[bpi-r3] sfp 2.5g
Hello,
I’m triyng to use a 2.5 SFP from FS on a bpi-r3. I use debian 12 with kernel 6.6 (branch 6.6 main from frank-w).
I tried on left port, SFP is detected :
root@bpi-r3:~# ethtool -m eth1
        Connector                                 : 0x22 (RJ45)
        Transceiver codes                         : 0x00 0x01 0x00 0x00 0x00 0x00 0x02 0x00 0x1e
        Transceiver type                          : SONET: OC-48, short reach
        Transceiver type                          : Extended: 2.5GBASE-T
        Encoding                                  : 0x05 (SONET Scrambled)
        BR, Nominal                               : 2500MBd
        Length (SMF,km)                           : 0km
        Length (SMF)                              : 0m
        Length (50um)                             : 0m
        Length (62.5um)                           : 0m
        Length (Copper)                           : 100m
        Laser wavelength                          : 0nm
        Vendor name                               : FS
        Vendor OUI                                : 64:9d:99
        Vendor PN                                 : SFP-2.5G-T
        Vendor rev                                : 1.0
        Option values                             : 0x00 0x1a
        Option                                    : RX_LOS implemented
        Option                                    : TX_FAULT implemented
        BR margin, max                            : 0%
        BR margin, min                            : 0%
        Vendor SN                                 : G2340039491
        Date code                                 : 231101
But dmesg give an error when inserted :
[   53.234283] mtk_soc_eth 15100000.ethernet eth1: validation with support 00,00000000,00000000,00000000 failed: -EINVAL
[   53.245020] sfp sfp-1: sfp_add_phy failed: -EINVAL
Full log below :
root@bpi-r3:~# dmesg
[    0.000000] Linux version 6.6.16-bpi-r3 (mtg@mtg-VirtualBox) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #3 SMP Thu Mar 14 11:13:32 CET 2024
[    0.000000] Machine model: Bananapi BPI-R3
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000011002000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: 0x0000000015194000..0x0000000015194fff (4 KiB) nomap non-reusable wo-boot@15194000
[    0.000000] OF: reserved mem: 0x00000000151e0000..0x00000000151e7fff (32 KiB) nomap non-reusable wo-ilm@151e0000
[    0.000000] OF: reserved mem: 0x00000000151e8000..0x00000000151e9fff (8 KiB) nomap non-reusable wo-dlm@151e8000
[    0.000000] OF: reserved mem: 0x00000000151f0000..0x00000000151f7fff (32 KiB) nomap non-reusable wo-ilm@151f0000
[    0.000000] OF: reserved mem: 0x00000000151f8000..0x00000000151f9fff (8 KiB) nomap non-reusable wo-dlm@151f8000
[    0.000000] OF: reserved mem: 0x0000000043000000..0x000000004302ffff (192 KiB) nomap non-reusable secmon@43000000
[    0.000000] OF: reserved mem: 0x000000004fc00000..0x000000004fcfffff (1024 KiB) nomap non-reusable wmcpu-reserved@4fc00000
[    0.000000] OF: reserved mem: 0x000000004fd00000..0x000000004fd3ffff (256 KiB) nomap non-reusable wo-emi@4fd00000
[    0.000000] OF: reserved mem: 0x000000004fd40000..0x000000004fd7ffff (256 KiB) nomap non-reusable wo-emi@4fd40000
[    0.000000] OF: reserved mem: 0x000000004fd80000..0x000000004ffbffff (2304 KiB) nomap non-reusable wo-data@4fd80000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
[    0.000000]   node   0: [mem 0x0000000043000000-0x000000004302ffff]
[    0.000000]   node   0: [mem 0x0000000043030000-0x000000004fbfffff]
[    0.000000]   node   0: [mem 0x000000004fc00000-0x000000004ffbffff]
[    0.000000]   node   0: [mem 0x000000004ffc0000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 28 pages/cpu s76584 r8192 d29912 u114688
[    0.000000] pcpu-alloc: s76584 r8192 d29912 u114688 alloc=28*4096
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: board=bpi-r3 earlycon=uart8250,mmio32,0x11002000 debug=7 root=/dev/mmcblk0p6 rootfstype=ext4 rootwait
[    0.000000] Unknown kernel command line parameters "board=bpi-r3", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000b9600000-0x00000000bd600000] (64MB)
[    0.000000] Memory: 1961948K/2097152K available (12608K kernel code, 2410K rwdata, 4200K rodata, 4480K init, 419K bss, 135204K reserved, 0K cma-reserved)
[    0.000000] trace event string verifier disabled
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 640 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[    0.008276] Console: colour dummy device 80x25
[    0.012740] printk: console [tty0] enabled
[    0.016854] printk: bootconsole [uart8250] disabled
[    0.021779] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[    0.021791] pid_max: default: 32768 minimum: 301
[    0.021900] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.021916] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.022508] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.022937] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.023056] rcu: Hierarchical SRCU implementation.
[    0.023063] rcu:     Max phase no-delay instances is 1000.
[    0.023455] EFI services will not be available.
[    0.023609] smp: Bringing up secondary CPUs ...
[    0.023933] Detected VIPT I-cache on CPU1
[    0.023973] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[    0.024006] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.024349] Detected VIPT I-cache on CPU2
[    0.024374] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[    0.024387] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.024672] Detected VIPT I-cache on CPU3
[    0.024691] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[    0.024701] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.024737] smp: Brought up 1 node, 4 CPUs
[    0.024780] SMP: Total of 4 processors activated.
[    0.024786] CPU features: detected: 32-bit EL0 Support
[    0.024792] CPU features: detected: CRC32 instructions
[    0.024838] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.024849] CPU: All CPU(s) started at EL2
[    0.024854] alternatives: applying system-wide alternatives
[    0.026424] devtmpfs: initialized
[    0.028474] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.028505] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.028627] pinctrl core: initialized pinctrl subsystem
[    0.028841] DMI not present or invalid.
[    0.029212] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.029766] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.029807] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.029836] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.030203] thermal_sys: Registered thermal governor 'fair_share'
[    0.030207] thermal_sys: Registered thermal governor 'bang_bang'
[    0.030214] thermal_sys: Registered thermal governor 'step_wise'
[    0.030220] thermal_sys: Registered thermal governor 'user_space'
[    0.030322] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.030388] ASID allocator initialised with 65536 entries
[    0.037993] Modules: 26688 pages in range for non-PLT usage
[    0.038006] Modules: 518208 pages in range for PLT usage
[    0.038731] cryptd: max_cpu_qlen set to 1000
[    0.039145] iommu: Default domain type: Translated
[    0.039160] iommu: DMA domain TLB invalidation policy: strict mode
[    0.039300] SCSI subsystem initialized
[    0.039399] libata version 3.00 loaded.
[    0.039512] usbcore: registered new interface driver usbfs
[    0.039537] usbcore: registered new interface driver hub
[    0.039564] usbcore: registered new device driver usb
[    0.039809] i2c-gpio i2c-gpio-0: using lines 528 (SDA) and 529 (SCL)
[    0.039923] i2c-gpio i2c-gpio-1: using lines 530 (SDA) and 531 (SCL)
[    0.039969] pps_core: LinuxPPS API ver. 1 registered
[    0.039976] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.039992] PTP clock support registered
[    0.040928] vgaarb: loaded
[    0.041827] clocksource: Switched to clocksource arch_sys_counter
[    0.045701] NET: Registered PF_INET protocol family
[    0.045850] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.046852] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.046881] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.046895] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.046969] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.047301] TCP: Hash tables configured (established 16384 bind 16384)
[    0.047392] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.047428] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.047562] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.047909] RPC: Registered named UNIX socket transport module.
