
inet6 addr: fe80::800c:43ff:fe26:6000/64 Scope:Link
RX packets:706603 errors:0 dropped:0 overruns:0 frame:0
TX packets:1527798 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:77333960 (73.7 MiB) TX bytes:2039953902 (1.8 GiB)
root@OpenWrt:~#
dangowrt
(Daniel Golle)
March 27, 2023, 8:33am
2
Did you install official OpenWrt snapshot as decribed here ? Because (due to the wifi interface names wlan0 and wlan1) this looks like SinoVoip’s MediaTek SDK firmware which is shipped with the board…
Compile your own firmware
dangowrt
(Daniel Golle)
March 27, 2023, 8:50am
4
Ok, so for SFP to work you have to compile like this:
git clone https://git.openwrt.org/openwrt/openwrt.git
cd openwrt
make menuconfig
# select Mediatek (ARM) -> FiLogic -> BPi-R3; select packages you want
make -j$(nproc)
I compiled with this source code
frank-w
(Frank W.)
March 27, 2023, 10:43am
7
Please use the source daniel suggested. If you use another source you cannot expect support from him
What is the source address?
openwrt has to source it! Thanks I’ll try.But the openwrt source code does not
luci-app-syncdial
I tried compiling with the openwrt source code, but I still can’t get the IP address. Is the module incompatible?
frank-w
(Frank W.)
April 7, 2023, 7:09am
13
On which port have you inserted the sfp? TL-SM410U is afaik the one daniel used in his tests.
You have to put the interface up (eth1 for wan-sfp,lan4 for lan-sfp).
Can you show your dmesg and ethtool output?
dmesg | grep -i 'eth\|sfp'
ethtool eth1;ethtool -m eth1
root@OpenWrt:/# dmesg | grep -i 'eth\|sfp'
[ 0.000000] psci: probing for conduit method from DT.
[ 1.130674] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009600000, irq 132
[ 1.139871] mtk_soc_eth 15100000.ethernet: generated random MAC address 9a:e5:db:eb:f5:af
[ 1.148637] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009600000, irq 132
[ 6.737968] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 6.746403] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 23.761804] sfp sfp1: Host maximum power 1.0W
[ 23.766912] sfp sfp2: Host maximum power 1.0W
[ 24.107376] sfp sfp2: module TP-LINK TL-SM410U rev 2.0 sn 122C304000986 dc 221228
[ 30.512894] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 30.578030] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 30.586465] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 30.622011] device eth0 entered promiscuous mode
[ 30.629104] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 30.736510] mt7530 mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
[ 30.745283] br-lan: port 5(sfp2) entered blocking state
[ 30.750562] br-lan: port 5(sfp2) entered disabled state
[ 30.758030] device sfp2 entered promiscuous mode
[ 139.526228] sfp sfp2: module removed
[ 143.597191] sfp sfp1: module TP-LINK TL-SM410U rev 2.0 sn 122C304000986 dc 221228
[ 234.482701] sfp sfp1: module removed
[ 238.857199] sfp sfp2: module TP-LINK TL-SM410U rev 2.0 sn 122C304000986 dc 221228
root@OpenWrt:/# ethtool eth1;ethtool -m eth1
/bin/ash: ethtool: not found
root@OpenWrt:/#
You don’t have ethtool installed. Please, install it and do these commands:
ethtool eth1
ethtool -m eth1
Sfp module must be plugged to sfp1 cage (near usb port).
Did you manually swap sfp module from sfp2 cage to sfp1? It seems, your sfp module was recognised by router, but was disconnected from sfp2 first and plugged to sfp1. Than it was disconnected from sfp1 and plugged to sfp2. Is this true?
[ 1.140889] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009680000, irq 134
[ 1.150653] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009680000, irq 134
[ 7.155723] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 7.164156] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 18.037568] sfp sfp1: Host maximum power 3.0W
[ 18.042688] sfp sfp2: Host maximum power 3.0W
[ 18.377478] sfp sfp2: module TP-LINK TL-SM410U rev 2.0 sn 122C304000986 dc 221228
[ 28.802670] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 28.848124] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 28.857045] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 28.897856] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 28.932194] device eth0 entered promiscuous mode
[ 29.067874] mt7530 mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
[ 29.077333] br-lan: port 5(sfp2) entered blocking state
[ 29.082623] br-lan: port 5(sfp2) entered disabled state
[ 29.090095] device sfp2 entered promiscuous mode
[ 29.099518] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[ 29.109573] br-wan: port 1(eth1) entered blocking state
[ 29.114863] br-wan: port 1(eth1) entered disabled state
[ 29.120336] device eth1 entered promiscuous mode
[ 29.126880] br-wan: port 1(eth1) entered blocking state
[ 29.132268] br-wan: port 1(eth1) entered forwarding state
[ 29.997487] br-wan: port 1(eth1) entered disabled state
Settings for eth1:
Supported ports: [ MII ]
Speed: 2500Mb/s
Duplex: Full
Auto-negotiation: on
Port: MII
PHYAD: 0
Transceiver: internal
Link detected: no
netlink error: No such device or address
[ 1067.373406] sfp sfp2: module removed
[ 1070.797471] sfp sfp1: module TP-LINK TL-SM410U rev 2.0 sn 122C304000986 dc 221228
Settings for eth1:
Supported ports: [ FIBRE ]
Speed: 2500Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Link detected: no
Identifier : 0x03 (SFP)
Connector : 0x07 (LC)
Transceiver codes : 0x00 0x00 0x00 0x00 0x00 0x00 0x40 0x00 0x00
Transceiver type : FC: Twisted Pair (TP)
Encoding : 0x01 (8B/10B)
BR, Nominal : 3100MBd
Length (SMF,km) : 0km
Length (SMF) : 0m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 0nm
Vendor name : TP-LINK
Vendor OUI : 00:00:00
Vendor PN : TL-SM410U
Vendor rev : 2.0
Option values : 0x00 0x18
Option : TX_FAULT implemented
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : 122C304000986
Date code : 221228
root@OpenWrt:/#
Settings for eth1:
Speed: 2500Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Link detected: no
Length (SMF) : 0m
Length (50um) : 0m
Length (OM3) : 0m
Vendor rev : 2.0
BR margin, max : 0%
BR margin, min : 0%
Date code : 221228
root@OpenWrt:/#
frank-w
(Frank W.)
August 9, 2023, 11:57am
19
please format code to be readable (select code and press the <> button) make sure there is an empty line between “normal” text and the code…for longer code do not post 3 messages, put output in textfile and append it or use pastebin or similar and put link in your message
I am very sorry, I am inserting the modules into SPF1 and 2 respectively and then using the command output. But what you said (select code and press the <> button) I’m not very good at it!