[    0.047920] RPC: Registered udp transport module.
[    0.047927] RPC: Registered tcp transport module.
[    0.047932] RPC: Registered tcp-with-tls transport module.
[    0.047938] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.047950] PCI: CLS 0 bytes, default 64
[    0.062012] Initialise system trusted keyrings
[    0.062269] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.062508] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.062695] NFS: Registering the id_resolver key type
[    0.062744] Key type id_resolver registered
[    0.062751] Key type id_legacy registered
[    0.062767] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.062776] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.062797] jffs2: version 2.2. (NAND) (SUMMARY)  \xc2\xa9 2001-2006 Red Hat, Inc.
[    0.081959] Key type asymmetric registered
[    0.081984] Asymmetric key parser 'x509' registered
[    0.082037] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.082048] io scheduler mq-deadline registered
[    0.082056] io scheduler kyber registered
[    0.082097] io scheduler bfq registered
[    0.127320] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.149855] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 2500000) is a ST16650V2
[    0.149916] printk: console [ttyS0] enabled
[    1.159547] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 117, base_baud = 1625000) is a ST16650V2
[    1.190130] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 118, base_baud = 1625000) is a ST16650V2
[    1.200259] mtk_rng 1020f000.rng: registered RNG driver
[    1.200513] random: crng init done
[    1.212408] loop: module loaded
[    1.217184] spi-nand spi0.0: Winbond SPI NAND was found.
[    1.222550] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    1.230864] 4 fixed-partitions partitions found on MTD device spi0.0
[    1.237228] Creating 4 MTD partitions on "spi0.0":
[    1.242032] 0x000000580000-0x000008000000 : "ubi"
[    1.359186] 0x000000380000-0x000000580000 : "fip"
[    1.366615] 0x000000100000-0x000000380000 : "reserved"
[    1.374877] 0x000000000000-0x000000100000 : "bl2"
[    1.382424] sfp sfp-1: Host maximum power 3.0W
[    1.387369] sfp sfp-2: Host maximum power 3.0W
[    1.522461] mtk_soc_eth 15100000.ethernet: generated random MAC address be:99:3b:32:fb:30
[    1.532674] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082d80000, irq 123
[    1.542518] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082d80000, irq 123
[    1.552134] usbcore: registered new interface driver usb-storage
[    1.558336] i2c_dev: i2c /dev entries driver
[    1.564836] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    1.573582] SMCCC: SOC_ID: ID = jep106:0426:7986 Revision = 0x00000000
[    1.580204] usbcore: registered new interface driver usbhid
[    1.585784] usbhid: USB HID core driver
[    1.590057] NET: Registered PF_INET6 protocol family
[    1.595639] Segment Routing with IPv6
[    1.599315] In-situ OAM (IOAM) with IPv6
[    1.603275] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.609582] NET: Registered PF_PACKET protocol family
[    1.614839] 8021q: 802.1Q VLAN Support v1.8
[    1.624943] Loading compiled-in X.509 certificates
[    1.640808] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    1.648171] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[    1.654446] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
[    1.881254] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.active (0x1000001)
[    1.890691] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[    1.950445] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[    1.959599] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[    1.968287] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=128)
[    1.988623] mt7530-mdio mdio-bus:1f lan0 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=129)
[    2.008793] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=130)
[    2.028964] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=131)
[    2.049130] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=132)
[    2.060494] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[    2.067249] DSA: tree 0 setup
[    2.070674] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[    2.078080] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[    2.086542] xhci-mtk 11200000.usb: xHCI Host Controller
[    2.091818] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[    2.102181] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[    2.111363] xhci-mtk 11200000.usb: irq 133, io mem 0x11200000
[    2.117185] xhci-mtk 11200000.usb: xHCI Host Controller
[    2.122407] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[    2.129792] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[    2.137301] hub 1-0:1.0: USB hub found
[    2.141066] hub 1-0:1.0: 2 ports detected
[    2.145382] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.153899] hub 2-0:1.0: USB hub found
[    2.157668] hub 2-0:1.0: 1 port detected
[    2.163194] clk: Disabling unused clocks
[    2.189974] Waiting for root device /dev/mmcblk0p6...
[    2.224736] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.236623] mmc0: new high speed SDHC card at address aaaa
[    2.242942] mmcblk0: mmc0:aaaa SA08G 7.40 GiB
[    2.255458]  mmcblk0: p1 p2 p3 p4 p5 p6
[    2.293599] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[    2.300911] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[    2.513598] EXT4-fs (mmcblk0p6): recovery complete
[    2.521348] EXT4-fs (mmcblk0p6): mounted filesystem c4133c1c-a36b-48da-952a-43ee4e59dcfb ro with ordered data mode. Quota mode: disabled.
[    2.533735] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    2.542154] devtmpfs: mounted
[    2.546592] Freeing unused kernel memory: 4480K
[    2.551174] Run /sbin/init as init process
[    2.555278]   with arguments:
[    2.558234]     /sbin/init
[    2.560930]   with environment:
[    2.564072]     HOME=/
[    2.566420]     TERM=linux
[    2.569114]     board=bpi-r3
[    2.601244] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[    2.782116] hub 1-1:1.0: USB hub found
[    2.785945] hub 1-1:1.0: 4 ports detected
[    3.324242] systemd[1]: System time before build time, advancing clock.
[    3.368429] systemd[1]: Failed to find module 'autofs4'
[    3.551698] systemd[1]: systemd 252.22-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    3.584398] systemd[1]: Detected architecture arm64.
[    3.628393] systemd[1]: Hostname set to <bpi-r3>.
[    4.202941] systemd[1]: Queued start job for default target graphical.target.
[    4.263398] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    4.302406] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    4.342397] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    4.382040] systemd[1]: Created slice user.slice - User and Session Slice.
[    4.421558] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[    4.461478] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    4.501440] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[    4.520794] systemd[1]: Expecting device dev-mmcblk0p5.device - /dev/mmcblk0p5...
[    4.561294] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
[    4.601315] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[    4.641360] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    4.681374] systemd[1]: Reached target paths.target - Path Units.
[    4.721337] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[    4.761315] systemd[1]: Reached target slices.target - Slice Units.
[    4.801345] systemd[1]: Reached target swap.target - Swaps.
[    4.841340] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    4.881584] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    4.927560] systemd[1]: systemd-journald-audit.socket - Journal Audit Socket was skipped because of an unmet condition check (ConditionSecurity=audit).
[    4.941770] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    4.981757] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    5.021894] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
[    5.061792] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    5.101661] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    5.141766] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    5.201502] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    5.243877] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    5.283861] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    5.324352] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    5.364312] systemd[1]: Starting [email protected] - Load Kernel Module configfs...
[    5.404248] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    5.444246] systemd[1]: Starting [email protected] - Load Kernel Module drm...
[    5.484248] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    5.524236] systemd[1]: Starting [email protected] - Load Kernel Module fuse...
[    5.564437] systemd[1]: Starting [email protected] - Load Kernel Module loop...
[    5.601974] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    5.614880] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    5.625855] systemd[1]: Starting systemd-journald.service - Journal Service...
[    5.789461] fuse: init (API version 7.39)
[    5.851696] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    5.894047] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line...
[    5.944151] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    5.994136] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    6.035102] systemd[1]: Started systemd-journald.service - Journal Service.
[    6.051186] EXT4-fs (mmcblk0p6): re-mounted c4133c1c-a36b-48da-952a-43ee4e59dcfb r/w. Quota mode: disabled.
[    6.744292] systemd-journald[1453]: Received client request to flush runtime journal.
[    6.755417] systemd-journald[1453]: File /var/log/journal/8db1f80e58d340ecbbac2846829338b6/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    7.546207] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[    7.567501] mtdblock: MTD device 'reserved' is NAND, please consider using UBI block devices instead.
[    7.574135] mtdblock: MTD device 'fip' is NAND, please consider using UBI block devices instead.
[    7.581513] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[    9.169634] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    9.172518] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.200019] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.206170] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   10.694322] lanbr0: port 1(lan3) entered blocking state
[   10.699583] lanbr0: port 1(lan3) entered disabled state
[   10.704945] mt7530-mdio mdio-bus:1f lan3: entered allmulticast mode
[   10.711264] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[   10.720634] mt7530-mdio mdio-bus:1f lan3: entered promiscuous mode
[   10.730222] lanbr0: port 2(lan2) entered blocking state
[   10.735529] lanbr0: port 2(lan2) entered disabled state
[   10.740788] mt7530-mdio mdio-bus:1f lan2: entered allmulticast mode
[   10.748418] mt7530-mdio mdio-bus:1f lan2: entered promiscuous mode
[   10.757293] lanbr0: port 3(lan1) entered blocking state
[   10.762674] lanbr0: port 3(lan1) entered disabled state
[   10.767957] mt7530-mdio mdio-bus:1f lan1: entered allmulticast mode
[   10.776580] mt7530-mdio mdio-bus:1f lan1: entered promiscuous mode
[   10.785194] lanbr0: port 4(lan0) entered blocking state
[   10.790434] lanbr0: port 4(lan0) entered disabled state
[   10.795728] mt7530-mdio mdio-bus:1f lan0: entered allmulticast mode
[   10.803332] mt7530-mdio mdio-bus:1f lan0: entered promiscuous mode
[   10.819447] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[   10.828072] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[   10.832685] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[   10.844864] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[   10.853136] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[   10.861154] mt7530-mdio mdio-bus:1f lan0: configuring for phy/gmii link mode
[   10.871595] mt7530-mdio mdio-bus:1f lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[   10.951910] lanbr0: port 4(lan0) entered blocking state
[   10.957168] lanbr0: port 4(lan0) entered forwarding state
[   10.963632] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
[   12.557581] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[   12.646911] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805
[   12.713064] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[   12.858635] mt798x-wmac 18000000.wifi: eeprom load fail, use default bin
[   15.934403] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[   16.077297] mt7530-mdio mdio-bus:1f lan4: configuring for inband/2500base-x link mode
[   53.130914] sfp sfp-1: module FS               SFP-2.5G-T       rev 1.0  sn G2340039491      dc 231101
I connected a product with a 2.5G port on the other side : led of the interface lights up but ping is KO.
Any idea what could be the issue ?
Thank you.
You probably need a quirk/fixup for it, if it is not already there in the debian image kernel.
I’m working on upstreaming some of these modules, and I am curious if this one is the same as the one I worked with. Could you help me and post the output of:
Find the device on the i2c-bus first with
i2cdetect -l
Then:
i2cdump -y <bus-nr-found>
Then
i2cdump -y <bus-nr-found> 0x56
This is a kernel thing,not debian (i guess you know it,but just to mention it).
Looks like your sfps eeprom does not provide the supported modes and you need a quirk to report them to network core api (e.g. phylink).
I saw it and edited it already :wink:
Indeed, and maybe we can do more, if there is also a rtl8221b behind Rollball protocol.
Thank you for your answers. Here is the output of the commands :
root@bpi-r3:/dev# i2cdetect -l
i2c-0   i2c             i2c-gpio-0                              I2C adapter
i2c-1   i2c             i2c-gpio-1                              I2C adapter
i2c-2   i2c             i2c-mt65xx                              I2C adapter
root@bpi-r3:/dev# i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 51 -- -- -- -- 56 -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@bpi-r3:/dev# i2cdump -y 0 0x56
No size specified (using byte-data access)
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 20 58 00 02 00 1c c8 49 20 70 00 8a 80 00 00 30     X.?.??I p.??..0
10: 82 00 00 00 00 00 41 a0 00 00 00 00 00 1c c8 49    ?.....A?.....??I
20: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00    ...........?....
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
Thanks!
So ths also looks like a rtl8221b behind rollball.
So At the least you can add to drivers/net/phy/sfp.c:
	SFP_QUIRK_M("FS", "SFP-2.5G-T", sfp_quirk_oem_2_5g),
It will disable auto negotiation and set the correct interface.
If you want to control the phy some more, you’ll need to add a patch-set…
Actually, it would be nice if you can test it… I was working on a testing image anyway, to test yet another module. I will add this one as well, but it will be a few days before I have the image.
Update sfp.c Change FS module to new fixup · ericwoud/linux@ca57821 (github.com)
This commit will need the rest of the patch-set.
Edit:
This last commit is different than the change above. It is part of the (first version of) my patchset.
eeprom looks really broken/invalid
Thank you, Yes, I will test the patch
No, I have added it to my bpir-rolling-stable branch, so it will be part of the image.
Edit:
The package containing this kernel will get rebuild overnight automatically. You could extract a kernel from that to test, or wait for me to finish an image (archlinuxarm).
Same as the module from the BPI store:
There should actually be a C22 accessible (mdio over i2c bridge) virtual device at the 0x56 address, which partly works. At least it has the ID of the PHY at offset 4 to 7. But further then that it does not really work and we use the Rollball protocol at address 0x51 to access the phy.
@clo
Could you also try
(Archlibux image with the patchset for your module)
I tested your image, and it’s working fine.
[root@bpir3 ~]# dmesg
[    0.000000] Linux version 6.7.9-bpi (nathalieeneric@rk3588) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #31 SMP PREEMPT Fri Mar 15 15:48:55 UTC 2024
[    0.000000] printk: legacy bootconsole [uart8250] enabled
[    0.000000] OF: reserved mem: 0x0000000043030000..0x00000000430300ff (0 KiB) nomap non-reusable atf-data@43030000
[    0.000000] OF: reserved mem: 0x0000000051000000..0x0000000052ffffff (32768 KiB) nomap non-reusable atf-buffer@51000000
[    0.000000]   node   0: [mem 0x0000000043031000-0x000000004fbfffff]
[    0.000000]   node   0: [mem 0x000000004ffc0000-0x0000000050ffffff]
[    0.000000]   node   0: [mem 0x0000000051000000-0x0000000052ffffff]
[    0.000000]   node   0: [mem 0x0000000053000000-0x00000000bfffffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] percpu: Embedded 19 pages/cpu s39272 r8192 d30360 u77824
[    0.000000] pcpu-alloc: s39272 r8192 d30360 u77824 alloc=19*4096
[    0.000000] Kernel command line: root=PARTLABEL=bpir3-sdmmc-root earlycon=uart8250,mmio32,0x11002000 console=ttyS0,115200 debug=7 rw rootwait audit=0
[    0.000000] audit: disabled (until reboot)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516095
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
[    0.000000] software IO TLB: mapped [mem 0x00000000bd600000-0x00000000bd800000] (2MB)
[    0.000000] Memory: 1988680K/2097148K available (10176K kernel code, 1480K rwdata, 4040K rodata, 3200K init, 421K bss, 108468K reserved, 0K cma-reserved)
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.008308] Console: colour dummy device 80x25
[    0.012796] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[    0.023209] pid_max: default: 32768 minimum: 301
[    0.027963] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.035410] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.043963] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.050646] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.057808] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.065547] rcu: Hierarchical SRCU implementation.
[    0.070357] rcu:     Max phase no-delay instances is 1000.
[    0.076085] EFI services will not be available.
[    0.080811] smp: Bringing up secondary CPUs ...
[    0.085763] Detected VIPT I-cache on CPU1
[    0.085817] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[    0.085853] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.086252] Detected VIPT I-cache on CPU2
[    0.086287] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[    0.086303] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.086648] Detected VIPT I-cache on CPU3
[    0.086677] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[    0.086691] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.086744] smp: Brought up 1 node, 4 CPUs
[    0.143339] SMP: Total of 4 processors activated.
[    0.148064] CPU features: detected: 32-bit EL0 Support
[    0.153223] CPU features: detected: CRC32 instructions
[    0.158393] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.166807] CPU: All CPU(s) started at EL2
[    0.170932] alternatives: applying system-wide alternatives
[    0.177373] devtmpfs: initialized
[    0.183753] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.193669] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.200695] pinctrl core: initialized pinctrl subsystem
[    0.206227] DMI not present or invalid.
[    0.210591] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.216948] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.224060] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.231873] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.240272] thermal_sys: Registered thermal governor 'fair_share'
[    0.240276] thermal_sys: Registered thermal governor 'bang_bang'
[    0.246407] thermal_sys: Registered thermal governor 'step_wise'
[    0.252440] thermal_sys: Registered thermal governor 'user_space'
[    0.258598] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.271592] ASID allocator initialised with 65536 entries
[    0.287573] Modules: 27904 pages in range for non-PLT usage
[    0.287589] Modules: 519424 pages in range for PLT usage
[    0.293912] cryptd: max_cpu_qlen set to 1000
[    0.473610] raid6: neonx8   gen()  3707 MB/s
[    0.643667] raid6: neonx4   gen()  3567 MB/s
[    0.813719] raid6: neonx2   gen()  3363 MB/s
[    0.983785] raid6: neonx1   gen()  2605 MB/s
[    1.153848] raid6: int64x8  gen()   966 MB/s
[    1.323911] raid6: int64x4  gen()  1168 MB/s
[    1.493941] raid6: int64x2  gen()  1870 MB/s
[    1.663996] raid6: int64x1  gen()  1325 MB/s
[    1.668286] raid6: using algorithm neonx8 gen() 3707 MB/s
[    1.834030] raid6: .... xor() 2662 MB/s, rmw enabled
[    1.839019] raid6: using neon recovery algorithm
[    1.843948] iommu: Default domain type: Translated
[    1.848760] iommu: DMA domain TLB invalidation policy: strict mode
[    1.855230] SCSI subsystem initialized
[    1.859093] libata version 3.00 loaded.
[    1.863062] usbcore: registered new interface driver usbfs
[    1.868601] usbcore: registered new interface driver hub
[    1.873956] usbcore: registered new device driver usb
[    1.879335] i2c-gpio i2c-gpio-0: using lines 528 (SDA) and 529 (SCL)
[    1.885861] i2c-gpio i2c-gpio-1: using lines 530 (SDA) and 531 (SCL)
[    1.892288] mc: Linux media interface: v0.10
[    1.896593] videodev: Linux video capture interface: v2.00
[    1.902129] pps_core: LinuxPPS API ver. 1 registered
[    1.907117] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    1.916304] PTP clock support registered
[    1.921358] vgaarb: loaded
[    1.924359] clocksource: Switched to clocksource arch_sys_counter
[    1.935884] NET: Registered PF_INET protocol family
[    1.940934] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.949634] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    1.958263] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.966060] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.974084] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.981764] TCP: Hash tables configured (established 16384 bind 16384)
[    1.988447] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.995215] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    2.002544] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    2.008263] PCI: CLS 0 bytes, default 64
[    2.012377] Unpacking initramfs...
[    2.016786] Initialise system trusted keyrings
[    2.021519] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    2.028424] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.034342] jffs2: version 2.2. (NAND) (SUMMARY)  \xc2\xa9 2001-2006 Red Hat, Inc.
[    2.073922] xor: measuring software checksum speed
[    2.081381]    8regs           :  3832 MB/sec
[    2.087889]    32regs          :  4678 MB/sec
[    2.094850]    arm64_neon      :  3872 MB/sec
[    2.099238] xor: using function: 32regs (4678 MB/sec)
[    2.104330] Key type asymmetric registered
[    2.108486] Asymmetric key parser 'x509' registered
[    2.113522] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.121013] io scheduler mq-deadline registered
[    2.125584] io scheduler kyber registered
[    2.129691] io scheduler bfq registered
[    2.148376] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    2.156779] printk: legacy console [ttyS0] disabled
[    2.182309] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 2500000) is a ST16650V2
[    2.191729] printk: legacy console [ttyS0] enabled
[    2.201374] printk: legacy bootconsole [uart8250] disabled
[    2.235854] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 117, base_baud = 1625000) is a ST16650V2
[    2.245067] Freeing initrd memory: 9792K
[    2.273506] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 118, base_baud = 1625000) is a ST16650V2
[    2.283718] mtk_rng 1020f000.rng: registered RNG driver
[    2.283979] random: crng init done
[    2.297259] loop: module loaded
[    2.303412] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[    2.311273] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[    2.321976] sfp sfp-1: Host maximum power 3.0W
[    2.327081] sfp sfp-2: Host maximum power 3.0W
[    2.465564] mtk_soc_eth 15100000.ethernet: generated random MAC address c6:30:f9:93:60:9a
[    2.473816] mtk_soc_eth 15100000.ethernet: generated random MAC address 66:64:c9:41:69:c1
[    2.484522] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082180000, irq 123
[    2.494563] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082180000, irq 123
[    2.504322] usbcore: registered new interface driver usb-storage
[    2.510696] i2c_dev: i2c /dev entries driver
[    2.517566] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    2.526737] ledtrig-cpu: registered to indicate activity on CPUs
[    2.532747] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    2.539639] usbcore: registered new interface driver usbhid
[    2.545235] usbhid: USB HID core driver
[    2.549753] NET: Registered PF_INET6 protocol family
[    2.555458] Segment Routing with IPv6
[    2.559130] In-situ OAM (IOAM) with IPv6
[    2.563075] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.569455] NET: Registered PF_PACKET protocol family
[    2.574649] 8021q: 802.1Q VLAN Support v1.8
[    2.586735] Loading compiled-in X.509 certificates
[    2.600054] Btrfs loaded, zoned=no, fsverity=no
[    2.612681] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    2.620222] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
[    2.674542] sfp sfp-1: module FS               SFP-2.5G-T       rev 1.0  sn G2340039491      dc 231101
[    2.844375] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.active (0x1000001)
[    2.853780] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[    2.943798] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[    2.952876] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[    2.961849] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=128)
[    2.982323] mt7530-mdio mdio-bus:1f lan0 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=129)
[    3.002663] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=130)
[    3.022974] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=131)
[    3.043263] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=132)
[    3.054954] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[    3.061683] DSA: tree 0 setup
[    3.065257] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[    3.072663] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[    3.081223] xhci-mtk 11200000.usb: xHCI Host Controller
[    3.086484] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[    3.096938] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[    3.106099] xhci-mtk 11200000.usb: irq 133, io mem 0x11200000
[    3.111943] xhci-mtk 11200000.usb: xHCI Host Controller
[    3.117170] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[    3.124558] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[    3.132099] hub 1-0:1.0: USB hub found
[    3.135869] hub 1-0:1.0: 2 ports detected
[    3.140187] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.148678] hub 2-0:1.0: USB hub found
[    3.152439] hub 2-0:1.0: 1 port detected
[    3.158618] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.165731] of_cfs_init
[    3.168257] of_cfs_init: OK
[    3.171155] clk: Disabling unused clocks
[    3.185506] Freeing unused kernel memory: 3200K
[    3.219654] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.224401] Run /init as init process
[    3.231286]   with arguments:
[    3.231513] mmc0: new high speed SDHC card at address e624
[    3.234239]     /init
[    3.240736] mmcblk0: mmc0:e624 SA08G 7.40 GiB
[    3.241970]   with environment:
[    3.249449]     HOME=/
[    3.251800]     TERM=linux
[    3.255419]  mmcblk0: p1 p2 p3
[    3.604441] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[    3.785647] hub 1-1:1.0: USB hub found
[    3.789695] hub 1-1:1.0: 4 ports detected
[    4.482335] F2FS-fs (mmcblk0p3): Found nat_bits in checkpoint
[    4.548719] F2FS-fs (mmcblk0p3): Mounted with checkpoint version = 7a29e49e
[    5.392205] systemd[1]: System time before build time, advancing clock.
[    5.533608] systemd[1]: systemd 255.4-2-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    5.565939] systemd[1]: Detected architecture arm64.
[    5.610111] systemd[1]: Hostname set to <bpir3>.
[    5.760417] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
[    6.502631] systemd[1]: Queued start job for default target Graphical Interface.
[    6.555574] systemd[1]: Unnecessary job was removed for /sys/subsystem/net/devices/wlan1.
[    6.563797] systemd[1]: Unnecessary job was removed for /sys/subsystem/net/devices/wlan0.
[    6.574170] systemd[1]: Created slice Slice /system/dirmngr.
[    6.615786] systemd[1]: Created slice Slice /system/getty.
[    6.655737] systemd[1]: Created slice Slice /system/gpg-agent.
[    6.695764] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    6.735757] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    6.775756] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    6.815799] systemd[1]: Created slice Slice /system/hostapd.
[    6.855745] systemd[1]: Created slice Slice /system/keyboxd.
[    6.895784] systemd[1]: Created slice Slice /system/modprobe.
[    6.935778] systemd[1]: Created slice Slice /system/serial-getty.
[    6.975341] systemd[1]: Created slice User and Session Slice.
[    7.014737] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.054595] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.094583] systemd[1]: Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[    7.110806] systemd[1]: Expecting device /dev/ttyS0...
[    7.144445] systemd[1]: Reached target Local Encrypted Volumes.
[    7.184442] systemd[1]: Reached target Local Integrity Protected Volumes.
[    7.224478] systemd[1]: Reached target Path Units.
[    7.254436] systemd[1]: Reached target Remote File Systems.
[    7.294430] systemd[1]: Reached target Slice Units.
[    7.324456] systemd[1]: Reached target Swaps.
[    7.354469] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.394721] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    7.440381] systemd[1]: Listening on Process Core Dump Socket.
[    7.476639] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.514969] systemd[1]: Listening on Journal Socket.
[    7.546333] systemd[1]: Listening on Network Service Netlink Socket.
[    7.584505] systemd[1]: TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.599114] systemd[1]: Listening on udev Control Socket.
[    7.634879] systemd[1]: Listening on udev Kernel Socket.
[    7.676182] systemd[1]: Listening on User Database Manager Socket.
[    7.714872] systemd[1]: Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    7.764645] systemd[1]: Mounting POSIX Message Queue File System...
[    7.807194] systemd[1]: Mounting Kernel Debug File System...
[    7.844805] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    7.860349] systemd[1]: Mounting Temporary Directory /tmp...
[    7.899465] systemd[1]: Starting Create List of Static Device Nodes...
[    7.937851] systemd[1]: Starting Load Kernel Module configfs...
[    7.977820] systemd[1]: Starting Load Kernel Module dm_mod...
[    8.017851] systemd[1]: Starting Load Kernel Module drm...
[    8.057817] systemd[1]: Starting Load Kernel Module fuse...
[    8.097957] systemd[1]: Starting Load Kernel Module loop...
[    8.137397] systemd[1]: Starting Setup MAC addresses...
[    8.174739] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    8.187574] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    8.200496] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
[    8.214598] systemd[1]: Starting Journal Service...
[    8.259531] systemd[1]: Starting Load Kernel Modules...
[    8.297913] systemd[1]: Starting Generate network units from Kernel command line...
[    8.312578] systemd-journald[1743]: Collecting audit messages is disabled.
[    8.344658] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    8.360236] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.381367] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.394718] systemd[1]: TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    8.410153] systemd[1]: Starting Coldplug All udev Devices...
[    8.412766] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.422622] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    8.459663] systemd[1]: Started Journal Service.
[    9.019456] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[    9.176515] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805
[    9.226774] systemd-journald[1743]: Received client request to flush runtime journal.
[    9.249771] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[    9.355373] mt798x-wmac 18000000.wifi: Load eeprom: /lib/firmware/mediatek/mt798x-wmac_rf.bin
[    9.363945] mt798x-wmac 18000000.wifi: Open eeprom file failed: /lib/firmware/mediatek/mt798x-wmac_rf.bin
[    9.413385] mt798x-wmac 18000000.wifi: eeprom load fail, use default bin
[   13.350595] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[   13.359086] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[   13.361693] brlan: port 1(eth1) entered blocking state
[   13.372878] brlan: port 1(eth1) entered disabled state
[   13.378143] mtk_soc_eth 15100000.ethernet eth1: entered allmulticast mode
[   13.385142] mtk_soc_eth 15100000.ethernet eth1: entered promiscuous mode
[   13.394104] brlan: port 2(wan) entered blocking state
[   13.399194] brlan: port 2(wan) entered disabled state
[   13.404267] mt7530-mdio mdio-bus:1f wan: entered allmulticast mode
[   13.410513] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[   13.420196] mt7530-mdio mdio-bus:1f wan: entered promiscuous mode
[   13.428569] brlan: port 3(lan0) entered blocking state
[   13.433730] brlan: port 3(lan0) entered disabled state
[   13.438918] mt7530-mdio mdio-bus:1f lan0: entered allmulticast mode
[   13.447222] mt7530-mdio mdio-bus:1f lan0: entered promiscuous mode
[   13.455600] brlan: port 4(lan1) entered blocking state
[   13.460775] brlan: port 4(lan1) entered disabled state
[   13.466021] mt7530-mdio mdio-bus:1f lan1: entered allmulticast mode
[   13.474335] mt7530-mdio mdio-bus:1f lan1: entered promiscuous mode
[   13.483491] brlan: port 5(lan2) entered blocking state
[   13.489292] brlan: port 5(lan2) entered disabled state
[   13.495272] mt7530-mdio mdio-bus:1f lan2: entered allmulticast mode
[   13.503575] mt7530-mdio mdio-bus:1f lan2: entered promiscuous mode
[   13.511919] brlan: port 6(lan3) entered blocking state
[   13.517126] brlan: port 6(lan3) entered disabled state
[   13.522315] mt7530-mdio mdio-bus:1f lan3: entered allmulticast mode
[   13.530821] mt7530-mdio mdio-bus:1f lan3: entered promiscuous mode
[   13.539692] brlan: port 7(lan4) entered blocking state
[   13.544908] brlan: port 7(lan4) entered disabled state
[   13.550088] mt7530-mdio mdio-bus:1f lan4: entered allmulticast mode
[   13.558641] mt7530-mdio mdio-bus:1f lan4: entered promiscuous mode
[   14.344712] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[   14.354856] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[   14.362590] 8021q: adding VLAN 0 to HW filter on device lan1
[   14.370477] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[   14.378176] 8021q: adding VLAN 0 to HW filter on device lan2
[   14.386138] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[   14.395278] 8021q: adding VLAN 0 to HW filter on device lan3
[   14.402972] mt7530-mdio mdio-bus:1f lan0: configuring for phy/gmii link mode
[   14.410671] 8021q: adding VLAN 0 to HW filter on device lan0
[   14.413315] mt7530-mdio mdio-bus:1f lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[   14.417718] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
[   14.431927] 8021q: adding VLAN 0 to HW filter on device wan
[   14.438598] brlan: port 3(lan0) entered blocking state
[   14.443751] brlan: port 3(lan0) entered forwarding state
[   14.450033] mt7530-mdio mdio-bus:1f lan4: configuring for inband/2500base-x link mode
[   14.459718] 8021q: adding VLAN 0 to HW filter on device lan4
[   14.734855] brlan: port 8(wlan0) entered blocking state
[   14.740137] brlan: port 8(wlan0) entered disabled state
[   14.745449] mt798x-wmac 18000000.wifi wlan0: entered allmulticast mode
[   14.752255] mt798x-wmac 18000000.wifi wlan0: entered promiscuous mode
[   14.760665] brlan: port 8(wlan0) entered blocking state
[   14.766197] brlan: port 8(wlan0) entered forwarding state
[   14.816566] brlan: port 9(wlan1) entered blocking state
[   14.821842] brlan: port 9(wlan1) entered disabled state
[   14.827535] mt798x-wmac 18000000.wifi wlan1: entered allmulticast mode
[   14.834316] mt798x-wmac 18000000.wifi wlan1: entered promiscuous mode
[   14.841923] brlan: port 9(wlan1) entered blocking state
[   14.847189] brlan: port 9(wlan1) entered forwarding state
[   15.294450] brlan: port 8(wlan0) entered disabled state
[   15.300079] brlan: port 9(wlan1) entered disabled state
[   19.229959] mtk_soc_eth 15100000.ethernet eth1: switched to phy/2500base-x link mode
[   20.389889] mtk_soc_eth 15100000.ethernet eth1: PHY [i2c:sfp-1:11] driver [RTL8221B-VB-CG 2.5Gbps PHY (C45)] (irq=POLL)
[   20.617402] brlan: port 8(wlan0) entered blocking state
[   20.622647] brlan: port 8(wlan0) entered forwarding state
[   21.027852] brlan: port 9(wlan1) entered blocking state
[   21.033097] brlan: port 9(wlan1) entered forwarding state
[   67.137873] mt7530-mdio mdio-bus:1f lan0: Link is Down
[   67.143101] brlan: port 3(lan0) entered disabled state
[   69.640631] mt7530-mdio mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control rx/tx
[   69.648590] brlan: port 2(wan) entered blocking state
[   69.653641] brlan: port 2(wan) entered forwarding state
[   83.313215] mt7530-mdio mdio-bus:1f wan: Link is Down
[   83.318369] brlan: port 2(wan) entered disabled state
[   85.274528] mt7530-mdio mdio-bus:1f lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[   85.282499] brlan: port 3(lan0) entered blocking state
[   85.287644] brlan: port 3(lan0) entered forwarding state
[  193.265071] mt7530-mdio mdio-bus:1f lan0: Link is Down
[  193.270301] brlan: port 3(lan0) entered disabled state
[  195.319825] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[  195.327868] brlan: port 4(lan1) entered blocking state
[  195.333006] brlan: port 4(lan1) entered forwarding state
[  207.705445] mt7530-mdio mdio-bus:1f lan1: Link is Down
[  207.710677] brlan: port 4(lan1) entered disabled state
[  210.545025] mt7530-mdio mdio-bus:1f lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[  210.552997] brlan: port 3(lan0) entered blocking state
[  210.558142] brlan: port 3(lan0) entered forwarding state
[  279.566726] mt798x-wmac 18000000.wifi wlan0: failed (err=-2) to del object (id=3)
[  279.574215] mt798x-wmac 18000000.wifi wlan1: failed (err=-2) to del object (id=3)
[  279.582835] mt798x-wmac 18000000.wifi wlan0: failed (err=-2) to del object (id=3)
[  279.590336] mt798x-wmac 18000000.wifi wlan1: failed (err=-2) to del object (id=3)
[  579.278319] mt7530-mdio mdio-bus:1f lan0: Link is Down
[  579.283674] brlan: port 3(lan0) entered disabled state
[  581.294667] mt7530-mdio mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control rx/tx
[  581.302553] brlan: port 2(wan) entered blocking state
[  581.307612] brlan: port 2(wan) entered forwarding state
[  592.396608] mt7530-mdio mdio-bus:1f wan: Link is Down
[  592.401896] brlan: port 2(wan) entered disabled state
[  595.090398] mt7530-mdio mdio-bus:1f lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[  595.098380] brlan: port 3(lan0) entered blocking state
[  595.103514] brlan: port 3(lan0) entered forwarding state
[  872.519881] mtk_soc_eth 15100000.ethernet eth1: No phy led trigger registered for speed(2500)
[  872.519900] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
[  872.536881] brlan: port 1(eth1) entered blocking state
[  872.542037] brlan: port 1(eth1) entered forwarding state
[  879.131234] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[  879.137843] brlan: port 1(eth1) entered disabled state
[  883.479880] mtk_soc_eth 15100000.ethernet eth1: No phy led trigger registered for speed(2500)
[  883.479896] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
[  883.497044] brlan: port 1(eth1) entered blocking state
[  883.502197] brlan: port 1(eth1) entered forwarding state
[  911.709165] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[  911.715773] brlan: port 1(eth1) entered disabled state
[  916.039890] mtk_soc_eth 15100000.ethernet eth1: No phy led trigger registered for speed(2500)
[  916.039912] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
[  916.057221] brlan: port 1(eth1) entered blocking state
[  916.062365] brlan: port 1(eth1) entered forwarding state
[ 1044.888183] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 1044.894883] brlan: port 1(eth1) entered disabled state
[ 1046.221214] mt7530-mdio mdio-bus:1f lan0: Link is Down
[ 1046.226470] brlan: port 3(lan0) entered disabled state
[ 1050.679883] mtk_soc_eth 15100000.ethernet eth1: No phy led trigger registered for speed(1000)
[ 1050.680041] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1050.696980] brlan: port 1(eth1) entered blocking state
[ 1050.702134] brlan: port 1(eth1) entered forwarding state
[ 1056.989580] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 1056.996069] brlan: port 1(eth1) entered disabled state
[ 1059.264678] mt7530-mdio mdio-bus:1f lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1059.272662] brlan: port 3(lan0) entered blocking state
[ 1059.277810] brlan: port 3(lan0) entered forwarding state
[ 1065.479880] mtk_soc_eth 15100000.ethernet eth1: No phy led trigger registered for speed(2500)
[ 1065.480038] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1065.497085] brlan: port 1(eth1) entered blocking state
[ 1065.502228] brlan: port 1(eth1) entered forwarding state
[ 1088.779786] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 1088.786267] brlan: port 1(eth1) entered disabled state
[ 1096.359880] mtk_soc_eth 15100000.ethernet eth1: No phy led trigger registered for speed(1000)
[ 1096.360040] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1096.376908] brlan: port 1(eth1) entered blocking state
[ 1096.382050] brlan: port 1(eth1) entered forwarding state
I tried to connect to a 2.5G port and also a 1G port and both speed where detected :
[root@bpir3 ~]# cat /sys/class/net/eth1/speed
2500
1000
[root@bpir3 ~]#
Works also on the other port :
[ 1524.526474] sfp sfp-1: module transmit fault indicated
[ 1524.531643] sfp sfp-1: module removed
[ 1527.234539] sfp sfp-2: module FS               SFP-2.5G-T       rev 1.0  sn G2340039491      dc 231101
[ 1532.119958] mt7530-mdio mdio-bus:1f lan4: switched to phy/2500base-x link mode
[ 1533.279896] mt7530-mdio mdio-bus:1f lan4: PHY [i2c:sfp-2:11] driver [RTL8221B-VB-CG 2.5Gbps PHY (C45)] (irq=POLL)
[ 1538.039888] mt7530-mdio mdio-bus:1f lan4: No phy led trigger registered for speed(1000)
[ 1538.140072] mt7530-mdio mdio-bus:1f lan4: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1538.148124] brlan: port 7(lan4) entered blocking state
[ 1538.153266] brlan: port 7(lan4) entered forwarding state
[ 1548.353143] mt7530-mdio mdio-bus:1f lan4: Link is Down
[ 1548.358462] brlan: port 7(lan4) entered disabled state
[ 1552.039885] mt7530-mdio mdio-bus:1f lan4: No phy led trigger registered for speed(2500)
[ 1552.140079] mt7530-mdio mdio-bus:1f lan4: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1552.148233] brlan: port 7(lan4) entered blocking state
[ 1552.153367] brlan: port 7(lan4) entered forwarding state
Thank you !
Thanks for trying, then I know I can add this module to the patchset.
This is an older version of the patchset, but at least I know that the module is a rtl8221b behind RollBall also.
Now, I’m trying to make this SFP works with kernel from frank :
https://github.com/frank-w/BPI-Router-Linux
I used sfp.c / sfp.h from your repo :
https://github.com/ericwoud/linux
But it’s not completely working. No errors in dmesg but interface remains down and ping is KO :
[    0.000000] Linux version 6.6.16-bpi-r3 (mtg@mtg-VirtualBox) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Tue Mar 19 10:13:32 CET 2024
[    0.000000] Memory: 1961948K/2097152K available (12608K kernel code, 2410K rwdata, 4204K rodata, 4480K init, 419K bss, 135204K reserved, 0K cma-reserved)
[    0.008275] Console: colour dummy device 80x25
[    0.012738] printk: console [tty0] enabled
[    0.016849] printk: bootconsole [uart8250] disabled
[    0.021777] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[    0.021789] pid_max: default: 32768 minimum: 301
[    0.021896] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.021912] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.022503] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.022932] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.023054] rcu: Hierarchical SRCU implementation.
[    0.023061] rcu:     Max phase no-delay instances is 1000.
[    0.023464] EFI services will not be available.
[    0.023616] smp: Bringing up secondary CPUs ...
[    0.023941] Detected VIPT I-cache on CPU1
[    0.023980] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[    0.024012] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.024356] Detected VIPT I-cache on CPU2
[    0.024380] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[    0.024394] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.024674] Detected VIPT I-cache on CPU3
[    0.024695] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[    0.024707] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.024742] smp: Brought up 1 node, 4 CPUs
[    0.024784] SMP: Total of 4 processors activated.
[    0.024790] CPU features: detected: 32-bit EL0 Support
[    0.024796] CPU features: detected: CRC32 instructions
[    0.024843] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.024854] CPU: All CPU(s) started at EL2
[    0.024860] alternatives: applying system-wide alternatives
[    0.026436] devtmpfs: initialized
[    0.028489] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.028520] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.028648] pinctrl core: initialized pinctrl subsystem
[    0.028861] DMI not present or invalid.
[    0.029235] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.029782] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.029821] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.029850] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.030226] thermal_sys: Registered thermal governor 'fair_share'
[    0.030230] thermal_sys: Registered thermal governor 'bang_bang'
[    0.030238] thermal_sys: Registered thermal governor 'step_wise'
[    0.030244] thermal_sys: Registered thermal governor 'user_space'
[    0.030342] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.030407] ASID allocator initialised with 65536 entries
[    0.038001] Modules: 26688 pages in range for non-PLT usage
[    0.038015] Modules: 518208 pages in range for PLT usage
[    0.038744] cryptd: max_cpu_qlen set to 1000
[    0.039157] iommu: Default domain type: Translated
[    0.039173] iommu: DMA domain TLB invalidation policy: strict mode
[    0.039307] SCSI subsystem initialized
[    0.039405] libata version 3.00 loaded.
[    0.039515] usbcore: registered new interface driver usbfs
[    0.039540] usbcore: registered new interface driver hub
[    0.039567] usbcore: registered new device driver usb
[    0.039816] i2c-gpio i2c-gpio-0: using lines 528 (SDA) and 529 (SCL)
[    0.039928] i2c-gpio i2c-gpio-1: using lines 530 (SDA) and 531 (SCL)
[    0.039976] pps_core: LinuxPPS API ver. 1 registered
[    0.039982] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.039998] PTP clock support registered
[    0.040936] vgaarb: loaded
[    0.041237] clocksource: Switched to clocksource arch_sys_counter
[    0.045122] NET: Registered PF_INET protocol family
[    0.045273] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.046277] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.046306] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.046320] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.046394] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.046725] TCP: Hash tables configured (established 16384 bind 16384)
[    0.046818] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.046854] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.046987] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.047322] RPC: Registered named UNIX socket transport module.
[    0.047333] RPC: Registered udp transport module.
[    0.047339] RPC: Registered tcp transport module.
[    0.047344] RPC: Registered tcp-with-tls transport module.
[    0.047350] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.047364] PCI: CLS 0 bytes, default 64
[    0.052029] Initialise system trusted keyrings
[    0.052261] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.052515] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.052751] NFS: Registering the id_resolver key type
[    0.052789] Key type id_resolver registered
[    0.052796] Key type id_legacy registered
[    0.052813] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.052821] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.052842] jffs2: version 2.2. (NAND) (SUMMARY)  \xc2\xa9 2001-2006 Red Hat, Inc.
[    0.071986] Key type asymmetric registered
[    0.072009] Asymmetric key parser 'x509' registered
[    0.072065] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.072076] io scheduler mq-deadline registered
[    0.072086] io scheduler kyber registered
[    0.072126] io scheduler bfq registered
[    0.109780] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.132148] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 2500000) is a ST16650V2
[    0.132211] printk: console [ttyS0] enabled
[    1.141287] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 117, base_baud = 1625000) is a ST16650V2
[    1.172026] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 118, base_baud = 1625000) is a ST16650V2
[    1.182177] mtk_rng 1020f000.rng: registered RNG driver
[    1.191252] loop: module loaded
[    1.196137] spi-nand spi0.0: Winbond SPI NAND was found.
[    1.201487] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    1.209798] 4 fixed-partitions partitions found on MTD device spi0.0
[    1.216221] Creating 4 MTD partitions on "spi0.0":
[    1.221000] 0x000000580000-0x000008000000 : "ubi"
[    1.340140] 0x000000380000-0x000000580000 : "fip"
[    1.347637] 0x000000100000-0x000000380000 : "reserved"
[    1.356016] 0x000000000000-0x000000100000 : "bl2"
[    1.363623] sfp sfp-1: Host maximum power 3.0W
[    1.368590] sfp sfp-2: Host maximum power 3.0W
[    1.502471] mtk_soc_eth 15100000.ethernet: generated random MAC address 12:08:af:64:50:52
[    1.512693] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082700000, irq 123
[    1.522569] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082700000, irq 123
[    1.532194] usbcore: registered new interface driver usb-storage
[    1.538387] i2c_dev: i2c /dev entries driver
[    1.544913] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    1.553661] SMCCC: SOC_ID: ID = jep106:0426:7986 Revision = 0x00000000
[    1.560302] usbcore: registered new interface driver usbhid
[    1.565886] usbhid: USB HID core driver
[    1.570140] NET: Registered PF_INET6 protocol family
[    1.575723] Segment Routing with IPv6
[    1.579405] In-situ OAM (IOAM) with IPv6
[    1.583363] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.589663] NET: Registered PF_PACKET protocol family
[    1.594982] 8021q: 802.1Q VLAN Support v1.8
[    1.605082] Loading compiled-in X.509 certificates
[    1.621102] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    1.628455] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[    1.634719] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
[    1.720921] sfp sfp-2: module FS               SFP-2.5G-T       rev 1.0  sn G2340039491      dc 231101
[    1.861250] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.active (0x1000001)
[    1.870685] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[    1.930473] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[    1.939627] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[    1.948325] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=128)
[    1.968676] mt7530-mdio mdio-bus:1f lan0 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=129)
[    1.988844] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=130)
[    2.009027] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=131)
[    2.029189] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=132)
[    2.040583] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[    2.047336] DSA: tree 0 setup
[    2.050770] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[    2.058173] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[    2.066612] xhci-mtk 11200000.usb: xHCI Host Controller
[    2.071872] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[    2.082234] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[    2.091406] xhci-mtk 11200000.usb: irq 133, io mem 0x11200000
[    2.097228] xhci-mtk 11200000.usb: xHCI Host Controller
[    2.102450] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[    2.109834] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[    2.117356] hub 1-0:1.0: USB hub found
[    2.121126] hub 1-0:1.0: 2 ports detected
[    2.125508] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.133982] hub 2-0:1.0: USB hub found
[    2.137747] hub 2-0:1.0: 1 port detected
[    2.143303] clk: Disabling unused clocks
[    2.170040] Waiting for root device /dev/mmcblk0p6...
[    2.204735] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.216423] mmc0: new high speed SDHC card at address aaaa
[    2.222757] mmcblk0: mmc0:aaaa SA08G 7.40 GiB
[    2.235216]  mmcblk0: p1 p2 p3 p4 p5 p6
[    2.274302] EXT4-fs (mmcblk0p6): mounted filesystem c4133c1c-a36b-48da-952a-43ee4e59dcfb ro with ordered data mode. Quota mode: disabled.
[    2.286750] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    2.294887] devtmpfs: mounted
[    2.299331] Freeing unused kernel memory: 4480K
[    2.391267] Run /sbin/init as init process
[    2.395362]   with arguments:
[    2.398318]     /sbin/init
[    2.401013]   with environment:
[    2.404151]     HOME=/
[    2.406499]     TERM=linux
[    2.409194]     board=bpi-r3
[    2.571246] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[    2.762106] hub 1-1:1.0: USB hub found
[    2.765921] hub 1-1:1.0: 4 ports detected
[    3.194012] systemd[1]: System time before build time, advancing clock.
[    3.256043] systemd[1]: Failed to find module 'autofs4'
[    3.420930] systemd[1]: systemd 252.22-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    3.453659] systemd[1]: Detected architecture arm64.
[    3.497552] systemd[1]: Hostname set to <bpi-r3>.
[    4.053159] systemd[1]: Queued start job for default target graphical.target.
[    4.123406] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    4.162531] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    4.202471] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    4.242058] systemd[1]: Created slice user.slice - User and Session Slice.
[    4.281567] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[    4.321498] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    4.361434] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[    4.380789] systemd[1]: Expecting device dev-mmcblk0p5.device - /dev/mmcblk0p5...
[    4.421291] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
[    4.461333] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[    4.501355] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    4.541390] systemd[1]: Reached target paths.target - Path Units.
[    4.581341] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[    4.621323] systemd[1]: Reached target slices.target - Slice Units.
[    4.661358] systemd[1]: Reached target swap.target - Swaps.
[    4.701345] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    4.741604] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    4.787564] systemd[1]: systemd-journald-audit.socket - Journal Audit Socket was skipped because of an unmet condition check (ConditionSecurity=audit).
[    4.801790] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    4.841786] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    4.881893] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
[    4.921840] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    4.961700] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    5.001739] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    5.071481] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    5.113949] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    5.153983] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    5.194494] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    5.234354] systemd[1]: Starting [email protected] - Load Kernel Module configfs...
[    5.284277] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    5.324302] systemd[1]: Starting [email protected] - Load Kernel Module drm...
[    5.374276] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    5.414299] systemd[1]: Starting [email protected] - Load Kernel Module fuse...
[    5.464381] systemd[1]: Starting [email protected] - Load Kernel Module loop...
[    5.501974] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    5.514877] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    5.525910] systemd[1]: Starting systemd-journald.service - Journal Service...
[    5.674292] fuse: init (API version 7.39)
[    5.675638] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    5.724230] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line...
[    5.774237] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    5.824201] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    5.856431] EXT4-fs (mmcblk0p6): re-mounted c4133c1c-a36b-48da-952a-43ee4e59dcfb r/w. Quota mode: disabled.
[    5.870844] systemd[1]: Started systemd-journald.service - Journal Service.
[    6.574484] systemd-journald[1455]: Received client request to flush runtime journal.
[    7.451365] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[    7.462158] mtdblock: MTD device 'reserved' is NAND, please consider using UBI block devices instead.
[    7.465899] mtdblock: MTD device 'fip' is NAND, please consider using UBI block devices instead.
[    7.469191] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[    9.034540] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.055390] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.061575] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   10.353689] lanbr0: port 1(lan3) entered blocking state
[   10.358936] lanbr0: port 1(lan3) entered disabled state
[   10.364255] mt7530-mdio mdio-bus:1f lan3: entered allmulticast mode
[   10.370521] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[   10.380662] mt7530-mdio mdio-bus:1f lan3: entered promiscuous mode
[   10.390900] lanbr0: port 2(lan2) entered blocking state
[   10.397307] lanbr0: port 2(lan2) entered disabled state
[   10.402575] mt7530-mdio mdio-bus:1f lan2: entered allmulticast mode
[   10.410124] mt7530-mdio mdio-bus:1f lan2: entered promiscuous mode
[   10.419545] lanbr0: port 3(lan1) entered blocking state
[   10.424906] lanbr0: port 3(lan1) entered disabled state
[   10.430190] mt7530-mdio mdio-bus:1f lan1: entered allmulticast mode
[   10.437993] mt7530-mdio mdio-bus:1f lan1: entered promiscuous mode
[   10.446907] lanbr0: port 4(lan0) entered blocking state
[   10.452212] lanbr0: port 4(lan0) entered disabled state
[   10.457463] mt7530-mdio mdio-bus:1f lan0: entered allmulticast mode
[   10.465079] mt7530-mdio mdio-bus:1f lan0: entered promiscuous mode
[   10.480979] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[   10.490842] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[   10.494638] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[   10.507577] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[   10.515739] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[   10.523981] mt7530-mdio mdio-bus:1f lan0: configuring for phy/gmii link mode
[   10.534304] mt7530-mdio mdio-bus:1f lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[   10.582325] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
[   10.589967] lanbr0: port 4(lan0) entered blocking state
[   10.596301] lanbr0: port 4(lan0) entered forwarding state
[   11.371501] random: crng init done
[   12.598491] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[   12.686231] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805
[   12.752219] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[   12.897079] mt798x-wmac 18000000.wifi: eeprom load fail, use default bin
[  173.547685] sfp sfp-2: module removed
[  176.080873] sfp sfp-1: module FS               SFP-2.5G-T       rev 1.0  sn G2340039491      dc 231101
I notices this line was present in dmesg with you image, but not here :
Do you know what I’m missing ?
Thanks.
6.6 does not have (latest version of) the phy driver from eric included
Btw. My name does not contain letter “c”
Sorry about that, corrected.
If I wan’t to make this SFP work with Debian, do you think I should use a more recent kernel like (6.7 ? 6.8 ?) or should I add the patches from Eric into 6.6 ?
My 6.6-main does not support bpi-r4 you should use 6.8-dango2
I use the SFP in a bpi-r3.
